cs_multigrid.cpp File Reference
#include <limits.h>
#include <stdarg.h>
#include <mpi.h>
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "base/cs_base.h"
#include "base/cs_base_accel.h"
#include "alge/cs_blas.h"
#include "base/cs_dispatch.h"
#include "base/cs_file.h"
#include "alge/cs_grid.h"
#include "alge/cs_grid_priv.h"
#include "base/cs_halo.h"
#include "base/cs_log.h"
#include "base/cs_math.h"
#include "alge/cs_matrix.h"
#include "alge/cs_matrix_default.h"
#include "alge/cs_matrix_util.h"
#include "base/cs_mem.h"
#include "mesh/cs_mesh.h"
#include "alge/cs_multigrid_smoother.h"
#include "base/cs_post.h"
#include "alge/cs_sles.h"
#include "alge/cs_sles_it.h"
#include "alge/cs_sles_pc.h"
#include "base/cs_timer.h"
#include "base/cs_timer_stats.h"
#include "base/cs_time_plot.h"
#include "base/cs_tree.h"
#include "alge/cs_multigrid.h"
+ Include dependency graph for cs_multigrid.cpp:
void cs_multigrid_initialize (void)
 Initialize multigrid solver API. More...
void cs_multigrid_finalize (void)
 Finalize multigrid solver API. More...
void cs_multigrid_set_max_grid_level_for_device (int level)
 Set maximum grid level which should run on device (i.e. GPU). More...
cs_multigrid_t * cs_multigrid_define (int f_id, const char *name, cs_multigrid_type_t mg_type)
 Define and associate a multigrid sparse linear system solver for a given field or equation name. More...
cs_multigrid_t * cs_multigrid_create (cs_multigrid_type_t mg_type, cs_tree_node_t *config)
 Create multigrid linear system solver info and context. More...
void cs_multigrid_destroy (void **context)
 Destroy multigrid linear system solver info and context. More...
void * cs_multigrid_copy (const void *context)
 Create multigrid sparse linear system solver info and context based on existing info and context. More...
cs_tree_node_t * cs_multigrid_get_config (cs_multigrid_t *mg)
 Access multigrid solver configuration dictionnary. More...
void cs_multigrid_log (const void *context, cs_log_t log_type)
 Log multigrid solver info. More...
void cs_multigrid_set_conv_diff (cs_multigrid_t *mg, bool conv_diff)
void cs_multigrid_set_coarsening_options (cs_multigrid_t *mg, int aggregation_limit, cs_grid_coarsening_t coarsening_type, int n_max_levels, cs_gnum_t min_g_rows, double p0p1_relax, int postprocess_block_size)
 Set multigrid coarsening parameters. More...
void cs_multigrid_set_coarsening_options_fine_grid (cs_multigrid_t *mg, int f_settings_threshold, int aggregation_limit, cs_grid_coarsening_t coarsening_type)
 Set specific multigrid coarsening parameters for fine grids. More...
void cs_multigrid_set_solver_options (cs_multigrid_t *mg, cs_sles_it_type_t descent_smoother_type, cs_sles_it_type_t ascent_smoother_type, cs_sles_it_type_t coarse_solver_type, int n_max_cycles, int n_max_iter_descent, int n_max_iter_ascent, int n_max_iter_coarse, int poly_degree_descent, int poly_degree_ascent, int poly_degree_coarse, double precision_mult_descent, double precision_mult_ascent, double precision_mult_coarse)
 Set multigrid parameters for associated iterative solvers. More...
void cs_multigrid_set_solver_options_d (cs_multigrid_t *mg, cs_sles_it_type_t descent_smoother_type, cs_sles_it_type_t ascent_smoother_type, cs_sles_it_type_t coarse_solver_type, int n_max_iter_descent, int n_max_iter_ascent, int n_max_iter_coarse, int poly_degree_descent, int poly_degree_ascent, int poly_degree_coarse)
 Set multigrid device solver parameters for associated iterative solvers. More...
void cs_multigrid_set_max_cycles (cs_multigrid_t *mg, int n_max_cycles)
 Set the max. number of cycles for a multigrid. More...
bool cs_multigrid_need_msr (const cs_multigrid_t *mg)
 Indicate if a multigrid solver requires an MSR matrix input. More...
void cs_multigrid_setup (void *context, const char *name, const cs_matrix_t *a, int verbosity)
 Setup multigrid sparse linear equation solver. More...
cs_sles_convergence_state_t cs_multigrid_solve (void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residual, const cs_real_t *rhs, cs_real_t *vx_ini, cs_real_t *vx, size_t aux_size, void *aux_vectors)
 Call multigrid sparse linear equation solver. More...
void cs_multigrid_free (void *context)
 Free multigrid sparse linear equation solver setup context. More...
cs_sles_pc_t * cs_multigrid_pc_create (cs_multigrid_type_t mg_type)
 Create a multigrid preconditioner. More...
cs_sles_pc_t * cs_multigrid_pc_create (cs_tree_node_t *config)
bool cs_multigrid_error_post_and_abort (cs_sles_t *sles, cs_sles_convergence_state_t state, const cs_matrix_t *a, const cs_real_t rhs[], cs_real_t vx[])
 Error handler for multigrid sparse linear equation solver. More...
void cs_multigrid_set_plot_options (cs_multigrid_t *mg, const char *base_name, bool use_iteration)
 Set plotting options for multigrid. More...
void cs_multigrid_get_merge_options (const cs_multigrid_t *mg, int *rank_stride, int *rows_mean_threshold, cs_gnum_t *rows_glob_threshold)
 Query the global multigrid parameters for parallel grid merging. More...
void cs_multigrid_set_merge_options (cs_multigrid_t *mg, int rank_stride, int rows_mean_threshold, cs_gnum_t rows_glob_threshold)
 Set global multigrid parameters for parallel grid merging behavior. More...
void cs_multigrid_get_merge_bottom_options (const cs_multigrid_t *mg, int *n_max_ranks, float *max_row_factor)
void cs_multigrid_set_merge_bottom_options (cs_multigrid_t *mg, int n_max_ranks, float max_row_factor)
◆ cs_multigrid_copy()
void * cs_multigrid_copy ( const void *  context)
Note that the configuration dictionnary remains shared with the copied context.
[in]contextpointer to reference info and context (actual type: cs_multigrid_t *)
pointer to newly created solver info object (actual type: cs_multigrid_t *)
◆ cs_multigrid_create()
cs_multigrid_t * cs_multigrid_create ( cs_multigrid_type_t  mg_type,
cs_tree_node_t *  config
The multigrid variant is an ACM (Additive Corrective Multigrid) method.
[in]mg_typetype of multigrid algorithm to use
[in]configconfiguration dictionary node, or null
pointer to new multigrid info and context
◆ cs_multigrid_define()
cs_multigrid_t * cs_multigrid_define ( int  f_id,
const char *  name,
This is a utility function: if finer control is needed, see cs_sles_define and cs_multigrid_create.
Note that this function returns a pointer directly to the multigrid solver management structure. This may be used to set further options, for example calling cs_multigrid_set_coarsening_options and cs_multigrid_set_solver_options. If needed, cs_sles_find may be used to obtain a pointer to the matching cs_sles_t container.
[in]nameassociated name if f_id < 0, or nullptr
◆ cs_multigrid_destroy()
void cs_multigrid_destroy ( void **  context)
[in,out]contextpointer to multigrid linear solver info (actual type: cs_multigrid_t **)
◆ cs_multigrid_error_post_and_abort()
bool cs_multigrid_error_post_and_abort ( cs_sles_t *  sles,
const cs_matrix_t *  a,
cs_real_t  vx[]
In case of divergence or breakdown, this error handler outputs postprocessing data to assist debugging, then aborts the run. It does nothing in case the maximum iteration count is reached.
[in,out]slespointer to solver object
[in]stateconvergence state
[in]amatrix
[in]rhsright hand side
[in,out]vxsystem solution
false (do not attempt new solve)
◆ cs_multigrid_finalize()
void cs_multigrid_finalize ( void  )
◆ cs_multigrid_free()
void cs_multigrid_free ( void *  context)
This function frees resolution-related data, incuding the current grid hierarchy, but does not free the whole context, as info used for logging (especially performance data) is maintained.
[in,out]contextpointer to multigrid solver info and context (actual type: cs_multigrid_t *)
◆ cs_multigrid_get_config()
cs_tree_node_t * cs_multigrid_get_config ( cs_multigrid_t *  mg)
[in,out]mgpointer to multigrid info and context
pointer to configuration dictionnary node
◆ cs_multigrid_get_merge_bottom_options()
void cs_multigrid_get_merge_bottom_options ( const cs_multigrid_t *  mg,
int *  n_max_ranks,
float *  max_row_factor
[in]mgpointer to multigrid info and context
[out]n_max_ranksmaximum number of MPI ranks for bottom grid
[out]max_row_factormaximum acceptable mean ratio of merged rows (per MPI rank) to finest rows.
◆ cs_multigrid_get_merge_options()
void cs_multigrid_get_merge_options ( const cs_multigrid_t *  mg,
int *  rank_stride,
int *  rows_mean_threshold,
cs_gnum_t *  rows_glob_threshold
[out]rank_stridenumber of ranks over which merging takes place, or nullptr
[out]rows_mean_thresholdmean number of rows under which merging should be applied, or nullptr
[out]rows_glob_thresholdglobal number of rows under which merging should be applied, or nullptr
◆ cs_multigrid_initialize()
void cs_multigrid_initialize ( void  )
◆ cs_multigrid_log()
void cs_multigrid_log ( const void *  context,
cs_log_t  log_type
[in]contextpointer to iterative solver info and context (actual type: cs_multigrid_t *)
[in]log_typelog type
◆ cs_multigrid_need_msr()
bool cs_multigrid_need_msr ( const cs_multigrid_t *  mg)
true if MSR is needed, false otherwise.
◆ cs_multigrid_pc_create() [1/2]
cs_sles_pc_t * cs_multigrid_pc_create ( cs_multigrid_type_t  mg_type)
pointer to newly created preconditioner object.
◆ cs_multigrid_pc_create() [2/2]
cs_sles_pc_t * cs_multigrid_pc_create ( cs_tree_node_t *  config)
◆ cs_multigrid_set_coarsening_options()
void cs_multigrid_set_coarsening_options ( cs_multigrid_t *  mg,
int  n_max_levels,
double  p0p1_relax,
[in]aggregation_limitmaximum allowed fine rows per coarse row
[in]coarsening_typecoarsening type; see cs_grid_coarsening_t
[in]n_max_levelsmaximum number of grid levels
[in]min_g_rowsglobal number of rows on coarse grids under which no coarsening occurs
[in]p0p1_relaxp0/p1 relaxation_parameter
[in]postprocess_block_sizeif > 0, postprocess coarsening (uses coarse row numbers modulo this value)
◆ cs_multigrid_set_coarsening_options_fine_grid()
void cs_multigrid_set_coarsening_options_fine_grid ( cs_multigrid_t *  mg,
[in]f_settings_thresholdgrids of this level or higher use standard (coarse grid) settings.
◆ cs_multigrid_set_conv_diff()
void cs_multigrid_set_conv_diff ( cs_multigrid_t *  mg,
bool  conv_diff
◆ cs_multigrid_set_max_cycles()
void cs_multigrid_set_max_cycles ( cs_multigrid_t *  mg,
int  n_max_cycles
[in]n_max_cyclesmaximum number of cycles
◆ cs_multigrid_set_max_grid_level_for_device()
void cs_multigrid_set_max_grid_level_for_device ( int  level)
◆ cs_multigrid_set_merge_bottom_options()
void cs_multigrid_set_merge_bottom_options ( cs_multigrid_t *  mg,
int  n_max_ranks,
[in]n_max_ranksmaximum number of MPI ranks for bottom grid
[in]max_row_factormaximum acceptable mean ratio of merged rows (per MPI rank) to finest rows.
◆ cs_multigrid_set_merge_options()
void cs_multigrid_set_merge_options ( cs_multigrid_t *  mg,
int  rank_stride,
[in]rank_stridenumber of ranks over which merging takes place
[in]rows_mean_thresholdmean number of rows under which merging should be applied
[in]rows_glob_thresholdglobal number of rows under which merging should be applied
◆ cs_multigrid_set_plot_options()
void cs_multigrid_set_plot_options ( cs_multigrid_t *  mg,
const char *  base_name,
bool  use_iteration
[in]base_namebase plot name to activate, nullptr otherwise
[in]use_iterationif true, use iteration as time stamp otherwise, use wall clock time
◆ cs_multigrid_set_solver_options()
void cs_multigrid_set_solver_options ( cs_multigrid_t *  mg,
int  n_max_cycles,
On a GPU, some parameters may be replaced by the closest GPU equivalents. For finer control, use cs_multigrid_set_solver_options_d after calling this function to modify parameters for solvers running on device.
[in]descent_smoother_typetype of smoother for descent
[in]ascent_smoother_typetype of smoother for ascent
[in]coarse_solver_typetype of solver for coarsest grid
[in]n_max_iter_descentmaximum iterations per descent smoothing
[in]n_max_iter_ascentmaximum iterations per ascent smoothing
[in]n_max_iter_coarsemaximum iterations per coarsest solution
[in]poly_degree_descentpreconditioning polynomial degree for descent phases (0: diagonal)
[in]poly_degree_ascentpreconditioning polynomial degree for ascent phases (0: diagonal)
[in]poly_degree_coarsepreconditioning polynomial degree for coarse solver (0: diagonal)
[in]precision_mult_descentprecision multiplier for descent smoothers (levels >= 1)
[in]precision_mult_ascentprecision multiplier for ascent smoothers
[in]precision_mult_coarseprecision multiplier for coarsest grid
◆ cs_multigrid_set_solver_options_d()
void cs_multigrid_set_solver_options_d ( cs_multigrid_t *  mg,
◆ cs_multigrid_setup()
void cs_multigrid_setup ( void *  context,
const char *  name,
int  verbosity
[in]namepointer to name of linear system
[in]aassociated matrix
[in]verbosityassociated verbosity
◆ cs_multigrid_solve()
cs_sles_convergence_state_t cs_multigrid_solve ( void *  context,
const char *  name,
int  verbosity,
double  precision,
double  r_norm,
int *  n_iter,
double *  residual,
const cs_real_t *  rhs,
cs_real_t *  vx_ini,
cs_real_t *  vx,
size_t  aux_size,
void *  aux_vectors
[in]amatrix
[in]precisionsolver precision
[in]r_normresidual normalization
[out]residualresidual
[in]vx_iniinitial system solution (vx if nonzero, nullptr if zero)
[in]aux_sizesize of aux_vectors (in bytes)
aux_vectorsoptional working area (internal allocation if nullptr)
convergence state
