1#ifndef CS_MATRIX_DEFAULT_H
2#define CS_MATRIX_DEFAULT_H
Definition: cs_field.h:275
Definition: cs_defs.h:332
unsigned cs_gnum_t
global mesh entity number
Definition: cs_defs.h:317
Definition: cs_defs.h:325
Definition: cs_matrix.h:108
cs_matrix_fill_type_t
Definition: cs_matrix.h:70
cs_matrix_type_t
Definition: cs_matrix.h:52
cs_matrix_t * cs_matrix_by_assembler(const cs_field_t *f, cs_matrix_type_t type)
Return matrix associated with a matrix assembler.
Definition: cs_matrix_default.cpp:962
int cs_matrix_get_tuning_runs(void)
Definition: cs_matrix_default.cpp:864
cs_matrix_t * cs_matrix_external(const char *type_name, bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size)
Return matrix wrapper for external library for a given fill type.
Definition: cs_matrix_default.cpp:666
const cs_gnum_t * cs_matrix_get_block_row_g_id(const cs_matrix_t *m)
Return a (0-based) global block row numbering for a given matrix.
Definition: cs_matrix_default.cpp:906
cs_matrix_t * cs_matrix_msr(void)
Definition: cs_matrix_default.cpp:621
cs_matrix_t * cs_matrix_copy_to_external(cs_matrix_t *src, bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size)
Copy base matrix to external library matrix type for given fill type.
Definition: cs_matrix_default.cpp:771
void cs_matrix_finalize(void)
Definition: cs_matrix_default.cpp:496
void cs_matrix_update_mesh(void)
Definition: cs_matrix_default.cpp:551
void cs_matrix_vector_native_multiply(bool symmetric, cs_lnum_t db_size, cs_lnum_t eb_size, int f_id, const cs_real_t *dam, const cs_real_t *xam, cs_real_t *vx, cs_real_t *vy)
Definition: cs_matrix_default.cpp:431
cs_matrix_t * cs_matrix_set_coefficients_by_assembler(const cs_field_t *f, cs_matrix_type_t type, bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size, const cs_real_t *da, const cs_real_t *xa)
Assign coefficients to a matrix using a matrix assembler.
Definition: cs_matrix_default.cpp:1007
void cs_matrix_release(cs_matrix_t **m)
Definition: cs_matrix_default.cpp:1141
void cs_matrix_initialize(void)
Definition: cs_matrix_default.cpp:475
void cs_matrix_default_set_type(cs_matrix_fill_type_t fill_type, cs_matrix_type_t type)
Set default matrix type for a given fill type.
Definition: cs_matrix_default.cpp:882
cs_matrix_t * cs_matrix_csr(void)
Definition: cs_matrix_default.cpp:634
void cs_matrix_default_set_tuned(cs_matrix_t *m)
Definition: cs_matrix_default.cpp:810
cs_matrix_t * cs_matrix_default(bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size)
Definition: cs_matrix_default.cpp:594
cs_matrix_t * cs_matrix_native(void)
Definition: cs_matrix_default.cpp:647
void cs_matrix_set_tuning_runs(int n_min_products)
Definition: cs_matrix_default.cpp:848
