cs_field_bc_coeffs_t Struct Reference
Field boundary condition descriptor (for variables) More...
#include <cs_field.h>
+ Collaboration diagram for cs_field_bc_coeffs_t:
Public Member Functions
 cs_field_bc_coeffs_t (void)
 cs_field_bc_coeffs_t (int field_dim)
 ~cs_field_bc_coeffs_t ()
cs_span< cs_real_t > get_val_ext () const
 Return a 1D span view of boundary condition external values. More...
cs::mdspan< cs_real_t, 2, cs::layout::left > get_val_ext_2d () const
 Return a 2D span view of boundary condition external values (1st dimension: face id, 2nd dimension: field dimension). More...
cs_span< cs_real_t > get_val_ext_s () const
 Return a 1D span view of boundary condition external scalar values. More...
cs::mdspan< cs_real_t, 2, cs::layout::left > get_val_ext_v () const
 Return a 2D span view of boundary condition external vector values. More...
cs::mdspan< cs_real_t, 2, cs::layout::left > get_val_ext_t () const
 Return a 2D span view of boundary condition external tensor values. More...
cs_span< cs_real_t > get_h_ext () const
 Return a 1D span view of boundary condition external exchange coefficient. More...
cs::mdspan< cs_real_t, 2, cs::layout::left > get_h_ext_2d () const
 Return a 2D span view of boundary condition external exchange coefficient (1st dimension: face id, 2nd dimension: field dimension). More...
cs_span< cs_real_t > get_h_ext_s () const
cs::mdspan< cs_real_t, 2, cs::layout::left > get_h_ext_v () const
 Return a 2D span view of boundary condition vector external exchange coefficients. More...
cs_span< cs_real_t > get_q_ext () const
 Return a 1D span view of boundary condition prescribed flux. More...
cs::mdspan< cs_real_t, 2, cs::layout::left > get_q_ext_2d () const
 Return a 2D span view of boundary condition prescribed flux (1st dimension: face id, 2nd dimension: field dimension). More...
cs_span< cs_real_t > get_q_ext_s () const
cs::mdspan< cs_real_t, 2, cs::layout::left > get_q_ext_v () const
 Return a 2D span view of boundary condition vector prescribed flux. More...
Public Attributes
int * icodcl
cs_real_t * rcodcl1
cs_real_t * rcodcl2
cs_real_t * rcodcl3
cs_real_t * h_int_tot
cs_real_t * h_rad
cs_real_t * flux_rad
cs_real_t * val_f
cs_real_t * val_f_pre
cs_real_t * flux_diff
cs_real_t * a
cs_real_t * b
cs_real_t * af
cs_real_t * bf
cs_real_t * ad
cs_real_t * bd
cs_real_t * ac
cs_real_t * bc
Constructor & Destructor Documentation
◆ cs_field_bc_coeffs_t() [1/2]
cs_field_bc_coeffs_t ( void  )
inline
◆ cs_field_bc_coeffs_t() [2/2]
cs_field_bc_coeffs_t ( int  field_dim)
inline
field_dimAssociated field dimension
◆ ~cs_field_bc_coeffs_t()
~cs_field_bc_coeffs_t ( )
inline
Member Function Documentation
◆ get_h_ext()
cs_span< cs_real_t > get_h_ext ( ) const
◆ get_h_ext_2d()
cs::mdspan< cs_real_t, 2, cs::layout::left > get_h_ext_2d ( ) const
2D span view of field boundary condition prescribed flux
◆ get_h_ext_s()
cs_span< cs_real_t > get_h_ext_s ( ) const
This is the same as cs_field_bc_coeffs_t::get_h_ext, with a more explicit naming scheme which is better aligned with s/v/t (scalar/vector/tensor).
◆ get_h_ext_v()
cs::mdspan< cs_real_t, 2, cs::layout::left > get_h_ext_v ( ) const
2D span view of field boundary condition external exchange coefficients.
◆ get_q_ext()
cs_span< cs_real_t > get_q_ext ( ) const
◆ get_q_ext_2d()
cs::mdspan< cs_real_t, 2, cs::layout::left > get_q_ext_2d ( ) const
◆ get_q_ext_s()
cs_span< cs_real_t > get_q_ext_s ( ) const
This is the same as cs_field_bc_coeffs_t::get_q_ext, with a more explicit naming scheme which is better aligned with s/v/t (scalar/vector/tensor).
◆ get_q_ext_v()
cs::mdspan< cs_real_t, 2, cs::layout::left > get_q_ext_v ( ) const
◆ get_val_ext()
cs_span< cs_real_t > get_val_ext ( ) const
◆ get_val_ext_2d()
cs::mdspan< cs_real_t, 2, cs::layout::left > get_val_ext_2d ( ) const
◆ get_val_ext_s()
cs_span< cs_real_t > get_val_ext_s ( ) const
This is the same as cs_field_bc_coeffs_t::get_val_ext, with a more explicit naming scheme which is better aligned with s/v/t (scalar/vector/tensor).
◆ get_val_ext_t()
cs::mdspan< cs_real_t, 2, cs::layout::left > get_val_ext_t ( ) const
2D span view of field boundary condition external tensor values.
◆ get_val_ext_v()
cs::mdspan< cs_real_t, 2, cs::layout::left > get_val_ext_v ( ) const
2D span view of field boundary condition external vector values.
Member Data Documentation
◆ a
a
Explicit coefficient
◆ ac
ac
Explicit coefficient for convection
◆ ad
ad
Explicit coefficient for divergence
◆ af
af
Explicit coefficient for diffusive flux
◆ b
b
Implicit coefficient
◆ bc
bc
Implicit coefficient for convection
◆ bd
bd
Implicit coefficient for divergence
◆ bf
bf
Implicit coefficient for diffusive flux
◆ flux_diff
cs_real_t* flux_diff
◆ flux_rad
cs_real_t* flux_rad
◆ h_int_tot
cs_real_t* h_int_tot
◆ h_rad
cs_real_t* h_rad
◆ icodcl
icodcl
Low-level BC type code
◆ rcodcl1
rcodcl1
1st part of low-level BC values definition
◆ rcodcl2
rcodcl2
2nd part of low-level BC values definition (a.k.a. hext, exterior exchange coefficient)
◆ rcodcl3
rcodcl3
3rd part of low-level BC values definition
◆ val_f
cs_real_t* val_f
◆ val_f_pre
cs_real_t* val_f_pre
