462 [[deprecated(
"renamed to solve_temperature")]] \
469 [[deprecated(
"renamed to solve_diameter")]] \
476 [[deprecated(
"renamed to solve_mass")]] \
Definition: cs_field.h:275
Definition: cs_defs.h:528
Definition: cs_defs.h:332
#define DISABLE_WARNING_PUSH
Definition: cs_defs.h:168
cs_real_t cs_real_4_t[4]
vector of 4 floating-point values
Definition: cs_defs.h:350
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:349
#define DISABLE_WARNING_POP
Definition: cs_defs.h:170
unsigned cs_gnum_t
global mesh entity number
Definition: cs_defs.h:317
cs_real_t cs_real_6_t[6]
Definition: cs_defs.h:351
Definition: cs_defs.h:529
cs_real_t cs_real_33_t[3][3]
Definition: cs_defs.h:358
Definition: cs_defs.h:325
@ dt
Definition: cs_field_pointer.h:61
cs_lagr_source_terms_t * cs_glob_lagr_source_terms
void cs_lagr_finalize_internal_cond(void)
Definition: cs_lagr.cpp:1624
cs_lagr_internal_condition_t * cs_glob_lagr_internal_conditions
cs_lagr_boundary_interactions_t * cs_glob_lagr_boundary_interactions
cs_lagr_consolidation_model_t * cs_glob_lagr_consolidation_model
cs_lagr_injection_set_t * cs_lagr_get_injection_set(cs_lagr_zone_data_t *zone_data, int zone_id, int set_id)
Provide access to injection set structure.
Definition: cs_lagr.cpp:1185
cs_lagr_precipitation_model_t * cs_get_lagr_precipitation_model(void)
Provide access to cs_lagr_precipitation_model_t.
Definition: cs_lagr.cpp:1386
cs_lagr_module_shape_t
Definition: cs_lagr.h:132
@ CS_LAGR_SHAPE_SPHEROID_STOC_MODEL
Definition: cs_lagr.h:138
@ CS_LAGR_SHAPE_SPHERE_MODEL
Definition: cs_lagr.h:135
@ CS_LAGR_SHAPE_SPHEROID_JEFFERY_MODEL
Definition: cs_lagr.h:141
void cs_lagr_solve_time_step(const int itypfb[], const cs_real_t *dt)
Definition: cs_lagr.cpp:1721
const cs_lagr_const_dim_t * cs_glob_lagr_const_dim
@ CS_LAGR_IN_IMPOSED_COMPONENTS
Definition: cs_lagr.h:105
@ CS_LAGR_IN_IMPOSED_NORM
Definition: cs_lagr.h:104
@ CS_LAGR_IN_IMPOSED_FLUID_VALUE
Definition: cs_lagr.h:102
cs_lagr_model_t * cs_glob_lagr_model
cs_lagr_internal_condition_t * cs_lagr_get_internal_conditions(void)
Return pointer to the main internal conditions structure.
Definition: cs_lagr.cpp:1510
cs_lagr_extra_module_t * cs_glob_lagr_extra_module
cs_lagr_bc_type
Definition: cs_lagr.h:83
@ CS_LAGR_OUTLET
Definition: cs_lagr.h:88
@ CS_LAGR_INLET
Definition: cs_lagr.h:87
@ CS_LAGR_DEPO2
Definition: cs_lagr.h:91
@ CS_LAGR_DEPO1
Definition: cs_lagr.h:90
@ CS_LAGR_BC_USER
Definition: cs_lagr.h:94
@ CS_LAGR_FOULING
Definition: cs_lagr.h:93
@ CS_LAGR_BC_UNDEFINED
Definition: cs_lagr.h:85
@ CS_LAGR_SYM
Definition: cs_lagr.h:86
@ CS_LAGR_DEPO_DLVO
Definition: cs_lagr.h:92
@ CS_LAGR_REBOUND
Definition: cs_lagr.h:89
cs_lagr_zone_data_t * cs_lagr_get_boundary_conditions(void)
Return pointer to the main boundary conditions structure.
Definition: cs_lagr.cpp:1544
cs_lagr_encrustation_t * cs_glob_lagr_encrustation
const cs_lagr_zone_data_t * cs_glob_lagr_boundary_conditions
cs_lagr_agglomeration_model_t * cs_glob_lagr_agglomeration_model
cs_lagr_boundary_interactions_t * cs_get_lagr_boundary_interactions(void)
Definition: cs_lagr.cpp:1642
cs_lagr_particle_counter_t * cs_lagr_get_particle_counter(void)
Get read/write pointer to global particle counter.
Definition: cs_lagr.cpp:1285
cs_lagr_specific_physics_t * cs_glob_lagr_specific_physics
cs_lagr_extra_module_t * cs_get_lagr_extra_module(void)
Definition: cs_lagr.cpp:1653
cs_lagr_shape_model_t * cs_get_lagr_shape_model(void)
Definition: cs_lagr.cpp:1410
cs_lagr_fragmentation_model_t * cs_glob_lagr_fragmentation_model
cs_lagr_brownian_t * cs_get_lagr_brownian(void)
Definition: cs_lagr.cpp:1494
cs_lagr_reentrained_model_t * cs_glob_lagr_reentrained_model
void cs_lagr_add_fields(void)
Create additional fields needed by the Lagrangien model.
Definition: cs_lagr.cpp:1063
void cs_lagr_init_arrays(void)
Definition: cs_lagr.cpp:966
cs_lagr_agglomeration_model_t * cs_get_lagr_agglomeration_model(void)
Definition: cs_lagr.cpp:1422
cs_lagr_physico_chemical_t * cs_glob_lagr_physico_chemical
cs_lagr_precipitation_model_t * cs_glob_lagr_precipitation_model
cs_lagr_source_terms_t * cs_get_lagr_source_terms(void)
Definition: cs_lagr.cpp:1458
void cs_lagr_solve_initialize(const cs_real_t *dt)
Definition: cs_lagr.cpp:1668
void cs_lagr_injection_set_default(cs_lagr_injection_set_t *zis)
Initialize injection set data structure fields to defaults.
Definition: cs_lagr.cpp:1212
cs_lagr_consolidation_model_t * cs_get_lagr_consolidation_model(void)
Definition: cs_lagr.cpp:1434
void cs_lagr_initialize_extra(cs_lnum_t n_continuous_phases)
Definition: cs_lagr.cpp:956
cs_lagr_clogging_model_t * cs_get_lagr_clogging_model(void)
Definition: cs_lagr.cpp:1398
@ CS_LAGR_PHYS_CTWR
Definition: cs_lagr.h:152
@ CS_LAGR_PHYS_COAL
Definition: cs_lagr.h:151
@ CS_LAGR_PHYS_OFF
Definition: cs_lagr.h:149
@ CS_LAGR_PHYS_HEAT
Definition: cs_lagr.h:150
cs_lagr_particle_counter_t * cs_lagr_update_particle_counter(void)
Update global particle counter.
Definition: cs_lagr.cpp:1302
cs_lagr_brownian_t * cs_glob_lagr_brownian
cs_lagr_specific_physics_t * cs_get_lagr_specific_physics(void)
Provide access to cs_lagr_specific_physics_t.
Definition: cs_lagr.cpp:1359
cs_lagr_encrustation_t * cs_get_lagr_encrustation(void)
Definition: cs_lagr.cpp:1470
cs_lagr_time_step_t * cs_get_lagr_time_step(void)
Definition: cs_lagr.cpp:1446
void cs_lagr_map_specific_physics(void)
Map specific phyical model features to Lagrangian structures.
Definition: cs_lagr.cpp:1150
const cs_lagr_zone_data_t * cs_glob_lagr_volume_conditions
cs_lagr_module_status_t
Definition: cs_lagr.h:122
@ CS_LAGR_OFF
Definition: cs_lagr.h:123
@ CS_LAGR_ONEWAY_COUPLING
Definition: cs_lagr.h:124
@ CS_LAGR_TWOWAY_COUPLING
Definition: cs_lagr.h:125
@ CS_LAGR_FROZEN_CONTINUOUS_PHASE
Definition: cs_lagr.h:126
cs_lagr_physico_chemical_t * cs_get_lagr_physico_chemical(void)
Definition: cs_lagr.cpp:1482
cs_real_33_t * cs_glob_lagr_b_face_proj
void() cs_lagr_injection_profile_compute_t(int zone_id, int location_id, const void *input, cs_lnum_t n_elts, const cs_lnum_t elt_ids[], cs_real_t profile[])
Function pointer for computation of particle injection profile.
Definition: cs_lagr.h:73
void cs_lagr_finalize_zone_conditions(void)
Finalize the global boundary and volume condition structures.
Definition: cs_lagr.cpp:1592
cs_lagr_time_step_t * cs_glob_lagr_time_step
cs_lagr_reentrained_model_t * cs_get_lagr_reentrained_model(void)
Provide access to cs_lagr_reentrained_model_t.
Definition: cs_lagr.cpp:1373
int cs_glob_lagr_log_frequency_n
const cs_lagr_particle_counter_t * cs_glob_lagr_particle_counter
cs_lagr_zone_data_t * cs_lagr_get_volume_conditions(void)
Return pointer to the main volume conditions structure.
Definition: cs_lagr.cpp:1568
cs_lagr_dim_t * cs_glob_lagr_dim
void cs_lagr_finalize(void)
Definition: cs_lagr.cpp:984
cs_lagr_shape_model_t * cs_glob_lagr_shape_model
cs_lagr_time_scheme_t * cs_glob_lagr_time_scheme
cs_lagr_clogging_model_t * cs_glob_lagr_clogging_model
Definition: cs_lagr.h:566
cs_real_t base_diameter
Definition: cs_lagr.h:572
cs_real_t scalar_kernel
Definition: cs_lagr.h:571
cs_real_t max_stat_weight
Definition: cs_lagr.h:570
cs_lnum_t n_max_classes
Definition: cs_lagr.h:568
cs_real_t min_stat_weight
Definition: cs_lagr.h:569
Definition: cs_lagr.h:882
int iclogt
Definition: cs_lagr.h:921
int inclg
Definition: cs_lagr.h:915
int has_part_impact_nbr
Definition: cs_lagr.h:904
char ** nombrd
Definition: cs_lagr.h:955
int npstft
Definition: cs_lagr.h:899
int ihdepm
Definition: cs_lagr.h:930
int inclgt
Definition: cs_lagr.h:918
int inbr
Definition: cs_lagr.h:912
int iscovc
Definition: cs_lagr.h:927
int npstf
Definition: cs_lagr.h:891
cs_real_t tstatp
Definition: cs_lagr.h:947
int ihsum
Definition: cs_lagr.h:939
int iclgst
Definition: cs_lagr.h:909
int iclogh
Definition: cs_lagr.h:924
int ihdepv
Definition: cs_lagr.h:933
int ihdiam
Definition: cs_lagr.h:936
Definition: cs_lagr.h:873
int lamvbr
Definition: cs_lagr.h:875
Definition: cs_lagr.h:545
cs_real_t jamlim
Definition: cs_lagr.h:547
cs_real_t diam_mean
Definition: cs_lagr.h:550
cs_real_t mporos
Definition: cs_lagr.h:548
cs_real_t csthpp
Definition: cs_lagr.h:549
Definition: cs_lagr.h:590
cs_real_t force_consol
Definition: cs_lagr.h:595
cs_real_t slope_consol
Definition: cs_lagr.h:594
cs_lnum_t iconsol
Definition: cs_lagr.h:592
cs_real_t rate_consol
Definition: cs_lagr.h:593
Definition: cs_lagr.h:158
int ndlaim
Definition: cs_lagr.h:163
int ncharm2
Definition: cs_lagr.h:165
int nlayer
Definition: cs_lagr.h:166
int nusbrd
Definition: cs_lagr.h:160
Definition: cs_lagr.h:173
int n_boundary_stats
Definition: cs_lagr.h:175
Definition: cs_lagr.h:810
cs_real_t * visref
Definition: cs_lagr.h:834
cs_real_t dnpenc
Definition: cs_lagr.h:837
int iencra
Definition: cs_lagr.h:815
cs_real_t * tprenc
Definition: cs_lagr.h:829
cs_real_t * enc2
Definition: cs_lagr.h:824
int npencr
Definition: cs_lagr.h:818
cs_real_t * enc1
Definition: cs_lagr.h:822
Definition: cs_lagr.h:579
Definition: cs_lagr.h:582
Definition: cs_lagr.h:581
Definition: cs_lagr.h:615
cs_real_t diameter_variance
Definition: cs_lagr.h:659
cs_real_t density
Definition: cs_lagr.h:675
int injection_frequency
Definition: cs_lagr.h:624
int temperature_profile
Definition: cs_lagr.h:642
cs_real_t shape
Definition: cs_lagr.h:661
cs_real_t velocity_magnitude
Definition: cs_lagr.h:653
int velocity_profile
Definition: cs_lagr.h:637
cs_real_t cp
Definition: cs_lagr.h:679
cs_lagr_injection_profile_compute_t * injection_profile_func
Definition: cs_lagr.h:628
cs_real_t diameter
Definition: cs_lagr.h:658
cs_gnum_t n_inject
Definition: cs_lagr.h:621
int cluster
Definition: cs_lagr.h:648
int location_id
Definition: cs_lagr.h:619
cs_real_t fouling_index
Definition: cs_lagr.h:677
int coal_number
Definition: cs_lagr.h:644
void * injection_profile_input
Definition: cs_lagr.h:631
cs_real_t flow_rate
Definition: cs_lagr.h:683
int zone_id
Definition: cs_lagr.h:617
int set_id
Definition: cs_lagr.h:618
int aggregat_class_id
Definition: cs_lagr.h:650
cs_real_t emissivity
Definition: cs_lagr.h:685
cs_real_t stat_weight
Definition: cs_lagr.h:681
cs_real_t temperature
Definition: cs_lagr.h:656
cs_real_t aggregat_fractal_dim
Definition: cs_lagr.h:651
Definition: cs_lagr.h:801
int * i_face_zone_id
Definition: cs_lagr.h:803
Definition: cs_lagr.h:273
int verbosity
Definition: cs_lagr.h:365
bool transport_GLM_rotated
Definition: cs_lagr.h:359
int dlvo
Definition: cs_lagr.h:320
int n_stat_classes
Definition: cs_lagr.h:354
int cs_used
Definition: cs_lagr.h:293
int deposition
Definition: cs_lagr.h:318
int physical_model
Definition: cs_lagr.h:287
int fragmentation
Definition: cs_lagr.h:352
int roughness
Definition: cs_lagr.h:324
int precipitation
Definition: cs_lagr.h:343
int n_user_variables
Definition: cs_lagr.h:356
int idistu
Definition: cs_lagr.h:308
int shape
Definition: cs_lagr.h:337
int fouling
Definition: cs_lagr.h:344
int n_temperature_layers
Definition: cs_lagr.h:288
int modcpl
Definition: cs_lagr.h:302
int agglomeration
Definition: cs_lagr.h:348
int consolidation
Definition: cs_lagr.h:341
int resuspension
Definition: cs_lagr.h:328
int clogging
Definition: cs_lagr.h:332
int idiffl
Definition: cs_lagr.h:314
bool viscous_terms
Definition: cs_lagr.h:362
Definition: cs_lagr.h:371
cs_gnum_t n_g_cumulative_total
Definition: cs_lagr.h:375
cs_real_t w_exit
Definition: cs_lagr.h:412
cs_gnum_t n_g_new
Definition: cs_lagr.h:385
cs_gnum_t n_g_resuspended
Definition: cs_lagr.h:400
cs_gnum_t n_g_exit
Definition: cs_lagr.h:388
cs_real_t w_fouling
Definition: cs_lagr.h:421
cs_real_t w_total
Definition: cs_lagr.h:406
cs_gnum_t n_g_failed
Definition: cs_lagr.h:403
cs_gnum_t n_g_fouling
Definition: cs_lagr.h:397
cs_gnum_t n_g_total
Definition: cs_lagr.h:382
cs_real_t w_resuspended
Definition: cs_lagr.h:424
cs_real_t w_deposited
Definition: cs_lagr.h:418
cs_gnum_t n_g_merged
Definition: cs_lagr.h:391
cs_gnum_t n_g_cumulative_failed
Definition: cs_lagr.h:379
cs_real_t w_merged
Definition: cs_lagr.h:415
cs_gnum_t n_g_deposited
Definition: cs_lagr.h:394
cs_real_t w_new
Definition: cs_lagr.h:409
Definition: cs_lagr.h:844
cs_real_t cstham
Definition: cs_lagr.h:847
cs_real_t fion
Definition: cs_lagr.h:866
cs_real_t phi_s
Definition: cs_lagr.h:860
cs_real_t lambda_vdw
Definition: cs_lagr.h:851
cs_real_t epseau
Definition: cs_lagr.h:854
cs_real_t phi_p
Definition: cs_lagr.h:857
cs_real_t valen
Definition: cs_lagr.h:863
Definition: cs_lagr.h:525
cs_real_t diameter
Definition: cs_lagr.h:530
int nbrclas
Definition: cs_lagr.h:528
cs_real_t * mp_diss
Definition: cs_lagr.h:538
cs_real_t rho
Definition: cs_lagr.h:532
int * nbprec
Definition: cs_lagr.h:534
cs_real_t * solub
Definition: cs_lagr.h:536
Definition: cs_lagr.h:503
int iflow
Definition: cs_lagr.h:511
cs_real_t denasp
Definition: cs_lagr.h:515
int ireent
Definition: cs_lagr.h:507
cs_real_t rayasp
Definition: cs_lagr.h:517
cs_real_t modyeq
Definition: cs_lagr.h:516
cs_real_t rayasg
Definition: cs_lagr.h:518
cs_real_t espasg
Definition: cs_lagr.h:514
Definition: cs_lagr.h:557
cs_real_t param_chmb
Definition: cs_lagr.h:559
Definition: cs_lagr.h:692
cs_real_t * volm
Definition: cs_lagr.h:745
int npts
Definition: cs_lagr.h:729
cs_real_t * t_st_k
Definition: cs_lagr.h:757
int ltsmas
Definition: cs_lagr.h:703
cs_real_t vmax
Definition: cs_lagr.h:736
cs_real_t tmamax
Definition: cs_lagr.h:739
int ltsthe
Definition: cs_lagr.h:711
cs_real_t * volp
Definition: cs_lagr.h:742
cs_real_3_t * t_st_vel
Definition: cs_lagr.h:751
cs_real_t * t_st_t_e
Definition: cs_lagr.h:763
cs_real_6_t * t_st_rij
Definition: cs_lagr.h:760
int ntxerr
Definition: cs_lagr.h:733
cs_real_t * t_st_imp_vel
Definition: cs_lagr.h:754
int ltsdyn
Definition: cs_lagr.h:697
int nstits
Definition: cs_lagr.h:726
cs_real_t * t_st_t_i
Definition: cs_lagr.h:766
cs_real_t * t_st_p
Definition: cs_lagr.h:748
Definition: cs_lagr.h:431
int & impvar
Definition: cs_lagr.h:477
int solve_temperature
Definition: cs_lagr.h:460
cs_real_t tpart
Definition: cs_lagr.h:486
cs_real_t cppart
Definition: cs_lagr.h:496
DISABLE_WARNING_POP int solve_temperature_seen
Definition: cs_lagr.h:453
int solve_mass
Definition: cs_lagr.h:475
int & itpvar
Definition: cs_lagr.h:463
int & idpvar
Definition: cs_lagr.h:470
DISABLE_WARNING_PUSH DISABLE_WARNING(-Wdeprecated-declarations) cs_lagr_specific_physics_t()
Default constructor with suppression of deprecated declarations, needed to hide warnings simply induc...
Definition: cs_lagr.h:442
int solve_diameter
Definition: cs_lagr.h:468
Definition: cs_lagr.h:182
int interpol_field
Definition: cs_lagr.h:228
int isttio
Definition: cs_lagr.h:210
int ilapoi
Definition: cs_lagr.h:235
int extended_t_scheme
Definition: cs_lagr.h:224
int isuila
Definition: cs_lagr.h:217
cs_real_t added_mass_const
Definition: cs_lagr.h:255
int cell_wise_integ
Definition: cs_lagr.h:259
cs_lnum_t max_track_propagation_loops
Definition: cs_lagr.h:263
int t_order
Definition: cs_lagr.h:220
int iilagr
Definition: cs_lagr.h:196
int iadded_mass
Definition: cs_lagr.h:252
int max_perio_or_rank_crossed
Definition: cs_lagr.h:266
Definition: cs_lagr.h:602
cs_real_t dtp
Definition: cs_lagr.h:605
cs_real_t ttclag
Definition: cs_lagr.h:608
Definition: cs_lagr.h:773
int n_zones
Definition: cs_lagr.h:777
cs_lagr_injection_set_t ** injection_set
Definition: cs_lagr.h:782
char * elt_type
Definition: cs_lagr.h:785
cs_real_t * particle_mass_flow
Definition: cs_lagr.h:788
int * zone_type
Definition: cs_lagr.h:778
int location_id
Definition: cs_lagr.h:775
cs_real_t * particle_heat_flow
Definition: cs_lagr.h:792
int * n_injection_sets
Definition: cs_lagr.h:780
