cs_time_stepping.cpp File Reference
Main time loop. More...
#include <float.h>
#include <stdarg.h>
#include <mpi.h>
#include "atmo/cs_at_data_assim.h"
#include "atmo/cs_atmo.h"
#include "atmo/cs_atmo_chemistry.h"
#include "atmo/cs_atmo_imbrication.h"
#include "atmo/cs_atmo_ground_model.h"
#include "base/cs_1d_wall_thermal.h"
#include "base/cs_ale.h"
#include "base/cs_array.h"
#include "base/cs_boundary_conditions_set_coeffs.h"
#include "base/cs_control.h"
#include "base/cs_coupling.h"
#include "base/cs_gas_mix.h"
#include "base/cs_ibm.h"
#include "base/cs_initialize_fields.h"
#include "base/cs_log_iteration.h"
#include "base/cs_mobile_structures.h"
#include "base/cs_parall.h"
#include "base/cs_physical_properties_default.h"
#include "base/cs_porosity_from_scan.h"
#include "base/cs_porous_model.h"
#include "base/cs_post.h"
#include "base/cs_post_default.h"
#include "base/cs_resource.h"
#include "base/cs_restart.h"
#include "base/cs_restart_default.h"
#include "base/cs_restart_main_and_aux.h"
#include "base/cs_restart_map.h"
#include "base/cs_runaway_check.h"
#include "base/cs_runge_kutta_integrator.h"
#include "base/cs_sat_coupling.h"
#include "base/cs_solve_all.h"
#include "base/cs_time_moment.h"
#include "base/cs_timer_stats.h"
#include "base/cs_turbomachinery.h"
#include "base/cs_vof.h"
#include "base/cs_volume_mass_injection.h"
#include "base/cs_wall_condensation.h"
#include "base/cs_wall_condensation_1d_thermal.h"
#include "cdo/cs_cdo_main.h"
#include "cdo/cs_domain_op.h"
#include "cdo/cs_domain_setup.h"
#include "cfbl/cs_cf_boundary_conditions.h"
#include "gui/cs_gui.h"
#include "lagr/cs_lagr.h"
#include "lagr/cs_lagr_lec.h"
#include "mesh/cs_mesh.h"
#include "mesh/cs_mesh_save.h"
#include "mesh/cs_mesh_adaptive_refinement.h"
#include "rayt/cs_rad_transfer.h"
#include "rayt/cs_rad_transfer_restart.h"
#include "turb/cs_les_balance.h"
#include "turb/cs_les_inflow.h"
#include "turb/cs_turbulence_bc.h"
#include "turb/cs_turbulence_htles.h"
#include "base/cs_time_stepping.h"
void cs_f_finalize_imbrication (void)
void cs_time_stepping (void)
void cs_time_stepping_read_checkpoint (void)
 Input a checkpoint. More...
void cs_time_stepping_write_checkpoint (bool checkpoint_mesh)
 Output a checkpoint. More...
Main time loop.
Main time loop.
◆ cs_f_finalize_imbrication()
void cs_f_finalize_imbrication ( void  )
◆ cs_time_stepping()
void cs_time_stepping ( void  )
Main time loop.
◆ cs_time_stepping_read_checkpoint()
void cs_time_stepping_read_checkpoint ( void  )
Input a checkpoint.
◆ cs_time_stepping_write_checkpoint()
void cs_time_stepping_write_checkpoint ( bool  checkpoint_mesh)
If needed, the mesh is also output in the checkpoint directory, exect if this function is called for checkpoint serialized in memory (which is a special case for FMI exchange).
[in]checkpoint_meshalso save mesh in checkpoint directory
