54 const int sys_error_code,
55 const char *
const format,
82 const int sys_error_code,
83 const char *
const format,
85 __attribute__((format(printf, 4, 5)));
92 const int sys_error_code,
93 const char *
const format,
bft_error_handler_t * bft_error_handler_get(void)
Returns the error handler associated with the bft_error() function.
Definition: bft_error.cpp:209
Definition: bft_error.cpp:187
void bft_error_handler_set(bft_error_handler_t *const handler)
Associates an error handler with the bft_error() function.
Definition: bft_error.cpp:221
void() bft_error_handler_t(const char *const file_name, const int line_num, const int sys_error_code, const char *const format, va_list arg_ptr)
Function pointer to opaque error handler.
Definition: bft_error.h:52
Definition: cs_defs.h:528
Definition: cs_defs.h:529
