cs_cdofb_monolithic_sles.h File Reference
+ Include dependency graph for cs_cdofb_monolithic_sles.h:
Typedefs
typedef struct _cs_cdofb_monolithic_t cs_cdofb_monolithic_t
void cs_cdofb_monolithic_sles_init_sharing (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant)
 Set pointers to shared structures. More...
void cs_cdofb_monolithic_sles_init_system_helper (const cs_navsto_param_t *nsp, const cs_param_saddle_t *saddlep, cs_cdofb_monolithic_t *sc)
 Define the system helper for a CDO-Fb scheme solving the Navier-Stokes equation using a monolithic approach for the velocity-pressure coupling. More...
void cs_cdofb_monolithic_sles_init_solver (const cs_navsto_param_t *nsp, const cs_param_saddle_t *saddlep, cs_cdofb_monolithic_t *sc)
 Define the saddle solver and its context for a CDO-Fb scheme solving the Navier-Stokes equation using a monolithic approach for the velocity-pressure coupling. More...
int cs_cdofb_monolithic_sles_alu (const cs_navsto_param_t *nsp, cs_saddle_solver_t *solver, cs_real_t *u_f, cs_real_t *p_c)
 Solve a linear system arising from the discretization of the Navier-Stokes equation using a monolithic velocity-pressure coupling with a CDO face-based approach. Solve this system using the Augmented Lagrangian-Uzawa algorithm. More...
int cs_cdofb_monolithic_sles_block_krylov (const cs_navsto_param_t *nsp, cs_saddle_solver_t *solver, cs_real_t *u_f, cs_real_t *p_c)
 Solve a linear system arising from the discretization of the Navier-Stokes equation with a CDO face-based approach. The system is split into a velocity block and the (unassembled) divergence operator Block preconditioning using a Schur approximation on a Krylov solver such as the GCR or MINRES is available. More...
int cs_cdofb_monolithic_sles_gkb_inhouse (const cs_navsto_param_t *nsp, cs_saddle_solver_t *solver, cs_real_t *u_f, cs_real_t *p_c)
 Solve a linear system arising from the discretization of the Navier-Stokes equation using a monolithic velocity-pressure coupling with a CDO face-based approach. Solve this system using the Golub-Kahan Bidiagonalization algorithm. In-house implementation. The PETSc implementation is also available but appears less efficient in our tests. More...
int cs_cdofb_monolithic_sles_full_system (const cs_navsto_param_t *nsp, cs_saddle_solver_t *solver, cs_real_t *u_f, cs_real_t *p_c)
 Solve a linear system arising from the discretization of the Navier-Stokes equation with a CDO face-based approach. The full system is treated as one block and solved as it is. In this situation, PETSc or MUMPS are usually considered. More...
int cs_cdofb_monolithic_sles_notay (const cs_navsto_param_t *nsp, cs_saddle_solver_t *solver, cs_real_t *u_f, cs_real_t *p_c)
 Solve a linear system arising from the discretization of the Navier-Stokes equation using a monolithic velocity-pressure coupling with a CDO face-based approach. Solve this system using the Notay's algebraic transformation. The full system is treated as one block and solved as it is. In this situation, PETSc or MUMPS are usually considered. More...
int cs_cdofb_monolithic_sles_uzawa_cg (const cs_navsto_param_t *nsp, cs_saddle_solver_t *solver, cs_real_t *u_f, cs_real_t *p_c)
 Solve a linear system arising from the discretization of the Navier-Stokes equation using a monolithic velocity-pressure coupling with a CDO face-based approach. Solve this system using the Uzawa-CG algorithm. More...
int cs_cdofb_monolithic_sles_afs (const cs_navsto_param_t *nsp, cs_saddle_solver_t *solver, cs_real_t *u_f, cs_real_t *p_c)
 Solve a linear system arising from the discretization of the Navier-Stokes equation using a monolithic velocity-pressure coupling with a CDO face-based approach. Solve this system using an Algebraic Fractional Step algorithm. An example of an AFS algorithm is the SIMPLE algorithm. More...
Typedef Documentation
◆ cs_cdofb_monolithic_t
◆ cs_cdofb_monolithic_sles_afs()
int cs_cdofb_monolithic_sles_afs ( const cs_navsto_param_t *  nsp,
cs_saddle_solver_t *  solver,
cs_real_t *  u_f,
cs_real_t *  p_c
[in]nspset of parameters related to the Navier-Stokes eqs.
[in,out]solverpointer to a cs_saddle_solver_t structure
[in,out]u_fvalues of the velocity at faces (3 components)
[in,out]p_cvalues of the pressure in cells
the (cumulated) number of iterations of the solver
◆ cs_cdofb_monolithic_sles_alu()
int cs_cdofb_monolithic_sles_alu ( const cs_navsto_param_t *  nsp,
cs_real_t *  u_f,
cs_real_t *  p_c
◆ cs_cdofb_monolithic_sles_block_krylov()
int cs_cdofb_monolithic_sles_block_krylov ( const cs_navsto_param_t *  nsp,
cs_real_t *  u_f,
cs_real_t *  p_c
[in,out]solverpointer to a saddle-point solver
◆ cs_cdofb_monolithic_sles_full_system()
int cs_cdofb_monolithic_sles_full_system ( const cs_navsto_param_t *  nsp,
cs_real_t *  u_f,
cs_real_t *  p_c
◆ cs_cdofb_monolithic_sles_gkb_inhouse()
int cs_cdofb_monolithic_sles_gkb_inhouse ( const cs_navsto_param_t *  nsp,
cs_real_t *  u_f,
cs_real_t *  p_c
◆ cs_cdofb_monolithic_sles_init_sharing()
void cs_cdofb_monolithic_sles_init_sharing ( const cs_mesh_t *  mesh,
const cs_cdo_quantities_t *  quant
[in]meshpointer to the mesh structure
[in]connectpointer to additional CDO connectivities
[in]quantpointer to additional CDO mesh quantities
◆ cs_cdofb_monolithic_sles_init_solver()
void cs_cdofb_monolithic_sles_init_solver ( const cs_navsto_param_t *  nsp,
const cs_param_saddle_t *  saddlep,
cs_cdofb_monolithic_t *  sc
[in]nspset of parameters for the Navier-Stokes system
[in]saddlepparameters for solving a saddle-point problem
[in,out]scpointer to a context structure cast on-the-fly
◆ cs_cdofb_monolithic_sles_init_system_helper()
void cs_cdofb_monolithic_sles_init_system_helper ( const cs_navsto_param_t *  nsp,
[in]nspNavier-Stokes paremeters
◆ cs_cdofb_monolithic_sles_notay()
int cs_cdofb_monolithic_sles_notay ( const cs_navsto_param_t *  nsp,
cs_real_t *  u_f,
cs_real_t *  p_c
◆ cs_cdofb_monolithic_sles_uzawa_cg()
int cs_cdofb_monolithic_sles_uzawa_cg ( const cs_navsto_param_t *  nsp,
cs_real_t *  u_f,
cs_real_t *  p_c
