#include "base/cs_defs.h"#include <assert.h>#include "bft/bft_error.h"#include "bft/bft_printf.h"#include "base/cs_dispatch.h"#include "base/cs_field.h"#include "base/cs_field_pointer.h"#include "base/cs_mem.h"#include "base/cs_parameters.h"#include "base/cs_physical_constants.h"#include "pprt/cs_physical_model.h"#include "base/cs_restart_default.h"#include "base/cs_velocity_pressure.h"#include "base/cs_vof.h"#include "base/cs_theta_scheme.h"
Include dependency graph for cs_theta_scheme.cpp:Functions | |
| static void | _theta_scheme_update_after_restart (void) |
| theta scheme update after restart for unread arrays. More... | |
| void | cs_theta_scheme_update_var_stage1 (void) |
| Management of the mass flux, the viscosity, the density, the specific heat and the tsnsa array in case of a theta-scheme. More... | |
| void | cs_theta_scheme_update_var_stage2 (void) |
| void | cs_theta_scheme_update_var_stage3 (void) |
| Allocate the array of structures local_models. More... | |
| void | cs_theta_scheme_update_var_stage4 (void) |
| void | cs_theta_scheme_update_var_stage5 (void) |
static |
| void cs_theta_scheme_update_var_stage1 | ( | void | ) |
Called at the very start of the time step
Please refer to the mass flux section of the theory guide for more informations.
| void cs_theta_scheme_update_var_stage2 | ( | void | ) |
Called at just after cs_physical_properties_update (and thus before cs_solve_navier_stokes)
| void cs_theta_scheme_update_var_stage3 | ( | void | ) |
Called just after cs_solve_navier_stokes, in loops for U/P and ALE
| void cs_theta_scheme_update_var_stage4 | ( | void | ) |
After cs_solve_navier_stokes and loops for U/P and ALE
| void cs_theta_scheme_update_var_stage5 | ( | void | ) |
Called just after cs_solve_transported_variables
