cs_sles_it.h File Reference
#include "base/cs_base.h"
#include "alge/cs_matrix.h"
#include "alge/cs_sles.h"
#include "alge/cs_sles_pc.h"
+ Include dependency graph for cs_sles_it.h:
Typedefs
typedef struct _cs_sles_it_t cs_sles_it_t
typedef struct _cs_sles_it_convergence_t cs_sles_it_convergence_t
Enumerations
enum  cs_sles_it_type_t {
  CS_SLES_PCG , CS_SLES_FCG , CS_SLES_IPCG , CS_SLES_JACOBI ,
  CS_SLES_BICGSTAB , CS_SLES_BICGSTAB2 , CS_SLES_GCR , CS_SLES_GMRES ,
  CS_SLES_P_GAUSS_SEIDEL , CS_SLES_P_SYM_GAUSS_SEIDEL , CS_SLES_PCR3 , CS_SLES_USER_DEFINED ,
  CS_SLES_N_IT_TYPES , CS_SLES_L1_JACOBI , CS_SLES_R_JACOBI , CS_SLES_RJ2 ,
  CS_SLES_RJ3 , CS_SLES_TS_F_GAUSS_SEIDEL , CS_SLES_TS_B_GAUSS_SEIDEL , CS_SLES_N_SMOOTHER_TYPES
cs_sles_convergence_state_t cs_user_sles_it_solver (cs_sles_it_t *c, const cs_matrix_t *a, cs_lnum_t diag_block_size, cs_sles_it_convergence_t *convergence, const cs_real_t *rhs, cs_real_t *vx_ini, cs_real_t *vx, size_t aux_size, void *aux_vectors)
cs_sles_it_t * cs_sles_it_define (int f_id, const char *name, cs_sles_it_type_t solver_type, int poly_degree, int n_max_iter)
 Define and associate an iterative sparse linear system solver for a given field or equation name. More...
cs_sles_it_t * cs_sles_it_create (cs_sles_it_type_t solver_type, int poly_degree, int n_max_iter, bool update_stats)
 Create iterative sparse linear system solver info and context. More...
void cs_sles_it_destroy (void **context)
 Destroy iterative sparse linear system solver info and context. More...
void * cs_sles_it_copy (const void *context)
 Create iterative sparse linear system solver info and context based on existing info and context. More...
void cs_sles_it_setup (void *context, const char *name, const cs_matrix_t *a, int verbosity)
 Setup iterative sparse linear equation solver. More...
cs_sles_convergence_state_t cs_sles_it_solve (void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residual, const cs_real_t *rhs, cs_real_t *vx, cs_real_t *vx_ini, size_t aux_size, void *aux_vectors)
 Call iterative sparse linear equation solver. More...
void cs_sles_it_free (void *context)
 Free iterative sparse linear equation solver setup context. More...
void cs_sles_it_log (const void *context, cs_log_t log_type)
 Log sparse linear equation solver info. More...
cs_sles_it_type_t cs_sles_it_get_type (const cs_sles_it_t *context)
 Return iterative solver type. More...
double cs_sles_it_get_last_initial_residual (const cs_sles_it_t *context)
 Return the initial residual for the previous solve operation with a solver. More...
cs_sles_pc_t * cs_sles_it_get_pc (cs_sles_it_t *context)
 Return a preconditioner context for an iterative sparse linear equation solver. More...
void cs_sles_it_transfer_pc (cs_sles_it_t *context, cs_sles_pc_t **pc)
 Assign a preconditioner to an iterative sparse linear equation solver, transfering its ownership to the solver context. More...
void cs_sles_it_transfer_parameters (const cs_sles_it_t *src, cs_sles_it_t *dest)
 Copy options from one iterative sparse linear system solver info and context to another. More...
void cs_sles_it_set_shareable (cs_sles_it_t *context, const cs_sles_it_t *shareable)
 Associate a similar info and context object with which some setup data may be shared. More...
void cs_sles_it_set_mpi_reduce_comm (cs_sles_it_t *context, MPI_Comm comm, MPI_Comm caller_comm)
 Set MPI communicator for global reductions. More...
void cs_sles_it_assign_order (cs_sles_it_t *context, cs_lnum_t **order)
 Assign ordering to iterative solver. More...
double cs_sles_it_get_breakdown_threshold (void)
 Retrieve the threshold value under which a breakdown happens in solvers like BiCGStab or BiCGStab2. More...
void cs_sles_it_set_breakdown_threshold (double threshold)
 Define the threshold value under which a breakdown happens in solvers like BiCGStab or BiCGStab2. More...
void cs_sles_it_set_fallback_threshold (cs_sles_it_t *context, cs_sles_convergence_state_t threshold, int n_iter_max)
 Define convergence level under which the fallback to another solver may be used if applicable. More...
void cs_sles_it_set_restart_interval (cs_sles_it_t *context, int interval)
 Define the number of iterations to be done before restarting the solver. Useful only for GCR or GMRES algorithms. More...
void cs_sles_it_set_n_max_iter (cs_sles_it_t *context, int n_max_iter)
 Define the max. number of iterations before stopping the algorithm. More...
bool cs_sles_it_error_post_and_abort (cs_sles_t *sles, cs_sles_convergence_state_t state, const cs_matrix_t *a, const cs_real_t *rhs, cs_real_t *vx)
 Error handler for iterative sparse linear equation solver. More...
void cs_sles_it_set_plot_options (cs_sles_it_t *context, const char *base_name, bool use_iteration)
 Set plotting options for an iterative sparse linear equation solver. More...
cs_sles_convergence_state_t cs_sles_it_convergence_test (cs_sles_it_t *c, unsigned n_iter, double residual, cs_sles_it_convergence_t *convergence)
const char * cs_sles_it_type_name []
Typedef Documentation
◆ cs_sles_it_convergence_t
◆ cs_sles_it_t
◆ cs_sles_it_type_t
Enumerator
CS_SLES_PCG
Preconditioned conjugate gradient
CS_SLES_FCG
Preconditions flexible conjugate gradient, described in [16]
CS_SLES_IPCG
Preconditions inexact conjugate gradient
CS_SLES_JACOBI
Jacobi
CS_SLES_BICGSTAB
Preconditioned BiCGstab (biconjugate gradient stabilized)
CS_SLES_BICGSTAB2
Preconditioned BiCGstab2
CS_SLES_GCR
Generalized conjugate residual
CS_SLES_GMRES
Preconditioned GMRES (generalized minimal residual)
Hybrid Gauss-Seidel
Hybrid symmetric Gauss-Seidel
CS_SLES_PCR3
3-layer conjugate residual
User-defined iterative solver
CS_SLES_N_IT_TYPES
Number of resolution algorithms excluding smoother only
CS_SLES_L1_JACOBI
L1-Jacobi smoother
CS_SLES_R_JACOBI
Weighted (relaxed) Jacobi smoother
CS_SLES_RJ2
Scheduled relaxed Jacobi smoother, M=2
CS_SLES_RJ3
Scheduled relaxed Jacobi smoother, M=3
Truncated forward Gauss-Seidel smoother
Truncated backward Gauss-Seidel smoother
Number of resolution algorithms including smoother only
◆ cs_sles_it_assign_order()
void cs_sles_it_assign_order ( cs_sles_it_t *  context,
cs_lnum_t **  order
The solver context takes ownership of the order array (i.e. it will handle its later deallocation).
This is useful only for Process-local Gauss-Seidel.
[in,out]contextpointer to iterative solver info and context
[in,out]orderpointer to ordering array
◆ cs_sles_it_convergence_test()
cs_sles_convergence_state_t cs_sles_it_convergence_test ( cs_sles_it_t *  c,
unsigned  n_iter,
double  residual,
cs_sles_it_convergence_t *  convergence
◆ cs_sles_it_copy()
void * cs_sles_it_copy ( const void *  context)
[in]contextpointer to reference info and context (actual type: cs_sles_it_t *)
pointer to newly created solver info object. (actual type: cs_sles_it_t *)
◆ cs_sles_it_create()
cs_sles_it_t * cs_sles_it_create ( cs_sles_it_type_t  solver_type,
int  poly_degree,
int  n_max_iter,
bool  update_stats
[in]solver_typetype of solver (PCG, Jacobi, ...)
[in]poly_degreepreconditioning polynomial degree (0: diagonal; -1: non-preconditioned; see Iterative linear solvers. for details)
[in]n_max_itermaximum number of iterations
[in]update_statsautomatic solver statistics indicator
◆ cs_sles_it_define()
cs_sles_it_t * cs_sles_it_define ( int  f_id,
const char *  name,
int  poly_degree,
int  n_max_iter
This is a utility function: if finer control is needed, see cs_sles_define and cs_sles_it_create.
Note that this function returns a pointer directly to the iterative solver management structure. This may be used to set further options, for example using cs_sles_it_set_plot_options. If needed, cs_sles_find may be used to obtain a pointer to the matching cs_sles_t container.
[in]nameassociated name if f_id < 0, or nullptr
[in]poly_degreepreconditioning polynomial degree (0: diagonal; -1: non-preconditioned)
pointer to newly created iterative solver info object.
◆ cs_sles_it_destroy()
void cs_sles_it_destroy ( void **  context)
[in,out]contextpointer to iterative solver info and context (actual type: cs_sles_it_t **)
◆ cs_sles_it_error_post_and_abort()
bool cs_sles_it_error_post_and_abort ( cs_sles_t *  sles,
const cs_matrix_t *  a,
const cs_real_t *  rhs,
cs_real_t *  vx
In case of divergence or breakdown, this error handler outputs postprocessing data to assist debugging, then aborts the run. It does nothing in case the maximum iteration count is reached.
[in,out]slespointer to solver object
[in]stateconvergence state
[in]amatrix
[in]rhsright hand side
[in,out]vxsystem solution
false (do not attempt new solve)
◆ cs_sles_it_free()
void cs_sles_it_free ( void *  context)
[in,out]contextpointer to iterative solver info and context (actual type: cs_sles_it_t *)
◆ cs_sles_it_get_breakdown_threshold()
double cs_sles_it_get_breakdown_threshold ( void  )
the value of the threshold
◆ cs_sles_it_get_last_initial_residual()
double cs_sles_it_get_last_initial_residual ( const cs_sles_it_t *  context)
This is useful for convergence tests when this solver is used as a preconditioning smoother.
This operation is only valid between calls to cs_sles_it_setup (or cs_sles_it_solve) and cs_sles_it_free. It returns -1 otherwise.
[in]contextpointer to iterative solver info and context
initial residual from last call to cs_sles_solve with this solver
◆ cs_sles_it_get_pc()
cs_sles_pc_t * cs_sles_it_get_pc ( cs_sles_it_t *  context)
This allows modifying parameters of a non default (Jacobi or polynomial) preconditioner.
pointer to preconditoner context
◆ cs_sles_it_get_type()
cs_sles_it_type_t cs_sles_it_get_type ( const cs_sles_it_t *  context)
selected solver type
◆ cs_sles_it_log()
void cs_sles_it_log ( const void *  context,
cs_log_t  log_type
[in]contextpointer to iterative solver info and context (actual type: cs_sles_it_t *)
[in]log_typelog type
◆ cs_sles_it_set_breakdown_threshold()
void cs_sles_it_set_breakdown_threshold ( double  threshold)
[in]thresholdvalue of the threshold
◆ cs_sles_it_set_fallback_threshold()
void cs_sles_it_set_fallback_threshold ( cs_sles_it_t *  context,
int  n_iter_max
Currently, this mechanism is used by default for solvers which may exhibit breakdown, such as BiCGstab and 3-layer conjugate residual solvers, which may fall back to a more robust preconditioned GMRES solver.
For those solvers, the default threshold is CS_SLES_MAX_ITERATION, meaning that reaching breakdown will lead to the use of the fallback mechanism.
[in]thresholdconvergence level under which fallback is used
[in]n_iter_maxmaximum number of iterations fo fallback solver
◆ cs_sles_it_set_mpi_reduce_comm()
void cs_sles_it_set_mpi_reduce_comm ( cs_sles_it_t *  context,
MPI_Comm  comm,
The system is solved only on ranks with a non-null communicator or if the caller communicator has less than 2 ranks. convergence info is broadcast across the caller communicator.
[in]commMPI communicator for solving
[in]caller_commMPI communicator of caller
The system is solved only on ranks with a non-null communicator or if the caller communicator has less than 2 ranks. convergence info is the broadcast across the caller communicator.
◆ cs_sles_it_set_n_max_iter()
void cs_sles_it_set_n_max_iter ( cs_sles_it_t *  context,
int  n_max_iter
[in]n_max_itermax. number of iterations
◆ cs_sles_it_set_plot_options()
void cs_sles_it_set_plot_options ( cs_sles_it_t *  context,
const char *  base_name,
bool  use_iteration
[in]base_namebase plot name to activate, nullptr otherwise
[in]use_iterationif true, use iteration as time stamp otherwise, use wall clock time
◆ cs_sles_it_set_restart_interval()
void cs_sles_it_set_restart_interval ( cs_sles_it_t *  context,
int  interval
[in]intervalconvergence level under which fallback is used
◆ cs_sles_it_set_shareable()
void cs_sles_it_set_shareable ( cs_sles_it_t *  context,
const cs_sles_it_t *  shareable
This is especially useful for sharing preconditioning data between similar solver contexts (for example ascending and descending multigrid smoothers based on the same matrix).
For preconditioning data to be effectively shared, cs_sles_it_setup (or cs_sles_it_solve) must be called on shareable before being called on context (without cs_sles_it_free being called in between, of course).
It is the caller's responsibility to ensure the context is not used for a cs_sles_it_setup or cs_sles_it_solve operation after the shareable object has been destroyed (normally by cs_sles_it_destroy).
[in]shareablepointer to iterative solver info and context whose context may be shared
◆ cs_sles_it_setup()
void cs_sles_it_setup ( void *  context,
const char *  name,
int  verbosity
[in]namepointer to system name
[in]aassociated matrix
[in]verbosityassociated verbosity
◆ cs_sles_it_solve()
cs_sles_convergence_state_t cs_sles_it_solve ( void *  context,
const char *  name,
int  verbosity,
double  precision,
double  r_norm,
int *  n_iter,
double *  residual,
cs_real_t *  vx_ini,
cs_real_t *  vx,
size_t  aux_size,
void *  aux_vectors
[in]amatrix
[in]precisionsolver precision
[in]r_normresidual normalization
[out]residualresidual
[in]vx_iniinitial system solution (vx if nonzero, nullptr if zero)
[in]aux_sizenumber of elements in aux_vectors (in bytes)
aux_vectorsoptional working area (internal allocation if nullptr)
convergence state
◆ cs_sles_it_transfer_parameters()
void cs_sles_it_transfer_parameters ( const cs_sles_it_t *  src,
cs_sles_it_t *  dest
Optional plotting contexts are shared between the source and destination contexts.
Preconditioner settings are to be handled separately.
[in]srcpointer to source info and context
[in,out]destpointer to destination info and context
◆ cs_sles_it_transfer_pc()
void cs_sles_it_transfer_pc ( cs_sles_it_t *  context,
cs_sles_pc_t **  pc
This allows assigning a non default (Jacobi or polynomial) preconditioner.
The input pointer is set to nullptr to make it clear the caller does not own the preconditioner anymore, though the context can be accessed using cs_sles_it_get_pc.
[in,out]pcpointer to preconditoner context
◆ cs_user_sles_it_solver()
cs_sles_convergence_state_t cs_user_sles_it_solver ( cs_sles_it_t *  c,
cs_sles_it_convergence_t *  convergence,
cs_real_t *  vx_ini,
cs_real_t *  vx,
size_t  aux_size,
void *  aux_vectors
◆ cs_sles_it_type_name
const char* cs_sles_it_type_name[]
extern
