cs_cf_model.h
1#ifndef CS_CF_MODEL_H
2#define CS_CF_MODEL_H
5 * Thermodynamic laws for the compressible module
30#include "base/cs_defs.h"
33 * Standard C library headers
37 * Local headers
38 *----------------------------------------------------------------------------*/
41 * Type definitions
44/* compressible model general options descriptor */
45/*-----------------------------------------------*/
46
47typedef struct {
48
49 int ieos; /* indicator of equation of state */
50
51 int ithvar; /* indicator for thermodynamic
52 variables initialization */
53
54 int icfgrp; /* indicator for hydrostatic balance
55 in boundary conditions */
56
57 double psginf; /* stiffened gas limit pressure (zero in
58 perfect gas) (Pa) for single phase model */
59
60 double gammasg; /* stiffened gas polytropic coefficient,
61 (dimensionless) for single phase model */
62
63 int hgn_relax_eq_st; /* source term step:
64 - -1 disabled
65 - 0 enabled */
66
68
69typedef enum {
70
77
79
80/*============================================================================
81 * Static global variables
82 *============================================================================*/
83
84/* pointer to main compressible model descriptor structure */
85
87
88/*=============================================================================
89 * Public function definitions
90 *============================================================================*/
91
92/*----------------------------------------------------------------------------*/
93/*
94 * \brief Provide access to compressible model global structure cs_glob_cf_model
95 */
96/*----------------------------------------------------------------------------*/
97
100
101/*----------------------------------------------------------------------------*/
102/*
103 * \brief Variable field definitions for the compressible module,
104 * according to calculation type selected by the user.
105 */
106/*----------------------------------------------------------------------------*/
107
108void
110
111/*----------------------------------------------------------------------------*/
112/*
113 * \brief Property field definitions for the compressible module,
114 * according to calculation type selected by the user.
115 */
116/*----------------------------------------------------------------------------*/
117
118void
120
121/*----------------------------------------------------------------------------*/
122/*
123 * \brief Setup options specific to the compressible model.
124 */
125/*----------------------------------------------------------------------------*/
126
127void
128cs_cf_setup(void);
129
130/*----------------------------------------------------------------------------*/
131/*
132 * \brief Print the compressible module options to setup.log.
133 */
134/*----------------------------------------------------------------------------*/
135
136void
138
139/*----------------------------------------------------------------------------*/
140/*
141 * \brief Initialize variables of the compressible flow model.
142 */
143/*----------------------------------------------------------------------------*/
144
145void
146cs_cf_initialize(void);
147
148/*----------------------------------------------------------------------------*/
149/*
150 * \brief Compute variable physical properties for the compressible model.
151 */
152/*----------------------------------------------------------------------------*/
153
154void
156
157/*----------------------------------------------------------------------------*/
158
159#endif /* CS_CF_MODEL_H */
const cs_cf_model_t * cs_glob_cf_model
void cs_cf_setup(void)
Definition: cs_cf_model.cpp:378
void cs_cf_model_log_setup(void)
Definition: cs_cf_model.cpp:422
void cs_cf_add_property_fields(void)
Property field definitions for the compressible module, according to calculation type selected by the...
Definition: cs_cf_model.cpp:319
void cs_cf_physical_properties(void)
Compute variable physical properties for the compressible module.
Definition: cs_cf_model.cpp:473
void cs_cf_add_variable_fields(void)
Variable field definitions for the compressible module, according to calculation type selected by the...
Definition: cs_cf_model.cpp:200
void cs_cf_initialize(void)
Definition: cs_cf_model.cpp:449
cs_cf_model_t * cs_get_glob_cf_model(void)
Provide access to compressible model global structure cs_glob_cf_model.
Definition: cs_cf_model.cpp:187
cs_cf_model_eos_t
Definition: cs_cf_model.h:69
@ CS_EOS_STIFFENED_GAS
Definition: cs_cf_model.h:73
@ CS_EOS_IDEAL_GAS
Definition: cs_cf_model.h:72
@ CS_EOS_MOIST_AIR
Definition: cs_cf_model.h:76
@ CS_EOS_NONE
Definition: cs_cf_model.h:71
@ CS_EOS_GAS_MIX
Definition: cs_cf_model.h:74
@ CS_EOS_HOMOGENEOUS_TWO_PHASE
Definition: cs_cf_model.h:75
int hgn_relax_eq_st
Definition: cs_cf_model.h:63
int icfgrp
Definition: cs_cf_model.h:54
double psginf
Definition: cs_cf_model.h:57
int ieos
Definition: cs_cf_model.h:49
int ithvar
Definition: cs_cf_model.h:51
double gammasg
Definition: cs_cf_model.h:60
Compressible model general options descriptor.
Definition: cs_cf_model.h:47
