cs_field_t Class Reference
Field descriptor. More...
#include <cs_field.h>
+ Collaboration diagram for cs_field_t:
Public Member Functions
cs_span_2d< cs_real_t > view (const int time_id=0) const
 Return a 2D span view of field values (n_vals, dim), even if the field is a scalar, in which case dim = 1. More...
cs_span< cs_real_t > get_vals_s (const int time_id=0) const
 Return a 1D span view of field values. If the field is not a scalar a fatal error is provoked. More...
cs_span_2d< cs_real_t > get_vals_v (const int time_id=0) const
 Return a 2D span view of field values. If the field is not a vector a fatal error is provoked. More...
cs_span_2d< cs_real_t > get_vals_t (const int time_id=0) const
 Return a 2D span view of field values. If the field is not a tensor a fatal error is provoked. More...
cs_span< cs_real_t > get_val_s (const int time_id=0) const
cs_span_2d< cs_real_t > get_val_v (const int time_id=0) const
cs_span_2d< cs_real_t > get_val_t (const int time_id=0) const
cs_span_2d< cs_real_t > get_grad_s () const
 Return a 2D span view of gradient values. If the field is not a scalar or if the gradient member is nullptr, a fatal error is provoked. More...
cs_span_3d< cs_real_t > get_grad_v () const
 Return a 3D span view of gradient values. If the field is not a vector or if the gradient member is nullptr, a fatal error is provoked. More...
cs_span_3d< cs_real_t > get_grad_t () const
 Return a 3D span view of gradient values. If the field is not a tensor or if the gradient member is nullptr, a fatal error is provoked. More...
cs_alloc_mode_t get_vals_alloc_mode (const int time_id=0) const
 Get the allocation mode of the values array. More...
cs_span_3d< cs_real_t > ns_view (const int time_id=0) const
 Return a 3D span view of field values. The view is of dimensions (ns_fields, n_vals, dim) More...
cs_span_2d< cs_real_t > get_ns_vals_s (const int time_id=0) const
cs_span_3d< cs_real_t > get_ns_vals_v (const int time_id=0) const
cs_span_3d< cs_real_t > get_ns_vals_t (const int time_id=0) const
cs_span_2d< cs_real_t > get_ns_val_s (const int time_id=0) const
cs_span_3d< cs_real_t > get_ns_val_v (const int time_id=0) const
cs_span_3d< cs_real_t > get_ns_val_t (const int time_id=0) const
void update_public_pointers (void)
 Update public pointers based on private members. More...
void update_size (const int time_id=-1)
 Resize field values automatically (vals, val, val_pre) based on the corresponding mesh_location. More...
void clear (const int time_id=-1)
 Clear data allocation. More...
void update_sub_fields_mapping (void) const
 Update data mapping for all sub-fields. More...
void map_values (cs_real_t *val_new, cs_real_t *val_pre_new)
 Map existing value arrays to field descriptor. More...
CS_F_HOST_DEVICE void set_ns_owner (int owner_id)
CS_F_HOST_DEVICE void set_ns_parameters (const int series_size, const int series_idx, const int series_owner)
CS_F_HOST_DEVICE bool is_series_owner () const
CS_F_HOST_DEVICE bool is_part_of_series () const
CS_F_HOST_DEVICE bool owner () const
CS_F_HOST_DEVICE int series_size () const
CS_F_HOST_DEVICE int series_owner () const
CS_F_HOST_DEVICE int series_id () const
CS_F_HOST_DEVICE bool has_sub_fields () const
CS_F_HOST_DEVICE bool is_sub_field () const
CS_F_HOST_DEVICE bool is_sub_field_of (const int owner_id) const
CS_F_HOST void initialize_sub_fields (void)
 Initialize values related to sub-fields (indices mainly) More...
CS_F_HOST void map_to_ns_data (void)
 Map internal and public pointers to data series owner. More...
int set_key_int (int key_id, int value)
 Assign a integer value for a given key to a field. More...
int set_key_int (const char *key, int value)
int get_key_int (int key_id) const
 Return a integer value for a given key associated with a field. More...
int get_key_int (const char *key) const
int set_key_int_bits (int key_id, int mask)
 Set integer bits matching a mask to 1 for a given key for a field. More...
int set_key_int_bits (const char *key, int mask)
int clear_key_int_bits (int key_id, int mask)
 Set integer bits matching a mask to 0 for a given key for a field. More...
int clear_key_int_bits (const char *key, int mask)
int set_key_double (int key_id, double value)
 Assign a floating point value for a given key to a field. More...
int set_key_double (const char *key, double value)
double get_key_double (int key_id) const
 Return a floating point value for a given key associated with a field. More...
double get_key_double (const char *key) const
int set_key_str (int key_id, const char *str)
 Assign a character string for a given key to a field. More...
int set_key_str (const char *key, const char *str)
const char * get_key_str (int key_id) const
 Return a character string for a given key associated with a field. More...
const char * get_key_str (const char *key) const
const void * get_key_struct (const int key_id, void *s) const
 Return a structure for a given key associated with a field. More...
const void * get_key_struct (const char *key, void *s) const
Public Attributes
const char * name
int id
int type
int dim
int location_id
int n_time_vals
cs_real_t ** vals
cs_real_t * val
cs_real_t * val_pre
cs_real_t * grad
cs_field_bc_coeffs_t * bc_coeffs
bool is_owner
int ns_size
int ns_idx
int ns_owner
cs_array_2d< cs_real_t > ** _vals
cs_array_3d< cs_real_t > ** _ns_vals
Members of this field are publicly accessible, to allow for concise syntax, as it is expected to be used in many places.
Member Function Documentation
◆ clear()
void clear ( const int  time_id = -1)
◆ clear_key_int_bits() [1/2]
int clear_key_int_bits ( const char *  key,
int  mask
If the key id is not valid, CS_FIELD_INVALID_KEY_ID is returned. If the field category is not compatible with the key (as defined by its type flag), CS_FIELD_INVALID_CATEGORY is returned. If the data type does not match, CS_FIELD_INVALID_TYPE is returned. If the key value has been locked, CS_FIELD_LOCKED is returned.
0 in case of success, > 1 in case of error
[in]keykey string
[in]maskmask
◆ clear_key_int_bits() [2/2]
int clear_key_int_bits ( int  key_id,
int  mask
[in]key_idkey id
[in]maskmask
◆ get_grad_s()
cs_span_2d< cs_real_t > get_grad_s ( ) const
cs_span_2d<cs_real_t>(:,3) view of the gradient values.
◆ get_grad_t()
cs_span_3d< cs_real_t > get_grad_t ( ) const
cs_span_3d<cs_real_t>(:,6,3) view of the gradient values.
◆ get_grad_v()
cs_span_3d< cs_real_t > get_grad_v ( ) const
cs_span_3d<cs_real_t>(:,3,3) view of the gradient values.
◆ get_key_double() [1/2]
double get_key_double ( const char *  key) const
If the key id is not valid, or the value type or field category is not compatible, a fatal error is provoked.
value associated with the key id for this field
[in]keykey string
◆ get_key_double() [2/2]
double get_key_double ( int  key_id) const
[in]key_idkey id
◆ get_key_int() [1/2]
int get_key_int ( const char *  key) const
[in]keykey string
◆ get_key_int() [2/2]
int get_key_int ( int  key_id) const
[in]key_idkey id
◆ get_key_str() [1/2]
const char * get_key_str ( const char *  key) const
string associated with the key id for this field
[in]keykey string
◆ get_key_str() [2/2]
const char * get_key_str ( int  key_id) const
[in]key_idkey id
◆ get_key_struct() [1/2]
const void * get_key_struct ( const char *  key,
void *  s
) const
pointer to structure associated with the key id for this field (same as s)
[in]keyKey string
[out]sstructure associated with key
◆ get_key_struct() [2/2]
const void * get_key_struct ( const int  key_id,
void *  s
) const
[in]key_idid of associated key
◆ get_ns_val_s()
cs_span_2d< cs_real_t > get_ns_val_s ( const int  time_id = 0) const
cs_span<cs_real_t> view of field values.
[in]time_idtime value id to get. 0 for val, 1 for val_pre
◆ get_ns_val_t()
cs_span_3d< cs_real_t > get_ns_val_t ( const int  time_id = 0) const
cs_span_2d<cs_real_t>(:,6) view of field values.
◆ get_ns_val_v()
cs_span_3d< cs_real_t > get_ns_val_v ( const int  time_id = 0) const
cs_span_2d<cs_real_t>(:,3) view of field values.
◆ get_ns_vals_s()
cs_span_2d< cs_real_t > get_ns_vals_s ( const int  time_id = 0) const
Deprecated:
Use get_ns_val_s instead
◆ get_ns_vals_t()
cs_span_3d< cs_real_t > get_ns_vals_t ( const int  time_id = 0) const
Deprecated:
Use get_ns_val_t instead
◆ get_ns_vals_v()
cs_span_3d< cs_real_t > get_ns_vals_v ( const int  time_id = 0) const
Deprecated:
Use get_ns_val_v instead
◆ get_val_s()
cs_span< cs_real_t > get_val_s ( const int  time_id = 0) const
◆ get_val_t()
cs_span_2d< cs_real_t > get_val_t ( const int  time_id = 0) const
◆ get_val_v()
cs_span_2d< cs_real_t > get_val_v ( const int  time_id = 0) const
◆ get_vals_alloc_mode()
cs_alloc_mode_t get_vals_alloc_mode ( const int  time_id = 0) const
cs_alloc_mode_t corresponding to the used allocation mode.
◆ get_vals_s()
cs_span< cs_real_t > get_vals_s ( const int  time_id = 0) const
Deprecated:
Use get_val_s instead
◆ get_vals_t()
cs_span_2d< cs_real_t > get_vals_t ( const int  time_id = 0) const
Deprecated:
Use get_val_t instead
◆ get_vals_v()
cs_span_2d< cs_real_t > get_vals_v ( const int  time_id = 0) const
Deprecated:
Use get_val_v instead
◆ has_sub_fields()
CS_F_HOST_DEVICE bool has_sub_fields ( ) const
inline
◆ initialize_sub_fields()
void initialize_sub_fields ( void  )
◆ is_part_of_series()
CS_F_HOST_DEVICE bool is_part_of_series ( ) const
inline
◆ is_series_owner()
CS_F_HOST_DEVICE bool is_series_owner ( ) const
inline
◆ is_sub_field()
CS_F_HOST_DEVICE bool is_sub_field ( ) const
inline
◆ is_sub_field_of()
CS_F_HOST_DEVICE bool is_sub_field_of ( const int  owner_id) const
inline
◆ map_to_ns_data()
void map_to_ns_data ( void  )
◆ map_values()
void map_values ( cs_real_t *  val_new,
cs_real_t *  val_pre_new
[in]val_newpointer to array of values
[in]val_pre_newpointer to array of previous values, or nullptr
◆ ns_view()
cs_span_3d< cs_real_t > ns_view ( const int  time_id = 0) const
cs_span_3d<cs_real_t> view of ns field values.
◆ owner()
CS_F_HOST_DEVICE bool owner ( ) const
inline
◆ series_id()
CS_F_HOST_DEVICE int series_id ( ) const
inline
◆ series_owner()
CS_F_HOST_DEVICE int series_owner ( ) const
inline
◆ series_size()
CS_F_HOST_DEVICE int series_size ( ) const
inline
◆ set_key_double() [1/2]
int set_key_double ( const char *  key,
double  value
[in]keykey string
[in]valuevalue
◆ set_key_double() [2/2]
int set_key_double ( int  key_id,
double  value
[in]key_idkey id
[in]valuevalue
◆ set_key_int() [1/2]
int set_key_int ( const char *  key,
int  value
[in]keykey string
[in]valuevalue
◆ set_key_int() [2/2]
int set_key_int ( int  key_id,
int  value
[in]key_idkey id
[in]valuevalue
◆ set_key_int_bits() [1/2]
int set_key_int_bits ( const char *  key,
int  mask
[in]keykey string
[in]maskmask
◆ set_key_int_bits() [2/2]
int set_key_int_bits ( int  key_id,
int  mask
[in]key_idkey id
[in]maskmask
◆ set_key_str() [1/2]
int set_key_str ( const char *  key,
const char *  str
[in]keykey string
[in]strstring associated with the key
◆ set_key_str() [2/2]
int set_key_str ( int  key_id,
const char *  str
[in]key_idkey id
◆ set_ns_owner()
CS_F_HOST_DEVICE void set_ns_owner ( int  owner_id)
inline
◆ set_ns_parameters()
CS_F_HOST_DEVICE void set_ns_parameters ( const int  series_size,
inline
◆ update_public_pointers()
void update_public_pointers ( void  )
◆ update_size()
void update_size ( const int  time_id = -1)
[in]time_idtime_id to reshape, -1 for all (default)
◆ update_sub_fields_mapping()
void update_sub_fields_mapping ( void  ) const
◆ view()
cs_span_2d< cs_real_t > view ( const int  time_id = 0) const
cs_span_2d<cs_real_t> view of field values
Member Data Documentation
◆ _ns_vals
cs_array_3d<cs_real_t>** _ns_vals
◆ _vals
◆ bc_coeffs
bc_coeffs
Boundary condition coefficients, for variable type fields
◆ dim
dim
Field dimension (usually 1 for scalar, 3 for vector, or 6 for symmetric tensor)
◆ grad
cs_real_t* grad
◆ id
id
Field id (based on order of field declaration, starting at 0)
◆ is_owner
is_owner
Ownership flag for values
◆ location_id
location_id
Id of matching mesh location
◆ n_time_vals
n_time_vals
Number of time values
◆ name
name
Canonical name
◆ ns_idx
int ns_idx
◆ ns_owner
int ns_owner
◆ ns_size
int ns_size
◆ type
type
Field type flag (sum of field mask constants, defining if a field is a variable, a property, ...)
◆ val
val
For each active location, pointer to matching values array
◆ val_pre
val_pre
For each active location, pointer to matching previous values array (only if n_time_vals > 1)
◆ vals
vals
vals[0][:] is a pointer to val vals[1][:] is a pointer to val_pre vals[p][:] is a pointer to p ith previous field values
The documentation for this class was generated from the following files:
