228 int extra_partitions_list[]);
cs_log_t
Definition: cs_log.h:44
void cs_partition_set_write_level(int write_flag)
Set partitioning write to file option.
Definition: cs_partition.cpp:3148
void cs_partition_set_preprocess_hints(bool join, bool join_periodic)
Define hints indicating if initial partitioning fo a preprocessing stage is required.
Definition: cs_partition.cpp:3165
bool cs_partition_get_preprocess(void)
Indicate if re-partitiong for the computation stage is required.
Definition: cs_partition.cpp:3200
cs_partition_algorithm_t
Definition: cs_partition.h:105
@ CS_PARTITION_METIS
Definition: cs_partition.h:113
@ CS_PARTITION_SFC_HILBERT_CUBE
Definition: cs_partition.h:111
@ CS_PARTITION_SFC_MORTON_CUBE
Definition: cs_partition.h:109
@ CS_PARTITION_BLOCK
Definition: cs_partition.h:114
@ CS_PARTITION_SFC_MORTON_BOX
Definition: cs_partition.h:108
@ CS_PARTITION_DEFAULT
Definition: cs_partition.h:107
@ CS_PARTITION_SCOTCH
Definition: cs_partition.h:112
@ CS_PARTITION_SFC_HILBERT_BOX
Definition: cs_partition.h:110
void cs_partition_external_library_info(cs_log_t log_type)
Print information on external libraries.
Definition: cs_partition.cpp:3002
void cs_partition_add_partitions(int n_extra_partitions, int extra_partitions_list[])
Define list of extra partitionings to build.
Definition: cs_partition.cpp:3245
void cs_partition_set_preprocess(bool active)
Activate or deactivate initial partitioning for preprocessing.
Definition: cs_partition.cpp:3182
void cs_partition_set_algorithm(cs_partition_stage_t stage, cs_partition_algorithm_t algorithm, int rank_step, bool ignore_perio)
Set algorithm for domain partitioning.
Definition: cs_partition.cpp:3065
void cs_partition(cs_mesh_t *mesh, cs_mesh_builder_t *mb, cs_partition_stage_t stage, int cell_dest[])
Partition mesh based on current options.
Definition: cs_partition.cpp:3275
Definition: cs_partition.h:80
@ CS_PARTITION_FOR_PREPROCESS
Definition: cs_partition.h:82
@ CS_PARTITION_P2P
Definition: cs_partition.h:84
@ CS_PARTITION_MAIN
Definition: cs_partition.h:83
@ CS_PARTITION_STAGE_COUNT
Definition: cs_partition.h:86
Definition: cs_mesh_builder.h:57
