Definition: cs_defs.h:332
unsigned cs_gnum_t
global mesh entity number
Definition: cs_defs.h:317
Definition: cs_defs.h:325
void cs_order_lnum_allocated(const cs_lnum_t list[], const cs_lnum_t number[], cs_lnum_t order[], size_t nb_ent)
Compute an ordering table associated with an array of local numbers.
Definition: cs_order.cpp:1163
void cs_order_gnum_allocated_i(const cs_lnum_t list[], const cs_gnum_t number[], const cs_lnum_t index[], cs_lnum_t order[], size_t nb_ent)
Compute a lexicographical ordering table associated with an indexed array of global numbers.
Definition: cs_order.cpp:1078
cs_lnum_t * cs_order_gnum_i(const cs_lnum_t list[], const cs_gnum_t number[], const cs_lnum_t index[], size_t nb_ent)
Return a lexicographical ordering table associated with an indexed array of global numbers.
Definition: cs_order.cpp:929
cs_lnum_t * cs_order_gnum(const cs_lnum_t list[], const cs_gnum_t number[], size_t nb_ent)
Return an ordering table associated with an array of global numbers.
Definition: cs_order.cpp:852
void cs_order_reorder_data(cs_lnum_t n_elts, size_t elt_size, const cs_lnum_t order[], void *data)
Reorder data based on ordering array.
Definition: cs_order.cpp:1381
void cs_order_real_allocated(const cs_lnum_t list[], const cs_real_t val[], cs_lnum_t order[], size_t nb_ent)
Compute an ordering table associated with an array of local values.
Definition: cs_order.cpp:1292
void cs_order_single_gnum(size_t n_ent, const cs_gnum_t base, const cs_gnum_t number[], size_t *n_single, cs_gnum_t *single[])
Build a sorted array containing a single occurence of each global number in a given array.
Definition: cs_order.cpp:1421
void cs_order_gnum_allocated_s(const cs_lnum_t list[], const cs_gnum_t number[], size_t stride, cs_lnum_t order[], size_t nb_ent)
Compute a lexicographical ordering table associated with an array of strided global numbers.
Definition: cs_order.cpp:1024
int cs_order_gnum_test(const cs_lnum_t list[], const cs_gnum_t number[], size_t nb_ent)
Test if an array of global numbers is ordered.
Definition: cs_order.cpp:789
void cs_order_lnum_allocated_s(const cs_lnum_t list[], const cs_lnum_t number[], size_t stride, cs_lnum_t order[], size_t nb_ent)
Compute a lexicographical ordering table associated with an array of strided local numbers.
Definition: cs_order.cpp:1232
cs_lnum_t * cs_order_gnum_s(const cs_lnum_t list[], const cs_gnum_t number[], size_t stride, size_t nb_ent)
Return a lexicographical ordering table associated with a strided array of global numbers.
Definition: cs_order.cpp:890
cs_lnum_t * cs_order_renumbering(const cs_lnum_t order[], size_t nb_ent)
Build local renumbering array based on ordering of entities.
Definition: cs_order.cpp:1332
void cs_order_gnum_allocated(const cs_lnum_t list[], const cs_gnum_t number[], cs_lnum_t order[], size_t nb_ent)
Compute an ordering table associated with an array of global numbers.
Definition: cs_order.cpp:959
