cs_preprocessor_data.h File Reference
#include "fvm/fvm_io_num.h"
#include "base/cs_base.h"
#include "mesh/cs_mesh.h"
+ Include dependency graph for cs_preprocessor_data.h:
Enumerations
enum  cs_preprocessor_data_restart_mode_t { CS_PREPROCESSOR_DATA_RESTART_AUTO , CS_PREPROCESSOR_DATA_RESTART_NONE , CS_PREPROCESSOR_DATA_RESTART_ONLY }
void cs_preprocessor_data_add_file (const char *file_name, size_t n_group_renames, const char **group_rename, const double transf_matrix[3][4])
int cs_preprocessor_check_perio (void)
cs_preprocessor_data_restart_mode_t cs_preprocessor_data_get_restart_mode (void)
 Return restart behavior for preprocessing. More...
void cs_preprocessor_data_set_restart_mode (cs_preprocessor_data_restart_mode_t mode)
 Define restart behavior in case of restart. More...
void cs_preprocessor_data_read_headers (cs_mesh_t *mesh, cs_mesh_builder_t *mesh_builder, bool ignore_cartesian)
void cs_preprocessor_data_read_mesh (cs_mesh_t *mesh, cs_mesh_builder_t *mesh_builder, bool ignore_cartesian)
◆ cs_preprocessor_data_restart_mode_t
Mesh preprocessing operations in case of restart.
Enumerator
use restart mesh for computation if present
do not use restart mesh for computation
use restart mesh as-is, with no additional preprocessing (default if restart is present)
◆ cs_preprocessor_check_perio()
int cs_preprocessor_check_perio ( void  )
◆ cs_preprocessor_data_add_file()
void cs_preprocessor_data_add_file ( const char *  file_name,
const char **  group_rename,
◆ cs_preprocessor_data_get_restart_mode()
cs_preprocessor_data_restart_mode_t cs_preprocessor_data_get_restart_mode ( void  )
preprocessing mode in case of restart.
◆ cs_preprocessor_data_read_headers()
void cs_preprocessor_data_read_headers ( cs_mesh_t *  mesh,
cs_mesh_builder_t *  mesh_builder,
◆ cs_preprocessor_data_read_mesh()
void cs_preprocessor_data_read_mesh ( cs_mesh_t *  mesh,
◆ cs_preprocessor_data_set_restart_mode()
void cs_preprocessor_data_set_restart_mode ( cs_preprocessor_data_restart_mode_t  mode)
If no restart/mesh_input.csm (or restart/mesh_input) file is found, CS_PREPROCESSOR_DATA_RESTART_NONE will be used.
[in]modechosen preprocessing mode on restart
