cs_mesh_adaptive_refinement.cpp File Reference
#include <float.h>
#include <limits.h>
#include <mpi.h>
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "fvm/fvm_io_num.h"
#include "fvm/fvm_triangulate.h"
#include "alge/cs_cell_to_vertex.h"
#include "alge/cs_gradient.h"
#include "alge/cs_matrix_default.h"
#include "base/cs_array.h"
#include "base/cs_ext_neighborhood.h"
#include "base/cs_field.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "base/cs_parall.h"
#include "base/cs_renumber.h"
#include "base/cs_renumber_update.h"
#include "base/cs_timer_stats.h"
#include "mesh/cs_mesh.h"
#include "mesh/cs_mesh_adjacencies.h"
#include "mesh/cs_mesh_coarsen.h"
#include "mesh/cs_mesh_coherency.h"
#include "mesh/cs_mesh_refine.h"
#include "mesh/cs_redistribute.h"
#include "mesh/cs_partition.h"
#include "mesh/cs_mesh_adaptive_refinement.h"
+ Include dependency graph for cs_mesh_adaptive_refinement.cpp:
static void _build_cell_r_level (cs_mesh_t *m, int *c_r_level)
static void _realloc_and_update_field_refinement (cs_field_t *f, const cs_lnum_t n_old, const cs_lnum_t o2n_idx[], const cs_lnum_t new_idx[], const cs_real_3_t cog[], const cs_real_3_t cell_cen[], const cs_real_t measure[])
static void _realloc_and_update_bc_coeffs_refinement (const cs_field_t *f, const cs_lnum_t n_old, const cs_lnum_t o2n_idx[])
static void _realloc_and_update_field_coarsening (cs_field_t *f, const cs_lnum_t n_old, const cs_lnum_t n2o_idx[], const cs_lnum_t n2o[], const cs_real_t measure[], const cs_lnum_t i_face_map[])
static void _realloc_and_update_bc_coeffs_coarsening (cs_field_t *f, const cs_lnum_t n_old, const cs_lnum_t n2o_idx[], const cs_lnum_t n2o[], const cs_real_t measure[])
static void _halo_sync_std_owner (cs_field_t *f, const cs_halo_t *halo)
 Sync a standard field. More...
static void _halo_sync_series_owner (cs_field_t *f, const cs_halo_t *halo)
 Sync a field which is a series owner and has subfields. More...
static void _halo_sync (cs_field_t *f)
 Sync a field. More...
static void _realloc_and_interp_after_refinement (cs_mesh_t *mesh, int location_id, const cs_lnum_t n_i_elts, const cs_lnum_t o2n_idx[], const cs_lnum_t new_idx[], const cs_real_3_t o_cog[], const cs_real_3_t n_cog[], const cs_real_t measure[])
static void _realloc_and_interp_after_coarsening (cs_mesh_t *mesh, int location_id, const cs_lnum_t n_i_elts, const cs_lnum_t n2o_idx[], const cs_lnum_t n2o[], const cs_real_t measure[], const cs_lnum_t i_face_map[])
static void _propagate_refinement (cs_mesh_t *m, int indic[])
static void _build_coarsen_refine_buffer_zone (cs_mesh_t *mesh, int indic[])
static void _load_balance (cs_mesh_t *mesh)
static void _free_gradients (void)
static void _update_mesh_quantities (cs_mesh_t *mesh)
static void _update_boundary_conditions (void)
static void _update_amr_mesh_data (cs_mesh_t *mesh)
static void _refine_step (const int indic[])
static void _coarsen_step (const int indic[])
static void _amr_finalize (void)
 Finalize AMR. More...
void cs_adaptive_refinement_define (int n_layers, int nt_interval, cs_amr_indicator_t *indic_func, const void *indic_input, int interpolation, bool load_balance)
 Activation and Initializing af the global AMR structure. More...
void cs_adaptive_refinement_update_gradients (void)
 Compute field gradients when necessary (for fields interpolation) More...
void cs_adaptive_refinement_free_gradients (void)
 Free field gradients. More...
void cs_adaptive_refinement_step (void)
 Perform a refinement / coarsening step. More...
static cs_amr_info_t _amr_info
cs_amr_info_t * cs_glob_amr_info = &_amr_info
static cs_timer_counter_t _amr_t_tot
static cs_timer_counter_t _amr_t_coarsen
static cs_timer_counter_t _amr_t_refine
static cs_timer_counter_t _amr_t_data
static cs_timer_counter_t _amr_t_load_balance
static cs_timer_counter_t _amr_t_renumber
static int _amr_stat_id = -1
◆ _amr_finalize()
static void _amr_finalize ( void  )
static
Finalize AMR.
This simply logs associated timers.
◆ _build_cell_r_level()
static void _build_cell_r_level ( cs_mesh_t *  m,
int *  c_r_level
static
◆ _build_coarsen_refine_buffer_zone()
static void _build_coarsen_refine_buffer_zone ( cs_mesh_t *  mesh,
int  indic[]
static
◆ _coarsen_step()
static void _coarsen_step ( const int  indic[])
static
◆ _free_gradients()
static void _free_gradients ( void  )
static
◆ _halo_sync()
static void _halo_sync ( cs_field_t *  f)
static
Sync a field.
[in]fpointer to cs_field_t
◆ _halo_sync_series_owner()
static void _halo_sync_series_owner ( cs_field_t *  f,
const cs_halo_t *  halo
static
[in]halopointer to cs_halo_t
◆ _halo_sync_std_owner()
static void _halo_sync_std_owner ( cs_field_t *  f,
static
◆ _load_balance()
static void _load_balance ( cs_mesh_t *  mesh)
static
◆ _propagate_refinement()
static void _propagate_refinement ( cs_mesh_t *  m,
int  indic[]
static
◆ _realloc_and_interp_after_coarsening()
static void _realloc_and_interp_after_coarsening ( cs_mesh_t *  mesh,
int  location_id,
static
◆ _realloc_and_interp_after_refinement()
static void _realloc_and_interp_after_refinement ( cs_mesh_t *  mesh,
int  location_id,
static
◆ _realloc_and_update_bc_coeffs_coarsening()
static void _realloc_and_update_bc_coeffs_coarsening ( cs_field_t *  f,
static
◆ _realloc_and_update_bc_coeffs_refinement()
static void _realloc_and_update_bc_coeffs_refinement ( const cs_field_t *  f,
static
◆ _realloc_and_update_field_coarsening()
static void _realloc_and_update_field_coarsening ( cs_field_t *  f,
static
◆ _realloc_and_update_field_refinement()
static void _realloc_and_update_field_refinement ( cs_field_t *  f,
static
◆ _refine_step()
static void _refine_step ( const int  indic[])
static
◆ _update_amr_mesh_data()
static void _update_amr_mesh_data ( cs_mesh_t *  mesh)
static
◆ _update_boundary_conditions()
static void _update_boundary_conditions ( void  )
static
◆ _update_mesh_quantities()
static void _update_mesh_quantities ( cs_mesh_t *  mesh)
static
◆ cs_adaptive_refinement_define()
void cs_adaptive_refinement_define ( int  n_layers,
int  nt_interval,
cs_amr_indicator_t *  indic_func,
const void *  indic_input,
int  interpolation,
bool  load_balance
[in]n_layersnumber of layers of refinement around user criteria
[in]nt_intervaltime_step interval between adaptation steps
[in]indic_funcuser function marking cells that should be refined
[in]indic_inputinput for indic_func or nullptr
[in]load_balanceactivate load balancing post mesh adapation
◆ cs_adaptive_refinement_free_gradients()
void cs_adaptive_refinement_free_gradients ( void  )
◆ cs_adaptive_refinement_step()
void cs_adaptive_refinement_step ( void  )
◆ cs_adaptive_refinement_update_gradients()
void cs_adaptive_refinement_update_gradients ( void  )
◆ _amr_info
static
Initial value:
false,
0,
cs_time_control_t(-1, -1, -1, false, false, false),
nullptr,
nullptr,
nullptr,
nullptr,
0,
nullptr,
false
Definition: cs_time_control.h:92
◆ _amr_stat_id
static
◆ _amr_t_coarsen
static
◆ _amr_t_data
static
◆ _amr_t_load_balance
static
◆ _amr_t_refine
static
◆ _amr_t_renumber
static
◆ _amr_t_tot
static
◆ cs_glob_amr_info
cs_amr_info_t* cs_glob_amr_info = &_amr_info
