cs_porous_model.cpp File Reference
Porous model management. More...
#include <float.h>
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "base/cs_base.h"
#include "base/cs_field.h"
#include "alge/cs_gradient.h"
#include "base/cs_log.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "cdo/cs_domain.h"
#include "alge/cs_matrix_default.h"
#include "mesh/cs_mesh.h"
#include "mesh/cs_mesh_adjacencies.h"
#include "base/cs_porosity_from_scan.h"
#include "base/cs_post.h"
#include "base/cs_preprocess.h"
#include "base/cs_renumber.h"
#include "fvm/fvm_nodal_from_desc.h"
#include "fvm/fvm_nodal_order.h"
#include "base/cs_porous_model.h"
+ Include dependency graph for cs_porous_model.cpp:
static void _porous_mesh_quantities_f_free (void)
 Free fluid mesh quantities. More...
static void _field_ibm_reallocate (cs_lnum_t n_ib_cells)
 Realloc boundary arrays for all defined fields. More...
void cs_porous_map_mesh_quantites_f_and_compute (void)
 Map fluid mesh quantities. More...
void cs_porous_model_set_model (int porous_model)
void cs_porous_model_init_disable_flag (void)
 Initialize disable_flag. More...
void cs_porous_model_set_has_disable_flag (int flag)
 Set (unset) has_disable_flag. More...
void cs_porous_model_init_fluid_quantities (void)
 Init fluid quantities. More...
void cs_porous_model_mesh_quantities_update (void)
 Compute solid quantities and update porosity field. More...
void cs_porous_model_auto_face_porosity (void)
 Automatic computation of the face porosity and factors. More...
void cs_porous_model_clip (void)
void cs_porous_model_fluid_surfaces_preprocessing (void)
 Preprocess the fluid surfaces. More...
void cs_porous_model_convert_cell_to_boundary (const cs_lnum_t n_ib_cells, const cs_lnum_t ibcell_cells[])
 Convert cell array to boundary array. More...
void cs_porous_model_postprocess_meshes (void)
 Initialize porous model arrays. More...
void cs_porous_model_post_immmersed_plane (const cs_lnum_t n_ib_cells, const cs_lnum_t n_ib_cells_filt, const cs_lnum_t ib_cells_filt[], const cs_lnum_t n_glob_vtx, const cs_lnum_t ibcell_cells[], const cs_lnum_t vtx_ids[][2], const cs_lnum_t w_vtx_idx[], const cs_lnum_t face_vertex_idx[], const cs_real_t w_vtx[][3])
 Post-processes the immersed boundary (ib) planes for display on paraview. More...
◆ _field_ibm_reallocate()
static void _field_ibm_reallocate ( cs_lnum_t  n_ib_cells)
static
Location sized must thus be known.
Fields that do not own their data should all have been mapped at this stage, and are checked.
[in]n_ib_cellsimmersed boundary cell number
◆ _porous_mesh_quantities_f_free()
static void _porous_mesh_quantities_f_free ( void  )
static
◆ cs_porous_map_mesh_quantites_f_and_compute()
void cs_porous_map_mesh_quantites_f_and_compute ( void  )
◆ cs_porous_model_auto_face_porosity()
void cs_porous_model_auto_face_porosity ( void  )
This is useful for the integral porous model.
◆ cs_porous_model_clip()
void cs_porous_model_clip ( void  )
◆ cs_porous_model_convert_cell_to_boundary()
void cs_porous_model_convert_cell_to_boundary ( const cs_lnum_t  n_ib_cells,
[in]n_ib_cellsimmersed cell number
[in]ibcell_cellsimmersed cell to cell connectivity
◆ cs_porous_model_fluid_surfaces_preprocessing()
void cs_porous_model_fluid_surfaces_preprocessing ( void  )
◆ cs_porous_model_init_disable_flag()
void cs_porous_model_init_disable_flag ( void  )
◆ cs_porous_model_init_fluid_quantities()
void cs_porous_model_init_fluid_quantities ( void  )
◆ cs_porous_model_mesh_quantities_update()
void cs_porous_model_mesh_quantities_update ( void  )
Compute solid quantities.
◆ cs_porous_model_post_immmersed_plane()
void cs_porous_model_post_immmersed_plane ( const cs_lnum_t  n_ib_cells,
[in]n_ib_cellsib cell number
[in]n_ib_cells_filtib cell number after filtering
[in]ib_cells_filtindices of the filtered cells
[in]n_glob_vtxtotal vertex number
[in]ibcell_cellsconnectivity ib_cell->cells
[in]ibcell_cells_filtconnectivity ib_cell->cells after filtering
[in]vtx_idsvertex ids on both sides of a IB vertex (v0<v1)
[in]w_vtx_idxib vertex indexes
[in]face_vertex_idxvertex indexes of the ib faces
[in]w_vtxib vertex coordinates
◆ cs_porous_model_postprocess_meshes()
void cs_porous_model_postprocess_meshes ( void  )
◆ cs_porous_model_set_has_disable_flag()
void cs_porous_model_set_has_disable_flag ( int  flag)
[in]flag1: on, 0: off
◆ cs_porous_model_set_model()
void cs_porous_model_set_model ( int  porous_model)
