cs_navsto_param_t Struct Reference
Structure storing the parameters related to the resolution of the Navier-Stokes system. More...
#include <cs_navsto_param.h>
+ Collaboration diagram for cs_navsto_param_t:
Public Attributes
Physical modelling
Which equations to solve ? Properties and their related fields are allocated according to the choice of model for Navier-Stokes
cs_navsto_param_model_t model
cs_navsto_param_model_flag_t model_flag
cs_turbulence_param_t * turbulence
Properties and fields related to the Navier-Stokes module
cs_physical_constants_t * phys_constants
cs_property_t * mass_density
cs_property_t * tot_viscosity
cs_property_t * lam_viscosity
Numerical options
Set of numerical options to build the linear system and how to solve it
cs_param_dof_reduction_t dof_reduction_mode
cs_navsto_param_coupling_t coupling
cs_param_space_scheme_t space_scheme
int n_boussinesq_terms
cs_navsto_param_boussinesq_t * boussinesq_param
Non-linear algorithm
Set of parameters to drive the resolution of the non-linearity arising from the Navier–Stokes system
cs_navsto_param_norm_type_t norm_type
cs_cdo_blas_square_norm_t * square_norm
cs_cdo_blas_square_norm_diff_t * square_norm_diff
cs_cdo_blas_dotprod_t * dotprod
cs_param_nl_algo_t nl_algo_type
cs_param_convergence_t nl_cvg_param
cs_param_psteady_t psteady_cvg_param
cs_iter_algo_param_aac_t anderson_param
cs_real_t delta_thermal_tolerance
int n_max_outer_iter
Output
int verbosity
cs_navsto_param_post_flag_t post_flag
cs_navsto_param_num_flag_t num_flag
Initial conditions (IC)
Set of parameters used to take into account the initial condition on the pressure and/or the velocity. CAUTION: so far, there is no check if the different IC are compatible with the boundary conditions for instance
bool velocity_ic_is_owner
int n_velocity_ic_defs
cs_xdef_t ** velocity_ic_defs
bool pressure_ic_is_owner
int n_pressure_ic_defs
cs_xdef_t ** pressure_ic_defs
Boundary conditions (BC)
Set of parameters used to take into account the boundary conditions on the pressure and/or the velocity.
const cs_boundary_t * boundaries
bool velocity_bc_is_owner
int n_velocity_bc_defs
cs_xdef_t ** velocity_bc_defs
bool pressure_bc_is_owner
int n_pressure_bc_defs
cs_xdef_t ** pressure_bc_defs
Other conditions
cs_real_t reference_pressure
Member Data Documentation
◆ anderson_param
anderson_param
Set of parameters to drive the Anderson acceleration (useful if the type of non-linear algorithm is set to Anderson acceleration).
◆ boundaries
const cs_boundary_t* boundaries
True if the definitions are stored inside this structure, otherwise the definitions are stored inside a dedicated cs_equation_param_t Most of the time this should be false since an equation is associated to to the resolution of the velocity field (the momentum equation).
◆ boussinesq_param
cs_navsto_param_boussinesq_t* boussinesq_param
How are defined the Degrees of freedom
◆ coupling
coupling
Choice of algorithm for solving the system
◆ delta_thermal_tolerance
Value under which one considers that the thermal equation is converged $ max_{c \in Cells} |T_c - T_{ref}|/|T_{ref}| < \epsilon$ Then stop iteration
◆ dof_reduction_mode
dof_reduction_mode
◆ dotprod
dotprod
Function used to compute the dot product between two mass flux arrays
◆ lam_viscosity
lam_viscosity
Laminar viscosity
◆ mass_density
mass_density
Mass_density of the fluid, pointer to cs_property_t used in several terms in the Navier-Stokes equations
◆ model
model
Modelling related to the Navier-Stokes system of equations
◆ model_flag
model_flag
Flag storing high-level option related to the Navier-Stokes system
◆ n_boussinesq_terms
◆ n_max_outer_iter
n_max_outer_iter
Stopping criterion related to the maximum number of outer iterations allowed. This outer iteration encompasses the Navier-Stokes system, and (according to the case settings) the turbulence system and/or the thermal system.
◆ n_pressure_bc_defs
n_pressure_bc_defs
Number of boundary conditions associated to the pressure field.
◆ n_pressure_ic_defs
n_pressure_ic_defs
Number of initial conditions associated to the pressure
◆ n_velocity_bc_defs
n_velocity_bc_defs
Number of definitions related to the settings of the boundary conditions for the velocity field.
◆ n_velocity_ic_defs
n_velocity_ic_defs
Number of initial conditions associated to the velocity
◆ nl_algo_type
nl_algo_type
Type of algorithm used to tackle the non-linearity arising from the advection term
◆ nl_cvg_param
nl_cvg_param
Structure storing several tolerances and metadata to drive the convergence of the non-linear iterative algorithm used to solve Navier-Stokes when the advection term is implicit and non linearized.
◆ norm_type
norm_type
Type of algorithm used to build the norm used in the treatment of the non-linearity arising from the advection term
◆ num_flag
num_flag
Flag storing which numerical options
◆ phys_constants
phys_constants
Main physical constants (gravity vector and Coriolis source term). This structure is shared with the legacy part.
◆ post_flag
post_flag
Flag storing which predefined post-processing has to be done
◆ pressure_bc_defs
pressure_bc_defs
Pointers to the definitions of the boundary conditions associated to the pressure field.
◆ pressure_bc_is_owner
True if the definitions are stored inside this structure, otherwise the definitions are stored inside a dedicated cs_equation_param_t if an equation solves the pressure field.
◆ pressure_ic_defs
pressure_ic_defs
Pointers to the definitions of the initial conditions associated to the pressure. In order to force a zero-mean pressure, the code can compute the average of the resulting pressure and subtract it
◆ pressure_ic_is_owner
◆ psteady_cvg_param
psteady_cvg_param
Structure storing several tolerances and metadata to drive the convergence of the pseudo-steady algorithm used to stop Navier-Stokes
◆ reference_pressure
reference_pressure
Value of the reference pressure p0 (used for rescaling or during update of physical quantities). By default: 0.
◆ space_scheme
space_scheme
Discretization scheme for space
◆ square_norm
square_norm
Function used to compute the square norm of the mass flux
◆ square_norm_diff
square_norm_diff
Function used to compute the square norm of the difference of mass fluxes
◆ tot_viscosity
tot_viscosity
Laminar viscosity + if needed the turbulent viscosity Pointer to cs_property_t associated to the diffusion term for the momentum equation
◆ turbulence
turbulence
Structure storing all information needed to set the turbulence modelling
◆ velocity_bc_defs
velocity_bc_defs
Array of pointers to the definition of boundary conditions for the velocity field
◆ velocity_bc_is_owner
◆ velocity_ic_defs
velocity_ic_defs
Pointers to the definitions of the initial conditions associated to the velocity. The code does not check if the resulting initial velocity satisfies the divergence constraint.
◆ velocity_ic_is_owner
True if the definitions are stored inside this structure, otherwise the definitions are stored inside a cs_equation_param_t structure dedicated to the momentum equation.
◆ verbosity
verbosity
Level of display of the information related to the Navier-Stokes system
