cs_boundary_conditions_set_coeffs_turb.h File Reference
+ Include dependency graph for cs_boundary_conditions_set_coeffs_turb.h:
void cs_boundary_conditions_set_coeffs_turb (int isvhb, cs_real_t velipb[][3], cs_real_t rijipb[][6], cs_real_t visvdr[], cs_real_t hbord[], cs_real_t theipb[])
 Boundary conditions for smooth walls (icodcl = CS_BC_WALL_MODELLED). More...
◆ cs_boundary_conditions_set_coeffs_turb()
void cs_boundary_conditions_set_coeffs_turb ( int  isvhb,
cs_real_t  visvdr[],
cs_real_t  hbord[],
cs_real_t  theipb[]
The wall functions may change the value of the diffusive flux.
The values at a boundary face $ \fib $ stored in the face center $ \centf $ of the variable $ P $ and its diffusive flux $ Q $ are written as:
P_{\face} = A_P^g + B_P^g P_{\centi}
and
Q_{\face} = A_P^f + B_P^f P_{\centi}
where $ P_\centi $ is the value of the variable $ P $ at the neighboring cell.
Warning:
  • For a vector field such as the velocity $ \vect{u} $ the boundary conditions may read:
  \vect{u}_{\face} = \vect{A}_u^g + \tens{B}_u^g \vect{u}_{\centi}
    and
  \vect{Q}_{\face} = \vect{A}_u^f + \tens{B}_u^f \vect{u}_{\centi}
    where $ \tens{B}_u^g $ and $ \tens{B}_u^f $ are 3x3 tensor matrix which coupled velocity components next to a boundary.
Please refer to the wall boundary conditions section of the theory guide for more informations, as well as the clptur section.
[in]isvhbid of field whose exchange coeffient should be saved at the walls, or -1.
[in]velipbvalue of the velocity at $ \centip $ of boundary cells
[in]rijipbvalue of $ R_{ij} $ at $ \centip $ of boundary cells
[out]visvdrdynamic viscosity after V. Driest damping in boundary cells
[out]hbordexchange coefficient at boundary
[in]theipbvalue of thermal scalar at $ \centip $ of boundary cells
