cs_param_amg.h File Reference
Routines to handle the set of parameters for algebraic multigrids (AMG) like boomerAMG of the HYPRE library, GAMG of the PETSc library or the Notay's K-cycle (in-house implementation) for instance. More...
+ Include dependency graph for cs_param_amg.h:
Classes
struct  cs_param_amg_boomer_t
 Set of the main parameters to setup the algebraic multigrid BoomerAMG belonging to the HYPRE library. These parameters are used to define this AMG directly in HYPRE or through the PETSc library according to the settings and the installed dependencies. Please refer to the HYPRE documentation for more details. More...
struct  cs_param_amg_gamg_t
 Set of the main parameters to setup the algebraic multigrid GAMG belonging to the PETSc library. These parameters are used to define this AMG directly in the PETSc library according to the settings. Please refer to the PETSc documentation for more details. More...
struct  cs_param_amg_hmg_t
 Set of the main parameters used to setup the algebraic multigrid HMG belonging to the PETSc library. HMG means Hybrid MultiGrid since it can rely on the coarsening of HYPRE and use solvers (smoother and coarse solver) of PETSc. These parameters are used to define this AMG directly in the PETSc library according to the settings. Please refer to the PETSc documentation for more details. More...
struct  cs_param_amg_inhouse_t
 Set of the main parameters used to setup the algebraic multigrid available natively in code_saturne (in-house implementations). These parameters are the most impacting ones. For a more advanced usage, this is still possible to consider the function cs_user_linear_solvers. More...
Enumerations
enum  cs_param_amg_type_t {
  CS_PARAM_AMG_NONE , CS_PARAM_AMG_HYPRE_BOOMER_V , CS_PARAM_AMG_HYPRE_BOOMER_W , CS_PARAM_AMG_INHOUSE_K ,
  CS_PARAM_AMG_INHOUSE_V , CS_PARAM_AMG_PETSC_GAMG_V , CS_PARAM_AMG_PETSC_GAMG_W , CS_PARAM_AMG_PETSC_HMG_V ,
  CS_PARAM_AMG_PETSC_HMG_W , CS_PARAM_N_AMG_TYPES
enum  cs_param_amg_boomer_coarsen_algo_t {
  CS_PARAM_AMG_BOOMER_COARSEN_FALGOUT = 6 , CS_PARAM_AMG_BOOMER_COARSEN_PMIS = 8 , CS_PARAM_AMG_BOOMER_COARSEN_HMIS = 10 , CS_PARAM_AMG_BOOMER_COARSEN_CGC = 21 ,
  CS_PARAM_AMG_BOOMER_COARSEN_CGC_E = 22 , CS_PARAM_AMG_BOOMER_N_COARSEN_ALGOS
 Type of algorithm used in boomerAMG to coarsen a level. Only a selection of algorithms is available here. Values are those given in HYPRE. More...
enum  cs_param_amg_boomer_interp_algo_t {
  CS_PARAM_AMG_BOOMER_INTERP_HYPERBOLIC = 2 , CS_PARAM_AMG_BOOMER_INTERP_EXT_PLUS_I_CC = 6 , CS_PARAM_AMG_BOOMER_INTERP_EXT_PLUS_I = 7 , CS_PARAM_AMG_BOOMER_INTERP_FF1 = 13 ,
  CS_PARAM_AMG_BOOMER_INTERP_EXTENDED = 14 , CS_PARAM_AMG_BOOMER_INTERP_EXT_PLUS_I_MATRIX = 17 , CS_PARAM_AMG_BOOMER_INTERP_EXT_PLUS_E_MATRIX = 18 , CS_PARAM_AMG_BOOMER_N_INTERP_ALGOS
enum  cs_param_amg_boomer_smoother_t {
  CS_PARAM_AMG_BOOMER_JACOBI = 0 , CS_PARAM_AMG_BOOMER_FORWARD_GS = 3 , CS_PARAM_AMG_BOOMER_BACKWARD_GS = 4 , CS_PARAM_AMG_BOOMER_HYBRID_SSOR = 6 ,
  CS_PARAM_AMG_BOOMER_L1_SGS = 8 , CS_PARAM_AMG_BOOMER_GAUSS_ELIM = 9 , CS_PARAM_AMG_BOOMER_BACKWARD_L1_GS = 13 , CS_PARAM_AMG_BOOMER_FORWARD_L1_GS = 14 ,
  CS_PARAM_AMG_BOOMER_CG = 15 , CS_PARAM_AMG_BOOMER_CHEBYSHEV = 16 , CS_PARAM_AMG_BOOMER_FCF_JACOBI = 17 , CS_PARAM_AMG_BOOMER_L1_JACOBI = 18 ,
  CS_PARAM_AMG_BOOMER_N_SMOOTHERS
 Type of algorithm used in boomerAMG to smooth a level. Only a selection of algorithms is available here. Values are those used in HYPRE. More...
enum  cs_param_amg_gamg_smoother_t {
  CS_PARAM_AMG_GAMG_BACKWARD_GS , CS_PARAM_AMG_GAMG_BILU0 , CS_PARAM_AMG_GAMG_CHEBYSHEV , CS_PARAM_AMG_GAMG_FORWARD_GS ,
  CS_PARAM_AMG_GAMG_HYBRID_SSOR , CS_PARAM_AMG_GAMG_JACOBI , CS_PARAM_AMG_GAMG_L1_JACOBI , CS_PARAM_AMG_GAMG_N_SMOOTHERS
enum  cs_param_amg_gamg_coarse_solver_t {
  CS_PARAM_AMG_GAMG_BJACOBI_LU , CS_PARAM_AMG_GAMG_CG , CS_PARAM_AMG_GAMG_GMRES , CS_PARAM_AMG_GAMG_LU ,
  CS_PARAM_AMG_GAMG_TFS , CS_PARAM_AMG_GAMG_N_COARSE_SOLVERS
enum  cs_param_amg_inhouse_solver_t {
  CS_PARAM_AMG_INHOUSE_FORWARD_GS = 1 , CS_PARAM_AMG_INHOUSE_BACKWARD_GS = 2 , CS_PARAM_AMG_INHOUSE_L1_JACOBI = 11 , CS_PARAM_AMG_INHOUSE_R_JACOBI = 12 ,
  CS_PARAM_AMG_INHOUSE_RJ2 = 13 , CS_PARAM_AMG_INHOUSE_RJ3 = 14 , CS_PARAM_AMG_INHOUSE_JACOBI = 3 , CS_PARAM_AMG_INHOUSE_PROCESS_GS = 4 ,
  CS_PARAM_AMG_INHOUSE_PROCESS_SGS = 5 , CS_PARAM_AMG_INHOUSE_CG = 6 , CS_PARAM_AMG_INHOUSE_CR3 = 7 , CS_PARAM_AMG_INHOUSE_GCR = 8 ,
  CS_PARAM_AMG_INHOUSE_GMRES = 9 , CS_PARAM_AMG_INHOUSE_N_SOLVERS
 Type of algorithm used in the in-house algorithm for smoothing each level or solving the coarse level. Only the most relevant algorithms are available here. More...
enum  cs_param_amg_inhouse_coarsen_t {
  CS_PARAM_AMG_INHOUSE_COARSEN_SPD_DX = 1 , CS_PARAM_AMG_INHOUSE_COARSEN_SPD_MX = 2 , CS_PARAM_AMG_INHOUSE_COARSEN_SPD_PW = 3 , CS_PARAM_AMG_INHOUSE_COARSEN_CONV_DIFF_DX = 4 ,
  CS_PARAM_AMG_INHOUSE_N_COARSENINGS
 Type of algorithm used in the in-house algorithm to coarsen each level. This enum avoids using the associated cs_grid_coarsening_t type which includes higher level headers. More...
bool cs_param_amg_boomer_is_needed (cs_param_solver_type_t solver, cs_param_precond_type_t precond, cs_param_amg_type_t amg)
 Return true if the settings rely on boomeramg, otherwise false. More...
bool cs_param_amg_gamg_is_needed (cs_param_solver_type_t solver, cs_param_precond_type_t precond, cs_param_amg_type_t amg)
 Return true if the settings rely on gamg, otherwise false. More...
bool cs_param_amg_hmg_is_needed (cs_param_solver_type_t solver, cs_param_precond_type_t precond, cs_param_amg_type_t amg)
 Return true if the settings rely on hmg, otherwise false. More...
bool cs_param_amg_inhouse_is_needed (cs_param_solver_type_t solver, cs_param_precond_type_t precond, cs_param_amg_type_t amg)
 Return true if the settings rely on the in-house implementation, otherwise false. More...
const char * cs_param_amg_get_type_name (cs_param_amg_type_t type)
 Get the name of the type of algebraic multigrid (AMG) More...
cs_param_solver_class_t cs_param_amg_get_class (cs_param_amg_type_t amg_type)
 Retrieve the related solver class from the amg type. More...
cs_param_amg_boomer_t * cs_param_amg_boomer_create (void)
 Create a new structure storing a set of parameters used when calling boomerAMG. Set default values for all parameters. More...
cs_param_amg_boomer_t * cs_param_amg_boomer_copy (const cs_param_amg_boomer_t *bamgp)
 Copy the given set of parameters used when calling boomerAMG into a new structure. More...
const char * cs_param_amg_get_boomer_smoother_name (cs_param_amg_boomer_smoother_t smoother)
 Get the name of the smoother used with BoomerAMG (HYPRE library) More...
void cs_param_amg_boomer_log (const char *name, const cs_param_amg_boomer_t *bamgp)
 Log the set of parameters used for setting BoomerAMG. More...
cs_param_amg_gamg_t * cs_param_amg_gamg_create (void)
 Create a new structure storing a set of parameters used when calling GAMG. Set default values for all parameters. More...
cs_param_amg_gamg_t * cs_param_amg_gamg_copy (const cs_param_amg_gamg_t *gamgp)
 Copy the given set of parameters used when calling GAMG into a new structure. More...
const char * cs_param_amg_get_gamg_smoother_name (cs_param_amg_gamg_smoother_t smoother)
 Get the name of the smoother used with GAMG (PETSc library) More...
const char * cs_param_amg_get_gamg_coarse_solver_name (cs_param_amg_gamg_coarse_solver_t coarse)
void cs_param_amg_gamg_log (const char *name, const cs_param_amg_gamg_t *gamgp)
 Log the set of parameters used for setting GAMG. More...
cs_param_amg_hmg_t * cs_param_amg_hmg_create (void)
 Create a new structure storing a set of parameters used when calling HMG. Set all parameters at their default value. More...
cs_param_amg_hmg_t * cs_param_amg_hmg_copy (const cs_param_amg_hmg_t *hmgp)
 Copy the given set of parameters used when calling HMG into a new structure. More...
void cs_param_amg_hmg_log (const char *name, const cs_param_amg_hmg_t *hmgp)
 Log the set of parameters used for setting HMG. More...
cs_param_amg_inhouse_t * cs_param_amg_inhouse_create (bool used_as_solver, bool used_as_k_cycle)
 Create a new structure storing a set of parameters used when calling the in-house AMG algo. Set default values for all parameters. More...
cs_param_amg_inhouse_t * cs_param_amg_inhouse_copy (const cs_param_amg_inhouse_t *amgp)
 Copy the given set of parameters used when calling in-house AMG algo. into a new structure. More...
const char * cs_param_amg_get_inhouse_solver_name (cs_param_amg_inhouse_solver_t solver)
 Get the name of the solver used with in-house AMG algo. More...
void cs_param_amg_inhouse_log (const char *name, const cs_param_amg_inhouse_t *amgp)
 Log the set of parameters used for setting in-house AMG algorithms. More...
◆ cs_param_amg_boomer_coarsen_algo_t
Enumerator
◆ cs_param_amg_boomer_interp_algo_t
Enumerator
◆ cs_param_amg_boomer_smoother_t
Enumerator
◆ cs_param_amg_gamg_coarse_solver_t
Enumerator
◆ cs_param_amg_gamg_smoother_t
Enumerator
◆ cs_param_amg_inhouse_coarsen_t
Enumerator
SPD, diag/extradiag ratio based
SPD, pairwise aggregation
for general matrices
◆ cs_param_amg_inhouse_solver_t
This enum avoids using cs_sles_it_type_t which includes higher level headers leading to loop cycle issues.
Enumerator
◆ cs_param_amg_type_t
Type of AMG (Algebraic MultiGrid) algorithm to use (either as a preconditioner with or a solver). There are different choices of implementation and of type of cycle
Enumerator
CS_PARAM_AMG_NONE
No specified algorithm
V-cycle Boomer algorithm (Hypre lib.)
W-cycle Boomer algorithm (Hypre lib.)
In-house algorithm with K-cycle
In-house algorithm with V-cycle
V-cycle GAMG algorithm (PETSc lib.)
W-cycle GAMG algorithm (PETSc lib.)
V-cycle HMG (hybrid AMG) from PETSc
W-cycle HMG (hybrid AMG) from PETSc
◆ cs_param_amg_boomer_copy()
cs_param_amg_boomer_t * cs_param_amg_boomer_copy ( const cs_param_amg_boomer_t *  bamgp)
[in]bamgpreference set of boomerAMG parameters
a pointer to a new set of boomerAMG parameters
◆ cs_param_amg_boomer_create()
cs_param_amg_boomer_t * cs_param_amg_boomer_create ( void  )
◆ cs_param_amg_boomer_is_needed()
bool cs_param_amg_boomer_is_needed ( cs_param_solver_type_t  solver,
inline
[in]solvertype of SLES solver
[in]precondtype of preconditioner
[in]amgtype of AMG
true or false
◆ cs_param_amg_boomer_log()
void cs_param_amg_boomer_log ( const char *  name,
[in]namename related to the current SLES
[in]bamgpset of boomerAMG parameters
◆ cs_param_amg_gamg_copy()
cs_param_amg_gamg_t * cs_param_amg_gamg_copy ( const cs_param_amg_gamg_t *  gamgp)
[in]gamgpreference set of GAMG parameters
a pointer to a new set of GAMG parameters
◆ cs_param_amg_gamg_create()
cs_param_amg_gamg_t * cs_param_amg_gamg_create ( void  )
◆ cs_param_amg_gamg_is_needed()
bool cs_param_amg_gamg_is_needed ( cs_param_solver_type_t  solver,
inline
[in]amgtype of AMG
true or false
◆ cs_param_amg_gamg_log()
void cs_param_amg_gamg_log ( const char *  name,
[in]gamgpset of gamgAMG parameters
◆ cs_param_amg_get_boomer_smoother_name()
const char * cs_param_amg_get_boomer_smoother_name ( cs_param_amg_boomer_smoother_t  smoother)
[in]smoothersmoother type
name of the given smoother type
◆ cs_param_amg_get_class()
cs_param_solver_class_t cs_param_amg_get_class ( cs_param_amg_type_t  amg_type)
[in]amg_typetype of AMG to consider
the related solver class or CS_PARAM_SOLVER_CLASS_CS
◆ cs_param_amg_get_gamg_coarse_solver_name()
const char * cs_param_amg_get_gamg_coarse_solver_name ( cs_param_amg_gamg_coarse_solver_t  coarse)
[in]coarsetype of predefined coarse solver
name of the given type of coarse solver
◆ cs_param_amg_get_gamg_smoother_name()
const char * cs_param_amg_get_gamg_smoother_name ( cs_param_amg_gamg_smoother_t  smoother)
◆ cs_param_amg_get_inhouse_solver_name()
const char * cs_param_amg_get_inhouse_solver_name ( cs_param_amg_inhouse_solver_t  solver)
[in]solversolver type
name of the given solver type
◆ cs_param_amg_get_type_name()
const char * cs_param_amg_get_type_name ( cs_param_amg_type_t  type)
[in]typetype of AMG
the associated type name
◆ cs_param_amg_hmg_copy()
cs_param_amg_hmg_t * cs_param_amg_hmg_copy ( const cs_param_amg_hmg_t *  hmgp)
[in]hmgpreference set of HMG parameters
a pointer to a new set of HMG parameters
◆ cs_param_amg_hmg_create()
cs_param_amg_hmg_t * cs_param_amg_hmg_create ( void  )
◆ cs_param_amg_hmg_is_needed()
bool cs_param_amg_hmg_is_needed ( cs_param_solver_type_t  solver,
inline
[in]amgtype of AMG
true or false
◆ cs_param_amg_hmg_log()
void cs_param_amg_hmg_log ( const char *  name,
[in]hmgpset of hmgAMG parameters
◆ cs_param_amg_inhouse_copy()
cs_param_amg_inhouse_t * cs_param_amg_inhouse_copy ( const cs_param_amg_inhouse_t *  amgp)
[in]amgpreference set of in-house AMG parameters
a pointer to a new set of in-house AMG parameters
◆ cs_param_amg_inhouse_create()
cs_param_amg_inhouse_t * cs_param_amg_inhouse_create ( bool  used_as_solver,
[in]used_as_solvertrue or false
[in]used_as_k_cycletrue or false
a pointer to a new set of parameters
◆ cs_param_amg_inhouse_is_needed()
bool cs_param_amg_inhouse_is_needed ( cs_param_solver_type_t  solver,
inline
[in]amgtype of AMG
true or false
◆ cs_param_amg_inhouse_log()
void cs_param_amg_inhouse_log ( const char *  name,
[in]amgpset of in-house AMG parameters
