cs_halo_hip.h File Reference
#include "base/cs_halo.h"
+ Include dependency graph for cs_halo_hip.h:
void cs_halo_hip_pack_send_buffer (const cs_halo_t *halo, hipStream_t stream, cs_halo_type_t sync_mode, cs_datatype_t data_type, cs_lnum_t stride, const void *val, void *send_buffer)
 Pack cs_real_t halo data to send into dense buffer, using HIP. More...
◆ cs_halo_hip_pack_send_buffer()
void cs_halo_hip_pack_send_buffer ( const cs_halo_t *  halo,
hipStream_t  stream,
cs_lnum_t  stride,
const void *  val,
void *  send_buffer
A local state and/or buffer may be provided, or the default (global) state and buffer will be used. If provided explicitely, the buffer must be of sufficient size.
[in]halopointer to halo structure
[in]streamassociated HIP stream
[in]sync_modesynchronization mode (standard or extended)
[in]stridenumber of (interlaced) values by entity
[in]varpointer to value array (device)
[out]send_bufferpointer to send buffer, null for global buffer
[in]data_typedata type
[out]send_bufferpointer to send buffer, NULL for global buffer
