cs_preprocess.h
1#ifndef CS_PREPROCESS_H
2#define CS_PREPROCESS_H
5 * Handle successive preprocessing operations.
31 * Local headers
34#include "base/cs_defs.h"
36#include "base/cs_halo.h"
37#include "mesh/cs_mesh.h"
41/*=============================================================================
42 * Macro definitions
43 *============================================================================*/
45/*============================================================================
46 * Type definitions
48
49/*=============================================================================
50 * Public function prototypes
52
53/*----------------------------------------------------------------------------
54 * Define all mesh preprocessing operations.
55 *----------------------------------------------------------------------------*/
56
57void
59
60/*----------------------------------------------------------------------------
61 * Apply all mesh preprocessing operations.
62 *
63 * parameters:
64 * halo_type <-> type of halo (standard or extended)
65 *----------------------------------------------------------------------------*/
66
67void
69
70/*----------------------------------------------------------------------------*/
79/*----------------------------------------------------------------------------*/
80
81void
84 cs_lnum_t n_faces,
85 const cs_lnum_t face_ids[]);
86
87/*----------------------------------------------------------------------------
88 * Update fortran arrays relative to the global mesh.
89 *----------------------------------------------------------------------------*/
90
91void
93
101/*----------------------------------------------------------------------------*/
102
103void
105
106/*----------------------------------------------------------------------------*/
107
108#endif /* CS_PREPROCESS_H */
Definition: cs_defs.h:325
cs_halo_type_t
Definition: cs_halo.h:53
void cs_preprocess_mesh(cs_halo_type_t halo_type)
Definition: cs_preprocess.cpp:217
void cs_preprocess_mesh_define(void)
Definition: cs_preprocess.cpp:175
void cs_preprocess_mesh_update_fortran(void)
Definition: cs_preprocess.cpp:524
void cs_preprocess_mesh_selected_b_faces_ignore(cs_mesh_t *m, cs_mesh_quantities_t *mq, cs_lnum_t n_faces, const cs_lnum_t face_ids[])
Apply numbering changes to ignore selected boundary faces.
Definition: cs_preprocess.cpp:459
void cs_preprocess_mesh_update_device(void)
Map some mesh arrays for use on device.
Definition: cs_preprocess.cpp:550
Definition: cs_mesh_quantities.h:88
Definition: cs_mesh.h:85
