cs_gui.cpp File Reference
#include <fcntl.h>
#include <unistd.h>
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "fvm/fvm_selector.h"
#include "base/cs_all_to_all.h"
#include "base/cs_array.h"
#include "atmo/cs_atmo.h"
#include "base/cs_base.h"
#include "base/cs_boundary.h"
#include "cfbl/cs_cf_model.h"
#include "cdo/cs_domain_setup.h"
#include "cdo/cs_equation.h"
#include "cdo/cs_equation_param.h"
#include "base/cs_ext_neighborhood.h"
#include "base/cs_field.h"
#include "base/cs_file.h"
#include "base/cs_function.h"
#include "base/cs_log.h"
#include "gui/cs_gui_util.h"
#include "gui/cs_gui_boundary_conditions.h"
#include "gui/cs_gui_specific_physics.h"
#include "gui/cs_gui_mobile_mesh.h"
#include "mesh/cs_geom.h"
#include "base/cs_internal_coupling.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "meg/cs_meg_prototypes.h"
#include "meg/cs_meg_xdef_wrapper.h"
#include "mesh/cs_mesh.h"
#include "alge/cs_multigrid.h"
#include "base/cs_order.h"
#include "base/cs_parall.h"
#include "base/cs_porous_model.h"
#include "alge/cs_param_sles.h"
#include "mesh/cs_partition.h"
#include "cdo/cs_property.h"
#include "base/cs_restart.h"
#include "base/cs_restart_map.h"
#include "base/cs_rotation.h"
#include "base/cs_selector.h"
#include "base/cs_timer.h"
#include "base/cs_time_moment.h"
#include "base/cs_time_table.h"
#include "cdo/cs_thermal_system.h"
#include "base/cs_physical_properties.h"
#include "base/cs_turbomachinery.h"
#include "alge/cs_sles.h"
#include "alge/cs_sles_it.h"
#include "base/cs_wall_functions.h"
#include "alge/cs_balance_by_zone.h"
#include "base/cs_fan.h"
#include "base/cs_velocity_pressure.h"
#include "base/cs_vof.h"
#include "base/cs_volume_zone.h"
#include "gui/cs_gui.h"
void cs_gui_cp_params (void)
void cs_gui_laminar_viscosity (void)
void cs_gui_dt (void)
void cs_gui_hydrostatic_pressure (void)
void cs_gui_hydrostatic_equ_param (void)
void cs_gui_dt_param (void)
void cs_gui_porosity (void)
void cs_gui_checkpoint_parameters (void)
 Read GUi-defined Checkpoint parameters. More...
void cs_gui_equation_parameters (void)
void cs_gui_finalize (void)
cs_equation_param_t * cs_gui_get_equation_param (const char *name)
void cs_gui_fluid_properties_value (const char *param, double *value)
void cs_gui_groundwater_property_laws (int permeability, int diffusion, int unsaturated)
void cs_gui_head_losses (const cs_zone_t *zone, const cs_real_3_t *cvara_vel, cs_real_t cku[][6])
 Compute GUI-defined head losses for a given volume zone. More...
void cs_gui_initial_conditions (void)
 Apply initial conditions based on GUI-defined settings. More...
void cs_gui_linear_solvers (void)
void cs_gui_momentum_source_terms (const cs_real_3_t *restrict vel, cs_real_3_t *restrict tsexp, cs_real_33_t *restrict tsimp)
void cs_gui_numerical_options (void)
void cs_gui_parallel_io (void)
void cs_gui_partition (void)
void cs_gui_mpi_algorithms (void)
void cs_gui_physical_constants (void)
void cs_gui_physical_properties (void)
void cs_gui_porous_model (void)
void cs_gui_properties_value (const char *property_name, double *value)
void cs_gui_properties_value_by_fluid_id (const int fluid_id, const char *property_name, double *value)
void cs_gui_scalar_model_settings (void)
void cs_gui_thermal_model (void)
int cs_gui_thermal_model_code (void)
void cs_gui_time_moments (void)
void cs_gui_turbomachinery (void)
void cs_gui_turbomachinery_rotor (void)
void cs_gui_turb_model (void)
void cs_gui_turb_ref_values (void)
void cs_gui_usage_log (void)
void cs_gui_user_variables (void)
void cs_gui_user_arrays (void)
void cs_gui_calculator_functions (void)
void cs_gui_zones (void)
void cs_gui_balance_by_zone (void)
void cs_gui_pressure_drop_by_zone (void)
void cs_gui_define_fans (void)
void cs_gui_error_estimator (void)
void cs_gui_internal_coupling (void)
const cs_gui_volume_meg_context_t * cs_gui_add_volume_meg_context (const cs_zone_t *zone, const cs_field_t *fields[], const int n_fields)
 Add new MEG context info. More...
void cs_gui_scalar_source_terms (cs_field_t *f, const cs_real_t *restrict pvar, cs_real_t *restrict tsexp, cs_real_t *restrict tsimp)
void cs_gui_thermal_source_terms (cs_field_t *f, const cs_real_t *restrict pvar, cs_real_t *restrict tsexp, cs_real_t *restrict tsimp)
void cs_gui_thermal_source_terms_setup (void)
 Define thermal scalar source terms as xdef. More...
void cs_gui_time_tables (void)
 Read GUI defined time tables. More...
void cs_gui_physical_variable (void)
int cs_gui_physical_properties_ht_lambda_is_anisotropic (void)
◆ cs_gui_add_volume_meg_context()
const cs_gui_volume_meg_context_t * cs_gui_add_volume_meg_context ( const cs_zone_t *  zone,
const cs_field_t *  fields[],
const int  n_fields
Add new volume MEG function context info.
[in]zonepointer to associated zone
[in]fieldsarray of field pointers
[in]n_fieldsnumber gof field pointers
: pointer to MEG context info
◆ cs_gui_balance_by_zone()
void cs_gui_balance_by_zone ( void  )
◆ cs_gui_calculator_functions()
void cs_gui_calculator_functions ( void  )
◆ cs_gui_checkpoint_parameters()
void cs_gui_checkpoint_parameters ( void  )
◆ cs_gui_cp_params()
void cs_gui_cp_params ( void  )
◆ cs_gui_define_fans()
void cs_gui_define_fans ( void  )
◆ cs_gui_dt()
void cs_gui_dt ( void  )
◆ cs_gui_dt_param()
void cs_gui_dt_param ( void  )
◆ cs_gui_equation_parameters()
void cs_gui_equation_parameters ( void  )
◆ cs_gui_error_estimator()
void cs_gui_error_estimator ( void  )
◆ cs_gui_finalize()
void cs_gui_finalize ( void  )
◆ cs_gui_fluid_properties_value()
void cs_gui_fluid_properties_value ( const char *  param,
double *  value
◆ cs_gui_get_equation_param()
cs_equation_param_t * cs_gui_get_equation_param ( const char *  name)
◆ cs_gui_groundwater_property_laws()
void cs_gui_groundwater_property_laws ( int  permeability,
int  diffusion,
int  unsaturated
◆ cs_gui_head_losses()
void cs_gui_head_losses ( const cs_zone_t *  zone,
const cs_real_3_t *  cvara_vel,
cs_real_t  cku[][6]
Head loss tensor coefficients for each cell are organized as follows: cku11, cku22, cku33, cku12, cku13, cku23.
[in]zonepointer to zone structure
[in]cvara_velvelocity values at the previous time step
[in,out]ckuhead loss coefficients
◆ cs_gui_hydrostatic_equ_param()
void cs_gui_hydrostatic_equ_param ( void  )
◆ cs_gui_hydrostatic_pressure()
void cs_gui_hydrostatic_pressure ( void  )
◆ cs_gui_initial_conditions()
void cs_gui_initial_conditions ( void  )
◆ cs_gui_internal_coupling()
void cs_gui_internal_coupling ( void  )
◆ cs_gui_laminar_viscosity()
void cs_gui_laminar_viscosity ( void  )
◆ cs_gui_linear_solvers()
void cs_gui_linear_solvers ( void  )
◆ cs_gui_momentum_source_terms()
void cs_gui_momentum_source_terms ( const cs_real_3_t *restrict  vel,
◆ cs_gui_mpi_algorithms()
void cs_gui_mpi_algorithms ( void  )
◆ cs_gui_numerical_options()
void cs_gui_numerical_options ( void  )
◆ cs_gui_parallel_io()
void cs_gui_parallel_io ( void  )
◆ cs_gui_partition()
void cs_gui_partition ( void  )
◆ cs_gui_physical_constants()
void cs_gui_physical_constants ( void  )
◆ cs_gui_physical_properties()
void cs_gui_physical_properties ( void  )
◆ cs_gui_physical_properties_ht_lambda_is_anisotropic()
int cs_gui_physical_properties_ht_lambda_is_anisotropic ( void  )
◆ cs_gui_physical_variable()
void cs_gui_physical_variable ( void  )
◆ cs_gui_porosity()
void cs_gui_porosity ( void  )
◆ cs_gui_porous_model()
void cs_gui_porous_model ( void  )
◆ cs_gui_pressure_drop_by_zone()
void cs_gui_pressure_drop_by_zone ( void  )
◆ cs_gui_properties_value()
void cs_gui_properties_value ( const char *  property_name,
double *  value
◆ cs_gui_properties_value_by_fluid_id()
void cs_gui_properties_value_by_fluid_id ( const int  fluid_id,
double *  value
◆ cs_gui_scalar_model_settings()
void cs_gui_scalar_model_settings ( void  )
◆ cs_gui_scalar_source_terms()
void cs_gui_scalar_source_terms ( cs_field_t *  f,
◆ cs_gui_thermal_model()
void cs_gui_thermal_model ( void  )
◆ cs_gui_thermal_model_code()
int cs_gui_thermal_model_code ( void  )
◆ cs_gui_thermal_source_terms()
void cs_gui_thermal_source_terms ( cs_field_t *  f,
◆ cs_gui_thermal_source_terms_setup()
void cs_gui_thermal_source_terms_setup ( void  )
◆ cs_gui_time_moments()
void cs_gui_time_moments ( void  )
◆ cs_gui_time_tables()
void cs_gui_time_tables ( void  )
◆ cs_gui_turb_model()
void cs_gui_turb_model ( void  )
◆ cs_gui_turb_ref_values()
void cs_gui_turb_ref_values ( void  )
◆ cs_gui_turbomachinery()
void cs_gui_turbomachinery ( void  )
◆ cs_gui_turbomachinery_rotor()
void cs_gui_turbomachinery_rotor ( void  )
◆ cs_gui_usage_log()
void cs_gui_usage_log ( void  )
◆ cs_gui_user_arrays()
void cs_gui_user_arrays ( void  )
◆ cs_gui_user_variables()
void cs_gui_user_variables ( void  )
◆ cs_gui_zones()
void cs_gui_zones ( void  )
