1#ifndef CS_MESH_ADJACENCIES_H
2#define CS_MESH_ADJACENCIES_H
54#define CS_ADJACENCY_SHARED (1 << 0)
56#define CS_ADJACENCY_STRIDE (1 << 1)
58#define CS_ADJACENCY_SIGNED (1 << 2)
Definition: cs_defs.h:528
Definition: cs_defs.h:529
Definition: cs_defs.h:325
unsigned short int cs_flag_t
Definition: cs_defs.h:334
cs_alloc_mode_t
Definition: cs_mem.h:46
void cs_mesh_adjacencies_update_cell_cells_e(void)
Update extended cell -> cell connectivites in mesh adjacencies helper API relative to mesh.
Definition: cs_mesh_adjacencies.cpp:712
const cs_adjacency_t * cs_mesh_adjacencies_cell_faces(void)
Return cell -> face connectivites in mesh adjacencies helper API relative to mesh.
Definition: cs_mesh_adjacencies.cpp:876
cs_mesh_adjacencies_t * cs_mesh_adjacencies_get_global(void)
Get non-const pointer to cs_glob_mesh_adacencies.
Definition: cs_mesh_adjacencies.cpp:592
void cs_adjacency_destroy(cs_adjacency_t **p_adj)
Destroy a cs_adjacency_t structure.
Definition: cs_mesh_adjacencies.cpp:1064
cs_adjacency_t * cs_mesh_adjacency_c2f_boundary(const cs_mesh_t *m)
Build a cells to boundary faces adjacency structure.
Definition: cs_mesh_adjacencies.cpp:2034
void cs_adjacency_dump(const char *name, FILE *_f, cs_adjacency_t *adj)
Dump a cs_adjacency_t structure to a file or into the standard output.
Definition: cs_mesh_adjacencies.cpp:1722
cs_adjacency_t * cs_adjacency_compose(int n_c_elts, const cs_adjacency_t *a2b, const cs_adjacency_t *b2c)
Create a new cs_adjacency_t structure from the composition of two cs_adjacency_t structures: (1) A ->...
Definition: cs_mesh_adjacencies.cpp:1102
void cs_mesh_adjacencies_update_cell_i_faces(void)
Ensure presence of cell -> interior face connectivites in mesh adjacencies helper API relative to mes...
Definition: cs_mesh_adjacencies.cpp:730
cs_adjacency_t * cs_adjacency_create(cs_flag_t flag, int stride, cs_lnum_t n_elts)
Create a cs_adjacency_t structure of size n_elts.
Definition: cs_mesh_adjacencies.cpp:926
cs_adjacency_t * cs_adjacency_create_from_s_arrays(cs_lnum_t n_elts, int stride, cs_lnum_t *ids, short int *sgn)
Create a cs_adjacency_t structure sharing arrays scanned with a stride.
Definition: cs_mesh_adjacencies.cpp:986
void cs_mesh_adjacencies_initialize(void)
Initialize mesh adjacencies helper API.
Definition: cs_mesh_adjacencies.cpp:604
cs_adjacency_t * cs_adjacency_difference(const cs_adjacency_t *a2b_1, const cs_adjacency_t *a2b_2)
Create a new cs_adjacency_t structure from the difference of two cs_adjacency_t structures: A -> B cr...
Definition: cs_mesh_adjacencies.cpp:1419
cs_adjacency_t * cs_adjacency_transpose(int n_b_elts, const cs_adjacency_t *a2b)
Create a new cs_adjacency_t structure from a one corresponding to A -> B. The resulting structure dea...
Definition: cs_mesh_adjacencies.cpp:1505
void cs_adjacency_sort(cs_adjacency_t *adj)
Sort each sub-list related to an entry in a cs_adjacency_t structure.
Definition: cs_mesh_adjacencies.cpp:1633
void cs_mesh_adjacencies_update_cell_b_faces(void)
Update cells -> boundary faces connectivity.
Definition: cs_mesh_adjacencies.cpp:745
cs_adjacency_t * cs_mesh_adjacency_c2f(const cs_mesh_t *m, int boundary_order)
Build a cells to faces adjacency structure.
Definition: cs_mesh_adjacencies.cpp:1815
cs_adjacency_t * cs_adjacency_create_from_i_arrays(cs_lnum_t n_elts, cs_lnum_t *idx, cs_lnum_t *ids, short int *sgn)
Create a cs_adjacency_t structure sharing arrays scanned with an index.
Definition: cs_mesh_adjacencies.cpp:1032
const cs_adjacency_t * cs_mesh_adjacencies_cell_vertices(void)
Return cell -> vertex connectivites in mesh adjacencies helper API relative to mesh.
Definition: cs_mesh_adjacencies.cpp:901
cs_adjacency_t * cs_mesh_adjacency_v2v(const cs_mesh_t *m)
Allocate and define a cs_adjacency_t structure related to the connectivity vertex to vertices through...
Definition: cs_mesh_adjacencies.cpp:2095
void cs_mesh_adjacencies_update_device(cs_alloc_mode_t alloc_mode)
Map some global mesh adjacency arrays for use on device.
Definition: cs_mesh_adjacencies.cpp:810
void cs_mesh_adjacencies_update_mesh(void)
Update mesh adjacencies helper API relative to mesh.
Definition: cs_mesh_adjacencies.cpp:669
void cs_adjacency_remove_self_entries(cs_adjacency_t *adj)
In an indexed list, remove id(s) corresponding to the current index. Useful for instance in order to ...
Definition: cs_mesh_adjacencies.cpp:1684
void cs_mesh_adjacencies_finalize(void)
Finalize mesh adjacencies helper API.
Definition: cs_mesh_adjacencies.cpp:639
cs_adjacency_t * cs_adjacency_concatenate(const cs_adjacency_t *a2b_1, const cs_adjacency_t *a2b_2)
Create a new cs_adjacency_t structure from the concatenation of two cs_adjacency_t structures: A -> B...
Definition: cs_mesh_adjacencies.cpp:1321
const cs_mesh_adjacencies_t * cs_glob_mesh_adjacencies
cs_adjacency_t * cs_mesh_adjacency_c2f_lower(const cs_mesh_t *m, int boundary_order)
Build a partial cells to faces adjacency structure.
Definition: cs_mesh_adjacencies.cpp:1929
int stride
Definition: cs_mesh_adjacencies.h:71
cs_lnum_t * idx
Definition: cs_mesh_adjacencies.h:74
cs_lnum_t n_elts
Definition: cs_mesh_adjacencies.h:73
cs_flag_t flag
Definition: cs_mesh_adjacencies.h:70
cs_lnum_t * ids
Definition: cs_mesh_adjacencies.h:75
short int * sgn
Definition: cs_mesh_adjacencies.h:76
Definition: cs_mesh_adjacencies.h:82
cs_lnum_t * cell_cells_idx
Definition: cs_mesh_adjacencies.h:91
Definition: cs_mesh_adjacencies.h:92
cs_lnum_t * cell_hb_faces_idx
Definition: cs_mesh_adjacencies.h:114
const cs_lnum_t * cell_cells_e_idx
Definition: cs_mesh_adjacencies.h:96
short int * cell_i_faces_sgn
Definition: cs_mesh_adjacencies.h:103
cs_lnum_t * cell_b_faces
Definition: cs_mesh_adjacencies.h:108
bool single_faces_to_cells
Definition: cs_mesh_adjacencies.h:86
const cs_adjacency_t * c2v
Definition: cs_mesh_adjacencies.h:128
cs_lnum_t * cell_i_faces
Definition: cs_mesh_adjacencies.h:102
const cs_adjacency_t * c2f
Definition: cs_mesh_adjacencies.h:121
Definition: cs_mesh_adjacencies.h:116
cs_adjacency_t * _c2f
Definition: cs_mesh_adjacencies.h:123
Definition: cs_mesh_adjacencies.h:97
cs_lnum_t * cell_b_faces_idx
Definition: cs_mesh_adjacencies.h:107
cs_adjacency_t * _c2v
Definition: cs_mesh_adjacencies.h:130
