1#ifndef CS_RAD_TRANSFER_H
2#define CS_RAD_TRANSFER_H
Definition: cs_time_control.h:92
Definition: cs_defs.h:332
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:349
@ CS_BOUNDARY_RAD_WALL_GRAY_1D_T
Definition: cs_rad_transfer.h:81
@ CS_BOUNDARY_RAD_WALL_GRAY_EXTERIOR_T
Definition: cs_rad_transfer.h:85
Definition: cs_rad_transfer.h:78
@ CS_BOUNDARY_RAD_WALL_GRAY_COND_FLUX
Definition: cs_rad_transfer.h:95
@ CS_BOUNDARY_RAD_WALL_REFL_COND_FLUX
Definition: cs_rad_transfer.h:99
@ CS_BOUNDARY_RAD_WALL_REFL_EXTERIOR_T
Definition: cs_rad_transfer.h:91
void cs_rad_transfer_finalize(void)
Finalize radiative transfer module.
Definition: cs_rad_transfer.cpp:300
cs_rad_quadrature_type_t
Definition: cs_rad_transfer.h:58
@ CS_RAD_QUADRATURE_DCT020_2468
Definition: cs_rad_transfer.h:67
@ CS_RAD_QUADRATURE_T4
Definition: cs_rad_transfer.h:64
@ CS_RAD_QUADRATURE_S8
Definition: cs_rad_transfer.h:62
@ CS_RAD_QUADRATURE_LC11
Definition: cs_rad_transfer.h:66
@ CS_RAD_QUADRATURE_S4
Definition: cs_rad_transfer.h:60
@ CS_RAD_QUADRATURE_T2
Definition: cs_rad_transfer.h:63
@ CS_RAD_QUADRATURE_TN
Definition: cs_rad_transfer.h:65
@ CS_RAD_QUADRATURE_S6
Definition: cs_rad_transfer.h:61
@ CS_RAD_ATMO_3D_DIFFUSE_SOLAR
Definition: cs_rad_transfer.h:111
@ CS_RAD_ATMO_3D_DIFFUSE_SOLAR_O3BAND
Definition: cs_rad_transfer.h:112
@ CS_RAD_ATMO_3D_INFRARED
Definition: cs_rad_transfer.h:114
@ CS_RAD_ATMO_3D_NONE
Definition: cs_rad_transfer.h:107
@ CS_RAD_ATMO_3D_DIRECT_SOLAR
Definition: cs_rad_transfer.h:108
@ CS_RAD_ATMO_3D_DIRECT_SOLAR_O3BAND
Definition: cs_rad_transfer.h:109
cs_rad_transfer_params_t * cs_glob_rad_transfer_params
cs_rad_transfer_model_t
Definition: cs_rad_transfer.h:48
@ CS_RAD_TRANSFER_P1
Definition: cs_rad_transfer.h:52
@ CS_RAD_TRANSFER_NONE
Definition: cs_rad_transfer.h:50
@ CS_RAD_TRANSFER_DOM
Definition: cs_rad_transfer.h:51
const char * cs_rad_transfer_quadrature_name[]
bool cs_rad_time_is_active(void)
Is time step for radiative transfer active?
Definition: cs_rad_transfer.cpp:316
const char * cs_rad_transfer_model_name[]
Structure containing the radiation module parameters.
Definition: cs_rad_transfer.h:128
int restart
Definition: cs_rad_transfer.h:158
int imfsck
Definition: cs_rad_transfer.h:143
int atmo_dr_o3_id
Definition: cs_rad_transfer.h:177
int i_quadrature
Definition: cs_rad_transfer.h:153
bool save_radiance_dir
Definition: cs_rad_transfer.h:204
int imrcfsk
Definition: cs_rad_transfer.h:144
int idiver
Definition: cs_rad_transfer.h:146
int ndirs
Definition: cs_rad_transfer.h:155
int iprefl
Definition: cs_rad_transfer.h:163
int nwsgg
Definition: cs_rad_transfer.h:159
int iimpar
Definition: cs_rad_transfer.h:133
int imgrey
Definition: cs_rad_transfer.h:135
int atmo_df_o3_id
Definition: cs_rad_transfer.h:185
cs_real_3_t * vect_s
Definition: cs_rad_transfer.h:156
cs_time_control_t time_control
Definition: cs_rad_transfer.h:212
int ifinfe
Definition: cs_rad_transfer.h:167
int nrphas
Definition: cs_rad_transfer.h:132
cs_real_t * angsol
Definition: cs_rad_transfer.h:157
int ifgrno
Definition: cs_rad_transfer.h:164
int atmo_model
Definition: cs_rad_transfer.h:169
int iwrp1t
Definition: cs_rad_transfer.h:142
double xnp1mx
Definition: cs_rad_transfer.h:145
int verbosity
Definition: cs_rad_transfer.h:134
cs_real_t * wq
Definition: cs_rad_transfer.h:160
int atmo_dr_id
Definition: cs_rad_transfer.h:173
int ifrefl
Definition: cs_rad_transfer.h:165
int itpimp
Definition: cs_rad_transfer.h:161
int ndirec
Definition: cs_rad_transfer.h:154
cs_real_t dispersion_coeff
Definition: cs_rad_transfer.h:194
bool dispersion
Definition: cs_rad_transfer.h:193
int itpt1d
Definition: cs_rad_transfer.h:166
int atmo_df_id
Definition: cs_rad_transfer.h:181
cs_rad_transfer_model_t type
Definition: cs_rad_transfer.h:130
int atmo_ir_id
Definition: cs_rad_transfer.h:189
int imoadf
Definition: cs_rad_transfer.h:138
int ipgrno
Definition: cs_rad_transfer.h:162
