cs_coolprop.hxx
1#ifndef CS_COOLPROP_HXX
2#define CS_COOLPROP_HXX
5 * Equation of state
35 * Local headers
40#include "base/cs_base.h"
42/*=============================================================================
43 * Local Macro Definitions
45
47 * Structure definition
49
51 * Global variables definition
53
54/*============================================================================
55 * Public function prototypes
57
58/*----------------------------------------------------------------------------*/
74/*----------------------------------------------------------------------------*/
75
76extern "C" void
77cs_phys_prop_coolprop(char *coolprop_material,
78 const char *coolprop_backend,
80 cs_phys_prop_type_t property,
81 const cs_lnum_t n_vals,
82 const cs_real_t var1[],
83 const cs_real_t var2[],
84 cs_real_t val[]);
85
86/*----------------------------------------------------------------------------*/
90/*----------------------------------------------------------------------------*/
91
92extern "C" void
94
95/*----------------------------------------------------------------------------*/
96
97#endif /* CS_COOLPROP_HXX */
98
void cs_coolprop_finalize(void)
Free state for Coolprop plugin.
Definition: cs_coolprop.cxx:363
void cs_phys_prop_coolprop(char *coolprop_material, const char *coolprop_backend, cs_phys_prop_thermo_plane_type_t thermo_plane, cs_phys_prop_type_t property, const cs_lnum_t n_vals, const cs_real_t var1[], const cs_real_t var2[], cs_real_t val[])
Computes physical properties in (P,h,Yi) for compressible flow.
Definition: cs_coolprop.cxx:110
Definition: cs_defs.h:332
Definition: cs_defs.h:325
Definition: cs_physical_properties.h:42
cs_phys_prop_type_t
Definition: cs_physical_properties.h:54
