cs_amr_info_t Struct Reference
#include <cs_mesh_adaptive_refinement.h>
+ Collaboration diagram for cs_amr_info_t:
Public Attributes
bool is_set
int n_layers
cs_time_control_t time_control
cs_amr_indicator_t * indic_func
const void * indic_input
cs_amr_refinement_interpolation_t * fields_interp_refinement_func
cs_amr_coarsening_interpolation_t * fields_interp_coarsening_func
int interpolation
int * indic_cells
bool load_balance
Member Data Documentation
◆ fields_interp_coarsening_func
cs_amr_coarsening_interpolation_t* fields_interp_coarsening_func
Fields interpolation function for coarsening
◆ fields_interp_refinement_func
cs_amr_refinement_interpolation_t* fields_interp_refinement_func
Fields interpolation function for refinement
◆ indic_cells
int* indic_cells
Array of size cs_glob_mesh->n_cells_with_ghosts that tags cells for coarsening/refinement.
◆ indic_func
cs_amr_indicator_t* indic_func
Associated indicator computation function.
◆ indic_input
const void* indic_input
Pointer to optional (untyped) value or structure.
◆ interpolation
int interpolation
0: P0 interpolation (default) 1: simple gradient-based interpolation for fields on cells (ignored for boundaries).
◆ is_set
bool is_set
Indicates if AMR is active.
◆ load_balance
bool load_balance
Perform load balancing after mesh adaptation.
◆ n_layers
int n_layers
Number of refinement layers around user zone.
◆ time_control
Time step interval at which an AMR step is performed.
