cs_dispatch_context Class Reference
#include <cs_dispatch.h>
+ Inheritance diagram for cs_dispatch_context:
+ Collaboration diagram for cs_dispatch_context:
Additional Inherited Members
- Public Member Functions inherited from cs_combined_context< cs_host_context, cs_void_context >
 cs_combined_context ()=default
 cs_combined_context (Contexts... contexts)
auto parallel_for_i_faces (const M *m, F &&f, Args &&... args)
auto parallel_for_b_faces (const M *m, F &&f, Args &&... args)
auto parallel_for (cs_lnum_t n, F &&f, Args &&... args)
auto parallel_for_reduce_sum (cs_lnum_t n, T &sum, F &&f, Args &&... args)
auto parallel_for_reduce (cs_lnum_t n, T &result, R &reducer, F &&f, Args &&... args)
void wait (void)
 Wait (synchronize) until launched computations have finished. More...
cs_dispatch_sum_type_t get_parallel_for_i_faces_sum_type (const M *m)
 Return sum type to be used with parallel_for_i_faces. More...
cs_dispatch_sum_type_t get_parallel_for_b_faces_sum_type (const M *m)
 Return sum type to be used with parallel_for_b_faces. More...
- Public Member Functions inherited from cs_dispatch_context_mixin< cs_combined_context< Contexts... > >
decltype(auto) parallel_for (cs_lnum_t n, F &&f, Args &&... args)=delete
decltype(auto) parallel_for_i_faces (const M *m, F &&f, Args &&... args)
decltype(auto) parallel_for_b_faces (const M *m, F &&f, Args &&... args)
decltype(auto) parallel_for_reduce_sum (cs_lnum_t n, T &sum, F &&f, Args &&... args)=delete
decltype(auto) parallel_for_reduce (cs_lnum_t n, T &r, R &reducer, F &&f, Args &&... args)=delete
decltype(auto) wait (void)=delete
bool try_get_parallel_for_i_faces_sum_type (const M *m, cs_dispatch_sum_type_t &st)
bool try_get_parallel_for_b_faces_sum_type (const M *m, cs_dispatch_sum_type_t &st)
Default cs_dispatch_context that is a combination of (CPU) and GPU (CUDA) context if available.
The documentation for this class was generated from the following file:
