cs_cdofb_monolithic.cpp File Reference
Build an algebraic CDO face-based system for the Navier-Stokes equations and solved it with a monolithic approach. More...
+ Include dependency graph for cs_cdofb_monolithic.cpp:
Macros
#define CS_CDOFB_MONOLITHIC_DBG   0
void cs_cdofb_monolithic_init_sharing (const cs_equation_param_t *mom_eqp, const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
void cs_cdofb_monolithic_finalize_common (void)
 Free shared pointers with lifecycle dedicated to this file. More...
cs::cdo_navsto_ctx_t * cs_cdofb_monolithic_init_scheme_context (const cs_navsto_param_t *nsp, cs_adv_field_t *adv_field, cs_real_t *mflux, cs_real_t *mflux_pre, cs_boundary_type_t *bf_type, void *cc_context)
 Initialize a cs_cdofb_monolithic_t structure. More...
void * cs_cdofb_monolithic_free_scheme_context (cs_cdofb_monolithic_t *sc)
 Destroy a cs_cdofb_monolithic_t structure. More...
void cs_cdofb_monolithic_steady (const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, cs_cdofb_monolithic_t *sc)
 Solve the steady Stokes or Oseen system with a CDO face-based scheme using a monolithic approach. More...
void cs_cdofb_monolithic_steady_nl (const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, cs_cdofb_monolithic_t *sc)
 Solve the steady Navier-Stokes system with a CDO face-based scheme using a monolithic approach and a non-linear algorithm (Picard or Anderson) to solve the non-linearities arising from the advection term. More...
void cs_cdofb_monolithic (const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, cs_cdofb_monolithic_t *sc)
 Solve the unsteady Navier-Stokes system with a CDO face-based scheme using a monolithic approach. According to the settings, this function can handle either an implicit Euler time scheme or more generally a theta time scheme. More...
void cs_cdofb_monolithic_nl (const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, cs_cdofb_monolithic_t *sc)
 Solve the unsteady Navier-Stokes system with a CDO face-based scheme using a monolithic approach. According to the settings, this function can handle either an implicit Euler time scheme or more generally a theta time scheme. Rely on Picard iterations to solve the non-linearities arising from the advection term. More...
◆ CS_CDOFB_MONOLITHIC_DBG
◆ cs_cdofb_monolithic()
void cs_cdofb_monolithic ( const cs_mesh_t *  mesh,
const cs_navsto_param_t *  nsp,
cs_cdofb_monolithic_t *  sc
[in]scpointer to a cs_cdofb_monolithic_t structure
◆ cs_cdofb_monolithic_finalize_common()
void cs_cdofb_monolithic_finalize_common ( void  )
◆ cs_cdofb_monolithic_free_scheme_context()
void * cs_cdofb_monolithic_free_scheme_context ( cs_cdofb_monolithic_t *  sc)
[in]scpointer to a scheme context structure to free
a null pointer
◆ cs_cdofb_monolithic_init_scheme_context()
cs::cdo_navsto_ctx_t * cs_cdofb_monolithic_init_scheme_context ( const cs_navsto_param_t *  nsp,
cs_adv_field_t *  adv_field,
cs_real_t *  mflux,
cs_real_t *  mflux_pre,
cs_boundary_type_t *  bf_type,
void *  cc_context
[in]mfluxcurrent values of the mass flux across primal faces
[in]mflux_precurrent values of the mass flux across primal faces
[in]bf_typetype of boundary for each boundary face
[in]cc_contextpointer to a cs_navsto_monolithic_t structure
a pointer to a new allocated cs_cdofb_monolithic_t structure
◆ cs_cdofb_monolithic_init_sharing()
void cs_cdofb_monolithic_init_sharing ( const cs_equation_param_t *  mom_eqp,
[in]mom_eqpequation parameter settings
◆ cs_cdofb_monolithic_nl()
void cs_cdofb_monolithic_nl ( const cs_mesh_t *  mesh,
[in,out]scpointer to a cs_cdofb_monolithic_t structure
◆ cs_cdofb_monolithic_steady()
void cs_cdofb_monolithic_steady ( const cs_mesh_t *  mesh,
Solve the steady Navier-Stokes system with a CDO face-based scheme using a monolithic approach.
◆ cs_cdofb_monolithic_steady_nl()
void cs_cdofb_monolithic_steady_nl ( const cs_mesh_t *  mesh,
Solve the steady Navier-Stokes system with a CDO face-based scheme using a monolithic approach and Picard iterations to solve the non-linearities arising from the advection term.
