cs_param_sles_t Struct Reference
Structure storing all metadata related to the resolution of a linear system with an iterative solver. More...
#include <cs_param_sles.h>
+ Collaboration diagram for cs_param_sles_t:
Public Attributes
char * name
int field_id
int verbosity
cs_param_solver_class_t solver_class
cs_param_precond_type_t precond
cs_param_solver_type_t solver
bool need_flexible
int restart
cs_param_amg_type_t amg_type
cs_param_precond_block_t precond_block_type
cs_param_resnorm_type_t resnorm_type
bool allow_no_op
bool mat_is_sym
cs_param_convergence_t cvg_param
void * context_param
Member Data Documentation
◆ allow_no_op
allow_no_op
allow one to not call the solve function in some specific situations Please refer to _needs_solving for more details
◆ amg_type
type of AMG algorithm
◆ context_param
context_param
Pointer to a structure cast on-the-fly storing specific parameters related to the given solver (MUMPS for instance)
◆ cvg_param
cvg_param
Structure storing the parameters to know if an iterative process has to stop (convergence or divergence).
◆ field_id
int field_id
Field id related to a SLES. By default, this is set to -1
◆ mat_is_sym
mat_is_sym
allow one to know if the matric is symmetric (independent of the way the storage is done). Default value is false
◆ name
char* name
System name (equation name if this is automatic)
◆ need_flexible
bool need_flexible
need a flexible variant ?
◆ precond
type of preconditioner
◆ precond_block_type
precond_block_type
type of block preconditioner to use (only meaningful for vector-valued systems or more complex systems)
◆ resnorm_type
resnorm_type
normalized or not the norm of the residual used for the stopping criterion See CS_EQKEY_SOLVER_RESNORM_TYPE for more details.
◆ restart
int restart
max. iter. before restarting
◆ solver
type of solver
◆ solver_class
class of SLES to consider
◆ verbosity
int verbosity
SLES verbosity
