How to set linear solvers with CDO/HHO schemes
Introduction
In code_saturne, a SLES means a S parse L inear E quation S olver. When using CDO/HHO schemes, the settings related to a SLES is stored in the structure cs_param_sles_t
To access more advanced settings, it is possible to retrieve this structure when one has a pointer to a cs_equation_param_t Simply write:
cs_equation_param_t * cs_equation_param_by_name(const char *eqname)
Return the cs_equation_param_t structure associated to a cs_equation_t structure based on the equatio...
Definition: cs_equation.cpp:592
cs_param_sles_t * cs_equation_param_get_sles_param(cs_equation_param_t *eqp)
Get the pointer to the set of parameters to handle the SLES solver associated to this set of equation...
Definition: cs_equation_param.cpp:1527
Definition: cs_param_sles.h:63
To get a full access to the low-level structures handling the linear algebra in code_saturne, please consider to edit the function cs_user_linear_solvers For a Finite Volume scheme, this is the main way to proceed.
Solve a linear system
Several examples are detailed hereafter to modify the default settings related to a linear solver.
A first example
Example: Use a BiCGstab iterative solver with a 1st order Neumann
polynomial preconditioner is used to solve a user-defined
equation
void cs_equation_param_set(cs_equation_param_t *eqp, cs_equation_key_t key, const char *keyval)
Set a parameter attached to a keyname in a cs_equation_param_t structure.
Definition: cs_equation_param.cpp:1489
@ CS_EQKEY_SOLVER
Definition: cs_equation_param.h:1261
@ CS_EQKEY_PRECOND
Definition: cs_equation_param.h:1270
A second example
For a symmetric positive definite (SPD) system, the solver of choice is the conjugate gradient (CS_PARAM_SOLVER_CG) or its flexible variant (CS_PARAM_SOLVER_FCG). In this case, a good preconditioner is a multilevel algorithm such as an algebraic multigrid (AMG). Different multigrid techniques are available when using code_saturne depending on the installation configuration (in-house implementations or algorithms available from PETSc and/or HYPRE libraries). Please refer to this section, for more details about AMG techniques.
Here is a second example:
/* Linear algebra settings */
#if defined(HAVE_PETSC)
#else
#endif
/* Manage the stopping criteria */
@ CS_EQKEY_SOLVER_RTOL
Definition: cs_equation_param.h:1268
@ CS_EQKEY_SOLVER_FAMILY
Definition: cs_equation_param.h:1284
@ CS_EQKEY_SOLVER_MAX_ITER
Definition: cs_equation_param.h:1264
@ CS_EQKEY_SOLVER_ATOL
Definition: cs_equation_param.h:1262
@ CS_EQKEY_SOLVER_DTOL
Definition: cs_equation_param.h:1263
If the external library PETSc is available, one uses its algebraic multigrid, otherwise one uses the in-house solver. Here a flexible conjugate gradient (fcg) with a diagonal preconditionning (jacobi).
Set the family of linear solvers
By default, in-house solvers are considered. With some choices of solver or preconditioner, one has to use an external library. The external libraries which can be linked to code_saturne are:
CS_EQKEY_SOLVER_FAMILY allows one to specify the family of linear solvers to consider. This can be useful if an automatic switch is not done or when there are several possibilities. For instance,
  • using HYPRE solver either directly from the HYPRE library or through the PETSc library;
  • using the MUMPS solver either directly from the MUMPS library or through the PETSc library.
/* Specify that this is an in-house solvers (default choice) */
/* Use solver/preconditioner available in the MUMPS library */
#if defined(HAVE_MUMPS)
#else
bft_error(__FILE__, __LINE__, 0, "%s: MUMPS is not available\n", __func__);
#endif
/* Use solver/preconditioner available in the PETSc library */
#else
bft_error(__FILE__, __LINE__, 0, "%s: PETSc is not available\n", __func__);
#endif
/* Use solver/preconditioner available in the HYPRE library */
#if defined(HAVE_HYPRE)
#else
bft_error(__FILE__, __LINE__, 0, "%s: HYPRE is not available\n", __func__);
#endif
Definition: bft_error.cpp:187
Set the linear solver
Available linear solvers are listed in cs_param_solver_type_t and can be set using the key CS_EQKEY_SOLVER and the key values gathered in the following table:
key value description associated type available family
"amg" Algebraic MultiGrid (AMG) iterative solver. This is a good choice to achieve a scalable solver related to symmetric positive definite system when used with the default settings. Usually, a better choice is to use it as a preconditioner of a Krylov solver (for instance a conjugate gradient). For convection-dominated systems, one needs to adapt the smoothers, the coarsening algorithm or the coarse solver. CS_PARAM_SOLVER_AMG saturne, PETSc, HYPRE
"bicgs", "bicgstab" stabilized BiCG algorithm (for non-symmetric linear systems). It may lead to breakdown. CS_PARAM_SOLVER_BICGS saturne, PETSc
"bicgstab2" variant of the stabilized BiCG algorithm (for non-symmetric linear systems). It may lead to breakdown. It should be more robust than the BiCGstab algorithm CS_PARAM_SOLVER_BICGS2 saturne, PETSc
"cg" Conjuguate gradient algorithm for symmetric positive definite (SPD) linear systems CS_PARAM_SOLVER_CG saturne, PETSc, HYPRE
"cr3" 3-layer conjuguate residual algorithm for non-symmetric linear systems CS_PARAM_SOLVER_CR3 saturne
"fcg" Flexible version of the conjuguate gradient algorithm. This is useful when the preconditioner changes between two successive iterations CS_PARAM_SOLVER_FCG saturne, PETSc
"fgmres" Flexible Generalized Minimal Residual: robust and flexible iterative solver. More efficient solver can be found on easy-to-solve systems. Additional settings related to the number of directions stored before restarting the algorithm (cf. the key CS_EQKEY_SOLVER_RESTART) CS_PARAM_SOLVER_FGMRES PETSc
"gauss_seidel", "gs" Gauss-Seidel algorithm (Jacobi on interfaces between MPI ranks in case of parallel computing). No preconditioner. CS_PARAM_SOLVER_GAUSS_SEIDEL saturne, PETSc, HYPRE
"gcr" Generalized Conjugate Residual: robust and flexible iterative solver. More efficient solver can be found on easy-to-solve systems. This is close to a FGMRES algorithm. Additional settings related to the number of directions stored before restarting the algorithm (cf. the key CS_EQKEY_SOLVER_RESTART). This is the default solver for a user-defined equation. CS_PARAM_SOLVER_GCR saturne, PETSc
"gmres" Generalized Conjugate Residual: robust iterative solver. More efficient solver can be found on easy-to-solve systems. Additional settings related to the number of directions stored before restarting the algorithm (cf. the key CS_EQKEY_SOLVER_RESTART) CS_PARAM_SOLVER_GMRES saturne, PETSc, HYPRE
"jacobi", "diag", "diagonal" Jacobi algorithm = reciprocal of the diagonal values (simplest iterative solver). This is an efficient solver if the linear system is dominated by the diagonal. No preconditioner. CS_PARAM_SOLVER_JACOBI saturne, PETSc, HYPRE
"mumps" sparse direct solver from the MUMPS library (cf. [1]). This is the most robust solver but it may require a huge memory (especially for 3D problems). By default, it performs a LU factorization on general matrices using double precision. More options are available using the function cs_param_sles_mumps and the function cs_param_sles_mumps_advanced. More options are available through the user-defined function cs_user_sles_mumps_hook CS_PARAM_SOLVER_MUMPS mumps, PETSc (according to the configuration)
"sym_gauss_seidel", "sgs" Symmetric Gauss-Seidel algorithm. Jacobi on interfaces between MPI ranks in case of parallel computing). No preconditioner. CS_PARAM_SOLVER_SYM_GAUSS_SEIDEL saturne, PETSc
"user" User-defined iterative solver (rely on the function cs_user_sles_it_solver) CS_PARAM_SOLVER_USER_DEFINED saturne
Set the preconditioner
Available preconditioners are listed in cs_param_precond_type_t and can be set using the key CS_EQKEY_PRECOND and the key values gathered in the following table:
key value description type family
"amg" Algebraic MultiGrid (AMG) iterative solver. See this section for more details. CS_PARAM_PRECOND_AMG saturne, PETSc, HYPRE
"block_jacobi", "bjacobi" Block Jacobi with an ILU(0) factorization in each block. By default, there is one block per MPI rank. CS_PARAM_PRECOND_BJACOB_ILU0 PETSc
"bjacobi_sgs", "bjacobi_ssor" Block Jacobi with a SSOR algorithm in each block. By default, there is one block per MPI rank. For a sequential run, this is the SSOr algorithm. CS_PARAM_PRECOND_BJACOB_SGS PETSc
"diag", "jacobi" Diagonal preconditioning CS_PARAM_PRECOND_DIAG saturne, PETSc, HYPRE
"ilu0" Incomplete LU factorization (zero fill-in meaning that the same sparsity level is used). CS_PARAM_PRECOND_ILU0 PETSc, HYPRE
"icc0" Incomplete Choleski factorization (zero fill-in meaning that the same sparsity level is used). For SPD matrices. CS_PARAM_PRECOND_ICC0 PETSc, HYPRE
"mumps" the sparse direct solver MUMPS used as preconditioner. Please refer to the MUMPS section for more details. CS_PARAM_PRECOND_MUMPS mumps
"none" No preconditioner. CS_PARAM_PRECOND_NONE saturne, PETSc, HYPRE
"poly1", "poly_1" 1st order Neumann polynomial preconditioning CS_PARAM_PRECOND_POLY1 saturne
"poly2", "poly_2" 2nd order Neumann polynomial preconditioning CS_PARAM_PRECOND_POLY2 saturne
"ssor" Symmetric Successive OverRelaxation (SSOR) algorithm. In case of parallel computations, each MPI rank performs a SSOR on the local matrix. CS_PARAM_PRECOND_SSOR PETSc
Algebraic multigrids
Algebraic multigrids (AMG) can be used either as a solver or as a preconditioner. According to this choice, the settings of the main components should be different. The main options related to an AMG algorithm are:
  • The choice of the cycle (V, W, K for instance)
  • The choice of the down and/or up smoothers (type and number of sweeps)
  • The choice of the coarse solver
  • The choice of the coarsening algorithm
AMG algorithm is a good choice to achieve a scalable solver. The default settings are related to a symmetric positive definite (SPD) system. Usually, a better efficiency is reached when the AMG is used as a preconditioner of a Krylov solver rather than as a solver. For convection-dominated systems, one needs to adapt the main ingredients.
Several multigrid algorithms are available in code_saturne. The default one is the in-house V-cycle. Use the key CS_EQKEY_AMG_TYPE to change the type of multigrid. Possible values for this key are gathered in the next table.
"v_cycle" This is the default choice. This corresponds to an in-house V-cycle detailed in [13] The main ingredients can set using the functions cs_param_sles_amg_inhouse and cs_param_sles_amg_inhouse_advanced Please refer to this section for more details.
"k_cycle" or "kamg" Switch to a K-cycle strategy. This type of cycle has been detailed in [17] Be aware that a lot of work can be done in the coarsest levels yielding more communications between MPI ranks during a parallel computation. The main ingredients can set using the functions cs_param_sles_amg_inhouse and cs_param_sles_amg_inhouse_advanced Please refer to this section for more details.
"boomer", "bamg" or "boomer_v" Switch to use the V-cycle of the BoomerAMG algorithm from the HYPRE library Please refer to this section for more details on the way to set the main ingredients.
"boomer_w" or "bamg_w" Switch to a W-cycle and the BoomerAMG algorithm from the HYPRE library. Please refer to this section for more details on the way to set the main ingredients.
"gamg" or "gamg_v" Switch to a V-cycle and the GAMG algorithm from the PETSc library. GAMG means "Geometric Algebraic multigrid. Please refer to [this section](GAMG) for more details on the way to set the main ingredients.
`"gamg_w"` Switch to a W-cycle and the GAMG algorithm from the [PETSc](https://petsc.org) library. GAMG means "Geometric Algebraic multigrid. Please refer to @ref cs_ug_cdo_sles_amg_gamg "this section" for more details on the way to set the main ingredients.
In-house multigrids
The in-house multigrid algorithms can be easily tuned thanks to the function cs_param_sles_amg_inhouse More advanced settings can also be added using the function cs_param_sles_amg_inhouse_advanced
cs_param_sles_t *slesp = eqp->sles_param;
assert(slesp->field_id > -1);
/* In case of an in-house K-cylcle multigrid as a preconditioner of a
linear iterative solver */
if ((slesp->precond == CS_PARAM_PRECOND_AMG) &&
/* Down: n_iter, smoother, poly. deg. */
/* Up: n_iter, smoother, poly. deg. */
/* Coarse: solver, poly. deg. */
/* coarsen algo, aggregation limit */
(slesp,
CS_CDO_KEEP_DEFAULT, /* max_levels */
500, /* coarse min_n_g_rows */
CS_CDO_KEEP_DEFAULT, /* p0p1_relax */
CS_CDO_KEEP_DEFAULT, /* coarse_max_iter */
CS_CDO_KEEP_DEFAULT); /* coarse_rtol_mult */
} /* K-cycle multigrid as preconditioner */
@ CS_PARAM_AMG_INHOUSE_FORWARD_GS
Definition: cs_param_amg.h:276
@ CS_PARAM_AMG_INHOUSE_BACKWARD_GS
Definition: cs_param_amg.h:277
@ CS_PARAM_AMG_INHOUSE_CG
Definition: cs_param_amg.h:287
@ CS_PARAM_AMG_INHOUSE_K
Definition: cs_param_amg.h:70
@ CS_PARAM_AMG_INHOUSE_COARSEN_SPD_PW
Definition: cs_param_amg.h:310
#define CS_CDO_KEEP_DEFAULT
Definition: cs_param_cdo.h:42
void cs_param_sles_amg_inhouse(cs_param_sles_t *slesp, int n_down_iter, cs_param_amg_inhouse_solver_t down_smoother, int down_poly_deg, int n_up_iter, cs_param_amg_inhouse_solver_t up_smoother, int up_poly_deg, cs_param_amg_inhouse_solver_t coarse_solver, int coarse_poly_deg, cs_param_amg_inhouse_coarsen_t coarsen_algo, int aggreg_limit)
Set the main members of a cs_param_amg_inhouse_t structure. This structure is not reset before applyi...
Definition: cs_param_sles.cpp:1514
void cs_param_sles_amg_inhouse_advanced(cs_param_sles_t *slesp, int max_levels, cs_gnum_t min_n_g_rows, double p0p1_relax, int coarse_max_iter, double coarse_rtol_mult)
Set the members of a cs_param_amg_inhouse_t structure used in advanced settings. CS_CDO_KEEP_DEFAULT ...
Definition: cs_param_sles.cpp:1574
@ CS_PARAM_PRECOND_AMG
Definition: cs_param_types.h:868
cs_param_sles_t * sles_param
Definition: cs_equation_param.h:843
int field_id
Definition: cs_param_sles.h:66
cs_param_precond_type_t precond
Definition: cs_param_sles.h:71
cs_param_amg_type_t amg_type
Definition: cs_param_sles.h:75
In the case of an advanced settings, it is possible to keep the default settings associated to a parameter using the value CS_CDO_KEEP_DEFAULT
It is also possible to access directly the structures and set the parameters in the function cs_user_linear_solvers . Here is an example of a such usage:
nullptr,
(mg,
3, /* aggregation_limit (default 3) */
CS_GRID_COARSENING_DEFAULT, /* coarsening_type (default 0) */
10, /* n_max_levels (default 25) */
30, /* min_g_cells (default 30) */
0.95, /* P0P1 relaxation (default 0.95) */
20); /* postprocessing (default 0) */
(mg,
CS_SLES_JACOBI, /* descent smoother type (default: CS_SLES_PCG) */
CS_SLES_JACOBI, /* ascent smoother type (default: CS_SLES_PCG) */
CS_SLES_PCG, /* coarse solver type (default: CS_SLES_PCG) */
50, /* n max cycles (default 100) */
5, /* n max iter for descent (default 2) */
5, /* n max iter for asscent (default 10) */
1000, /* n max iter coarse solver (default 10000) */
0, /* polynomial precond. degree descent (default 0) */
0, /* polynomial precond. degree ascent (default 0) */
1, /* polynomial precond. degree coarse (default 0) */
-1.0, /* precision multiplier descent (< 0 forces max iters) */
-1.0, /* precision multiplier ascent (< 0 forces max iters) */
0.1); /* requested precision multiplier coarse (default 1) */
@ p
Definition: cs_field_pointer.h:63
#define CS_F_(e)
Definition: cs_field_pointer.h:47
@ CS_GRID_COARSENING_DEFAULT
Definition: cs_grid.h:50
cs_multigrid_t * cs_multigrid_define(int f_id, const char *name, cs_multigrid_type_t mg_type)
Define and associate a multigrid sparse linear system solver for a given field or equation name.
Definition: cs_multigrid.cpp:4607
void cs_multigrid_set_coarsening_options(cs_multigrid_t *mg, int aggregation_limit, cs_grid_coarsening_t coarsening_type, int n_max_levels, cs_gnum_t min_g_rows, double p0p1_relax, int postprocess_block_size)
Set multigrid coarsening parameters.
Definition: cs_multigrid.cpp:4946
void cs_multigrid_set_solver_options(cs_multigrid_t *mg, cs_sles_it_type_t descent_smoother_type, cs_sles_it_type_t ascent_smoother_type, cs_sles_it_type_t coarse_solver_type, int n_max_cycles, int n_max_iter_descent, int n_max_iter_ascent, int n_max_iter_coarse, int poly_degree_descent, int poly_degree_ascent, int poly_degree_coarse, double precision_mult_descent, double precision_mult_ascent, double precision_mult_coarse)
Set multigrid parameters for associated iterative solvers.
Definition: cs_multigrid.cpp:5032
struct _cs_multigrid_t cs_multigrid_t
Definition: cs_multigrid.h:69
@ CS_MULTIGRID_V_CYCLE
Definition: cs_multigrid.h:60
@ CS_SLES_JACOBI
Definition: cs_sles_it.h:63
@ CS_SLES_PCG
Definition: cs_sles_it.h:59
or
nullptr,
-1,
10000);
assert(strcmp(cs_sles_pc_get_type(cs_sles_it_get_pc(c)), "multigrid") == 0);
(mg,
CS_SLES_P_GAUSS_SEIDEL, /* descent smoother (CS_SLES_P_SYM_GAUSS_SEIDEL) */
CS_SLES_P_GAUSS_SEIDEL, /* ascent smoother (CS_SLES_P_SYM_GAUSS_SEIDEL) */
CS_SLES_PCG, /* coarse solver (CS_SLES_P_GAUSS_SEIDEL) */
1, /* n max cycles (default 1) */
1, /* n max iter for descent (default 1) */
1, /* n max iter for asscent (default 1) */
500, /* n max iter coarse solver (default 1) */
0, /* polynomial precond. degree descent (default) */
0, /* polynomial precond. degree ascent (default) */
0, /* polynomial precond. degree coarse (default 0) */
1.0); /* requested precision multiplier coarse (default 1) */
cs_sles_pc_t * cs_multigrid_pc_create(cs_multigrid_type_t mg_type)
Create a multigrid preconditioner.
Definition: cs_multigrid.cpp:5682
void cs_sles_it_transfer_pc(cs_sles_it_t *context, cs_sles_pc_t **pc)
Assign a preconditioner to an iterative sparse linear equation solver, transfering its ownership to t...
Definition: cs_sles_it.cpp:5558
cs_sles_pc_t * cs_sles_it_get_pc(cs_sles_it_t *context)
Return a preconditioner context for an iterative sparse linear equation solver.
Definition: cs_sles_it.cpp:5529
cs_sles_it_t * cs_sles_it_define(int f_id, const char *name, cs_sles_it_type_t solver_type, int poly_degree, int n_max_iter)
Define and associate an iterative sparse linear system solver for a given field or equation name.
Definition: cs_sles_it.cpp:4606
struct _cs_sles_it_t cs_sles_it_t
Definition: cs_sles_it.h:95
@ CS_SLES_P_GAUSS_SEIDEL
Definition: cs_sles_it.h:70
@ CS_SLES_FCG
Definition: cs_sles_it.h:60
const char * cs_sles_pc_get_type(cs_sles_pc_t *pc)
Return type name of preconditioner context.
Definition: cs_sles_pc.cpp:818
void * cs_sles_pc_get_context(cs_sles_pc_t *pc)
Return pointer to preconditioner context structure pointer.
Definition: cs_sles_pc.cpp:864
Definition: cs_sles_pc.h:65
In order to get the best efficiency in case of HPC computations, parallel grid merging can be optimized as follows:
nullptr,
4, /* # of ranks merged at a time */
300, /* mean # of cells under which we merge */
500); /* global # of cells under which we merge */
void cs_multigrid_set_merge_options(cs_multigrid_t *mg, int rank_stride, int rows_mean_threshold, cs_gnum_t rows_glob_threshold)
Set global multigrid parameters for parallel grid merging behavior.
Definition: cs_multigrid.cpp:6040
BoomerAMG
The main ingredients of the BoomerAMG algorithm are defined thanks to the functions cs_param_sles_boomeramg and cs_param_sles_boomeramg_advanced for additional parameters.
// Example: How to set the boomeramg preconditioner
/* Set the main parameters of the BoomerAMG algorithm */
/* n_down_iter, down smoother */
/* n_up_iter, up smoother */
/* coarse solver */
/* coarsening algorithm */
/* Set advanced parameters for BoomerAMG */
0.5, /* strong threshold */
8, /* Pmax */
2, /* n_agg_levels */
2); /* n_agg_paths */
@ CS_EQKEY_AMG_TYPE
Definition: cs_equation_param.h:1242
@ CS_PARAM_AMG_BOOMER_INTERP_EXT_PLUS_I_CC
Definition: cs_param_amg.h:106
@ CS_PARAM_AMG_BOOMER_COARSEN_PMIS
Definition: cs_param_amg.h:89
@ CS_PARAM_AMG_BOOMER_GAUSS_ELIM
Definition: cs_param_amg.h:129
@ CS_PARAM_AMG_BOOMER_HYBRID_SSOR
Definition: cs_param_amg.h:127
void cs_param_sles_boomeramg_advanced(cs_param_sles_t *slesp, double strong_thr, cs_param_amg_boomer_interp_algo_t interp_algo, int p_max, int n_agg_lv, int n_agg_paths)
Set the members of a cs_param_amg_boomer_t structure used in advanced settings. This structure is all...
Definition: cs_param_sles.cpp:1704
void cs_param_sles_boomeramg(cs_param_sles_t *slesp, int n_down_iter, cs_param_amg_boomer_smoother_t down_smoother, int n_up_iter, cs_param_amg_boomer_smoother_t up_smoother, cs_param_amg_boomer_smoother_t coarse_solver, cs_param_amg_boomer_coarsen_algo_t coarsen_algo)
Set the main members of a cs_param_amg_boomer_t structure. This structure is allocated and initialize...
Definition: cs_param_sles.cpp:1661
We strongly invite users to read the HYPRE documentation and especially the part dedicated to BoomerAMG to understand the different choices BoomerAMG documentation
GAMG
The main ingredients of the GAMG algorithm are defined thanks to the functions cs_param_sles_gamg and cs_param_sles_gamg_advanced for additional parameters.
// Example: How to set the GAMG preconditioner
/* Set the main parameters of the GAMG algorithm */
/* coarse solver */
/* Set advanced parameters for GAMG */
0.01, // coarsening threshold
2, // n_agg_levels
true, // use older square graph algo.
2); // number of SA sweeps
// SA = smooth aggregation
@ CS_PARAM_AMG_GAMG_TFS
Definition: cs_param_amg.h:197
@ CS_PARAM_AMG_GAMG_BACKWARD_GS
Definition: cs_param_amg.h:177
@ CS_PARAM_AMG_GAMG_FORWARD_GS
Definition: cs_param_amg.h:180
void cs_param_sles_gamg(cs_param_sles_t *slesp, int n_down_iter, cs_param_amg_gamg_smoother_t down_smoother, int n_up_iter, cs_param_amg_gamg_smoother_t up_smoother, cs_param_amg_gamg_coarse_solver_t coarse_solver)
Set the main members of a cs_param_amg_gamg_t structure. This structure is allocated,...
Definition: cs_param_sles.cpp:1782
void cs_param_sles_gamg_advanced(cs_param_sles_t *slesp, double threshold, int n_agg_lv, bool use_sq_grph, int n_smooth_agg)
Set the members of a cs_param_amg_gamg_t structure used in advanced settings. This structure is alloc...
Definition: cs_param_sles.cpp:1822
We strongly invite users to read the PETSc documentation dedicated to algebraic multigrid to understand the different choices GAMG documentation
Alternative way (low-level API)
HYPRE setting functions can be called thanks to a lower-level API (relying on a setup hook function). Here is an example of a such usage
In the function cs_user_linear_solvers,
nullptr,
CS_SLES_HYPRE_PCG, /* solver type */
CS_SLES_HYPRE_BOOMERAMG, /* preconditioner type */
_hypre_p_setup_hook,
nullptr);
cs_sles_hypre_set_host_device(sc, 1); /* run on GPU */
void cs_sles_hypre_set_host_device(cs_sles_hypre_t *context, int use_device)
Define whether the solver should run on the host or accelerated device.
Definition: cs_sles_hypre.cpp:1420
cs_sles_hypre_t * cs_sles_hypre_define(int f_id, const char *name, cs_sles_hypre_type_t solver_type, cs_sles_hypre_type_t precond_type, cs_sles_hypre_setup_hook_t *setup_hook, void *context)
Define and associate a HYPRE linear system solver for a given field or equation name.
Definition: cs_sles_hypre.cpp:298
@ CS_SLES_HYPRE_PCG
Definition: cs_sles_hypre.h:70
@ CS_SLES_HYPRE_BOOMERAMG
Definition: cs_sles_hypre.h:62
struct _cs_sles_hypre_t cs_sles_hypre_t
Definition: cs_sles_hypre.h:108
where the function _hypre_p_setup_hook is defined as follows:
static void
_hypre_p_setup_hook([[maybe_unused]] int verbosity,
[[maybe_unused]] void *context,
void *solver_p)
HYPRE_Solver solver = (HYPRE_Solver)solver_p;
HYPRE_Solver precond = nullptr;
/* Get pointer to preconditioner, based on solver type (here for PCG) */
HYPRE_PCGGetPrecond(solver, &precond);
/* Assuming the preconditioner is BoomerAMG, set options */
HYPRE_BoomerAMGSetCoarsenType(precond, 8) ; /* HMIS */
HYPRE_BoomerAMGSetAggNumLevels(precond, 2);
HYPRE_BoomerAMGSetPMaxElmts(precond, 4);
HYPRE_BoomerAMGSetInterpType(precond, 7); /* extended+i */
HYPRE_BoomerAMGSetStrongThreshold(precond, 0.5); /* 2d=>0.25 3d=>0.5 */
HYPRE_BoomerAMGSetRelaxType(precond, 6); /* Sym G.S./Jacobi hybrid */
HYPRE_BoomerAMGSetRelaxOrder(precond, 0);
GAMG advanced settings
Up to now, the advanced settings of GAMG is possible inside cs_user_linear_solvers Here is an example of a such usage
/* Initialization must be called before setting options;
it does not need to be called before calling
cs_sles_petsc_define(), as this is handled automatically. */
PETSC_COMM_WORLD = cs_glob_mpi_comm;
PetscInitializeNoArguments();
/* See the PETSc documentation for the options database */
PetscOptionsSetValue(nullptr, "-ksp_type", "cg");
PetscOptionsSetValue(nullptr, "-pc_type", "gamg");
PetscOptionsSetValue(nullptr, "-pc_gamg_agg_nsmooths", "1");
PetscOptionsSetValue(nullptr, "-mg_levels_ksp_type", "richardson");
PetscOptionsSetValue(nullptr, "-mg_levels_pc_type", "sor");
PetscOptionsSetValue(nullptr, "-mg_levels_ksp_max_it", "1");
PetscOptionsSetValue(nullptr, "-pc_gamg_threshold", "0.02");
PetscOptionsSetValue(nullptr, "-pc_gamg_reuse_interpolation", "TRUE");
PetscOptionsSetValue(nullptr, "-pc_gamg_square_graph", "4");
MPI_Comm cs_glob_mpi_comm
Definition: cs_defs.cpp:179
Sparse direct solver: MUMPS
For the most difficult to solve linear systems or in order to check a numerical scheme, it may be useful to solve the linear systems with a direct solver. In code_saturne, this is possible using the MUMPS library.
Example: Use MUMPS to solve a user-defined equation
#else
#endif
Additional options
Additional options may be set to improve the performance of the sparse direct solver. Please refer to the MUMPS documentation to know more about the different options.
/* Parameters related to a user-defined equation */
false, /* single-precision ? */
CS_PARAM_MUMPS_FACTO_LU); /* type of factorization */
// Keeping the ordering is valuable to save time in case of unsteady
// computations and when the mesh is not modified during the computation
1, // size of the block for analysis
true, // keep ordering
-1, // pct memory increase < 0 --> not used
0, // BLR compression: 0 --> not used
1, // iterative refinement steps
true); // advanced optimizations
@ CS_PARAM_MUMPS_FACTO_LU
LU factorization is the most generic factorization available with MUMPS. It can handle general matric...
Definition: cs_param_mumps.h:73
@ CS_PARAM_MUMPS_MEMORY_AUTO
Definition: cs_param_mumps.h:152
@ CS_PARAM_MUMPS_ANALYSIS_QAMD
Definition: cs_param_mumps.h:122
void cs_param_sles_mumps(cs_param_sles_t *slesp, bool is_single, cs_param_mumps_facto_type_t facto_type)
Set the main members of a cs_param_mumps_t structure. This structure is allocated and initialized wit...
Definition: cs_param_sles.cpp:2002
void cs_param_sles_mumps_advanced(cs_param_sles_t *slesp, cs_param_mumps_analysis_algo_t analysis_algo, int block_analysis, bool keep_ordering, double mem_coef, double blr_threshold, int ir_steps, cs_param_mumps_memory_usage_t mem_usage, bool advanced_optim)
Set the members related to an advanced settings of a cs_param_mumps_t structure. This structure is al...
Definition: cs_param_sles.cpp:2038
The function cs_param_sles_mumps allows one to set the two following main parameters:
  1. The factorization is performed using a single (parameter = "true") ou a double precision (parameter = "false"). If the usage of MUMPS is not as a preconditioner, then one advises to consider a double-precision factorization.
  2. Which type of factorization to perform ? There are the following choices:
Further options are available through the function cs_param_sles_mumps_advanced in order to reach a better performance but this is case dependent.
There are three main stages in the resolution:
  1. The analysis stage : renumbering to improve the fill-in of the factorization
  2. the factorization stage
  3. The solve stage (apply the factorization)
Renumbering
During the analysis stage, an important step is the renumbering. The quality of the analysis and in particular of the renumbering has a direct impact on the efficiency of the factorization and its fill-in (memory consumption).
Several algorithms are available according to your MUMPS installation. Some of these algorithms rely on external libraries such as (PT-)Scotch ou (Par)Metis
The type of algorithm which can be set from code_saturne is stored in cs_param_mumps_analysis_algo_t
parameter description dependency
CS_PARAM_MUMPS_ANALYSIS_AMD AMD sequential algorithm. Well-suited for 2D cases. no
CS_PARAM_MUMPS_ANALYSIS_QAMD QAMD sequential algorithmn. Well-suited for 2D cases. no
CS_PARAM_MUMPS_ANALYSIS_PORD Sequential algorithmn. For 3D cases if there is no dependency in your MUMPS installation no
CS_PARAM_MUMPS_ANALYSIS_SCOTCH Sequential algorithm for 3D cases. Scotch or PT-Scotch
CS_PARAM_MUMPS_ANALYSIS_PTSCOTCH Parallel algorithm for 3D cases. PT-Scotch
CS_PARAM_MUMPS_ANALYSIS_METIS Sequential algorithm for 3D cases. Often the best choice METIS or PARMETIS
CS_PARAM_MUMPS_ANALYSIS_PARMETIS Parallel algorithm for 3D cases. PARMETIS
CS_PARAM_MUMPS_ANALYSIS_AUTO The choice is performed by MUMPS according to the available algorithms and the type of matrices
Iterative refinement
When the system is really ill-conditioned, it can be useful to add one or several steps of iterative refinement to improvement the solution. By default, no iteration is performed. A fixed number of iterations is always performed.
Block Low Rank (BLR) algorithms
There is no BLR activated if the value of the parameter related to the BLR algorithm is set to 0. When the value is positive, BLR is activated for the factorization and solve stages using the UCFS variant and the value is used to indicate the level of compression. When the value is negative, the UFSC algorithm is used instead.
If the option CS_PARAM_MUMPS_MEMORY_CONSTRAINED is set, other compressions are activated (cleaning of the workspace, ICNTL(37)=1 and ICNTL(40)=1) in addition to the BLR compression.
Memory increase
In some cases (for instance with 2D cases), the estimation of the memory consumption is not sufficient and an error message is returned. To circumvent this issue, one needs to set a correct mem_coef parameter. This is directly given to ICNTL(14) in MUMPS.
Interfaces with MUMPS structures
To get the finest control on the tuning of the MUMPS solver, one has to use the function cs_user_sles_mumps_hook
This function is called before the main stages:
  1. Before the analysis step
  2. Before the factorization step
void
cs_user_sles_mumps_hook([[maybe_unused]] const cs_param_sles_t *slesp,
void *pmumps)
// Case of a factorization in double-precision
DMUMPS_STRUC_C *mumps = static_cast<DMUMPS_STRUC_C *>(pmumps);
assert(mumps != nullptr);
/* If MUMPS is used in single-precision, one has to modify the declaration as
follows:
SMUMPS_STRUC_C *mumps = static_cast<SMUMPS_STRUC_C *>(pmumps);
All the remaining settings are identical in the single or double-precision
case.
// Advanced settings
mumps->CNTL(4) = 0.0; /* Static pivoting */
mumps->ICNTL(58) = 2; /* Symbolic factorization {0, 1, or 2}*/
void cs_user_sles_mumps_hook(const cs_param_sles_t *slesp, void *context, void *pmumps)
Function pointer for advanced user settings of a MUMPS solver. This function is called two times duri...
Definition: cs_sles_mumps.cpp:2674
According to the configuration single or double precision, the structure storing the MUMPS solver differs. In case of a single precision factorization, the cast is done to a pointer to a SMUMPS_STRUC_C structure
Solve a saddle-point linear system
Saddle-point systems arise from the monolithic velocity-pressure coupling of the Navier-Stokes equations or from the discretization of CDO cell-based schemes (steady diffusion equation equation for instance). Some examples of settings involving differents strategies of resolution are presented hereafter.
One considers the following type of saddle-point systems $\mathsf{Mx = b}$ with
 \mathsf{M} = \begin{bmatrix}
    A & B^T \\
    B & 0
 \end{bmatrix}
 \qquad
 \text{and}
 \qquad
 \mathsf{b} =
 \begin{bmatrix}
    f \\
    g
 \end{bmatrix}
where $A$ is a square non-singular matrix (symmetric or not according to the numerical and/or modelling choices).
The key CS_EQKEY_SADDLE_SOLVER enables to set the solver (or the strategy) to solve the saddle-point problem associated to an equation. More details are gathered in the following table.
"none" No solver. No saddle-point system to solve. CS_PARAM_SADDLE_SOLVER_NONE saturne
"alu" Uzawa algorithm with an Augmented Lagrangian acceleration. Segregated technique. CS_PARAM_SADDLE_SOLVER_ALU saturne
"fgmres" Flexible GMRES Krylov solver on the full system. Possibility to consider block preconditioning. The choice to approximate the Schur complement has an impact on the effeciency of the algorithm. Monolithic technique. CS_PARAM_SADDLE_SOLVER_FGMRES PETSc
"gcr" GCR (Generalized Conjugate Residual) Krylov solver on the full system along with block preconditioning. The choice to approximate the Schur complement has an impact on the effeciency of the algorithm. Monolithic technique. CS_PARAM_SADDLE_SOLVER_GCR saturne
"gkb" Golub-Kahan bidiagonalization. An augmentation of the (1,1) block is possible. Use this technique on symmetric saddle-point systems. Segregated technique. CS_PARAM_SADDLE_SOLVER_GKB saturne
"minres" MINRES Krylov solver on the full system along with block preconditioning. Close to the choice "gcr" but only for symmetric saddle-point systems. Monolithic technique. CS_PARAM_SADDLE_SOLVER_MINRES saturne
"mumps" MUMPS sparse direct solver on the full system. Monolithic technique. CS_PARAM_SADDLE_SOLVER_MUMPS MUMPS
"notay" Notay's algebraic transformation. Monolithic technique relying on a FMGRES on the modified system. Block preconditioning can be specified on the transformed blocks. (Experimental) CS_PARAM_SADDLE_SOLVER_NOTAY_TRANSFORM PETSc
"uzawa_cg" Uzawa algorithm accelerated by a CG technique. Only for symmetric saddle-point systems. The choice to approximate the Schur complement has an impact on the effeciency of the algorithm. Segregated technique. CS_PARAM_SADDLE_SOLVER_UZAWA_CG saturne
In segregated technique, the (1,1)-block solver refers to the main solver. It can be set following the rationale described in Solve a linear system In monolothic technique, the (1,1)-block solver refers to the approximation of this block for preconditioning. Moreover, for some strategies, additional SLES such as the Schur complement system can also be specified using the same rationale described in Solve a linear system.
Augmented Lagrangian Uzawa algorithm (ALU)
Here is a first example to set a saddle-point solver. One assumes that the external library MUMPS has been installed and has been configured with code_saturne (see the installation guide for more details here).
/* Parameters related to the momentum equation */
/* Linear algebra settings for the saddle-point system */
#else
#endif
@ CS_EQKEY_SADDLE_SOLVER
Definition: cs_equation_param.h:1279
@ CS_EQKEY_SADDLE_AUGMENT_SCALING
Definition: cs_equation_param.h:1273
@ CS_EQKEY_SADDLE_ATOL
Definition: cs_equation_param.h:1272
@ CS_EQKEY_SADDLE_RTOL
Definition: cs_equation_param.h:1277
@ CS_EQKEY_SADDLE_MAX_ITER
Definition: cs_equation_param.h:1275
Since the velocity block is augmented by the term $\underline{\mathsf{grad}}\,\mathsf{div}$ (with a scaling coefficient given by CS_EQKEY_SADDLE_AUGMENT_SCALING), the resulting linear system is hard to solve for an iterative method (or one needs a very specific preconditionner for $H(\mathsf{div})$). Our strategy is to consider the sparse direct solver MUMPS [1]. Here is an example of an advanced usage of the MUMPS settings.
CS_PARAM_MUMPS_FACTO_LDLT_SPD); /* type of facto. */
3, // size of the block for analysis
false, // keep ordering
0, // iterative refinement steps
@ CS_PARAM_MUMPS_FACTO_LDLT_SPD
This factorization is devoted to SPD matrices and corresponds to a Cholesky factorization....
Definition: cs_param_mumps.h:75
@ CS_PARAM_MUMPS_MEMORY_CONSTRAINED
Definition: cs_param_mumps.h:151
@ CS_PARAM_MUMPS_ANALYSIS_PTSCOTCH
Definition: cs_param_mumps.h:125
Since the velocity block is vector-valued, one can benefit from a block analysis (the third parameter is set to 3).
Here is a second example.
/* More advanced usage */
-1, // pct memory increase < 0 = not used
0, // BLR compression: 0 = not used
#else
#endif
@ CS_EQKEY_SLES_VERBOSITY
Definition: cs_equation_param.h:1283
@ CS_PARAM_MUMPS_ANALYSIS_AUTO
Definition: cs_param_mumps.h:129
Block preconditioners with a Krylov solver
In-house solvers
The two in-house Krylov solvers available with block preconditioning are
  • Minres (Minimal residual) algorithm for symmetric indefinite systems such as systems encountered in the case of Stokes systems
  • GCR (Generalized conjugate residual) algorithm for general indefinite systems. This is a flexible solver (preconditioner may vary between two iterations).
These two algorithms are optimized to handle saddle-point problems in code_saturne since the (1,2) and (2,1) which are transposed is stored only once. Moreover, this block is stored in an unassembled way.
/* Parameters related to the Stokes settings.
MINRES is not possible with a non-symmetric saddle-point system */
/* Linear algebra settings for the (1,1)-block */
#if defined(HAVE_PETSC) /* One assumes that PETSc is installed with Hypre */
/* Must be set after the previous line to switch to PETSC in order to be
able to use a block preconditioning for the velocity block */
/* Set the main parameters for BoomerAMG (Please refer to the Hypre
documentation for more details) */
/* coarse solver */
8, /* Pmax */
#else /* PETSc not installed */
/* n_down_iter, down smoother, down poly. deg. */
/* n_up_iter, up smoother, up poly. deg. */
/* coarse solver, coarse poly. deg. */
/* Set advanced parameters for an in-house AMG */
CS_CDO_KEEP_DEFAULT, // max. levels
100, // min. n_g_rows
CS_CDO_KEEP_DEFAULT, // p0p1 relax.
CS_CDO_KEEP_DEFAULT, // coarse max. iter
1e-2); // coarse rtol mult.
#endif
/* Linear algebra settings for the Schur complement approximation */
@ CS_EQKEY_SADDLE_SCHUR_APPROX
Definition: cs_equation_param.h:1278
@ CS_EQKEY_PRECOND_BLOCK_TYPE
Definition: cs_equation_param.h:1271
@ CS_PARAM_AMG_BOOMER_COARSEN_HMIS
Definition: cs_param_amg.h:90
@ CS_PARAM_AMG_BOOMER_FORWARD_L1_GS
Definition: cs_param_amg.h:131
@ CS_PARAM_AMG_BOOMER_BACKWARD_L1_GS
Definition: cs_param_amg.h:130
PETSc solvers
Other block preconditioners with a Krylov solver can be set using the external librairy PETSc. The two main differences (in addition to the use of the PETSc library) are:
  1. The Krylov solver is a flexible GMRES algorithm
  2. The Schur complement approximation can differ since one hinges on the choices available in PETSc. Please refer to the PETSc documentation for more details.
One uses the FIELDSPLIT functionnality to set the block preconditioning strategy.
Golub-Kahan Bidiagonalization algorithm (GKB)
The linear system may be augmented to improve the convergence rate of the algorithm (but the system is harder to solve). Here is another example:
/* Linear algebra settings for the (1,1) block */
#else
#endif
Notay's algebraic transformation (Experimental)
Here is an example in the case of a saddle-point system stemming from the Navier-Stokes equations.
/* Linear algebra settings for the saddle-point system.
* Notay's algebraic transformation is an experimental feature
* The main solver is a FGMRES on the full saddle-point problem.
/* Set the solver for the (1,1)-block preconditioner --> the velocity block
in the case of the Navier-Stokes system */
Uzawa algorithm with a CG acceleration
#else
#endif
The Schur complement related to the saddle-point system $\mathsf{Mx = b}$ detailed above is $\mathsf{S} = \mathsf{-B\cdot A^{-1} \cdot B}$ This is a square matrix. The cost to build exactly this matrix is prohibitive. Thus, one needs an approximation denoted by $\mathsf{\widetilde{S}}$
An approximation of the Schur complement is needed by the following strategies:
  • Block preconditionner with a Krylov method as in "fgmres" (only with PETSc), "gcr" or "minres"
  • Uzawa algorithm with a CG acceleration: "uzawa_cg"
The efficiency of the strategy to solve the saddle-point problem is related to the quality of the approximation. Several types of approximation of the Schur complement are available and a synthesis of the different options is gathered in the following table.
key value description related type family
"none" No approximation. The Schur complement approximation is not used. CS_PARAM_SADDLE_SCHUR_NONE all
"diag_inv" $\mathsf{\widetilde{S}} = \mathsf{-B\cdot diag(A)^{-1} \cdot B}$ CS_PARAM_SADDLE_SCHUR_DIAG_INVERSE saturne, petsc
"identity" The identity matrix is used. CS_PARAM_SADDLE_SCHUR_IDENTITY saturne, petsc
"lumped_inv" $\mathsf{\widetilde{S}} = \mathsf{-B\cdot L \cdot B}$ where $\mathsf{A\,L = 1}$, $\mathsf{1}$ is the vector fill with the value 1. CS_PARAM_SADDLE_SCHUR_LUMPED_INVERSE saturne
"mass_scaled" The pressure mass matrix is used with a scaling coefficient. This scaling coefficient is related to the viscosity for instance when dealing with the Navier-Stokes system. CS_PARAM_SADDLE_SCHUR_MASS_SCALED saturne
"mass_scaled_diag_inv" This is a combination of the "mass_scaled" and "diag_inv" approximation. CS_PARAM_SADDLE_SCHUR_MASS_SCALED_DIAG_INVERSE saturne
"mass_scaled_lumped_inv" This is a combination of the "mass_scaled" and "lumped_inv" approximation. CS_PARAM_SADDLE_SCHUR_MASS_SCALED_LUMPED_INVERSE saturne
To set the way to approximate the Schur complement use
For the Schur approximation implying the "diag_inv" or the "lumped_inv" approximation, one needs to build and then solve a linear system associated to the Schur approximation. In the case of the "lumped_inv", an additionnal linear system is solved to define the vector $\mathsf{L}$ from the resolution of $\mathsf{A\,L =
1}$. Please consider the examples below for more details.
Example 1: "mass_scaled"
In the first example, one assumes that the saddle-point solver is associated to the structure cs_equation_param_t nammed mom_eqp. For instance, one uses a gcr strategy for solving the saddle-point problem. This is one of the simpliest settings for the Schur complement approximation. The "mass_scaled" approximation is well-suited for solving the Stokes problem since the pressure mass matrix is a rather good approximation (in terms of spectral behavior) of the Schur complement.
/* Nothing else to add for the approximation of the Schur complement */
Example 2: "mass_scaled_diag_inv"
In the second example, one assumes that the saddle-point solver is associated to the structure cs_equation_param_t nammed mom_eqp. One now considers a more elaborated approximation which needs to solve a system implying the Schur complement approximation.
CS_EQKEY_SADDLE_SCHUR_APPROX, "mass_scaled_diag_inv");
/* Retrieve the set of parameters to handle the system associated to the
cs_param_sles_t *schur_slesp =
/* Set the solver, its preconditionner and the stopping criteria */
int ierr = cs_param_sles_set_solver("fgmres", schur_slesp);
assert(ierr == 0);
ierr = cs_param_sles_set_precond("amg", schur_slesp);
assert(ierr == 0);
ierr = cs_param_sles_set_amg_type("boomer", schur_slesp);
assert(ierr == 0);
/* One uses CS_CDO_KEEP_DEFAULT as parameter to keep unchanged the default
settings */
1e-2, /* rtol */
CS_CDO_KEEP_DEFAULT, /* atol */
CS_CDO_KEEP_DEFAULT, /* dtol */
CS_CDO_KEEP_DEFAULT); /* max. iter. */
cs_param_saddle_t * cs_equation_param_get_saddle_param(cs_equation_param_t *eqp)
Get the pointer to the set of parameters to handle a saddle-point solver This is only useful if some ...
Definition: cs_equation_param.cpp:1549
cs_param_sles_t * cs_param_saddle_get_schur_sles_param(const cs_param_saddle_t *saddlep)
Get the pointer to the set of parameters to handle a SLES. This SLES is associated to the approximati...
Definition: cs_param_saddle.cpp:791
int cs_param_sles_set_solver(const char *keyval, cs_param_sles_t *slesp)
Set the solver associated to this SLES from its keyval.
Definition: cs_param_sles.cpp:657
int cs_param_sles_set_precond(const char *keyval, cs_param_sles_t *slesp)
Set the preconditioner associated to this SLES from its keyval.
Definition: cs_param_sles.cpp:825
void cs_param_sles_set_cvg_param(cs_param_sles_t *slesp, double rtol, double atol, double dtol, int max_iter)
Set the convergence criteria for the given SLES parameters. One can use the parameter value CS_CDO_KE...
Definition: cs_param_sles.cpp:1423
int cs_param_sles_set_amg_type(const char *keyval, cs_param_sles_t *slesp)
Set the type of algebraic multigrid (AMG) associated to this SLES from its keyval.
Definition: cs_param_sles.cpp:1190
Structure storing all metadata related to the resolution of a saddle-point linear system....
Definition: cs_param_saddle.h:280
Example 3: "lumped_inv"
In the third and last example, one assumes that the saddle-point solver is associated to the structure cs_equation_param_t nammed mom_eqp. One now considers a more elaborated approximation which needs to solve a system implying the Schur complement approximation and an additional system to build the Schur complement approximation (the system related to $\mathsf{A\,L = 1}$).
int ierr = cs_param_sles_set_solver("fcg", schur_slesp);
assert(ierr == 0);
assert(ierr == 0);
settings */
1e-2, /* rtol */
15); /* max. iter. */
ierr = cs_param_sles_set_amg_type("gamg", schur_slesp);
assert(ierr == 0);
/* Retrieve the additional system (the one used for the lumped inverse") */
ierr = cs_param_sles_set_solver("fgmres", xtra_slesp);
assert(ierr == 0);
ierr = cs_param_sles_set_precond("amg", xtra_slesp);
assert(ierr == 0);
ierr = cs_param_sles_set_amg_type("boomer", xtra_slesp);
assert(ierr == 0);
ierr = cs_param_sles_set_precond_block_type("diag", xtra_slesp);
assert(ierr == 0);
1e-2, /* rtol */
20); /* max. iter. */
cs_param_sles_t * cs_param_saddle_get_xtra_sles_param(const cs_param_saddle_t *saddlep)
Get the pointer to the set of parameters to handle a SLES. This SLES is associated to an extra-operat...
Definition: cs_param_saddle.cpp:813
int cs_param_sles_set_precond_block_type(const char *keyval, cs_param_sles_t *slesp)
Set the type of block preconditioner associated to this SLES from its keyval.
Definition: cs_param_sles.cpp:1358
Additional settings
Immediate exit
In some cases, the initial residual is very small leading to an immediate exit. If this happens and it should not be the case, one can specify a stronger criterion to trigger the immediate exit. In the function cs_user_linear_solvers, add the following lines for instance:
/* Redefine the threshold under which an immediate exit occurs */
void cs_sles_set_epzero(double new_value)
Set the threshold value used in the detection of immediate exit.
Definition: cs_sles.cpp:934
Allow no operation
An immediate exit is possible (i.e. there is no solve) when the norm of the right-hand side is equal to zero or very close to zero (cs_sles_set_epzero). To allow this kind of behavior for the SLES associated to an equation, one has to set the key CS_EQKEY_SOLVER_NO_OP to true.
/* In case of a in-house solver, allow one to skip the solve in some
specific situation rhs and solution nearly equal to zero */
@ CS_EQKEY_SOLVER_NO_OP
Definition: cs_equation_param.h:1265
