cs_internal_coupling.cpp File Reference
#include <limits.h>
#include <mpi.h>
#include "bft/bft_printf.h"
#include "bft/bft_error.h"
#include "fvm/fvm_defs.h"
#include "fvm/fvm_selector.h"
#include "base/cs_dispatch.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "base/cs_sort.h"
#include "base/cs_search.h"
#include "mesh/cs_mesh_connect.h"
#include "base/cs_coupling.h"
#include "alge/cs_gradient_boundary.h"
#include "base/cs_halo.h"
#include "alge/cs_matrix.h"
#include "mesh/cs_mesh.h"
#include "mesh/cs_mesh_boundary.h"
#include "mesh/cs_mesh_group.h"
#include "base/cs_field.h"
#include "base/cs_selector.h"
#include "base/cs_parall.h"
#include "base/cs_velocity_pressure.h"
#include "base/cs_internal_coupling.h"
+ Include dependency graph for cs_internal_coupling.cpp:
int cs_internal_coupling_n_couplings (void)
 Return number of defined internal couplings. More...
void cs_internal_coupling_add (const char criteria_cells[], const char criteria_faces[])
 Define coupling volume using given selection criteria. More...
void cs_internal_coupling_add_volume (const char criteria_cells[])
 Define coupling volume using given criteria. Then, this volume will be separated from the rest of the domain with thin walls. More...
void cs_internal_coupling_add_volume_zone (const cs_zone_t *z)
 Define coupling volume using given cs_zone_t. Then, this volume will be separated from the rest of the domain with thin walls. More...
void cs_internal_coupling_add_volume_zones (int n_zones, const int zone_ids[])
void cs_internal_coupling_add_boundary_groups (cs_internal_coupling_t *cpl, const char *interior_name, const char *exterior_name)
 Define internal coupling volume boundary group names. More...
void cs_internal_coupling_bcs (int bc_type[])
 Impose wall BCs to internal coupled faces if not yet defined. More...
void cs_internal_coupling_finalize (void)
 Destruction of all internal coupling related structures. More...
cs_internal_coupling_t * cs_internal_coupling_by_id (int coupling_id)
 Return the coupling associated with a given coupling_id. More...
void cs_internal_coupling_exchange_var (const cs_internal_coupling_t *cpl, int stride, cs_real_t distant[], cs_real_t local[])
 Exchange quantities from distant to local (update local using distant). More...
void cs_internal_coupling_exchange_by_cell_id (const cs_internal_coupling_t *cpl, int stride, const cs_real_t tab[], cs_real_t local[])
 Exchange variable between groups using cell id. More...
void cs_internal_coupling_exchange_by_face_id (const cs_internal_coupling_t *cpl, int stride, const cs_real_t tab[], cs_real_t local[])
 Exchange variable between groups using face id. More...
void cs_internal_coupling_coupled_faces (const cs_internal_coupling_t *cpl, cs_lnum_t *n_local, const cs_lnum_t *faces_local[], cs_lnum_t *n_distant, const cs_lnum_t *faces_distant[])
void cs_internal_coupling_spmv_contribution (bool exclude_diag, const cs_field_t *f, const cs_real_t *restrict x, cs_real_t *restrict y)
void cs_internal_coupling_matrix_add_ids (int coupling_id, const cs_gnum_t *r_g_id, cs_matrix_assembler_t *ma)
void cs_internal_coupling_matrix_add_values (const cs_field_t *f, cs_lnum_t db_size, cs_lnum_t eb_size, const cs_gnum_t r_g_id[], cs_matrix_assembler_values_t *mav)
void cs_internal_coupling_setup (void)
 Setup internal coupling related parameters. More...
void cs_internal_coupling_initialize (void)
 Initialize internal coupling related structures. More...
void cs_internal_coupling_log (const cs_internal_coupling_t *cpl)
void cs_internal_coupling_dump (void)
void cs_internal_coupling_preprocess (cs_mesh_t *mesh)
void cs_internal_coupling_map (cs_mesh_t *mesh)
void cs_internal_coupling_add_entity (int f_id)
void cs_ic_field_set_exchcoeff (const cs_field_t *f, const cs_real_t *h_int_tot)
 Update internal coupling coefficients of the field of the given id using given boundary exchange coefficients passed by face id. More...
void cs_ic_field_dist_data_by_face_id (const int field_id, int stride, const cs_real_t tab_distant[], cs_real_t tab_local[])
 Get distant data using face id at all coupling faces for a given field id. More...
void cs_internal_coupling_update_bc_coeffs_s (cs_dispatch_context &ctx, const cs_field_bc_coeffs_t *bc_coeffs, const cs_internal_coupling_t *cpl, const bool compute_diffusion_coeffs, cs_halo_type_t halo_type, int w_stride, double clip_coeff, int hyd_p_flag, cs_real_t f_ext[][3], const cs_real_t *c_weight, const cs_real_t weighb[], cs_real_t *df_limiter, const cs_real_t *var)
 Update scalar boundary condition coefficients for internal coupling. More...
template<cs_lnum_t stride>
void cs_internal_coupling_update_bc_coeffs_strided (cs_dispatch_context &ctx, const cs_field_bc_coeffs_t *bc_coeffs, const cs_internal_coupling_t *cpl, cs_halo_type_t halo_type, double clip_coeff, cs_real_t *df_limiter, const cs_real_t var[][stride], const cs_real_t *c_weight)
 Update vector boundary condition coefficients for internal coupling. More...
template void cs_internal_coupling_update_bc_coeffs_strided (cs_dispatch_context &ctx, const cs_field_bc_coeffs_t *bc_coeffs, const cs_internal_coupling_t *cpl, cs_halo_type_t halo_type, double clip_coeff, cs_real_t *df_limiter, const cs_real_t var[][3], const cs_real_t *c_weight)
template void cs_internal_coupling_update_bc_coeffs_strided (cs_dispatch_context &ctx, const cs_field_bc_coeffs_t *bc_coeffs, const cs_internal_coupling_t *cpl, cs_halo_type_t halo_type, double clip_coeff, cs_real_t *df_limiter, const cs_real_t var[][6], const cs_real_t *c_weight)
◆ cs_ic_field_dist_data_by_face_id()
void cs_ic_field_dist_data_by_face_id ( const int  field_id,
int  stride,
[in]field_idfield id
[in]stridenumber of values (interlaced) by entity
[in]tab_distantexchanged data by face id
[out]tab_locallocal data by face id
◆ cs_ic_field_set_exchcoeff()
void cs_ic_field_set_exchcoeff ( const cs_field_t *  f,
const cs_real_t *  h_int_tot
[in]fpointer to field
[in]h_int_totboundary exchange coefficients passed by face id
◆ cs_internal_coupling_add()
void cs_internal_coupling_add ( const char  criteria_cells[],
Then, this volume must be separated from the rest of the domain with a wall.
[in]criteria_cellscriteria for the first group of cells
[in]criteria_facescriteria for faces to be joined
◆ cs_internal_coupling_add_boundary_groups()
void cs_internal_coupling_add_boundary_groups ( cs_internal_coupling_t *  cpl,
const char *  interior_name,
const char *  exterior_name
This is used only for internal couplings based on a separation of volumes (cs_internal_coupling_add_volume, cs_internal_coupling_add_volume_zone, cs_internal_coupling_add_volume_zones).
The interior name is used for faces adjacent to the main volume, and the exterio name for faces adjacent to the selected (exterior) volume.
This allows filtering faces on each side of the boundary in a simpler manner.
[in,out]cplpointer to mesh structure to modify
◆ cs_internal_coupling_add_entity()
void cs_internal_coupling_add_entity ( int  f_id)
◆ cs_internal_coupling_add_volume()
void cs_internal_coupling_add_volume ( const char  criteria_cells[])
◆ cs_internal_coupling_add_volume_zone()
void cs_internal_coupling_add_volume_zone ( const cs_zone_t *  z)
Define coupling volume using a cs_zone_t. Then, this volume will be separated from the rest of the domain with thin walls.
[in]zpointer to cs_volume_zone_t
◆ cs_internal_coupling_add_volume_zones()
void cs_internal_coupling_add_volume_zones ( int  n_zones,
[in]n_zonesnumber of associated volume zones
[in]zone_idsids of associated volume zones
◆ cs_internal_coupling_bcs()
void cs_internal_coupling_bcs ( int  bc_type[])
[in,out]bc_typeface boundary condition type
◆ cs_internal_coupling_by_id()
cs_internal_coupling_t * cs_internal_coupling_by_id ( int  coupling_id)
[in]coupling_idassociated with a coupling entity
pointer to associated coupling structure
◆ cs_internal_coupling_coupled_faces()
void cs_internal_coupling_coupled_faces ( const cs_internal_coupling_t *  cpl,
cs_lnum_t *  n_local,
const cs_lnum_t *  faces_local[],
cs_lnum_t *  n_distant,
const cs_lnum_t *  faces_distant[]
◆ cs_internal_coupling_dump()
void cs_internal_coupling_dump ( void  )
◆ cs_internal_coupling_exchange_by_cell_id()
void cs_internal_coupling_exchange_by_cell_id ( const cs_internal_coupling_t *  cpl,
int  stride,
cs_real_t  local[]
[in]cplpointer to coupling entity
[in]stridenumber of values (non interlaced) by entity
[in]tabvariable exchanged
[out]locallocal data
◆ cs_internal_coupling_exchange_by_face_id()
void cs_internal_coupling_exchange_by_face_id ( const cs_internal_coupling_t *  cpl,
int  stride,
cs_real_t  local[]
◆ cs_internal_coupling_exchange_var()
void cs_internal_coupling_exchange_var ( const cs_internal_coupling_t *  cpl,
int  stride,
cs_real_t  local[]
[in]stridestride (e.g. 1 for double, 3 for interleaved coordinates)
[in]distantdistant values (to send), size coupling->n_distant
[out]locallocal values (to receive), size coupling->n_local
◆ cs_internal_coupling_finalize()
void cs_internal_coupling_finalize ( void  )
◆ cs_internal_coupling_initialize()
void cs_internal_coupling_initialize ( void  )
◆ cs_internal_coupling_log()
void cs_internal_coupling_log ( const cs_internal_coupling_t *  cpl)
◆ cs_internal_coupling_map()
void cs_internal_coupling_map ( cs_mesh_t *  mesh)
◆ cs_internal_coupling_matrix_add_ids()
void cs_internal_coupling_matrix_add_ids ( int  coupling_id,
const cs_gnum_t *  r_g_id,
cs_matrix_assembler_t *  ma
◆ cs_internal_coupling_matrix_add_values()
void cs_internal_coupling_matrix_add_values ( const cs_field_t *  f,
cs_lnum_t  db_size,
cs_lnum_t  eb_size,
cs_matrix_assembler_values_t *  mav
◆ cs_internal_coupling_n_couplings()
int cs_internal_coupling_n_couplings ( void  )
number of internal couplings
◆ cs_internal_coupling_preprocess()
void cs_internal_coupling_preprocess ( cs_mesh_t *  mesh)
◆ cs_internal_coupling_setup()
void cs_internal_coupling_setup ( void  )
◆ cs_internal_coupling_spmv_contribution()
void cs_internal_coupling_spmv_contribution ( bool  exclude_diag,
◆ cs_internal_coupling_update_bc_coeffs_s()
void cs_internal_coupling_update_bc_coeffs_s ( cs_dispatch_context &  ctx,
const cs_field_bc_coeffs_t *  bc_coeffs,
int  w_stride,
double  clip_coeff,
int  hyd_p_flag,
const cs_real_t *  c_weight,
cs_real_t *  df_limiter,
const cs_real_t *  var
[in]ctxreference to dispatch context
[in]bc_coeffsassociated BC coefficients structure
[in]cplstructure associated with internal coupling
[in]compute_diffusion_coeffscompute diffusion coefficients or not
[in]halo_typehalo type
[in]incif 0, solve on increment; 1 otherwise
[in]w_stridestride for weighting coefficient
[in]clip_coeffclipping coefficient
[in]hyd_p_flagflag for hydrostatic pressure
[in]f_extexterior force generating pressure
[in]c_weightweighted gradient coefficient variable, or nullptr
[in]weighbboundary face weight for cells i in case of tensor diffusion, or nullptr
[in]df_limiterdiffusion limiter array
[in]vargradient's base variable
◆ cs_internal_coupling_update_bc_coeffs_strided() [1/3]
template void cs_internal_coupling_update_bc_coeffs_strided ( cs_dispatch_context &  ctx,
double  clip_coeff,
◆ cs_internal_coupling_update_bc_coeffs_strided() [2/3]
double  clip_coeff,
◆ cs_internal_coupling_update_bc_coeffs_strided() [3/3]
double  clip_coeff,
[in]bc_coeffsboundary condition structure
