cs_param_saddle.h File Reference
Handle the settings of saddle-point systems. These systems arise from the monolithic coupling of the Navier-Stokes equations or in mixed formulation of scalar-valued equations. More...
+ Include dependency graph for cs_param_saddle.h:
Classes
struct  cs_param_saddle_t
 Structure storing all metadata related to the resolution of a saddle-point linear system. A saddle-point system is depicted as. More...
struct  cs_param_saddle_context_alu_t
 Structure storing additional elements associated with the usage of the Augmented Lagrangian Uzawa (ALU) algorithm. More...
struct  cs_param_saddle_context_block_krylov_t
 Structure storing additional elements associated with the usage of block preconditioners with a Krylov solver. More...
struct  cs_param_saddle_context_gkb_t
 Structure storing additional elements associated with the usage of the Golub-Kahan Bidiagonalization (GKB) algorithm. More...
struct  cs_param_saddle_context_notay_t
 Structure storing additional elements associated with the usage of the Notay's algebraic transformation. More...
struct  cs_param_saddle_context_uzacg_t
 Structure storing additional elements associated with the usage of the Uzawa-CG algorithm (an Uzawa algorithm accelerated with a Conjugate Gradient algorithm) More...
struct  cs_param_saddle_context_simple_t
 Structure storing additional elements associated with the usage of the Algebraic Fractional Step methods (AFS) including SIMPLE-like algorithm. More...
Enumerations
enum  cs_param_saddle_precond_t {
  CS_PARAM_SADDLE_PRECOND_NONE , CS_PARAM_SADDLE_PRECOND_AFS , CS_PARAM_SADDLE_PRECOND_DIAG , CS_PARAM_SADDLE_PRECOND_LOWER ,
  CS_PARAM_SADDLE_PRECOND_SGS , CS_PARAM_SADDLE_PRECOND_UPPER , CS_PARAM_SADDLE_PRECOND_UZAWA , CS_PARAM_SADDLE_N_PRECOND
 Type of preconditioner used to solve a saddle-point system. Up to now, this happens only in two cases: (1) with CDO cell-based schemes and (2) with the Stokes or Navier-Stokes equations with CDO face-based schemes and a monolithic approach (fully coupled) velocity-pressure coupling. More...
enum  cs_param_saddle_solver_t {
  CS_PARAM_SADDLE_SOLVER_NONE , CS_PARAM_SADDLE_SOLVER_ALU , CS_PARAM_SADDLE_SOLVER_AFS , CS_PARAM_SADDLE_SOLVER_FGMRES ,
  CS_PARAM_SADDLE_SOLVER_GCR , CS_PARAM_SADDLE_SOLVER_GKB , CS_PARAM_SADDLE_SOLVER_MINRES , CS_PARAM_SADDLE_SOLVER_MUMPS ,
  CS_PARAM_SADDLE_SOLVER_NOTAY_TRANSFORM , CS_PARAM_SADDLE_SOLVER_SIMPLE , CS_PARAM_SADDLE_SOLVER_UZAWA_CG , CS_PARAM_SADDLE_N_SOLVERS
 Type of solver used to solve a saddle-point system. Up to now, this happens only with CDO cell-based schemes or when solving the fully coupled Navier-Stokes system (monolithic) with CDO face-based schemes. A saddle-point system is an indefinite system. More...
enum  cs_param_saddle_schur_approx_t {
  CS_PARAM_SADDLE_SCHUR_NONE , CS_PARAM_SADDLE_SCHUR_DIAG_INVERSE , CS_PARAM_SADDLE_SCHUR_IDENTITY , CS_PARAM_SADDLE_SCHUR_LUMPED_INVERSE ,
  CS_PARAM_SADDLE_SCHUR_MASS_SCALED , CS_PARAM_SADDLE_SCHUR_MASS_SCALED_DIAG_INVERSE , CS_PARAM_SADDLE_SCHUR_MASS_SCALED_LUMPED_INVERSE , CS_PARAM_SADDLE_N_SCHUR_APPROX
 Strategy to build the Schur complement approximation. This appears in block preconditioning or Uzawa algorithms when a fully coupled (also called monolithic) approach) is used. More...
void cs_param_saddle_set_restart_range (cs_param_saddle_t *saddlep, int restart_range)
 Set the number of iterations to store before starting a Krylov solver. More...
void cs_param_saddle_set_notay_scaling (cs_param_saddle_t *saddlep, double scaling_coef)
 Set the scaling coefficient used in the Notay's transformation devised in "Algebraic multigrid for Stokes equations" SIAM J. Sci. Comput. Vol. 39 (5), 2017 In this article, this scaling is denoted by alpha. More...
void cs_param_saddle_set_simple_relaxation_scaling (cs_param_saddle_t *saddlep, const double scaling_coef)
 Set the scaling coefficient used in the AFS/SIMPLE-like method devised in "SIMPLE-like preconditioners for saddle point problems from the steady Navier–Stokes equations", J. Comput. Appl. Vol. 302,2016, In this article, this scaling is denoted by alpha. More...
void cs_param_saddle_set_augmentation_coef (cs_param_saddle_t *saddlep, double coef)
 Set the scaling in front of the augmentation term when an ALU, a GKB or a block Krylov algorithm is considered. More...
double cs_param_saddle_get_augmentation_coef (const cs_param_saddle_t *saddlep)
 Get the scaling coefficient in front of the augmentation term when an ALU, GKB or block Krylov algorithm is considered. More...
const char * cs_param_saddle_get_type_name (cs_param_saddle_solver_t type)
 Retrieve the name of the type of saddle-point solver. More...
cs_param_saddle_t * cs_param_saddle_create (void)
 Create a cs_param_saddle_t structure No solver is set by default. More...
void cs_param_saddle_free (cs_param_saddle_t **p_saddlep)
 Free the structure storing the parameter settings for a saddle-point system. More...
const char * cs_param_saddle_get_name (const cs_param_saddle_t *saddlep)
 Retrieve the name of the saddle-point solver. More...
void cs_param_saddle_set_name (const char *name, cs_param_saddle_t *saddlep)
 Set the name of the saddle-point system. More...
void cs_param_saddle_set_block11_sles_param (cs_param_saddle_t *saddlep, const cs_param_sles_t *block11_slesp)
 Assign the cs_param_sles_t structure (shared) related to the (1,1)-block to the structure managing the resolution of the saddle-point problems. More...
int cs_param_saddle_set_precond (const char *keyval, cs_param_saddle_t *saddlep)
 Set the type of preconditioning to apply for this saddle-point system. More...
int cs_param_saddle_set_schur_approx (const char *keyval, cs_param_saddle_t *saddlep)
 Set the type of Schur approximation to apply to this saddle-point system. More...
int cs_param_saddle_set_solver_class (const char *keyval, cs_param_saddle_t *saddlep)
 Set the class of solver to apply for this saddle-point system. More...
int cs_param_saddle_set_solver (const char *keyval, cs_param_saddle_t *saddlep)
 Set the type of solver to apply for this saddle-point system. More...
void cs_param_saddle_try_init_schur_sles_param (cs_param_saddle_t *saddlep)
 Initialize a cs_param_sles_t structure for the Schur approximation nested inside a cs_param_saddle_t structure. By default, this member is not allocated. Do nothing if the related structure is already allocated. More...
cs_param_sles_t * cs_param_saddle_get_schur_sles_param (const cs_param_saddle_t *saddlep)
 Get the pointer to the set of parameters to handle a SLES. This SLES is associated to the approximation of the Schur complement. This is only useful for solving a saddle-point problem relying on an elaborated approximation of the Schur complement. More...
cs_param_sles_t * cs_param_saddle_get_xtra_sles_param (const cs_param_saddle_t *saddlep)
 Get the pointer to the set of parameters to handle a SLES. This SLES is associated to an extra-operation specific to a saddle-point solver It returns a non-null pointer only for some sadlle-point solver relying on a more elaborated Schur complement approximation. More...
cs_param_sles_t * cs_param_saddle_get_init_sles_param (const cs_param_saddle_t *saddlep)
 Get the pointer to the set of parameters to handle a SLES. This SLES is associated to the initial saddle-point problem. It returns a non null pointer only for some sadlle-point solver. More...
void cs_param_saddle_copy (const cs_param_saddle_t *ref, cs_param_saddle_t *dest)
 Copy a cs_param_saddle_t structure from ref to dest. More...
void cs_param_saddle_log (const cs_param_saddle_t *saddlep)
 Log the setup information for the given cs_param_saddle_t structure. More...
◆ cs_param_saddle_precond_t
Enumerator
No preconditioner to apply.
A block-diagonal preconditioner is used. The (1,1)-block is an approximation of the (1,1)-block in the saddle-point system based on a cheap resolution. The parameter settings for this resolution relies on the structure cs_param_sles_t. The (2,2)-block is approximated by the Schur approximation given (by default the identity).
A 2x2 block matrix is used as preconditioner with the (1,2)-block fills with zero. The (1,1)-block is an approximation of the (1,1)-block in the saddle-point system based on a cheap resolution. The parameter settings for this resolution relies on the structure cs_param_sles_t. The (2,2)-block is approximated by the Schur approximation given (by default the identity).
A symmetric Gauss-Seidel 2x2 block preconditioner is used. The (1,1)-block is an approximation of the (1,1)-block in the saddle-point system based on a cheap resolution. The parameter settings for this resolution relies on the structure cs_param_sles_t The (2,2)-block is approximated by the Schur approximation given (by default the identity).
A 2x2 block matrix is used as preconditioner with the (2,1)-block fills with zero. The (1,1)-block is an approximation of the (1,1)-block in the saddle-point system based on a cheap resolution. The parameter settings for this resolution relies on the structure cs_param_sles_t The (2,2)-block is approximated by the Schur approximation given (by default the identity).
An Uzawa-like 2x2 block preconditioner. One needs a Schur approximation.
◆ cs_param_saddle_schur_approx_t
\[ \begin{bmatrix} A&B^t\\ B&O  \end{bmatrix}\]
The exact Schur complement is then
\[ S = -B \cdot A^{-1} \cdot B \]
Enumerator
There is no Schur complement approximation.
The Schur complement approximation is defined as
\[ S \approx -B \cdot diag(A)^{-1} \cdot B^t \]
The Schur complement approximation is simply the identity matrix
\[ B \cdot lumped(A^{-1}) \cdot B^t \]
where $x=lumped(A^{-1})$ results from $A.x = \bf{1}$ ( $\bf{1}$ is the array fills with 1 in each entry)
The Schur complement approximation is simply a scaled diagonal mass matrix related to the (2,2)-block
\[ S \approx \alpha M_{22} + \frac{1}{dt} B.diag(A)^{-1}.B^t \]
where $M_{22}$ is the mass matrix related to the (2,2)-block
\[ S \approx \alpha \cdot M_{22} + \frac{1}{dt} B\cdot lumped(A^{-1})
 \cdot B^t \]
where $ M_{22} $ is the mass matrix related to the (2,2) block and where $x=lumped(A^{-1})$ results from $A.x = \bf{1}$ ( $\bf{1}$ is the array fills with 1 in each entry)
◆ cs_param_saddle_solver_t
Enumerator
No solver defined. No saddle-point to solve.
In-house solver based on the Uzawa algorithm with an Augmented Lagrangian acceleration. In this case, one has to specify the scaling coefficient for the augmented system (in the current case, a grad-div operator)
AFS means Algebraic Fractional Step. It corresponds to an algebraic reformulation of classical fractional step methods. This follows the work of Bonelle and Ma (see HAL preprint online)
Flexible variant of the GMRES Krylov iterative solver. This solver can be applied to a general indefinite systems. Up to now, this solver can be called only through the PETSc library.
GCR = Genreralized Conjugate Residual. This iterative solver can be applied to a general indefinite systems. It relies on a specific storage of the saddle-point system: (1,1)-block is assembled and the (2,1)-block is unassembled. The (1,2) is not stored since this is the transposition of the (2,1)-block. This solver is an in-house version of the Notay's variant for the GCR. One can specify the solver for the (1,1)-block preconditioner and also the type of Schur approximation for the (2,2)-block.
GKB = Golub-Kahan bi-diagonalization. This solver can be applied to a symmetrice saddle-point system (or very slightly unsymmetric system). The stopping crietrion is different from the other solvers since it relies on an approximation of the residual in the energy norm (evaluation on-the-fly). This solver is available throught PETSc or directly with code_saturne. Moreover, one can add an augmentation term as in the ALU algorithm.
MinRes = Minimal Residual algorithm. This iterative solver can be applied to an indefinite symmetric systems. This is like a CG solver for symmetric saddle-point systems. This solver relies on a specific storage of the saddle-point system: (1,1)-block is assembled and the (2,1)-block is unassembled. The (1,2) is not stored since this the transposition of the (2,1)-block. One can specify the solver for the (1,1)-block preconditioner and also the type of Schur approximation for the (2,2)-block.
Sparse direct solver based on the external library called MUMPS. This iterative solver can be applied to a general indefinite systems. Be careful that according to the boundary conditions. The pressure can be defined up to a constant. In this situation, MUMPS can breakdown since there is a non empty kernel.
Transform the saddle-point problem into an equivalent system without a zero block for the (2,2) block. This transformation allows one to consider standard preconditionner and iterative Krylov solver. This is an experimental feature (only tested in sequential run)
Resolution using an uzawa algorithm optimized using a conjugate gradient reformulation. Two systems are solved at each iteration (one related to the velocity block, one related to the Schur complement approximation - size of the pressure space). The first one is specified using the cs_sles_param_t structure related to the (1,1)-block and the second system is specified using the cs_sles_param_t structure related to the Schur approximation.
◆ cs_param_saddle_copy()
void cs_param_saddle_copy ( const cs_param_saddle_t *  ref,
cs_param_saddle_t *  dest
[in]refreference structure to be copied
[in,out]destdestination structure
◆ cs_param_saddle_create()
cs_param_saddle_t * cs_param_saddle_create ( void  )
a pointer to the new cs_param_saddle_t structure
◆ cs_param_saddle_free()
void cs_param_saddle_free ( cs_param_saddle_t **  p_saddlep)
[in,out]p_saddlepdouble pointer to the structure to free
◆ cs_param_saddle_get_augmentation_coef()
double cs_param_saddle_get_augmentation_coef ( const cs_param_saddle_t *  saddlep)
[in]saddlepset of parameters for solving a saddle-point
0 if not relevant or the value of the augmentation coefficient
◆ cs_param_saddle_get_init_sles_param()
cs_param_sles_t * cs_param_saddle_get_init_sles_param ( const cs_param_saddle_t *  saddlep)
[in]saddleppointer to a cs_param_saddle_t structure
a pointer to a cs_param_sles_t structure
◆ cs_param_saddle_get_name()
const char * cs_param_saddle_get_name ( const cs_param_saddle_t *  saddlep)
[in]saddleppointer to a set of saddle-point parameters
a string
◆ cs_param_saddle_get_schur_sles_param()
cs_param_sles_t * cs_param_saddle_get_schur_sles_param ( const cs_param_saddle_t *  saddlep)
◆ cs_param_saddle_get_type_name()
const char * cs_param_saddle_get_type_name ( cs_param_saddle_solver_t  type)
[in]typetype of saddle-point solver
a string
◆ cs_param_saddle_get_xtra_sles_param()
cs_param_sles_t * cs_param_saddle_get_xtra_sles_param ( const cs_param_saddle_t *  saddlep)
◆ cs_param_saddle_log()
void cs_param_saddle_log ( const cs_param_saddle_t *  saddlep)
[in]saddleppointer to the structure
◆ cs_param_saddle_set_augmentation_coef()
void cs_param_saddle_set_augmentation_coef ( cs_param_saddle_t *  saddlep,
double  coef
[in,out]saddlepset of parameters for solving a saddle-point
[in]coefvalue of the scaling coefficient
◆ cs_param_saddle_set_block11_sles_param()
void cs_param_saddle_set_block11_sles_param ( cs_param_saddle_t *  saddlep,
const cs_param_sles_t *  block11_slesp
[in,out]saddleppointer to the structure to update
[in]block11_slespset of parameters for the (1,1) block
◆ cs_param_saddle_set_name()
void cs_param_saddle_set_name ( const char *  name,
[in]namename associated to this saddle-point system
◆ cs_param_saddle_set_notay_scaling()
void cs_param_saddle_set_notay_scaling ( cs_param_saddle_t *  saddlep,
double  scaling_coef
[in]scaling_coefvalue of the scaling coefficient
◆ cs_param_saddle_set_precond()
int cs_param_saddle_set_precond ( const char *  keyval,
[in]keyvalvalue of the key for the preconditioner
0 if no error detected, > 0 otherwise
◆ cs_param_saddle_set_restart_range()
void cs_param_saddle_set_restart_range ( cs_param_saddle_t *  saddlep,
int  restart_range
[in]restart_rangenumber of directions
◆ cs_param_saddle_set_schur_approx()
int cs_param_saddle_set_schur_approx ( const char *  keyval,
[in]keyvalvalue of the key for the schur approx.
◆ cs_param_saddle_set_simple_relaxation_scaling()
void cs_param_saddle_set_simple_relaxation_scaling ( cs_param_saddle_t *  saddlep,
◆ cs_param_saddle_set_solver()
int cs_param_saddle_set_solver ( const char *  keyval,
◆ cs_param_saddle_set_solver_class()
int cs_param_saddle_set_solver_class ( const char *  keyval,
◆ cs_param_saddle_try_init_schur_sles_param()
void cs_param_saddle_try_init_schur_sles_param ( cs_param_saddle_t *  saddlep)
