cs_matrix_assembler.h File Reference
#include "base/cs_halo.h"
#include "base/cs_log.h"
+ Include dependency graph for cs_matrix_assembler.h:
Macros
#define CS_MATRIX_DISTANT_ROW_USE_COL_IDX   (1 << 0)
#define CS_MATRIX_DISTANT_ROW_USE_COL_G_ID   (1 << 1)
#define CS_MATRIX_EXTERNAL_HALO   (1 << 2)
Typedefs
typedef struct _cs_matrix_assembler_t cs_matrix_assembler_t
typedef struct _cs_matrix_assembler_values_t cs_matrix_assembler_values_t
typedef void() cs_matrix_assembler_values_init_t(void *matrix, cs_lnum_t db_size, cs_lnum_t eb_size)
 Function pointer for initialization of matrix coefficients using local row ids and column indexes. More...
typedef void() cs_matrix_assembler_values_add_t(void *matrix, cs_lnum_t n, cs_lnum_t stride, const cs_lnum_t row_id[], const cs_lnum_t col_idx[], const cs_real_t val[])
 Function pointer for addition to matrix coefficients using local row ids and column indexes. More...
typedef void() cs_matrix_assembler_values_add_g_t(void *matrix, cs_lnum_t n, cs_lnum_t stride, const cs_gnum_t row_g_id[], const cs_gnum_t col_g_id[], const cs_real_t val[])
 Function pointer for addition to matrix coefficients using global row ids and column indexes. More...
typedef void() cs_matrix_assembler_values_begin_t(void *matrix)
 Function pointer to start the final assembly of matrix coefficients. More...
typedef void() cs_matrix_assembler_values_end_t(void *matrix)
 Function pointer to complete the final assembly of matrix coefficients. More...
cs_matrix_assembler_t * cs_matrix_assembler_create (const cs_gnum_t l_range[2], bool separate_diag)
 Create a matrix assembler structure. More...
cs_matrix_assembler_t * cs_matrix_assembler_create_from_shared (cs_lnum_t n_rows, bool separate_diag, const cs_lnum_t row_idx[], const cs_lnum_t col_id[], const cs_halo_t *halo)
 Create a matrix assembler structure based on a given connectivity and associated halo structure. More...
void cs_matrix_assembler_destroy (cs_matrix_assembler_t **ma)
 Destroy a matrix assembler structure. More...
void cs_matrix_assembler_compute (cs_matrix_assembler_t *ma)
 Compute internal structures required by a matrix assembler. More...
void cs_matrix_assembler_set_options (cs_matrix_assembler_t *ma, int flags)
 Set option flags for a given matrix assembler structure. More...
int cs_matrix_assembler_get_options (const cs_matrix_assembler_t *ma)
 Return the option flags for a given matrix assembler structure. More...
void cs_matrix_assembler_add_g_ids (cs_matrix_assembler_t *ma, cs_lnum_t n, const cs_gnum_t row_g_id[], const cs_gnum_t col_g_id[])
 Add entries to a matrix assembler structure. More...
void cs_matrix_assembler_set_comm (cs_matrix_assembler_t *ma, MPI_Comm comm)
 Assign specific MPI communicator to matrix assembler. More...
const cs_gnum_t * cs_matrix_assembler_get_l_range (const cs_matrix_assembler_t *ma)
 Return a pointer to local global row range associated with a matrix assembler. More...
const cs_halo_t * cs_matrix_assembler_get_halo (const cs_matrix_assembler_t *ma)
 Return a pointer to the halo structure associated with a matrix assembler. More...
bool cs_matrix_assembler_get_separate_diag (const cs_matrix_assembler_t *ma)
 Indicate if the matrix assembler is based on a separate diagonal. More...
cs_lnum_t cs_matrix_assembler_get_n_rows (const cs_matrix_assembler_t *ma)
 Return the number of rows associated with a matrix assembler. More...
cs_gnum_t cs_matrix_assembler_get_n_g_rows (const cs_matrix_assembler_t *ma)
 Return the global number of rows associated with a matrix assembler. More...
cs_lnum_t cs_matrix_assembler_get_n_columns (const cs_matrix_assembler_t *ma)
 Return the number of columns associated with a matrix assembler. More...
const cs_lnum_t * cs_matrix_assembler_get_row_index (const cs_matrix_assembler_t *ma)
 Return a row index associated with a matrix assembler. More...
const cs_lnum_t * cs_matrix_assembler_get_col_ids (const cs_matrix_assembler_t *ma)
 Return a column ids associated with a matrix assembler. More...
void cs_matrix_assembler_get_rank_counts (const cs_matrix_assembler_t *ma, int rc[4])
 Return info on the number of neighbor ranks a matrix assembler may communicate with. More...
void cs_matrix_assembler_log_rank_counts (const cs_matrix_assembler_t *ma, cs_log_t log_id, const char *name)
 Log rank counts for a given matrix assembler. More...
cs_matrix_assembler_values_t * cs_matrix_assembler_values_create (const cs_matrix_assembler_t *ma, bool sep_diag, cs_lnum_t db_size, cs_lnum_t eb_size, void *matrix, cs_matrix_assembler_values_init_t *init, cs_matrix_assembler_values_add_t *add, cs_matrix_assembler_values_add_g_t *add_g, cs_matrix_assembler_values_begin_t *begin, cs_matrix_assembler_values_end_t *end)
 Create and initialize a matrix assembler values structure. More...
void cs_matrix_assembler_values_finalize (cs_matrix_assembler_values_t **mav)
 Finalize matrix assembler values structure. More...
void cs_matrix_assembler_values_add (cs_matrix_assembler_values_t *mav, cs_lnum_t n, const cs_lnum_t row_id[], const cs_lnum_t col_id[], const cs_real_t val[])
 Add values to a matrix assembler values structure using local row and column ids. More...
void cs_matrix_assembler_values_add_g (cs_matrix_assembler_values_t *mav, cs_lnum_t n, const cs_gnum_t row_g_id[], const cs_gnum_t col_g_id[], const cs_real_t val[])
 Add values to a matrix assembler values structure using global row and column ids. More...
void cs_matrix_assembler_values_done (cs_matrix_assembler_values_t *mav)
 Start assembly of matrix values structure. More...
◆ CS_MATRIX_DISTANT_ROW_USE_COL_G_ID
◆ CS_MATRIX_DISTANT_ROW_USE_COL_IDX
Matrix assembler option flags
◆ CS_MATRIX_EXTERNAL_HALO
Typedef Documentation
◆ cs_matrix_assembler_t
Structure used to pre-build a matrix structure
◆ cs_matrix_assembler_values_add_g_t
Values whose global row id is outside the local range should be ignored (this allows simply filtering values before calling this function, avoiding an extra copy (a copy will probably be done by the function anyways).
Warning
The matrix pointer must point to valid data when the selection function is called, so the life cycle of the data pointed to should be at least as long as that of the assembler values structure.
[in,out]matrixuntyped pointer to matrix description structure
[in]nnumber of values to add
[in]strideassociated data block size
[in]row_g_idassociated global row ids
[in]col_g_idassociated global column ids
[in]valpointer to values (size: n*stride)
◆ cs_matrix_assembler_values_add_t
Values whose associated row index is negative should be ignored; Values whose column index is -1 are assumed to be assigned to a separately stored diagonal. Other indexes should be valid.
Warning
Remarks
Note that we pass column indexes (not ids) here; as the caller is already assumed to have identified the index matching a given column id.
[in]row_idassociated local row ids
[in]col_idxassociated local column indexes
◆ cs_matrix_assembler_values_begin_t
Warning
◆ cs_matrix_assembler_values_end_t
Warning
◆ cs_matrix_assembler_values_init_t
Warning
[in]db_sizediagonal block sizes
[in]eb_sizeextra-diagonal block sizes
◆ cs_matrix_assembler_values_t
Structure used to set matrix coefficients
◆ cs_matrix_assembler_add_g_ids()
void cs_matrix_assembler_add_g_ids ( cs_matrix_assembler_t *  ma,
cs_lnum_t  n,
This function should be called by a single thread for a given assembler.
[in,out]mapointer to matrix assembler structure
[in]nnumber of entries
[in]col_g_idglobal column ids associated with entries
[in]row_g_idglobal row ids associated with entries
◆ cs_matrix_assembler_compute()
void cs_matrix_assembler_compute ( cs_matrix_assembler_t *  ma)
The associated vector halo is also computed at this stage.
◆ cs_matrix_assembler_create()
cs_matrix_assembler_t * cs_matrix_assembler_create ( const cs_gnum_t  l_range[2],
bool  separate_diag
The associated matrix structure data will initially be empty, though the range of rows associated with the current rank must be defined immediately.
[in]l_rangeglobal id range [min, max[ for local rank
[in]separate_diagif true, diagonal terms are handled separately
pointer to created matrix assembler structure
◆ cs_matrix_assembler_create_from_shared()
cs_matrix_assembler_t * cs_matrix_assembler_create_from_shared ( cs_lnum_t  n_rows,
bool  separate_diag,
const cs_halo_t *  halo
The assembler may not be later modified when built this way.
The connectivity arrays and halo will be shared by the caller, so their life cycle must be at least as long as the matrix assembler structure.
[in]n_rowsnumber fo local rows
[in]row_idxmatrix row index
[in]col_idmatrix column indexes
[in]haloassociated halo structure
◆ cs_matrix_assembler_destroy()
void cs_matrix_assembler_destroy ( cs_matrix_assembler_t **  ma)
[in,out]mapointer to matrix assembler structure pointer
◆ cs_matrix_assembler_get_col_ids()
const cs_lnum_t * cs_matrix_assembler_get_col_ids ( const cs_matrix_assembler_t *  ma)
These ids relative to all columns of successive rows, with columns ordered by local id, so local columns appear first, distant columns after. Depending on the separate_diag option used when creating the matrix assembler, the columns may include the diagonal or not. The matching index can be obtained using cs_matrix_assembler_get_row_index.
Warning
the returned index is valid only as long as the matrix assembly structure exists.
[in]mapointer to matrix assembler structure
pointer to matrix structure row index
◆ cs_matrix_assembler_get_halo()
const cs_halo_t * cs_matrix_assembler_get_halo ( const cs_matrix_assembler_t *  ma)
pointer to halo structure
◆ cs_matrix_assembler_get_l_range()
const cs_gnum_t * cs_matrix_assembler_get_l_range ( const cs_matrix_assembler_t *  ma)
pointer to local range
◆ cs_matrix_assembler_get_n_columns()
cs_lnum_t cs_matrix_assembler_get_n_columns ( const cs_matrix_assembler_t *  ma)
number of columns associated with matrix assembler
◆ cs_matrix_assembler_get_n_g_rows()
cs_gnum_t cs_matrix_assembler_get_n_g_rows ( const cs_matrix_assembler_t *  ma)
number of rows associated with matrix assembler
◆ cs_matrix_assembler_get_n_rows()
cs_lnum_t cs_matrix_assembler_get_n_rows ( const cs_matrix_assembler_t *  ma)
◆ cs_matrix_assembler_get_options()
int cs_matrix_assembler_get_options ( const cs_matrix_assembler_t *  ma)
Flags are defined as a sum (bitwise or) of constants, described in cs_matrix_assembler_set_options.
option flags (sum of integer constants) used y this structure
◆ cs_matrix_assembler_get_rank_counts()
void cs_matrix_assembler_get_rank_counts ( const cs_matrix_assembler_t *  ma,
int  rc[4]
[out]rcrank counts; the 4 values are:
  • 0 number of communicating ranks for vector update (halo)
  • 1 number of communicating ranks for matrix assembly
  • 2 maximum number of communicating ranks for halo construction (assumed ranks algorithm)
  • 3 maximum number of communicating ranks for matrix assembly determination (assumed ranks algorithm)
◆ cs_matrix_assembler_get_row_index()
const cs_lnum_t * cs_matrix_assembler_get_row_index ( const cs_matrix_assembler_t *  ma)
This index is a CSR type index relative to all columns, including or excluding the diagonal depending on the separate_diag option used when creating the matrix assembler. The matching column ids can be obtained using cs_matrix_assembler_get_col_ids.
Warning
◆ cs_matrix_assembler_get_separate_diag()
bool cs_matrix_assembler_get_separate_diag ( const cs_matrix_assembler_t *  ma)
true if the associated structure has a separate diagonal, false otherwise
◆ cs_matrix_assembler_log_rank_counts()
void cs_matrix_assembler_log_rank_counts ( const cs_matrix_assembler_t *  ma,
cs_log_t  log_id,
const char *  name
[in]log_idlog type
[in]namename of this assembler
◆ cs_matrix_assembler_set_comm()
void cs_matrix_assembler_set_comm ( cs_matrix_assembler_t *  ma,
MPI_Comm  comm
This must be called before cs_matrix_assembler_compute.
[in]commassigned MPI communicator
◆ cs_matrix_assembler_set_options()
void cs_matrix_assembler_set_options ( cs_matrix_assembler_t *  ma,
int  flags
When used, this function should be called before defining entries (in case of future option additions) and in any case before computing the final structure.
Flags are defined as a sum (bitwise or) of constants, described below:
  • CS_MATRIX_DISTANT_ROW_USE_COL_IDX indicates that column indexes matching distant row data are computed and maintained, so the associated coefficient contributions can be added more efficiently.
  • CS_MATRIX_DISTANT_ROW_USE_COL_G_ID indicates that columns global ids matching distant row data are maintained directly, so no lookup to a global id description of matrix columns is needed; this option is useful only when using an external library allowing incremental setting or accumulation of coefficients using global column ids, such as with PETSc's MatSetValues. When building matrices locally first (which includes most cases, whether internal matrices, or using library conversion or import functions such as PETSc's MatCreateMPIAIJWithArrays) this is slightly less efficient, as column ids will need to be matched to each row's columns a second time for those (exchanged) coefficients.
  • CS_MATRIX_EXTERNAL_HALO indicates that we do not need to build an associated halo structure, as it will be built externally (i.e. by an external library such as PETSc, HYPRE, ...) using its own equivalent structures.
[in]flagssum of matrix assembler flag constants (bitwise or)
◆ cs_matrix_assembler_values_add()
void cs_matrix_assembler_values_add ( cs_matrix_assembler_values_t *  mav,
cs_lnum_t  n,
If the matching matrix coefficients use a block structure, the values passed to this function should use the same block size.
Note also that if the matrix has different diagonal and extradiagonal block sizes, separate calls to this function should be used for both types of coefficients; in addition, in this case, diagonal coefficients should only be provided by the owning rank (this also impacts how the associated matrix assembler structure is defined).
This function may be called by different threads, as long those threads do not add contributions to the same rows (assuming caution is taken in the case of external libraries so that their builder functions have the same property).
[in,out]mavpointer to matrix assembler values structure
[in]col_idlocal column ids associated with entries
[in]row_idlocal row ids associated with entries
[in]valvalues associated with entries
◆ cs_matrix_assembler_values_add_g()
void cs_matrix_assembler_values_add_g ( cs_matrix_assembler_values_t *  mav,
cs_lnum_t  n,
◆ cs_matrix_assembler_values_create()
cs_matrix_assembler_values_t * cs_matrix_assembler_values_create ( const cs_matrix_assembler_t *  ma,
bool  sep_diag,
cs_lnum_t  db_size,
cs_lnum_t  eb_size,
void *  matrix,
cs_matrix_assembler_values_init_t *  init,
cs_matrix_assembler_values_add_t *  add,
cs_matrix_assembler_values_add_g_t *  add_g,
cs_matrix_assembler_values_begin_t *  begin,
cs_matrix_assembler_values_end_t *  end
The associated values will initially be set to zero.
This is a low-level function, which should be called by a simpler function (cs_matrix_assembler_values_init) which provides the necessary function pointers.
Warning
The matrix pointer must point to valid data when the selection function is called, so the life cycle of the data pointed to should be at least as long as that of the assembler values structure. In a similar manner, the life cycle of the associated matrix assembler must also be at least as long as that of the assembler values structure.
[in]maassociated matrix assembly structure
[in]sep_diagtrue if diagonal terms are stored separately
[in]initpointer to matrix coefficients initialization function
[in]addpointer to matrix coefficients addition from local ids function
[in]add_gpointer to matrix coefficients addition from global ids function
[in]beginpointer to matrix coefficients assembly start function (optional)
[in]endpointer to matrix coefficients assembly end function (optional)
pointer to initialized matrix assembler structure;
◆ cs_matrix_assembler_values_done()
void cs_matrix_assembler_values_done ( cs_matrix_assembler_values_t *  mav)
The call to this function is always optional, and indicates that assembly may begin. Calling it before cs_matrix_assembler_values_finalize may be useful when the underlying libraries can overlap communication (or other operations such as matrix trasformation) and computation.
Remarks
When values have been added to rows belonging to another rank, communication will occur here. Splitting this function could add another opportunity for overlap of computation and communication, but is not done as of 2016, as it would add complexity, with probably limited returns, as the effective asynchonous progress of MPI libraries is usually limited.
[in,out]mavpointer to matrix assembler data structure
◆ cs_matrix_assembler_values_finalize()
void cs_matrix_assembler_values_finalize ( cs_matrix_assembler_values_t **  mav)
When this function returns, the assembler values structure has been destroyed, and the associated matrix is fully assembled (i.e. ready to use).
[in,out]mavpointer to matrix assembler values structure pointer
