cs_sles.cpp File Reference
Sparse linear equation solver driver. More...
#include <stdarg.h>
#include <mpi.h>
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "base/cs_array.h"
#include "base/cs_base.h"
#include "alge/cs_blas.h"
#include "base/cs_dispatch.h"
#include "base/cs_field.h"
#include "base/cs_log.h"
#include "base/cs_halo.h"
#include "base/cs_map.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "mesh/cs_mesh.h"
#include "alge/cs_matrix.h"
#include "alge/cs_matrix_default.h"
#include "alge/cs_matrix_util.h"
#include "base/cs_parall.h"
#include "base/cs_post.h"
#include "base/cs_timer.h"
#include "base/cs_timer_stats.h"
#include "alge/cs_sles.h"
+ Include dependency graph for cs_sles.cpp:
void cs_sles_set_epzero (double new_value)
 Set the threshold value used in the detection of immediate exit. More...
double cs_sles_get_epzero (void)
 Get the current threshold value used in the detection of immediate exit. More...
void cs_sles_initialize (void)
 Initialize sparse linear equation solver API. More...
void cs_sles_finalize (void)
 Finalize sparse linear equation solver API. More...
void cs_sles_log (cs_log_t log_type)
 Log sparse linear equation solver info. More...
cs_sles_t * cs_sles_find (int f_id, const char *name)
 Return pointer to linear system object, based on matching field id or system name. More...
cs_sles_t * cs_sles_find_or_add (int f_id, const char *name)
void cs_sles_push (int f_id, const char *name)
 Temporarily replace field id with name for matching calls to cs_sles_setup, cs_sles_solve, cs_sles_free, and other operations involving access through a field id. More...
void cs_sles_pop (int f_id)
 Restore behavior temporarily modified by cs_sles_push. More...
cs_sles_t * cs_sles_define (int f_id, const char *name, void *context, const char *type_name, cs_sles_setup_t *setup_func, cs_sles_solve_t *solve_func, cs_sles_free_t *free_func, cs_sles_log_t *log_func, cs_sles_copy_t *copy_func, cs_sles_destroy_t *destroy_func)
 Define sparse linear equation solver for a given field or equation name. More...
void cs_sles_set_verbosity (cs_sles_t *sles, int verbosity)
 Set the verbosity for a given linear equation solver. More...
int cs_sles_get_verbosity (cs_sles_t *sles)
 Get the verbosity for a given linear equation solver. More...
void cs_sles_set_post_output (cs_sles_t *sles, int writer_id)
 Activate postprocessing output for a given linear equation solver. More...
int cs_sles_get_post_output (cs_sles_t *sles)
 Return the id of the associated writer if postprocessing output is active for a given linear equation solver. More...
const char * cs_sles_get_type (cs_sles_t *sles)
 Return type name of solver context. More...
void * cs_sles_get_context (cs_sles_t *sles)
 Return pointer to solver context structure pointer. More...
int cs_sles_get_f_id (const cs_sles_t *sles)
 Return field id associated with a given sparse linear equation solver. More...
const char * cs_sles_get_name (const cs_sles_t *sles)
 Return name associated with a given sparse linear equation solver. More...
bool cs_sles_get_allow_no_op (const cs_sles_t *sles)
 Query if immediate_return ("no-op") is allowed when initial guess is zero (solve by increments) and the RHS is already zero within the normalized tolerance criteria. More...
void cs_sles_set_allow_no_op (cs_sles_t *sles, bool allow_no_op)
 Indicate if immediate_return ("no-op") is allowed when initial guess is zero (solve by increments) and the RHS is already zero within the normalized tolerance criteria. More...
void cs_sles_setup (cs_sles_t *sles, const cs_matrix_t *a)
 Setup sparse linear equation solver. More...
cs_sles_convergence_state_t cs_sles_solve (cs_sles_t *sles, const cs_matrix_t *a, double precision, double r_norm, bool vx_ini_0, int *n_iter, double *residual, const cs_real_t *rhs, cs_real_t *vx, size_t aux_size, void *aux_vectors)
 General sparse linear system resolution. More...
void cs_sles_free (cs_sles_t *sles)
 Free sparse linear equation solver setup. More...
int cs_sles_copy (cs_sles_t *dest, const cs_sles_t *src)
 Copy the definition of a sparse linear equation solver to another. More...
void cs_sles_set_error_handler (cs_sles_t *sles, cs_sles_error_handler_t *error_handler_func)
 Associate a convergence error handler to a given sparse linear equation solver. More...
cs_sles_define_t * cs_sles_get_default_define (void)
 Return pointer to default sparse linear solver definition function. More...
void cs_sles_set_default_define (cs_sles_define_t *define_func)
 Set default sparse linear solver definition function. More...
void cs_sles_set_default_verbosity (cs_sles_verbosity_t *verbosity_func)
 Set default verbosity definition function. More...
void cs_sles_post_error_output_def (const char *name, int mesh_id, const cs_matrix_t *a, const cs_real_t *rhs, cs_real_t *vx)
 Output default post-processing data for failed system convergence. More...
void cs_sles_post_output_var (const char *name, int mesh_id, int location_id, int writer_id, int diag_block_size, cs_real_t var[])
 Output post-processing variable related to system convergence. More...
const char * cs_sles_base_name (int f_id, const char *name)
 Return base name associated to a field id, name couple. More...
const char * cs_sles_name (int f_id, const char *name)
 Return name associated to a field id, name couple. More...
The Sparse Linear Equation Solver subsystem is designed to allow both simple usage of built-in solvers, and plugging of solvers from external libraries.
As the options associated with different solvers may be very varied, this subsystem is based on the use of a series of callback functions which may be associated with a given linear system (defined either by field id for quick and recurrent access, or by unique system name). It is possible to provide a default function so calls for the resolution of systems not specified before can be handled.
To summarize, the functions here define a linear system solver driver, with the real work being done by functions bound to this model. The main intent is to help manage passing varied user options to the solvers, and handling consistency of logging.
◆ cs_sles_base_name()
const char * cs_sles_base_name ( int  f_id,
const char *  name
This is simply a utility function which will return its name argument if f_id < 0, and the associated field's name otherwise.
[in]nameassociated name if f_id < 0, or nullptr
pointer to base name associated to the field id, name couple
◆ cs_sles_copy()
int cs_sles_copy ( cs_sles_t *  dest,
const cs_sles_t *  src
The intended use of this function is to allow associating different solvers to related systems, so as to differentiate logging, while using the same settings by default.
If the source solver does not provide a cs_sles_copy_t function, No modification is done to the solver. If the copy function is available, the context is copied, as are the matching function pointers.
If previous settings have been defined and used, they are saved as per cs_sles_define.
[in,out]destpointer to destination solver object
[in]srcpointer to source solver object
0 in case of success, 1 in case of failure
◆ cs_sles_define()
cs_sles_t * cs_sles_define ( int  f_id,
const char *  name,
void *  context,
const char *  type_name,
cs_sles_setup_t *  setup_func,
cs_sles_solve_t *  solve_func,
cs_sles_free_t *  free_func,
cs_sles_log_t *  log_func,
cs_sles_copy_t *  copy_func,
cs_sles_destroy_t *  destroy_func
If this system did not previously exist, it is added to the list of "known" systems.
The context pointer is used to point to a structure adapted to the function pointers given here, and combined with those functions, allows using both built-in, external, or user-defined solvers.
It is recommended the context type name provided here directly relate to the associated structure type (for example, "cs_sles_it_t" or "cs_multigrid_t").
[in,out]contextpointer to solver context management structure (cs_sles subsystem becomes owner)
[in]type_namecontext structure or object type name
[in]setup_funcpointer to system setup function
[in]solve_funcpointer to system solution function (also calls setup_func if not done yet or free_func called since last solve)
[in]free_funcpointer function freeing system setup
[in]log_funcpointer to system info logging function (optional, but recommended)
[in]copy_funcpointer to settings copy function (optional)
[in]destroy_funcpointer to function destroying solver context (called with cs_sles_finalize or with a new call to this function for the same system)
pointer to associated linear system object
◆ cs_sles_finalize()
void cs_sles_finalize ( void  )
◆ cs_sles_find()
cs_sles_t * cs_sles_find ( int  f_id,
const char *  name
If this system did not previously exist, a null pointer is returned.
pointer to associated linear system object, or nullptr
◆ cs_sles_find_or_add()
cs_sles_t * cs_sles_find_or_add ( int  f_id,
const char *  name
If this system did not previously exist, it is created and added to to the list of "known" systems. In this case, it will be usable only if cs_sles_define() is called for the same field id and name (in which case calling the present function is redundant), or if cs_sles_set_sefault_define() has been previously used to define the default solver policy.
◆ cs_sles_free()
void cs_sles_free ( cs_sles_t *  sles)
This function frees resolution-related data, such as multigrid hierarchy, preconditioning, and any other temporary arrays or objects required for resolution, but maintains context information such as that used for logging (especially performance data).
[in,out]slespointer to solver object
◆ cs_sles_get_allow_no_op()
bool cs_sles_get_allow_no_op ( const cs_sles_t *  sles)
[in]slespointer to solver object
true if immediate return is allowed, false if at least one iteration is required
◆ cs_sles_get_context()
void * cs_sles_get_context ( cs_sles_t *  sles)
The context structure depends on the type of solver used, which may in turn be determined by the string returned by cs_sles_get_type(). If may be used by appropriate functions specific to that type.
pointer to solver-specific linear system info and context
◆ cs_sles_get_default_define()
cs_sles_define_t * cs_sles_get_default_define ( void  )
The associated function will be used to provide a definition when cs_sles_setup or cs_sles_solve is used for a system for which no matching call to cs_sles_define has been done.
define_func pointer to default definition function
◆ cs_sles_get_epzero()
double cs_sles_get_epzero ( void  )
the value of the threshold
◆ cs_sles_get_f_id()
int cs_sles_get_f_id ( const cs_sles_t *  sles)
associated field id (or -1 if defined by name)
◆ cs_sles_get_name()
const char * cs_sles_get_name ( const cs_sles_t *  sles)
pointer to associated linear system object name
◆ cs_sles_get_post_output()
int cs_sles_get_post_output ( cs_sles_t *  sles)
id od associated writer, or 0
◆ cs_sles_get_type()
const char * cs_sles_get_type ( cs_sles_t *  sles)
The returned string is intended to help determine which type is associated with the void * pointer returned by cs_sles_get_context for a given solver definition, so as to be able to call additional specific functions beyond the generic functions assigned to a cs_sles_t object.
If no type_name string was associated to the solver upon its definition by cs_sles_define, or it has not been defined yet, the string returned is "<undefined>". It is recommended the type name provided cs_sles_define directly relate to the associated structure type (for example, "cs_sles_it_t" or "cs_multigrid_t").
pointer to linear system solver specific type name
◆ cs_sles_get_verbosity()
int cs_sles_get_verbosity ( cs_sles_t *  sles)
This verbosity will be used by cs_sles_setup and cs_sles_solve.
verbosity level
◆ cs_sles_initialize()
void cs_sles_initialize ( void  )
◆ cs_sles_log()
void cs_sles_log ( cs_log_t  log_type)
[in]log_typelog type (CS_LOG_SETUP or CS_LOG_PERFORMANCE)
◆ cs_sles_name()
const char * cs_sles_name ( int  f_id,
const char *  name
pointer to name associated to the field id, name couple
◆ cs_sles_pop()
void cs_sles_pop ( int  f_id)
Deprecated:
This function matches cs_sles_push, which is deprecated.
◆ cs_sles_post_error_output_def()
void cs_sles_post_error_output_def ( const char *  name,
int  mesh_id,
const cs_matrix_t *  a,
const cs_real_t *  rhs,
cs_real_t *  vx
[in]namevariable name
[in]mesh_idid of error output mesh, or 0 if none
[in]alinear equation matrix
[in]rhsright hand side
[in,out]vxcurrent system solution
◆ cs_sles_post_output_var()
void cs_sles_post_output_var ( const char *  name,
int  mesh_id,
int  location_id,
int  writer_id,
cs_real_t  var[]
[in]location_idmesh location id (cells or vertices)
[in]writer_idid of specified associated writer, or CS_POST_WRITER_ALL_ASSOCIATED for all
[in]diag_block_sizeblock size for diagonal
[in,out]varvariable values
◆ cs_sles_push()
void cs_sles_push ( int  f_id,
const char *  name
This function is provided to allow some peculiar calling sequences, in which cs_equation_iterative_solve_scalar is called with a given field id, but specific solver options must still be set. In the future, a cleaner method to handle those exceptional cases would be preferred. As such, only a stack depth of 1 is allowed.
◆ cs_sles_set_allow_no_op()
void cs_sles_set_allow_no_op ( cs_sles_t *  sles,
bool  allow_no_op
[in]allow_no_optrue if immediate return is allowed, false if at least one iteration is required
◆ cs_sles_set_default_define()
void cs_sles_set_default_define ( cs_sles_define_t *  define_func)
The provided function will be used to provide a definition when cs_sles_setup or cs_sles_solve is used for a system for which no matching call to cs_sles_define has been done.
[in]define_funcpointer to default definition function
◆ cs_sles_set_default_verbosity()
void cs_sles_set_default_verbosity ( cs_sles_verbosity_t *  verbosity_func)
The provided function will be used to define the verbosity when cs_sles_find_or_add is called.
[in]verbosity_funcpointer to default verbosity function
◆ cs_sles_set_epzero()
void cs_sles_set_epzero ( double  new_value)
◆ cs_sles_set_error_handler()
void cs_sles_set_error_handler ( cs_sles_t *  sles,
cs_sles_error_handler_t *  error_handler_func
The error will be called whenever convergence fails. To dissassociate the error handler, this function may be called with handler = nullptr.
The association will only be successful if the matching solver has already been defined.
[in]error_handler_funcpointer to convergence error handler function
◆ cs_sles_set_post_output()
void cs_sles_set_post_output ( cs_sles_t *  sles,
int  writer_id
This allows the output of the residual at the end of each solution series, using a single postprocessing writer. By default, no output is activated.
[in]writer_idid of the writer
◆ cs_sles_set_verbosity()
void cs_sles_set_verbosity ( cs_sles_t *  sles,
int  verbosity
By default, the verbosity is set to 0, or the value returned by the function set with cs_sles_set_default_define().
[in]verbosityverbosity level
◆ cs_sles_setup()
void cs_sles_setup ( cs_sles_t *  sles,
Use of this function is optional: if a cs_sles_solve is called for the same system before this function is called, the latter will be called automatically.
If no options were previously provided for the matching system, default options will be used.
[in]amatrix
◆ cs_sles_solve()
cs_sles_convergence_state_t cs_sles_solve ( cs_sles_t *  sles,
double  precision,
double  r_norm,
bool  vx_ini_0,
int *  n_iter,
double *  residual,
cs_real_t *  vx,
size_t  aux_size,
void *  aux_vectors
Note that if cs_sles_setup was previously called for this system, and cs_sles_free has not been called since, the matrix provided should be the same. The optional separation between the two stages is intended to allow amortizing the cost of setup over multiple solutions.
If the initial solution iz zero, setting vx_ini_0 to true may allow extra optimizations with some solvers, and avoids requiring an upstream initialization.
The system is considered to have converged when residual/r_norm <= precision, residual being the L2 norm of a.vx-rhs.
[in]amatrix
[in]precisionsolver precision
[in]r_normresidual normalization
[in]vx_ini_0if true, initialize solution to 0
[out]residualresidual
[in,out]vxsystem solution
[in]aux_sizesize of aux_vectors (in bytes)
aux_vectorsoptional working area (internal allocation if nullptr)
convergence state
