Field boundary condition descriptor (for variables)
Definition: cs_field.h:107
Definition: cs_defs.h:332
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:349
cs_real_t cs_real_2_t[2]
Definition: cs_defs.h:348
cs_real_t cs_real_6_t[6]
Definition: cs_defs.h:351
void cs_ext_force_anisotropic_flux(const cs_mesh_t *m, cs_mesh_quantities_t *fvq, int init, int nswrgp, int ircflp, const cs_real_3_t frcxt[], const cs_real_t cofbfp[], const cs_real_t i_visc[], const cs_real_t b_visc[], cs_real_6_t viscel[], const cs_real_2_t weighf[], cs_real_t *i_massflux, cs_real_t *b_massflux)
Project the external source terms to the faces in coherence with cs_face_anisotropic_diffusion_scalar...
void cs_tensor_divergence(const cs_mesh_t *m, int init, const cs_real_3_t i_massflux[], const cs_real_3_t b_massflux[], cs_real_3_t *diverg)
Add the integrated mass flux on the cells for a tensor variable.
void cs_divergence(const cs_mesh_t *m, int init, const cs_real_t i_massflux[], const cs_real_t b_massflux[], cs_real_t *diverg)
Add the integrated mass flux on the cells.
void cs_tensor_face_flux(const cs_mesh_t *m, const cs_mesh_quantities_t *fvq, int f_id, int itypfl, int iflmb0, int init, int inc, const cs_equation_param_t *eqp, const cs_real_t c_rho[], const cs_real_t b_rho[], const cs_real_6_t c_var[], const cs_field_bc_coeffs_t *bc_coeffs_ts, cs_real_3_t *i_massflux, cs_real_3_t *b_massflux)
Add to a flux.
void cs_mass_flux(const cs_mesh_t *m, const cs_mesh_quantities_t *fvq, int f_id, int itypfl, int iflmb0, int init, int inc, int imrgra, int nswrgu, cs_gradient_limit_t imligu, int iwarnu, double epsrgu, double climgu, const cs_real_t rom[], const cs_real_t romb[], const cs_real_3_t vel[], cs_field_bc_coeffs_t *bc_coeffs_v, cs_real_t *i_massflux, cs_real_t *b_massflux)
void cs_ext_force_flux(const cs_mesh_t *m, cs_mesh_quantities_t *fvq, int init, int nswrgu, const cs_real_3_t frcxt[], const cs_real_t cofbfp[], cs_real_t *i_massflux, cs_real_t *b_massflux, const cs_real_t i_visc[], const cs_real_t b_visc[], const cs_real_t viselx[], const cs_real_t visely[], const cs_real_t viselz[])
Project the external source terms to the faces in coherence with cs_face_diffusion_scalar for the imp...
@ vel
Definition: cs_field_pointer.h:66
cs_gradient_limit_t
Definition: cs_gradient.h:73
Definition: cs_mesh_quantities.h:88
