cs_wall_functions.h File Reference
#include "bft/bft_printf.h"
#include "base/cs_base.h"
#include "base/cs_math.h"
+ Include dependency graph for cs_wall_functions.h:
Classes
struct  cs_wall_functions_t
 wall functions descriptor. More...
Enumerations
enum  cs_wall_f_type_t {
  CS_WALL_F_UNSET = -999 , CS_WALL_F_DISABLED = 0 , CS_WALL_F_1SCALE_POWER = 1 , CS_WALL_F_1SCALE_LOG = 2 ,
  CS_WALL_F_2SCALES_LOG = 3 , CS_WALL_F_SCALABLE_2SCALES_LOG = 4 , CS_WALL_F_2SCALES_VDRIEST = 5 , CS_WALL_F_2SCALES_SMOOTH_ROUGH = 6 ,
  CS_WALL_F_2SCALES_CONTINUOUS = 7
enum  cs_wall_f_s_type_t {
  CS_WALL_F_S_UNSET = -999 , CS_WALL_F_S_ARPACI_LARSEN = 0 , CS_WALL_F_S_VDRIEST = 1 , CS_WALL_F_S_LOUIS = 2 ,
  CS_WALL_F_S_MONIN_OBUKHOV = 3 , CS_WALL_F_S_SMOOTH_ROUGH = 4
static void cs_wall_functions_1scale_power (cs_real_t l_visc, cs_real_t vel, cs_real_t y, int *iuntur, cs_gnum_t *nsubla, cs_gnum_t *nlogla, cs_real_t *ustar, cs_real_t *uk, cs_real_t *yplus, cs_real_t *ypup, cs_real_t *cofimp)
 Power law: Werner & Wengle. More...
static void cs_wall_functions_1scale_log (cs_real_t l_visc, cs_real_t vel, cs_real_t y, int *iuntur, cs_gnum_t *nsubla, cs_gnum_t *nlogla, cs_real_t *ustar, cs_real_t *uk, cs_real_t *yplus, cs_real_t *ypup, cs_real_t *cofimp)
 Log law: piecewise linear and log, with one velocity scale based on the friction. More...
static cs_real_t _uplus (cs_real_t yp, cs_real_t ka, cs_real_t B, cs_real_t cuv, cs_real_t y0, cs_real_t n)
static cs_real_t _dupdyp (cs_real_t yp, cs_real_t ka, cs_real_t B, cs_real_t cuv, cs_real_t y0, cs_real_t n)
static void cs_wall_functions_2scales_continuous (cs_real_t rnnb, cs_real_t l_visc, cs_real_t t_visc, cs_real_t vel, cs_real_t y, cs_real_t kinetic_en, int *iuntur, cs_gnum_t *nsubla, cs_gnum_t *nlogla, cs_real_t *ustar, cs_real_t *uk, cs_real_t *yplus, cs_real_t *ypup, cs_real_t *cofimp)
 Continuous law of the wall between the linear and log law, with two velocity scales based on the friction and the turbulent kinetic energy. Can be used with RANS model either in high Reynolds or in low Reynolds (if the underlying RANS model is compatible). More...
static void cs_wall_functions_2scales_log (cs_real_t l_visc, cs_real_t t_visc, cs_real_t vel, cs_real_t y, cs_real_t kinetic_en, int *iuntur, cs_gnum_t *nsubla, cs_gnum_t *nlogla, cs_real_t *ustar, cs_real_t *uk, cs_real_t *yplus, cs_real_t *ypup, cs_real_t *cofimp)
 Log law: piecewise linear and log, with two velocity scales based on the friction and the turbulent kinetic energy. More...
static void cs_wall_functions_2scales_scalable (cs_real_t l_visc, cs_real_t t_visc, cs_real_t vel, cs_real_t y, cs_real_t kinetic_en, int *iuntur, cs_gnum_t *nsubla, cs_gnum_t *nlogla, cs_real_t *ustar, cs_real_t *uk, cs_real_t *yplus, cs_real_t *dplus, cs_real_t *ypup, cs_real_t *cofimp)
 Scalable wall function: shift the wall if $ y^+ < y^+_{lim} $. More...
static cs_real_t _vdriest_dupdyp_integral (cs_real_t yplus)
static void cs_wall_functions_2scales_vdriest (cs_real_t rnnb, cs_real_t l_visc, cs_real_t vel, cs_real_t y, cs_real_t kinetic_en, int *iuntur, cs_gnum_t *nsubla, cs_gnum_t *nlogla, cs_real_t *ustar, cs_real_t *uk, cs_real_t *yplus, cs_real_t *ypup, cs_real_t *cofimp, cs_real_t *lmk, cs_real_t kr, bool wf)
 Two velocity scales wall function using Van Driest mixing length. More...
static void cs_wall_functions_2scales_smooth_rough (cs_real_t l_visc, cs_real_t t_visc, cs_real_t vel, cs_real_t y, cs_real_t rough_d, cs_real_t kinetic_en, int *iuntur, cs_gnum_t *nsubla, cs_gnum_t *nlogla, cs_real_t *ustar, cs_real_t *uk, cs_real_t *yplus, cs_real_t *dplus, cs_real_t *ypup, cs_real_t *cofimp)
 Two velocity scales wall function with automatic switch from rough to smooth. More...
static void cs_wall_functions_disabled (cs_real_t l_visc, cs_real_t t_visc, cs_real_t vel, cs_real_t y, int *iuntur, cs_gnum_t *nsubla, cs_gnum_t *nlogla, cs_real_t *ustar, cs_real_t *uk, cs_real_t *yplus, cs_real_t *dplus, cs_real_t *ypup, cs_real_t *cofimp)
 No wall function. More...
static void cs_wall_functions_s_arpaci_larsen (cs_real_t l_visc, cs_real_t prl, cs_real_t prt, cs_real_t rough_t, cs_real_t uk, cs_real_t yplus, cs_real_t dplus, cs_real_t *htur, cs_real_t *yplim)
 The correction of the exchange coefficient is computed thanks to a similarity model between dynamic viscous sub-layer and themal sub-layer. More...
static void cs_wall_functions_s_vdriest (cs_real_t prl, cs_real_t prt, cs_real_t yplus, cs_real_t *htur)
 The correction of the exchange coefficient $ h_{tur} = \sigma \dfrac{y^+}{t^+} $ is computed thanks to a numerical integration of: More...
static void cs_wall_functions_s_smooth_rough (cs_real_t l_visc, cs_real_t prl, cs_real_t prt, cs_real_t rough_t, cs_real_t uk, cs_real_t yplus, cs_real_t dplus, cs_real_t *htur)
 Rough Smooth Thermal Wall Function - Prototype. More...
cs_wall_functions_t * cs_get_glob_wall_functions (void)
void cs_wall_functions_velocity (cs_wall_f_type_t iwallf, cs_real_t l_visc, cs_real_t t_visc, cs_real_t vel, cs_real_t y, cs_real_t rough_d, cs_real_t rnnb, cs_real_t kinetic_en, cs_real_t rough_t, cs_real_t buoyant_param, cs_real_t delta_t, cs_real_t turb_prandtl, int icodcl_th_fid, cs_real_t flux, cs_field_t *f_th, int *iuntur, cs_gnum_t *nsubla, cs_gnum_t *nlogla, cs_real_t *ustar, cs_real_t *uk, cs_real_t *yplus, cs_real_t *ypup, cs_real_t *cofimp, cs_real_t *dplus, cs_real_t *cfnns, cs_real_t *cfnnk, cs_real_t *cfnne, cs_real_t *dlmo)
 Compute the friction velocity and $y^+$ / $u^+$. More...
void cs_wall_functions_scalar (cs_wall_f_s_type_t iwalfs, cs_real_t l_visc, cs_real_t prl, cs_real_t prt, cs_real_t rough_t, cs_real_t uk, cs_real_t yplus, cs_real_t dplus, cs_real_t *htur, cs_real_t *yplim)
 Compute the correction of the exchange coefficient between the fluid and the wall for a turbulent flow. More...
const cs_wall_functions_t * cs_glob_wall_functions
◆ cs_wall_f_s_type_t
Enumerator
CS_WALL_F_S_UNSET
CS_WALL_F_S_VDRIEST
CS_WALL_F_S_LOUIS
◆ cs_wall_f_type_t
Enumerator
CS_WALL_F_UNSET
CS_WALL_F_DISABLED
◆ _dupdyp()
static cs_real_t _dupdyp ( cs_real_t  yp,
cs_real_t  ka,
cs_real_t  B,
cs_real_t  cuv,
cs_real_t  y0,
cs_real_t  n
inlinestatic
◆ _uplus()
static cs_real_t _uplus ( cs_real_t  yp,
cs_real_t  ka,
cs_real_t  B,
cs_real_t  cuv,
cs_real_t  y0,
cs_real_t  n
inlinestatic
◆ _vdriest_dupdyp_integral()
static cs_real_t _vdriest_dupdyp_integral ( cs_real_t  yplus)
inlinestatic
◆ cs_get_glob_wall_functions()
cs_wall_functions_t * cs_get_glob_wall_functions ( void  )
◆ cs_wall_functions_1scale_log()
static void cs_wall_functions_1scale_log ( cs_real_t  l_visc,
cs_real_t  vel,
cs_real_t  y,
int *  iuntur,
cs_gnum_t *  nsubla,
cs_gnum_t *  nlogla,
cs_real_t *  ustar,
cs_real_t *  uk,
cs_real_t *  yplus,
cs_real_t *  ypup,
cs_real_t *  cofimp
inlinestatic
[in]ifacface number
[in]l_visckinematic viscosity
[in]velwall projected cell center velocity
[in]ywall distance
[out]iunturindicator: 0 in the viscous sublayer
[out]nsublacounter of cell in the viscous sublayer
[out]nloglacounter of cell in the log-layer
[out]ustarfriction velocity
[out]ukfriction velocity
[out]yplusdimensionless distance to the wall
[out]ypupyplus projected vel ratio
[out]cofimp$\frac{|U_F|}{|U_I^p|}$ to ensure a good turbulence production
◆ cs_wall_functions_1scale_power()
static void cs_wall_functions_1scale_power ( cs_real_t  l_visc,
cs_real_t  vel,
cs_real_t  y,
int *  iuntur,
cs_gnum_t *  nsubla,
cs_gnum_t *  nlogla,
cs_real_t *  ustar,
cs_real_t *  uk,
cs_real_t *  yplus,
cs_real_t *  ypup,
cs_real_t *  cofimp
inlinestatic
[in]ywall distance
◆ cs_wall_functions_2scales_continuous()
static void cs_wall_functions_2scales_continuous ( cs_real_t  rnnb,
cs_real_t  l_visc,
cs_real_t  t_visc,
cs_real_t  vel,
cs_real_t  y,
int *  iuntur,
cs_gnum_t *  nsubla,
cs_gnum_t *  nlogla,
cs_real_t *  ustar,
cs_real_t *  uk,
cs_real_t *  yplus,
cs_real_t *  ypup,
cs_real_t *  cofimp
inlinestatic
[in]rnnb$\vec{n}.(\tens{R}\vec{n})$
[in]t_viscturbulent kinematic viscosity
[in]ywall distance
[in]kinetic_enturbulent kinetic energy
◆ cs_wall_functions_2scales_log()
static void cs_wall_functions_2scales_log ( cs_real_t  l_visc,
cs_real_t  t_visc,
cs_real_t  vel,
cs_real_t  y,
int *  iuntur,
cs_gnum_t *  nsubla,
cs_gnum_t *  nlogla,
cs_real_t *  ustar,
cs_real_t *  uk,
cs_real_t *  yplus,
cs_real_t *  ypup,
cs_real_t *  cofimp
inlinestatic
[in]ywall distance
◆ cs_wall_functions_2scales_scalable()
static void cs_wall_functions_2scales_scalable ( cs_real_t  l_visc,
cs_real_t  t_visc,
cs_real_t  vel,
cs_real_t  y,
int *  iuntur,
cs_gnum_t *  nsubla,
cs_gnum_t *  nlogla,
cs_real_t *  ustar,
cs_real_t *  uk,
cs_real_t *  yplus,
cs_real_t *  dplus,
cs_real_t *  ypup,
cs_real_t *  cofimp
inlinestatic
[in]ywall distance
[out]dplusdimensionless shift to the wall for scalable wall functions
◆ cs_wall_functions_2scales_smooth_rough()
static void cs_wall_functions_2scales_smooth_rough ( cs_real_t  l_visc,
cs_real_t  t_visc,
cs_real_t  vel,
cs_real_t  y,
cs_real_t  rough_d,
int *  iuntur,
cs_gnum_t *  nsubla,
cs_gnum_t *  nlogla,
cs_real_t *  ustar,
cs_real_t *  uk,
cs_real_t *  yplus,
cs_real_t *  dplus,
cs_real_t *  ypup,
cs_real_t *  cofimp
inlinestatic
$ u^+ $ is computed as follows:
\[ u^+ = \dfrac{1}{\kappa}
            \ln \left(\dfrac{(y+y_0) u_k}{\nu + \alpha \xi u_k} \right)
           + Cst_{smooth} \]
with $ \alpha = \exp \left(- \kappa(Cst_{rough}-Cst_{smooth})\right)
                \simeq 0.26 $ and $ y_0 = \alpha \xi \exp \left(-\kappa Cst_{smooth} \right)
            = \xi \exp \left(-\kappa Cst_{rough} \right)
            \simeq \dfrac{\xi}{33}$.
[in]ywall distance
[in]rough_droughness length scale (not sand grain)
[out]dplusdimensionless shift to the wall due to rough_d
◆ cs_wall_functions_2scales_vdriest()
static void cs_wall_functions_2scales_vdriest ( cs_real_t  rnnb,
cs_real_t  l_visc,
cs_real_t  vel,
cs_real_t  y,
int *  iuntur,
cs_gnum_t *  nsubla,
cs_gnum_t *  nlogla,
cs_real_t *  ustar,
cs_real_t *  uk,
cs_real_t *  yplus,
cs_real_t *  ypup,
cs_real_t *  cofimp,
cs_real_t *  lmk,
cs_real_t  kr,
bool  wf
inlinestatic
\[ u^+ = \int_0^{y_k^+} \dfrac{dy_k^+}{1+L_m^k} \]
with $ L_m^k $ standing for Van Driest mixing length:
\[ L_m^k = \kappa y_k^+ (1 - exp(\dfrac{-y_k^+}{A})) \]
A polynome fitting the integral is used for $ y_k^+ < 200 $, and a log law is used for $ y_k^+ >= 200 $.
A wall roughness can be taken into account in the mixing length as proposed by Rotta (1962) with Cebeci & Chang (1978) correlation.
[in]ywall distance
[in]lmkdimensionless mixing length
[in]krwall roughness
[in]wfenable full wall function computation, if false, uk is not recomputed and uplus is the only output
◆ cs_wall_functions_disabled()
static void cs_wall_functions_disabled ( cs_real_t  l_visc,
cs_real_t  t_visc,
cs_real_t  vel,
cs_real_t  y,
int *  iuntur,
cs_gnum_t *  nsubla,
cs_gnum_t *  nlogla,
cs_real_t *  ustar,
cs_real_t *  uk,
cs_real_t *  yplus,
cs_real_t *  dplus,
cs_real_t *  ypup,
cs_real_t *  cofimp
inlinestatic
No wall function.
[in]ywall distance
◆ cs_wall_functions_s_arpaci_larsen()
static void cs_wall_functions_s_arpaci_larsen ( cs_real_t  l_visc,
cs_real_t  prl,
cs_real_t  prt,
cs_real_t  rough_t,
cs_real_t  uk,
cs_real_t  yplus,
cs_real_t  dplus,
cs_real_t *  htur,
cs_real_t *  yplim
inlinestatic
$ T^+ $ is computed as follows:
  • For a laminar Prandtl number smaller than 0.1 (such as liquid metals), the standard model with two sub-layers (Prandtl-Taylor) is used.
  • For a laminar Prandtl number larger than 0.1 (such as liquids and gas), a model with three sub-layers (Arpaci-Larsen) is used.
The final exchange coefficient is:
 h = \dfrac{K}{\centip \centf} h_{tur}
[in]l_visckinetic viscosity
[in]prllaminar Prandtl number
[in]prtturbulent Prandtl number
[in]rough_tscalar roughness length scale
[in]ukvelocity scale based on TKE
[in]yplusdimensionless distance to the wall
[out]hturcorrection for the exchange coefficient ( $ Pr y^+/T^+ $)
[out]yplimvalue of the limit for $ y^+ $
◆ cs_wall_functions_s_smooth_rough()
static void cs_wall_functions_s_smooth_rough ( cs_real_t  l_visc,
cs_real_t  prl,
cs_real_t  prt,
cs_real_t  rough_t,
cs_real_t  uk,
cs_real_t  yplus,
cs_real_t  dplus,
cs_real_t *  htur
inlinestatic
[in]prlmolecular Prandtl number ( $ Pr=\sigma=\frac{\mu C_p}{\lambda_f} $ )
[in]prtturbulent Prandtl number ( $ \sigma_t $ )
[in]dplusdimensionless shift to the wall for scalable wall function
◆ cs_wall_functions_s_vdriest()
static void cs_wall_functions_s_vdriest ( cs_real_t  prl,
cs_real_t  prt,
cs_real_t  yplus,
cs_real_t *  htur
inlinestatic
 \dfrac{T^+}{\sigma}
          = \int_0^{y_k^+} \dfrac{dy_k^+}{1+\dfrac{\sigma}{\sigma_t}\nu_t^+}
with $ \nu_t^+ = L_m^k $ as assumed in the derivation of the two scales wall function using Van Driest mixing length. Therefore $ L_m^k = \kappa y_k^+(1 - exp(\dfrac{-y_k^+}{A})) $ is taken.
Notice that we integrate up to $ y^+=100 $ (YP100), beyond that value the profile is prolonged by a logarithm relying on the fact that $ \nu_t^+=\kappa y^+ $ beyond $ y^+=100 $.
◆ cs_wall_functions_scalar()
void cs_wall_functions_scalar ( cs_wall_f_s_type_t  iwalfs,
cs_real_t  l_visc,
cs_real_t  prl,
cs_real_t  prt,
cs_real_t  rough_t,
cs_real_t  uk,
cs_real_t  yplus,
cs_real_t  dplus,
cs_real_t *  htur,
cs_real_t *  yplim
This is function of the dimensionless distance to the wall $ y^+ = \dfrac{\centip \centf u_\star}{\nu}$.
Then the return coefficient reads:
 h_{tur} = Pr \dfrac{y^+}{T^+}
[in]iwalfstype of wall functions for scalar
[in]rough_tscalar roughness lenghth scale
[in]dplusdimensionless distance for scalable wall functions
[out]hturcorrected exchange coefficient
◆ cs_wall_functions_velocity()
void cs_wall_functions_velocity ( cs_wall_f_type_t  iwallf,
cs_real_t  l_visc,
cs_real_t  t_visc,
cs_real_t  vel,
cs_real_t  y,
cs_real_t  rough_d,
cs_real_t  rnnb,
cs_real_t  rough_t,
cs_real_t  delta_t,
int  icodcl_th_fid,
cs_real_t  flux,
cs_field_t *  f_th,
int *  iuntur,
cs_gnum_t *  nsubla,
cs_gnum_t *  nlogla,
cs_real_t *  ustar,
cs_real_t *  uk,
cs_real_t *  yplus,
cs_real_t *  ypup,
cs_real_t *  cofimp,
cs_real_t *  dplus,
cs_real_t *  cfnns,
cs_real_t *  cfnnk,
cs_real_t *  cfnne,
cs_real_t *  dlmo
[in]iwallfwall function type
[in]ywall distance
[in]rough_droughness length scale (not sand grain roughness)
[in]kinetic_enturbulent kinetic energy (cell center)
[in]rough_tboundary_thermal_roughness
[in]buoyant_paramBuoyant parameter: g beta delta Theta v
[in]delta_ttemperature delta
[in]turb_prandtlturbulent Prandtl
[in]icodcl_th_fidicodcl_th_f[f_id]]
[in]flux
[in,out]iunturindicator: 0 in the viscous sublayer
[in,out]nsublacounter of cell in the viscous sublayer
[in,out]nloglacounter of cell in the log-layer
[out]cfbnnscorrectif factors
[out]cfnnk
[out]cfnne
[out]dlmoinverse of Obukhov length
[in]ywall distance
[in]flux
[out]cfbnnscorrective factors
[out]cfnnk
[out]cfnne
◆ cs_glob_wall_functions
const cs_wall_functions_t* cs_glob_wall_functions
extern
