cs_cf_compute.h
1#ifndef CS_CF_CFL_COMPUTE__
2#define CS_CF_CFL_COMPUTE__
5 * Operators for compressible flows
35 * Local headers
38#include "base/cs_defs.h"
41 * Public function prototypes
44/*----------------------------------------------------------------------------*/
59/*----------------------------------------------------------------------------*/
60
61void
63 const cs_real_3_t *vel,
64 const cs_real_t *crom,
65 const cs_real_t *brom,
66 const cs_real_t *p,
67 cs_field_bc_coeffs_t *bc_coeffs_v,
68 cs_field_bc_coeffs_t *bc_coeffs_p,
69 cs_real_t *imasfl,
70 cs_real_t *bmasfl);
71
72/*----------------------------------------------------------------------------*/
73/*
74 * \param[in] iterns Navier-Stokes iteration number
75 */
76/*----------------------------------------------------------------------------*/
77
78void
80
81/*----------------------------------------------------------------------------*/
82/*
83 * \param[in] wcf compressible constraint
84 */
85/*----------------------------------------------------------------------------*/
86
87void
89
90/*----------------------------------------------------------------------------*/
91
92#endif /* CS_CF_CFL_COMPUTE__ */
Definition: cs_dispatch.h:2288
Field boundary condition descriptor (for variables)
Definition: cs_field.h:107
void cs_compressible_pressure_ausm_mass_flux(cs_dispatch_context &ctx, const cs_real_3_t *vel, const cs_real_t *crom, const cs_real_t *brom, const cs_real_t *p, cs_field_bc_coeffs_t *bc_coeffs_v, cs_field_bc_coeffs_t *bc_coeffs_p, cs_real_t *imasfl, cs_real_t *bmasfl)
Compute the "mass flux" at the faces for the CFL restriction computation and the solving of the press...
Definition: cs_cf_compute.cpp:555
void cs_cf_cfl_compute(cs_real_t wcf[])
Computation of the constraint for the CFL (compressible algorithm)
Definition: cs_cf_compute.cpp:1081
void cs_cf_convective_mass_flux(int iterns)
Update the convective mass flux before the velocity prediction step. It is the first step of the comp...
Definition: cs_cf_compute.cpp:718
Definition: cs_defs.h:332
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:349
@ p
Definition: cs_field_pointer.h:63
@ vel
Definition: cs_field_pointer.h:66
