◆ CS_ALL_FACES
| #define CS_ALL_FACES 0 /* All faces: interior + border */ |
◆ CS_BND_FACES
| #define CS_BND_FACES 1 /* Boundary faces */ |
◆ CS_CDO_KEEP_DEFAULT
| #define CS_CDO_KEEP_DEFAULT -2 |
◆ CS_CDO_N_MAX_REACTIONS
| #define CS_CDO_N_MAX_REACTIONS 8 |
◆ CS_CDO_OMP_ASSERT
| #define CS_CDO_OMP_ASSERT |
e | ) |
assert(e) |
◆ CS_CDO_OMP_CHUNK_SIZE
| #define CS_CDO_OMP_CHUNK_SIZE 128 |
◆ CS_CDO_OMP_SCHEDULE
◆ CS_CDO_OMP_SYNC_MODE
| #define CS_CDO_OMP_SYNC_MODE |
◆ CS_INT_FACES
| #define CS_INT_FACES 2 /* Interior faces */ |
◆ CS_N_DOFS_CELL_0TH
| #define CS_N_DOFS_CELL_0TH 1 |
◆ CS_N_DOFS_CELL_1ST
| #define CS_N_DOFS_CELL_1ST 4 |
◆ CS_N_DOFS_CELL_2ND
| #define CS_N_DOFS_CELL_2ND 10 |
◆ CS_N_DOFS_FACE_0TH
| #define CS_N_DOFS_FACE_0TH 1 |
◆ CS_N_DOFS_FACE_1ST
| #define CS_N_DOFS_FACE_1ST 3 |
◆ CS_N_DOFS_FACE_2ND
| #define CS_N_DOFS_FACE_2ND 6 |
◆ cs_param_cdo_mode_t
| Enumerator |
| CS_PARAM_CDO_MODE_OFF | |
| CS_PARAM_CDO_MODE_WITH_FV | |
| CS_PARAM_CDO_MODE_NS_WITH_FV | |
| CS_PARAM_CDO_MODE_ONLY | |
◆ cs_param_cdo_has_cdo()
| bool cs_param_cdo_has_cdo |
void |
◆ cs_param_cdo_has_cdo_and_fv()
| bool cs_param_cdo_has_cdo_and_fv |
void |
Tell if FVM and CDO are used.
◆ cs_param_cdo_has_cdo_main()
| bool cs_param_cdo_has_cdo_main |
void |
Tell if CDO is used to solve main equations.
◆ cs_param_cdo_has_cdo_only()
| bool cs_param_cdo_has_cdo_only |
void |
Tell if CDO is only used.
◆ cs_param_cdo_has_fv_main()
| bool cs_param_cdo_has_fv_main |
void |
Tell if FVM is used to solve main equations.
◆ cs_param_cdo_has_fv_only()
| bool cs_param_cdo_has_fv_only |
void |
◆ cs_param_cdo_has_NS_with_fv()
| bool cs_param_cdo_has_NS_with_fv |
void |
◆ cs_param_cdo_log()
| void cs_param_cdo_log |
void |
Print a welcome message indicating what is the current CDO status.
◆ cs_param_cdo_mode_get()
Get the mode of activation for the CDO/HHO schemes.
- Returns
- the mode of activation for the CDO/HHO module
◆ cs_param_cdo_mode_set()
Set the global variable storing the mode of activation to apply to CDO/HHO schemes.
◆ cs_param_cdo_setup_log()
| void cs_param_cdo_setup_log |
void |
Print generic parameters used with CDO/HHO schemes.
◆ cs_glob_param_cdo_mode
