Build system
In this section, some specific aspects of the build system are described.
Base tools
The code_saturne build system is based mostly on the GNU Autotools, and provides a traditional configure, make, make install sequence).
Those tools have their sets of advantages and disadvantages, but are very well documented. A very practical feature, not available in such a natural form in some other build frameworks, is the possibility to provide a quick and complete list of available options using configure --help.
Specific adaptations
  • To rebuild or update configure scripts and associated Makefile templates, run ./sbin/bootstap from the top source directory. Some scripts may also be rebuilt automatically when the Autotools maintainer mode is enabled (which is the default when sources are pulled from Git), but to ensure a complete update, the above command is recommended.
  • To allow detecting compilers used and provide default flags, a config/cs_auto_flags.sh script is run by configure. Modifying this file does not require running ./sbin/bootstap, so it is possible to adapt it easily when porting to a new machine or set of compilers, even on cluster environments where the Autotools might not be available.
  • Though Autotools allow both in-tree and out of tree builds, only out-of tree builds are recommended and supported for code_saturne, as specified in the install documentation. In-tree builds might work, but they will pollute the source tree with generated files, prohibit multiple builds (such as side-by-side debug and production builds). No precaution is taken in code_saturne to avoid name conflicts between provided files and generated files, since this is not an issue with out-of-tree builds.
  • Since Automake has only partial support for modern Fortran, and does not handle module dependencies, all Fortran module dependencies must be handled explicitly. Using recursive make, they are build first based on rules in the src/Makefile.am Automake template (whereas most files to be compiled are listed in sub-directories). As Fortran is progressively being replaced by C in code_saturne, new modules are rarely added, limiting the inconvenience.
  • Since code_saturne is managed through Python scripts, many settings detected at configure and build time are saved for use in Python through some specific files, output by configure (bin/cs_config.py and the intermediate config/code_saturne_build.cfg.in file) and make install (bin/cs_package.py and the final config/code_saturne_build.cfg file). Currently, most settings are used directly from the installed cs_config.py and cs_package.py, but migrating to import of settings from config/code_saturne_build.cfg is recommended.
  • Libtool has some nice features relative to building and organizing libraries, but unfortunately decides that it is always right, even when it is wrong. In addition, it does not handle some compilers or languages, such as CUDA. So Libtool was removed from the code_saturne build system in August 2022 (for version 7.3). Shared libraries are now handled through addtional Automake rules and a build-aux/cs_link_library.py helper script.
  • Since code_saturne allows for user-defined functions and subroutines, a specific solution is required for those.
  • All m4 files specific to code_saturne are found in m4, and prefixed by cs_ (so may be listed as m4/cs_*.m4). Other m4 files in the same directory are generated or copied by automake.
Compiling the main solver executable
The main solver executable is usually cs_solver, but variants such as nc_solver, or other executables for unit testing are handled in a similar manner.
The main executable is compiled using the Python scripts. When installed or installing, the appropriate code is found in cs_compile.py (under bin in the code sources, and Python package install path in installed code). When building, since the available path structure is different, some methods are overloaded, using code from build-aux/cs_compile_build.py.
Code version determination
To avoid requiring extra steps when releasing a version, which have proved to be error-prone in the past, the code version handling is semi-automatic.
Since it is good practice to provide some form of release notes, and such notes require human intervention, the version number is based on entries available in the NEWS.md file in the top source directory. This is completed by info available from Git, if available. Based on this information, a build_aux/cs_version.py script determines the major, minor, and release numbers,n possibly with an additional Git hash, and a flag indicating whether the version based on Git is further modified (i.e. if there are uncommitted changes).
So when editing the NEWS.md, care must be taken to follow the existing format and naming conventions.
The following logic is also applied in the build_aux/cs_version.py script:
  • For each major code version x, there are 4 minor versions y (0, 1, 2, 3). When y would reach 4, x is incremented, and y set to 0.
  • In non-release branches, such as the master branch, the version number is based on the version following the last release branch (so 6.2 is followed by 6.3, 6.3 is followed by 7.0, etc.), to which the -alpha qualifier is added.
  • In release branches:
    • Prior to an x.y.0 release, the version number is automatically suffixed by beta, unless a tag containing -rc is found in Git, in which case this is used instead (for release candidates).
    • After a x.y.0, and while x.y.z is marked as unreleased in NEWS.md (rather than providing a release date), the version will appear as x.y.(z-1)-patch.
Roadmap
The GNU Autotools provide some nice features, and the code_saturne build system represents a large amount of work over multiple years, but this system is showing its age, and perhaps not evolving well enough to suit current needs.
Worse, these tools have lacked consistent integration from the start. For example, Autoconf allows generating multiple config.h files (such as cs_config.h and cs_config_priv.h), but Automake can only handle one. This has required writing work-arounds. Libtool possibly causes more issues than it solves. And finally, its cross-platform aspects are very limited. So Windows ports are basically limited to the Windows Subsystem for Linux.
Alternatives also have their advantages and disadvantages:
  • CMake is very complete, cross-platform, and used by many software projects, but is also quite complex.
    • It does not have a nice equivalent to configure --help. Though cmake -LAH is similar, it immediately caches some results, and should thus be run in a specific directory, making it a bit more tricky to use.
    • It requires learning a specific language. Perhaps not more complicated than the m4 scripts used in Autotools, but still one more than the main programming languages used in code_saturne.
    • We have not tested/evaluated the generation of configuration files (such as config/code_saturne_build.cfg) yet.
    • The caching behavior can lead to subtle issues.
      • With the GNU autotools, it is easy to obtain the full configuration command from config.log or config.status, adapt it if necessary, empty the build directory, and generate a new configuration. Doing the equivalent with CMake does not seem so straightforward.
    • It requires a CMake installation (though it is now almost ubiquitous).
    • On the advantages side, it does not require regenerating configure and Makefile.in files (using sbin/bootstrap in code_saturne) when CMake files are modified.
  • Meson seems like an interesting system, used by some large projects, and has the advantage of being based on Python, which is already familiar to most code_saturne developers.
    • A disadvantage is that its reliance on the Ninja build system, adds an installation and build dependency.
  • Pure Python, such as used in the PETSc build system, is interesting, but may require a significant coding investment.
For now, a safe solution seems to be to rewrite some parts of the build system in Python, as is already done in quite a few areas (see files in build-aux), and progressively reduce the reliance on the Autotools (now reduced to Autconf and Automake).
Automake could be replaced by hand-coded Makefiles, using configure to transform Makefile.in templates in the source tree to Makefiles in the build tree (so as to keep the essential possibility of using out-of-tree builds). Dependency rules would need to be generated in a manner similar to that used by Automake, but could be extended to automatic Fortran dependencies (though automatic handling of Fortran binding dependencies would remain tricky).
A first step would be to reduce the number of Makefile templates by using a single Makefile for a whole subtree, rather than recursive Makefiles. As such, a few Makefiles coud be handled at the preprocessor, src, and doc levels, for clarity and to avoid duplicating local rules. Makefiles at an even higher level could be interesting, but to keed the possibility of building only a specific subsystem at a time (useful when developing), specific target names for the various sub-systems would need to be used.
Autoconf could be replaced incrementally by Python code. Most tests and m4 macros would actually be clearer in Python, but some tests from Automake, such as determining C/C++ type sizes even when cross-compiling, may require additional work.
Specific Automake rules
Preprocessor
As the preprocessor is an executable, compilation flags for position-independent code are only added for optional plugin code, not the rest of the code. This could be easily changed.
Libraries and plugins
For files which may be compiled into plugins rather than the main libraries (such as src/base/fvm/fvm_to_catalyst.cxx), an associated non-installable library is defined in the matching directory's Automake (Makefile.am) rules, so as to force the file's compilation while still letting Automake handle its dependencies. This is done because Automake only manages rules for programs and libraries, not for individual object files. Another workaround would be to use rules for built (generated) sources.
When not using Libtool, Automake assumes archive (.a) form libraries, so flags for position-independent code are added specifically in the code_saturne build configuration (and can be adapted in config/cs_auto_flags.sh).
To build libraries, a build-aux/cs_link_library.py helper script is used. This script assumes knowledge of some linker options, so to port or update on various (especially non-Linux) systems, it may need to be adapted and extended.
Local targets are then defined so as to build the appropriate libraries, using the matching object (.o), and not library archive (.a) files.
This allows avoiding the use of libtool, while still benefiting from Automake's main features (source file dependency tracking, install targets, ...).
