cs_equation_param_t Struct Reference
Set of parameters to handle an unsteady convection-diffusion-reaction equation with term sources. More...
#include <cs_equation_param.h>
+ Collaboration diagram for cs_equation_param_t:
Public Attributes
bool time_control_owner
cs_time_control_t * time_control
General settings
char *restrict name
cs_equation_type_t type
int dim
int verbosity
cs_flag_t flag
cs_flag_t post_flag
cs_param_space_scheme_t space_scheme
cs_param_dof_reduction_t dof_reduction
int space_poly_degree
Legacy Settings
int iconv
int istat
int idircl
int ndircl
int idiff
int idifft
int idften
int iswdyn
int ischcv
int ibdtso
int isstpc
int nswrgr
int nswrsm
int imvisf
int imrgra
int imligr
int d_imligr
int ircflu
int iwgrec
int icoupl
double theta
double blencv
double blend_st
double epsilo
double epsrsm
double epsrgr
double climgr
double d_climgr
double rc_clip_factor
double b_rc_clip_factor
double relaxv
int d_gradient_r
int b_rc_gradient
int b_diff_flux_rc
int diffusion_limiter_id
int convection_limiter_id
cs_runge_kutta_def_t rk_def
Settings for the boundary conditions
cs_param_bc_type_t default_bc
int n_bc_defs
cs_xdef_t ** bc_defs
cs_param_bc_enforce_t default_enforcement
cs_real_t strong_pena_bc_coeff
cs_real_t weak_pena_bc_coeff
Numerical settings for the time-dependent parameters
int n_ic_defs
cs_xdef_t ** ic_defs
bool do_lumping
cs_hodge_param_t time_hodgep
cs_property_t * time_property
cs_param_time_scheme_t time_scheme
Numerical settings for the diffusion (Laplacian div-grad) term
cs_hodge_param_t diffusion_hodgep
cs_property_t * diffusion_property
Numerical settings for the curl-curl term
cs_hodge_param_t curlcurl_hodgep
cs_property_t * curlcurl_property
Numerical settings for the grad-div term
cs_hodge_param_t graddiv_hodgep
cs_property_t * graddiv_property
Numerical settings for the advection term
cs_param_advection_form_t adv_formulation
cs_param_advection_scheme_t adv_scheme
cs_param_advection_strategy_t adv_strategy
cs_param_advection_extrapol_t adv_extrapol
cs_real_t upwind_portion
double stab_scaling_coef
cs_adv_field_t * adv_field
cs_property_t * adv_scaling_property
Numerical settings for the reaction term
The contribution of a reaction term to the algebraic system is either at the left-hand and/or right-hand side according to the choice of time scheme
cs_hodge_param_t reaction_hodgep
int n_reaction_terms
cs_property_t ** reaction_properties
Definition of the related source terms
The contribution of a source term to the algebraic system is always at right-hand side whatever is the choice of time scheme
int n_source_terms
cs_xdef_t ** source_terms
Definition of the related volume mass injection
The contribution of a volume mass injection to the algebraic system is always at right-hand side whatever is the choice of time scheme, and is defined in a manner similar to boundary conditions. For variables whose injection value matches the "ambient" value, no term needs to be added.
int n_volume_mass_injections
cs_xdef_t ** volume_mass_injections
Enforcement of values inside the computational domain
This is different from the enforcement of boundary conditions but rely on the same algebraic manipulation. Only an algebraic manipulation is used to enforce interior/border DoFs.
int n_enforcements
cs_enforcement_param_t ** enforcement_params
Settings related to the resolution of the algebraic system
cs_param_sles_t * sles_param
cs_param_saddle_t * saddle_param
cs_param_nl_algo_t incremental_algo_type
cs_param_convergence_t incremental_algo_cvg
cs_real_t incremental_relax_factor
cs_iter_algo_param_aac_t incremental_anderson_param
Member Data Documentation
◆ adv_extrapol
adv_extrapol
Extrapolation used to estimate the advection field (please refer to cs_param_advection_extrapol_t)
◆ adv_field
adv_field
Pointer to the cs_adv_field_t structure associated to the advection term
◆ adv_formulation
adv_formulation
Type of formulation (conservative, non-conservative...) for the advective term
◆ adv_scaling_property
May be set to NULL even if the advection term is activated. The value of this property in each cell is a multiplicative coefficient in front of the advection term (boundary terms are also considered) This is useful to treat the thermal module using the variable temperature instead of the enthalpy for instance or in the solidification module.
◆ adv_scheme
adv_scheme
Numerical scheme used for the discretization of the advection term
◆ adv_strategy
adv_strategy
Strategy used to handle the advection term (please refer to cs_param_advection_strategy_t)
◆ b_diff_flux_rc
b_diff_flux_rc
Indicate whether the fluxes (convective and diffusive) and boundary conditions at the faces should be reconstructed:
  • 0: no reconstruction
  • 1: reconstruction
  • Finer-grained limiters may be added in the future. Deactivating the reconstruction of the fluxes can have a stabilizing effect on the calculation, and help follow the maximum principal, with less degradation of the global precision than deactivating the reconstruction on the volume mesh.
◆ b_rc_clip_factor
b_rc_clip_factor
For least-squares gradient-based boundary reconstruction, factor of gradient limitation (high value means little limitation, no limitation if negative). A (default) value of 1 ensures the reconstructed value is within bounds of adjacent cell values.
◆ b_rc_gradient
b_rc_gradient
Type of boundary gradient reconstruction Same codes as for imrgra (default is 2: least-squares, using extended neighborhood if available)
◆ bc_defs
bc_defs
Pointers to the definitions of the boundary conditions
◆ blencv
blencv
Proportion of second-order convective scheme (0 corresponds to an upwind first-order scheme); in case of LES calculation, a second-order scheme is recommended and activated by default (blencv = 1).
Relevant when iconv = 1.
◆ blend_st
blend_st
Proportion of second-order convective scheme (0 corresponds to an upwind first-order scheme) after the slope test is activated; in case of LES calculation, a second-order scheme is recommended and activated by default (blend_st = 1).
Relevant wheniconv = 1.
◆ climgr
climgr
Volume gradient limitation factor (high value means little limitation, negative value means no limitation).
Relevant when imligr > CS_GRADIENT_LIMIT_NONE. Recommended only for least-squares gradients, as applying a limitation factor breaks the locally conservative property of Gauss gradients.
◆ convection_limiter_id
Convection limiter field id (-1 if not used)
◆ curlcurl_hodgep
curlcurl_hodgep
Set of parameters for the discrete Hodge operator related to the curl-curl operator
◆ curlcurl_property
curlcurl_property
Pointer to the property related to the curl-curl term
◆ d_climgr
d_climgr
Diffusion reconstruction gradient limitation factor (high value means little limitation, negative value means no limitation).
◆ d_gradient_r
d_gradient_r
Type of gradient for diffusion reconstruction Same codes as for imrgra (default is 2: least-squares, using extended neighborhood if available)
◆ d_imligr
d_imligr
Type of diffusion reconstruction gradient limiter
◆ default_bc
default_bc
Default boundary condition related to this equation. Valid choices:
◆ default_enforcement
default_enforcement
Type of strategy to enforce an essential boundary condition (Dirichlet for instance) when no predefined strategy is prescribed. See cs_param_bc_enforce_t for more details.
◆ diffusion_hodgep
diffusion_hodgep
Set of parameters for the discrete Hodge operator related to the diffusion
◆ diffusion_limiter_id
Diffusion limiter field id (-1 if not used)
◆ diffusion_property
diffusion_property
Pointer to the property related to the diffusion term
◆ dim
int dim
Dimension of the unknown
◆ do_lumping
do_lumping
Set to true or false. Activate several actions: Perform a mass lumping of the matrices related to the time and reaction discretization. All source terms are evaluated using a barycentric quadrature.
◆ dof_reduction
How is defined DoF
◆ enforcement_params
enforcement_params
Array of cs_enforcement_param_t structures storing the settings of each enforcement
◆ epsilo
epsilo
Relative precision for the solution of the linear system. The default is epsilo = $ 10^-8 $. When there are enough iterations on the reconstruction of the right-hand side of the equation, the value may be increased (by default, in case of second-order in time, with nswrsm = 5 or 10, epsilo is increased to $ 10^-5 $.
◆ epsrgr
epsrgr
Relative precision for the iterative gradient reconstruction. (when imrgra = 0).
◆ epsrsm
epsrsm
Relative precision on the reconstruction of the right hand-side. The default is epsrsm = $ 10^-8 $. When there are not enough iterations on the reconstruction of the right-hand side of the equation, the value may be increased (by default, in case of second-order in time, with nswrsm = 5 or 10, epsrsm is increased to $ 10^-5 $ ).
◆ flag
flag
Flag to know if unsteady or diffusion or convection or reaction or source terms are activated or not
◆ graddiv_hodgep
graddiv_hodgep
Set of parameters for the discrete Hodge operator related to the grad-div operator
◆ graddiv_property
graddiv_property
Pointer to the property related to the grad-div term
◆ ibdtso
ibdtso
Backward differential scheme in time order.
◆ ic_defs
ic_defs
List of pointers to the definition of the inititial condition
◆ iconv
iconv
Indicate if the convection is taken into account (1) or not (0). By default, 0 for the pressure or f in v2f model, 1 for the other unknowns.
◆ icoupl
icoupl
Internal coupling indicator
  • -1: not coupled (default)
  • 1: coupled
◆ idften
idften
Type of diffusivity flag (sum of mask constants defining if diffusivity is isotropic, anisotropic, ... Masks are defined in Scalar_params).
◆ idiff
idiff
Indifcate if diffusion is taken into account (1) or not (0).
◆ idifft
idifft
When diffusion is taken into account (idiff = 1), indicate if the turbulent diffusion is taken into account (idifft = 1) or not (0).
◆ idircl
idircl
Indicate whether the diagonal of the matrix should be slightly shifted if there is no Dirichlet boundary condition and if istat = 0 (0: false / 1: true). Indeed, in such a case, the matrix for the general advection/diffusion equation is singular. A slight shift in the diagonal will make it invertible again. By default, idircl is set to 1 for all the unknowns, except $\overline{f}$ in the v2f model (whose equation already contain another diagonal term).
Remarks
this code is defined automatically based on the presence of Dirichlet BCs.
◆ imligr
imligr
Type of gradient limiter
◆ imrgra
imrgra
Type of gradient reconstruction
  • 0: iterative reconstruction of the non-orthogonalities
  • 1: least squares method based on the first neighbor cells (those which share a face with the treated cell)
  • 2, 3: least squares method using the extended neighborhood
  • 4: Green-Gauss based using the least squares method (first neighbors) to compute face values
  • 5, 6: Green-Gauss based using the least squares method with an extended neighborhood to compute face values
    If the computation fails due to mesh quality aspects, it is usually effective to use imrgra = 3, 5, or 6.
◆ imvisf
imvisf
Face viscosity field interpolation
  • 0: aritmetic (default)
  • 1: harmonic
◆ incremental_algo_cvg
Set of parameters to drive the convergence of the incremental algorithm
◆ incremental_algo_type
Type of algorithm used to handle a (non-linear) incremental resolution
◆ incremental_anderson_param
Set of parameters dedicated to the driving of the Anderson acceleration. This is only useful if the incremental_algo_type is set to the Anderson acceleration.
◆ incremental_relax_factor
strictly positive value for the relaxation of the incremental algorithm A recommanded range is between 0.5 and 0.9
◆ ircflu
ircflu
Indicate whether the convective and diffusive fluxes at the faces should be reconstructed:
  • 1: reconstruction Deactivating the reconstruction of the fluxes can have a stabilizing effect on the calculation. It is sometimes useful with the $ k-\epsilon
$ model, if the mesh is strongly non-orthogonal in the near-wall region, where the gradients of k and $ \epsilon $ are strong. In such a case, setting ircflu = 0 will probably help (switching to a first order convective scheme, blencv = 0, for k and $ \epsilon $ might also help in that case).
◆ ischcv
ischcv
Indicate the type of second-order convective scheme
  • 0: Second Order Linear Upwind
  • 1: Centered
  • 2: Second Order with upwind-gradient reconstruction (SOLU)
  • 3: Blending between SOLU and Centered scheme based on "hybrid_blend" field
  • 4: NVD/TVD Scheme Then "limiter_choice" keyword must be set:
  • 0: Gamma
  • 1: SMART
  • 2: CUBISTA
  • 3: SUPERBEE
  • 4: MUSCL
  • 5: MINMOD
  • 6: CLAM
  • 7: STOIC
  • 8: OSHER
  • 9: WASEB — VOF scheme —
  • 10: M-HRIC
  • 11: M-CICSAM
  • 12: M-STACS
◆ isstpc
isstpc
Indicate whether a slope test should be used to switch from a second-order to an upwind convective scheme under certain conditions, to ensure stability.
  • 0: slope test activated
  • 1: slope test deactivated
  • 2: continuous limiter ensuring boundedness (beta limiter) The use of the slope test stabilises the calculation but may reduce the spatial convergence order.
◆ istat
istat
Indicate whether unsteady terms are present (1) or not (0) in the matrices. By default, 0 for the pressure or f in v2f model, 1 for the other unknowns.
◆ iswdyn
iswdyn
Dynamic relaxation type:
  • 0 no dynamic relaxation
  • 1 dynamic relaxation depending on $ \delta \varia^k $
  • 2 dynamic relaxation depending on $ \delta \varia^k $ and $ \delta \varia^{k-1} $.
◆ iwgrec
iwgrec
Gradient calculation weighting
  • 0: standard
  • 1: weighted
◆ n_bc_defs
n_bc_defs
Number of boundary conditions which are defined for this equation
◆ n_enforcements
n_enforcements
Number of enforcements which have been specified
◆ n_ic_defs
n_ic_defs
Number of definitions for setting the intial condition
◆ n_reaction_terms
n_reaction_terms
Number of reaction terms to consider.
◆ n_source_terms
n_source_terms
Number of source terms to consider.
◆ n_volume_mass_injections
Number of volume injections to consider.
◆ name
char* restrict name
name of the equation
◆ ndircl
ndircl
Number of Dirichlet BCs
◆ nswrgr
nswrgr
Iteration limit for the iterative gradient reconstruction (imrgra = 0). If imrgra = 0 and nswrgr <= 1, gradients are not reconstructed.
◆ nswrsm
nswrsm
Iteration limit for the reconstruction of the right-hand sides of the equations with a first-order scheme in time (standard case), the default values are 2 for pressure and 1 for the other variables. With a second-order scheme in time (ischtp = 2) or LES, the default values are 5 for pressure and 10 for the other variables.
◆ post_flag
post_flag
Flag to determine if predefined post-treatments such as Peclet, are requested
◆ rc_clip_factor
rc_clip_factor
If >= 0, clipping factor for reconstructed values (in flux computation). If active (>= 0), scalar minima and maxima may be exceeded only by a factor s = (rc_clip_factor - 1), so with a value of 1, clipping is done exactly at the minima and maxima. For vectors and tensors, the distance to neighbors an vector norm are used as bounds, as minima and maxima are not defined.
◆ reaction_hodgep
reaction_hodgep
Set of parameters for the discrete Hodge operator related to the reaction terms
◆ reaction_properties
reaction_properties
List of properties associated to each reaction term
◆ relaxv
relaxv
Relaxation coefficient for the associated variable. This relaxation parameter is only useful for the pressure with the unsteady algorithm (so as to improve the convergence in case of meshes of insufficient quality or of some turbulent models (k-epsilon, v2f, k-omega) and ikecou = 0; if ikecou = 1, relaxv is ignored.
Default values are 0.7 for turbulent variables and 1. for pressure. relaxv also stores the value of the relaxation coefficient when using the steady algorithm, deduced from the value of relxst (defaulting to relaxv = 1. - relxst).
Used only for the pressure and for turbulent variables ( $ k-\epsilon $, v2f or $ k-\omega $ models without coupling) with the unsteady algorithm. Always used with the steady algorithm.
◆ rk_def
rk_def
Containing info of RK integrator id in the global Runge-Kutta structure list, and RK scheme.
◆ saddle_param
saddle_param
Set of parameters to specify how to solve a saddle-point system. Up to now, only CDO cell-based schemes yield this type of problem. Other saddle-point problems arise when dealing with Stokes or Navier-Stokes equations with a monolithic velocity/pressure coupling. In the latter case, this is directly handled by the structures dedicated to the Navier-Stokes solver.
◆ sles_param
sles_param
Set of parameters to specify how to to solve the algebraic system
  • iterative solver
  • preconditioner
  • tolerance...
◆ source_terms
source_terms
List of definition of each source term
◆ space_poly_degree
space_poly_degree
Maximum degree of the polynomial basis
◆ space_scheme
Space discretization scheme
◆ stab_scaling_coef
stab_scaling_coef
Value of the scaling coefficient in front of the stabilization term when a SOLU or CIP scheme is used (cf. CS_PARAM_ADVECTION_SCHEME_SOLU, CS_PARAM_ADVECTION_SCHEME_SOLU_SYM, CS_PARAM_ADVECTION_SCHEME_CIP or CS_PARAM_ADVECTION_SCHEME_CIP_CW). By default, this is set to -1.0 and later modified automatically to 1.0 if not modified by a user. Should be > 0.
◆ strong_pena_bc_coeff
Value of the penalization coefficient used to enforce the Dirichlet boundary conditions when CS_PARAM_BC_ENFORCE_PENALIZED is set. This value should be sufficiently large in order to neglect off-diagonal terms.
◆ theta
theta
Value of $ \theta $ used to express at the second order the terms of convection, diffusion and the source terms which are linear functions of the solved variable, according to the formula $ \phi^{n+\theta} = (1-\theta) \phi^n + \theta \phi^{n+1} $. Generally, only the values 1 and 0.5 are used. The user is not allowed to modify this variable.
  • 1: first-order
  • 0.5: second-order
    For the pressure, theta is always 1. For the other variables, theta = 0.5 is used when the second-order time scheme is activated (ischtp = 2, standard for LES calculations), otherwise theta = 1.
◆ time_control
cs_time_control_t* time_control
◆ time_control_owner
◆ time_hodgep
time_hodgep
Set of parameters for the discrete Hodge operator related to the unsteady term
◆ time_property
time_property
Pointer to the cs_property_t structure related to the unsteady term
◆ time_scheme
time_scheme
Type of numerical scheme used for the time discretization
NB: theta is share with the legacy scheme
◆ type
type of equation: predefined...
◆ upwind_portion
upwind_portion
Value between 0. and 1. (0: centered scheme, 1: pure upwind scheme) Introduce a constant portion of upwinding in a centered scheme Only useful if the advection scheme is set to CS_PARAM_ADVECTION_SCHEME_HYBRID_CENTERED_UPWIND
◆ verbosity
verbosity
Verbosity for the resolution (0 or 1 for a reasonable log size, 2 or more for troubleshooting).
◆ volume_mass_injections
List of definitions of injection values
◆ weak_pena_bc_coeff
weak_pena_bc_coeff
Value of the penalization coefficient used to enforce the Dirichlet boundary condition when CS_PARAM_BC_ENFORCE_WEAK_NITSCHE or CS_PARAM_BC_ENFORCE_WEAK_SYM is set. This two latter strategies have a lesser influence on the conditioning number of the linear system than the choice CS_PARAM_BC_ENFORCE_PENALIZED
