cs_mesh_connect.h
1#ifndef CS_MESH_CONNECT_H
2#define CS_MESH_CONNECT_H
5 * Extract nodal connectivity mesh representations from a native mesh.
31 * Local headers
34#include "fvm/fvm_nodal.h"
36#include "base/cs_base.h"
37#include "mesh/cs_mesh.h"
38
43/*=============================================================================
44 * Macro definitions
46
48 * Type definitions
50
51/*============================================================================
52 * Static global variables
53 *============================================================================*/
54
55/*=============================================================================
56 * Public function prototypes
58
59/*----------------------------------------------------------------------------
60 * Extract a mesh's "cells -> faces" connectivity.
61 *
62 * We consider a common numbering for internal and boundary faces, in which
63 * boundary faces are defined first. The common id for the i-th boundary
64 * face is thus i, and that of the j-th interior face is n_b_faces + j.
65 *
66 * If ind_cel_extr != NULL, then:
67 * --- ind_cel_extr[cell_id] = id in the list to extract (0 to n-1)
68 * if cell cell_id should be extracted
69 * --- ind_cel_extr[cell_id] = -1 if cells cell_id should be ignored
70 *
71 * parameters:
72 * mesh <-- pointer to mesh structure
73 * extr_cell_size <-- size of extr_cell_id[] array
74 * extr_cell_id <-- extr_cell_id = ids of extracted cells, or -1
75 * p_cell_faces_idx --> cells -> faces index
76 * p_cell_faces_val --> cells -> faces connectivity
77 *----------------------------------------------------------------------------*/
78
79void
81 cs_lnum_t extr_cell_size,
82 const cs_lnum_t extr_cell_id[],
83 cs_lnum_t **const p_cell_faces_idx,
84 cs_lnum_t **const p_cell_faces_val);
85
86/*----------------------------------------------------------------------------
87 * Build a nodal connectivity structure from a subset of a mesh's cells.
88 *
89 * The list of cells to extract is optional (if none is given, all cells
90 * faces are extracted by default).
91 *
92 * parameters:
93 * mesh <-- base mesh
94 * name <-- extracted mesh name
95 * include_families <-- include family info if true
96 * cell_list_size <-- size of cell_list[] array
97 * cell_list <-- list of cells (0 to n-1), or NULL
98 *
99 * returns:
100 * pointer to extracted nodal mesh
101 *----------------------------------------------------------------------------*/
102
103fvm_nodal_t *
105 const char *name,
106 bool include_families,
107 cs_lnum_t cell_list_size,
108 const cs_lnum_t cell_list[]);
109
110/*----------------------------------------------------------------------------
111 * Build a nodal connectivity structure from a subset of a mesh's faces.
112 *
113 * The lists of faces to extract are optional (if none is given, boundary
114 * faces are extracted by default).
115 *
116 * parameters:
117 * mesh <-- base mesh
118 * name <-- extracted mesh name
119 * include_families <-- include family info if true
120 * i_face_list_size <-- size of i_face_list[] array
121 * b_face_list_size <-- size of b_face_list[] array
122 * i_face_list <-- list of interior faces (0 to n-1), or NULL
123 * b_face_list <-- list of boundary faces (0 to n-1), or NULL
124 *
125 * returns:
126 * pointer to extracted nodal mesh
127 *----------------------------------------------------------------------------*/
128
129fvm_nodal_t *
131 const char *name,
132 bool include_families,
133 cs_lnum_t i_face_list_size,
134 cs_lnum_t b_face_list_size,
135 const cs_lnum_t i_face_list[],
136 const cs_lnum_t b_face_list[]);
137
138/*----------------------------------------------------------------------------*/
150/*----------------------------------------------------------------------------*/
151
152void
154 const char v_flag[],
155 cs_lnum_t **v2c_idx,
156 cs_lnum_t **v2c);
157
158/*----------------------------------------------------------------------------*/
159
161
162#endif /* CS_MESH_CONNECT_H */
Definition: cs_defs.h:528
Definition: cs_defs.h:529
Definition: cs_defs.h:325
fvm_nodal_t * cs_mesh_connect_cells_to_nodal(const cs_mesh_t *mesh, const char *name, bool include_families, cs_lnum_t cell_list_size, const cs_lnum_t cell_list[])
Definition: cs_mesh_connect.cpp:440
void cs_mesh_connect_get_cell_faces(const cs_mesh_t *mesh, cs_lnum_t extr_cell_size, const cs_lnum_t extr_cell_id[], cs_lnum_t **const p_cell_faces_idx, cs_lnum_t **const p_cell_faces_val)
Definition: cs_mesh_connect.cpp:285
void cs_mesh_connect_vertices_to_cells(cs_mesh_t *mesh, const char v_flag[], cs_lnum_t **v2c_idx, cs_lnum_t **v2c)
Build a vertex to cell connectivity for marked vertices only.
Definition: cs_mesh_connect.cpp:755
fvm_nodal_t * cs_mesh_connect_faces_to_nodal(const cs_mesh_t *mesh, const char *name, bool include_families, cs_lnum_t i_face_list_size, cs_lnum_t b_face_list_size, const cs_lnum_t i_face_list[], const cs_lnum_t b_face_list[])
Definition: cs_mesh_connect.cpp:689
Definition: mesh.f90:26
Definition: cs_mesh.h:85
