cs_equation_param.cpp File Reference
Structure and functions handling the specific settings related to a cs_equation_t structure. More...
#include <cassert>
#include <cctype>
#include "base/cs_mem.h"
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "alge/cs_param_sles_setup.h"
#include "alge/cs_saddle_solver_setup.h"
#include "base/cs_log.h"
#include "base/cs_volume_zone.h"
#include "cdo/cs_cdo_advection.h"
#include "cdo/cs_cdo_bc.h"
#include "cdo/cs_cdocb_priv.h"
#include "cdo/cs_hodge.h"
#include "cdo/cs_equation_param.h"
+ Include dependency graph for cs_equation_param.cpp:
static int _find_or_add_ic (cs_equation_param_t *eqp, int z_id)
 Find an existing "initial condition" definition related to the given zone id or add a new one. More...
static void _set_key (cs_equation_param_t *eqp, cs_equation_key_t key, const char *keyval)
 Set a parameter attached to a keyname in a cs_equation_param_t structure. More...
cs_equation_param_t * cs_equation_param_create (const char *name, cs_equation_type_t type, int dim, cs_param_bc_type_t default_bc)
 Create a cs_equation_param_t structure with the given parameters. The remaining parameters are set with default values;. More...
void cs_equation_param_copy_from (const cs_equation_param_t *ref, cs_equation_param_t *dst, bool copy_fld_id)
 Copy the settings from one cs_equation_param_t structure to another one. The name is not copied. More...
void cs_equation_param_copy_bc (const cs_equation_param_t *ref, cs_equation_param_t *dst)
 Copy only the part dedicated to the boundary conditions and the DoF (degrees of freedom) enforcement from one cs_equation_param_t structure to another one. More...
void cs_equation_param_clear (cs_equation_param_t *eqp)
 Free the contents of a cs_equation_param_t. More...
cs_equation_param_t * cs_equation_param_free (cs_equation_param_t *eqp)
 Free a cs_equation_param_t. More...
void cs_equation_param_set (cs_equation_param_t *eqp, cs_equation_key_t key, const char *keyval)
cs_param_sles_t * cs_equation_param_get_sles_param (cs_equation_param_t *eqp)
 Get the pointer to the set of parameters to handle the SLES solver associated to this set of equation parameters. More...
cs_param_saddle_t * cs_equation_param_get_saddle_param (cs_equation_param_t *eqp)
 Get the pointer to the set of parameters to handle a saddle-point solver This is only useful if some cases (the momemtum equation when a monolithic coupling is considered or the solution of a scalar-valued CDO cell-based schemes) More...
void cs_equation_param_set_sles (cs_equation_param_t *eqp)
 Set parameters for initializing SLES structures used for the resolution of the linear system. Settings are related to this equation. More...
void cs_equation_param_set_quadrature_to_all (cs_equation_param_t *eqp, cs_quadrature_type_t qtype)
 Apply the given quadrature rule to all existing definitions under the cs_equation_param_t structure. More...
void cs_equation_param_lock_settings (cs_equation_param_t *eqp)
 Lock settings to prevent from unwanted modifications. More...
void cs_equation_param_unlock_settings (cs_equation_param_t *eqp)
 Unlock settings. Be sure that is really wanted (inconsistency between the setup logging and what is used may appear) More...
void cs_equation_param_ensure_consistent_settings (cs_equation_param_t *eqp)
 At this stage, the numerical settings should not be modified anymore by the user. One makes a last set of modifications if needed to ensure a consistent numerical settings. More...
void cs_equation_param_log (const cs_equation_param_t *eqp)
 Print the detail of a cs_equation_param_t structure. More...
bool cs_equation_param_has_robin_bc (const cs_equation_param_t *eqp)
 Ask if the parameter settings of the equation has requested the treatment of Robin boundary conditions. More...
cs_xdef_t * cs_equation_add_ic_by_value (cs_equation_param_t *eqp, const char *z_name, cs_real_t *val)
 Define the initial condition for the unknown related to this equation. This definition applies to a volume zone. By default, the unknown is set to zero everywhere. Here a constant value is set to all the unknows belonging to the given zone with name z_name If a definition already exists for the given zone name, then the previous definition is replaced. More...
cs_xdef_t * cs_equation_add_ic_by_qov (cs_equation_param_t *eqp, const char *z_name, double quantity)
 Define the initial condition for the unknown related to this equation. This definition applies to a volume zone. By default, the unknown is set to zero everywhere. Here the value set to each unknown belonging to the given zone with name z_name is such that the integral over the cells of the zone returns the requested quantity If a definition already exists for the given zone name, then the previous definition is replaced. More...
cs_xdef_t * cs_equation_add_ic_by_analytic (cs_equation_param_t *eqp, const char *z_name, cs_analytic_func_t *analytic, void *input)
 Define the initial condition for the unknown related to this equation. This definition applies to a volume zone. By default, the unknown is set to zero everywhere. Here the initial value for each unknown associated to the zone with name z_name is set according to an analytical function If a definition already exists for the given zone name, then the previous definition is replaced. More...
cs_xdef_t * cs_equation_add_ic_by_dof_func (cs_equation_param_t *eqp, const char *z_name, cs_flag_t loc_flag, cs_dof_func_t *func, void *input)
 Define the initial condition for the unknown related to this equation. This definition applies to a volume zone. By default, the unknown is set to zero everywhere. Case of a definition by a DoF function. If a definition already exists for the given zone name, then the previous definition is replaced. More...
void cs_equation_add_xdef_bc (cs_equation_param_t *eqp, cs_xdef_t *xdef)
 Set a boundary condition from an existing cs_xdef_t structure The lifecycle of the cs_xdef_t structure is now managed by the current cs_equation_param_t structure. More...
cs_xdef_t * cs_equation_add_bc_by_value (cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_real_t *values)
 Define and initialize a new structure to set a boundary condition related to the given equation structure z_name corresponds to the name of a pre-existing cs_zone_t. More...
cs_xdef_t * cs_equation_add_bc_by_array (cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, bool full_length)
cs_xdef_t * cs_equation_add_bc_by_field (cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_field_t *field)
cs_xdef_t * cs_equation_add_bc_by_analytic (cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_analytic_func_t *analytic, void *input)
 Define and initialize a new structure to set a boundary condition related to the given equation param structure ml_name corresponds to the name of a pre-existing cs_mesh_location_t. More...
cs_xdef_t * cs_equation_add_bc_by_time_func (cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_time_func_t *t_func, void *input)
 Define and initialize a new structure to set a boundary condition related to the given equation param structure ml_name corresponds to the name of a pre-existing cs_mesh_location_t Definition relying on a cs_time_func_t function pointer. More...
cs_xdef_t * cs_equation_add_bc_by_dof_func (cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_flag_t loc_flag, cs_dof_func_t *func, void *input)
 Define and initialize a new structure to set a boundary condition related to the given cs_equation_param_t structure ml_name corresponds to the name of a pre-existing cs_mesh_location_t. More...
cs_xdef_t * cs_equation_find_bc (cs_equation_param_t *eqp, const char *z_name)
 Return pointer to existing boundary condition definition structure for the given equation param structure and zone. More...
void cs_equation_remove_bc (cs_equation_param_t *eqp, const char *z_name)
 Remove boundary condition from the given equation param structure for a given zone. More...
void cs_equation_remove_ic (cs_equation_param_t *eqp, const char *z_name)
 Remove initial condition from the given equation param structure for a given zone. More...
void cs_equation_add_sliding_condition (cs_equation_param_t *eqp, const char *z_name)
 Define and initialize a new structure to set a sliding boundary condition related to the given equation structure z_name corresponds to the name of a pre-existing cs_zone_t. More...
void cs_equation_add_diffusion (cs_equation_param_t *eqp, cs_property_t *property)
 Associate a new term related to the Laplacian operator for the equation associated to the given cs_equation_param_t structure Laplacian means div-grad (either for vector-valued or scalar-valued equations) More...
void cs_equation_add_curlcurl (cs_equation_param_t *eqp, cs_property_t *property, int inversion)
 Associate a new term related to the curl-curl operator for the equation associated to the given cs_equation_param_t structure. More...
void cs_equation_add_graddiv (cs_equation_param_t *eqp, cs_property_t *property)
 Associate a new term related to the grad-div operator for the equation associated to the given cs_equation_param_t structure. More...
void cs_equation_add_time (cs_equation_param_t *eqp, cs_property_t *property)
 Associate a new term related to the time derivative operator for the equation associated to the given cs_equation_param_t structure. More...
void cs_equation_add_advection (cs_equation_param_t *eqp, cs_adv_field_t *adv_field)
 Associate a new term related to the advection operator for the equation associated to the given cs_equation_param_t structure. More...
void cs_equation_add_advection_scaling_property (cs_equation_param_t *eqp, cs_property_t *property)
 Associate a scaling property to the advection. More...
int cs_equation_add_reaction (cs_equation_param_t *eqp, cs_property_t *property)
 Associate a new term related to the reaction operator for the equation associated to the given cs_equation_param_t structure. More...
cs_xdef_t * cs_equation_add_source_term_by_val (cs_equation_param_t *eqp, const char *z_name, cs_real_t *val)
 Add a new source term by initializing a cs_xdef_t structure. Case of a definition by a constant value. More...
cs_xdef_t * cs_equation_add_source_term_by_analytic (cs_equation_param_t *eqp, const char *z_name, cs_analytic_func_t *func, void *input)
 Add a new source term by initializing a cs_xdef_t structure. Case of a definition by an analytical function. More...
cs_xdef_t * cs_equation_add_source_term_by_dof_func (cs_equation_param_t *eqp, const char *z_name, cs_flag_t loc_flag, cs_dof_func_t *func, void *input)
 Add a new source term by initializing a cs_xdef_t structure. Case of a definition by a DoF function. More...
cs_xdef_t * cs_equation_add_source_term_by_array (cs_equation_param_t *eqp, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, bool full_length)
 Add a new source term by initializing a cs_xdef_t structure. Case of a definition by an array. More...
cs_xdef_t * cs_equation_add_volume_mass_injection_by_value (cs_equation_param_t *eqp, const char *z_name, double *val)
 Add a new volume mass injection definition source term by initializing a cs_xdef_t structure, using a constant value. More...
cs_xdef_t * cs_equation_add_volume_mass_injection_by_qov (cs_equation_param_t *eqp, const char *z_name, double *quantity)
 Add a new volume mass injection definition source term by initializing a cs_xdef_t structure, using a constant quantity distributed over the associated zone's volume. More...
cs_xdef_t * cs_equation_add_volume_mass_injection_by_analytic (cs_equation_param_t *eqp, const char *z_name, cs_analytic_func_t *func, void *input)
 Add a new volume mass injection definition source term by initializing a cs_xdef_t structure, using an analytical function. More...
cs_xdef_t * cs_equation_add_volume_mass_injection_by_dof_func (cs_equation_param_t *eqp, const char *z_name, cs_flag_t loc_flag, cs_dof_func_t *func, void *input)
 Add a new volume mass injection definition source term by initializing a cs_xdef_t structure, using a DoF function. More...
cs_xdef_t * cs_equation_add_volume_mass_injection_by_array (cs_equation_param_t *eqp, const char *z_name, cs_flag_t loc_flag, cs_real_t *array, bool is_owner, bool full_length)
 Add a new volume mass injection definition source term by initializing a cs_xdef_t structure, using an array. More...
cs_enforcement_param_t * cs_equation_add_vertex_dof_enforcement (cs_equation_param_t *eqp, cs_lnum_t n_vertices, const cs_lnum_t vertex_ids[], const cs_real_t ref_value[], const cs_real_t vtx_values[])
 Add an enforcement of the value of degrees of freedom located at the mesh vertices. The spatial discretization scheme for the given equation has to be CDO vertex-based or CDO vertex+cell-based schemes. More...
cs_enforcement_param_t * cs_equation_add_edge_dof_enforcement (cs_equation_param_t *eqp, cs_lnum_t n_edges, const cs_lnum_t edge_ids[], const cs_real_t ref_value[], const cs_real_t edge_values[])
 Add an enforcement of the value of degrees of freedom located at the mesh edges. The spatial discretization scheme for the given equation has to be CDO edge-based schemes. More...
cs_enforcement_param_t * cs_equation_add_face_dof_enforcement (cs_equation_param_t *eqp, cs_lnum_t n_faces, const cs_lnum_t face_ids[], const cs_real_t ref_value[], const cs_real_t face_values[])
 Add an enforcement of the value of degrees of freedom located at the mesh faces. The spatial discretization scheme for the given equation has to be CDO face-based schemes. More...
cs_enforcement_param_t * cs_equation_add_cell_enforcement (cs_equation_param_t *eqp, cs_lnum_t n_cells, const cs_lnum_t cell_ids[], const cs_real_t ref_value[], const cs_real_t cell_values[])
 Add an enforcement of the value related to the degrees of freedom associated to the list of selected cells. More...
cs_enforcement_param_t * cs_equation_add_or_replace_cell_enforcement (cs_equation_param_t *eqp, int enforcement_id, cs_lnum_t n_cells, const cs_lnum_t cell_ids[], const cs_real_t ref_value[], const cs_real_t cell_values[])
 Add a new enforcement if enforcement_id does not exist or replace it otherwise. Enforcement of the value related to the degrees of freedom associated to the list of selected cells. More...
void cs_equation_time_control_clear (cs_equation_param_t *eqp)
 Clear time_control data from the given equation param. More...
void cs_equation_time_control_add (cs_equation_param_t *eqp, cs_time_control_t *time_control, bool shallow_copy)
 Add a time control instance to an equation param structure. More...
void cs_equation_time_control_add_default (cs_equation_param_t *eqp)
 Add a time control instance to an equation param structure based on default values (hard copy). More...
static const cs_real_t _weak_pena_bc_coef_by_default = 1e2
static const cs_real_t _strong_pena_bc_coef_by_default = 1e12
static const char _err_empty_eqp []
◆ _find_or_add_ic()
static int _find_or_add_ic ( cs_equation_param_t *  eqp,
int  z_id
static
[in,out]eqppointer to a cs_equation_param_t structure
[in]z_idid related to a zone
the definition id
◆ _set_key()
static void _set_key ( cs_equation_param_t *  eqp,
const char *  keyval
static
[in]keykey related to the member of eq to set
[in]keyvalaccessor to the value to set
◆ cs_equation_add_advection()
void cs_equation_add_advection ( cs_equation_param_t *  eqp,
cs_adv_field_t *  adv_field
[in]adv_fieldpointer to a cs_adv_field_t structure
◆ cs_equation_add_advection_scaling_property()
void cs_equation_add_advection_scaling_property ( cs_equation_param_t *  eqp,
cs_property_t *  property
[in]propertypointer to a cs_property_t structure
◆ cs_equation_add_bc_by_analytic()
cs_xdef_t * cs_equation_add_bc_by_analytic ( cs_equation_param_t *  eqp,
const char *  z_name,
cs_analytic_func_t *  analytic,
void *  input
[in]bc_typetype of boundary condition to add
[in]z_namename of the associated zone (if nullptr or "" if all cells are considered)
[in]analyticpointer to an analytic function defining the value
[in]inputnullptr or pointer to a structure cast on-the-fly
a pointer to the new cs_xdef_t structure
◆ cs_equation_add_bc_by_array()
cs_xdef_t * cs_equation_add_bc_by_array ( cs_equation_param_t *  eqp,
cs_flag_t  loc,
cs_real_t *  array,
bool  is_owner,
bool  full_length
[in]z_namename of the related boundary zone
[in]locinformation to know where are located values
[in]arraypointer to an array
[in]is_ownertransfer the lifecycle to the cs_xdef_t struct. (true or false)
[in]full_lengthif true, size of "array" should be allocated to the total numbers of entities related to the given location. If false, a new list is allocated and filled with the related subset indirection.
a pointer to the new allocated cs_xdef_t structure
◆ cs_equation_add_bc_by_dof_func()
cs_xdef_t * cs_equation_add_bc_by_dof_func ( cs_equation_param_t *  eqp,
cs_flag_t  loc_flag,
cs_dof_func_t *  func,
void *  input
[in]loc_flaglocation where values are computed
[in]funcpointer to cs_dof_func_t function
◆ cs_equation_add_bc_by_field()
cs_xdef_t * cs_equation_add_bc_by_field ( cs_equation_param_t *  eqp,
cs_field_t *  field
[in]fieldpointer to a cs_field_t structure
◆ cs_equation_add_bc_by_time_func()
cs_xdef_t * cs_equation_add_bc_by_time_func ( cs_equation_param_t *  eqp,
cs_time_func_t *  t_func,
void *  input
[in]t_funcpointer to an analytic function defining the value
◆ cs_equation_add_bc_by_value()
cs_xdef_t * cs_equation_add_bc_by_value ( cs_equation_param_t *  eqp,
cs_real_t *  values
[in]valuespointer to a array storing the values
◆ cs_equation_add_cell_enforcement()
cs_enforcement_param_t * cs_equation_add_cell_enforcement ( cs_equation_param_t *  eqp,
cs_lnum_t  n_cells,
One assumes that values are interlaced if eqp->dim > 1 ref_value or elt_values has to be defined. If both parameters are defined, one keeps the definition in elt_values
[in]n_cellsnumber of selected cells
[in]cell_idslist of cell ids
[in]ref_valueignored if nullptr
[in]cell_valueslist of associated values, ignored if nullptr
a pointer to a cs_enforcement_param_t structure
◆ cs_equation_add_curlcurl()
void cs_equation_add_curlcurl ( cs_equation_param_t *  eqp,
cs_property_t *  property,
int  inversion
[in]inversion> 0: true, false otherwise
◆ cs_equation_add_diffusion()
void cs_equation_add_diffusion ( cs_equation_param_t *  eqp,
◆ cs_equation_add_edge_dof_enforcement()
cs_enforcement_param_t * cs_equation_add_edge_dof_enforcement ( cs_equation_param_t *  eqp,
cs_lnum_t  n_edges,
[in]n_edgesnumber of edges to enforce
[in]edge_idslist of edges
[in]ref_valuedefault values or ignored (may be nullptr)
[in]edge_valueslist of associated values, ignored if nullptr
◆ cs_equation_add_face_dof_enforcement()
cs_enforcement_param_t * cs_equation_add_face_dof_enforcement ( cs_equation_param_t *  eqp,
cs_lnum_t  n_faces,
[in]n_facesnumber of faces to enforce
[in]face_idslist of faces
[in]face_valueslist of associated values, ignored if nullptr
◆ cs_equation_add_graddiv()
void cs_equation_add_graddiv ( cs_equation_param_t *  eqp,
◆ cs_equation_add_ic_by_analytic()
cs_xdef_t * cs_equation_add_ic_by_analytic ( cs_equation_param_t *  eqp,
void *  input
[in]z_namename of the associated zone (if null or "" if all cells are considered)
[in]inputnull or pointer to a structure cast on-the-fly
◆ cs_equation_add_ic_by_dof_func()
cs_xdef_t * cs_equation_add_ic_by_dof_func ( cs_equation_param_t *  eqp,
cs_flag_t  loc_flag,
void *  input
[in]loc_flagwhere information is computed
[in]funcpointer to a DoF function
◆ cs_equation_add_ic_by_qov()
cs_xdef_t * cs_equation_add_ic_by_qov ( cs_equation_param_t *  eqp,
double  quantity
[in]z_namename of the associated zone (if null or "" all cells are considered)
[in]quantityquantity to distribute over the mesh location
◆ cs_equation_add_ic_by_value()
cs_xdef_t * cs_equation_add_ic_by_value ( cs_equation_param_t *  eqp,
cs_real_t *  val
[in]valpointer to the value
◆ cs_equation_add_or_replace_cell_enforcement()
cs_enforcement_param_t * cs_equation_add_or_replace_cell_enforcement ( cs_equation_param_t *  eqp,
int  enforcement_id,
cs_lnum_t  n_cells,
[in]enforcement_idid of the enforcement to handle
◆ cs_equation_add_reaction()
int cs_equation_add_reaction ( cs_equation_param_t *  eqp,
the id related to the reaction term
◆ cs_equation_add_sliding_condition()
void cs_equation_add_sliding_condition ( cs_equation_param_t *  eqp,
const char *  z_name
◆ cs_equation_add_source_term_by_analytic()
cs_xdef_t * cs_equation_add_source_term_by_analytic ( cs_equation_param_t *  eqp,
cs_analytic_func_t *  func,
void *  input
[in]funcpointer to an analytical function
◆ cs_equation_add_source_term_by_array()
cs_xdef_t * cs_equation_add_source_term_by_array ( cs_equation_param_t *  eqp,
cs_flag_t  loc,
cs_real_t *  array,
bool  is_owner,
bool  full_length
[in]full_lengthif true, the size of "array" should be allocated to the total numbers of entities related to the given location. If false, a new list is allocated and filled with the related subset indirection.
◆ cs_equation_add_source_term_by_dof_func()
cs_xdef_t * cs_equation_add_source_term_by_dof_func ( cs_equation_param_t *  eqp,
cs_flag_t  loc_flag,
void *  input
[in]loc_flaglocation of element ids given as parameter
◆ cs_equation_add_source_term_by_val()
cs_xdef_t * cs_equation_add_source_term_by_val ( cs_equation_param_t *  eqp,
cs_real_t *  val
[in]z_namename of the associated zone (if nullptr or "" all cells are considered)
[in]valvalue to set
◆ cs_equation_add_time()
void cs_equation_add_time ( cs_equation_param_t *  eqp,
◆ cs_equation_add_vertex_dof_enforcement()
cs_enforcement_param_t * cs_equation_add_vertex_dof_enforcement ( cs_equation_param_t *  eqp,
[in]n_verticesnumber of vertices to enforce
[in]vertex_idslist of vertices
[in]vtx_valueslist of associated values, ignored if nullptr
◆ cs_equation_add_volume_mass_injection_by_analytic()
cs_xdef_t * cs_equation_add_volume_mass_injection_by_analytic ( cs_equation_param_t *  eqp,
void *  input
◆ cs_equation_add_volume_mass_injection_by_array()
cs_xdef_t * cs_equation_add_volume_mass_injection_by_array ( cs_equation_param_t *  eqp,
cs_flag_t  loc_flag,
cs_real_t *  array,
bool  is_owner,
bool  full_length
◆ cs_equation_add_volume_mass_injection_by_dof_func()
cs_xdef_t * cs_equation_add_volume_mass_injection_by_dof_func ( cs_equation_param_t *  eqp,
cs_flag_t  loc_flag,
void *  input
◆ cs_equation_add_volume_mass_injection_by_qov()
cs_xdef_t * cs_equation_add_volume_mass_injection_by_qov ( cs_equation_param_t *  eqp,
double *  quantity
[in]quantitypointer to quantity to distribute over the zone
◆ cs_equation_add_volume_mass_injection_by_value()
cs_xdef_t * cs_equation_add_volume_mass_injection_by_value ( cs_equation_param_t *  eqp,
double *  val
◆ cs_equation_add_xdef_bc()
void cs_equation_add_xdef_bc ( cs_equation_param_t *  eqp,
cs_xdef_t *  xdef
[in]xdefpointer to the cs_xdef_t structure to transfer
◆ cs_equation_find_bc()
cs_xdef_t * cs_equation_find_bc ( cs_equation_param_t *  eqp,
const char *  z_name
a pointer to the cs_xdef_t structure if present, or nullptr
◆ cs_equation_param_clear()
void cs_equation_param_clear ( cs_equation_param_t *  eqp)
The cs_equation_param_t structure itself is not freed, but all its sub-structures are freed.
This is useful for equation parameters which are accessed through field keywords.
◆ cs_equation_param_copy_bc()
void cs_equation_param_copy_bc ( const cs_equation_param_t *  ref,
cs_equation_param_t *  dst
[in]refpointer to the reference cs_equation_param_t
[in,out]dstpointer to the cs_equation_param_t to update
◆ cs_equation_param_copy_from()
void cs_equation_param_copy_from ( const cs_equation_param_t *  ref,
cs_equation_param_t *  dst,
bool  copy_fld_id
[in]copy_fld_idcopy also the field id or not
◆ cs_equation_param_create()
cs_equation_param_t * cs_equation_param_create ( const char *  name,
int  dim,
[in]namename of the equation
[in]typetype of equation
[in]dimdim of the variable associated to this equation
[in]default_bctype of boundary condition set by default
a pointer to a new allocated cs_equation_param_t structure
◆ cs_equation_param_ensure_consistent_settings()
void cs_equation_param_ensure_consistent_settings ( cs_equation_param_t *  eqp)
◆ cs_equation_param_free()
cs_equation_param_t * cs_equation_param_free ( cs_equation_param_t *  eqp)
a null pointer
◆ cs_equation_param_get_saddle_param()
cs_param_saddle_t * cs_equation_param_get_saddle_param ( cs_equation_param_t *  eqp)
a pointer to a cs_param_saddle_t structure
◆ cs_equation_param_get_sles_param()
cs_param_sles_t * cs_equation_param_get_sles_param ( cs_equation_param_t *  eqp)
a pointer to a cs_param_sles_t structure
◆ cs_equation_param_has_robin_bc()
bool cs_equation_param_has_robin_bc ( const cs_equation_param_t *  eqp)
true or false
◆ cs_equation_param_lock_settings()
void cs_equation_param_lock_settings ( cs_equation_param_t *  eqp)
◆ cs_equation_param_log()
void cs_equation_param_log ( const cs_equation_param_t *  eqp)
◆ cs_equation_param_set()
void cs_equation_param_set ( cs_equation_param_t *  eqp,
const char *  keyval
◆ cs_equation_param_set_quadrature_to_all()
void cs_equation_param_set_quadrature_to_all ( cs_equation_param_t *  eqp,
If the default quadrature has been modified by the code, this function set the value of the quadrture to the given parameter whatever was the previous value.
To get a more detailed control of the quadrature rule, please consider the function cs_xdef_set_quadrature
[in]qtypetype of quadrature to apply
◆ cs_equation_param_set_sles()
void cs_equation_param_set_sles ( cs_equation_param_t *  eqp)
◆ cs_equation_param_unlock_settings()
void cs_equation_param_unlock_settings ( cs_equation_param_t *  eqp)
◆ cs_equation_remove_bc()
void cs_equation_remove_bc ( cs_equation_param_t *  eqp,
const char *  z_name
If no matching boundary condition is found, the function returns silently.
◆ cs_equation_remove_ic()
void cs_equation_remove_ic ( cs_equation_param_t *  eqp,
const char *  z_name
◆ cs_equation_time_control_add()
void cs_equation_time_control_add ( cs_equation_param_t *  eqp,
cs_time_control_t *  time_control,
bool  shallow_copy
[in]eqppointer to equation param structure
[in]time_controlpointer to cs_time_control to add.
[in]shallow_copyshould the addition be only a shallow copy (pointer) or a real copy (data copy).
◆ cs_equation_time_control_add_default()
void cs_equation_time_control_add_default ( cs_equation_param_t *  eqp)
◆ cs_equation_time_control_clear()
void cs_equation_time_control_clear ( cs_equation_param_t *  eqp)
[in,out]eqpEquation param instance
◆ _err_empty_eqp
const char _err_empty_eqp[]
static
Initial value:
N_(" Stop setting an empty cs_equation_param_t structure.\n"
" Please check your settings.\n")
#define N_(String)
Definition: cs_defs.h:62
◆ _strong_pena_bc_coef_by_default
static
◆ _weak_pena_bc_coef_by_default
static
