cdo_navsto_ctx_t Struct Reference
Context related to CDO face-based discretization when dealing with Navier-Stokes equations and vector-valued face unknowns. More...
#include <cs_navsto_context.h>
+ Inheritance diagram for cdo_navsto_ctx_t:
+ Collaboration diagram for cdo_navsto_ctx_t:
Public Member Functions
cs_real_t * get_mass_flux (bool previous) const
 Retrieve the mass flux array related to the Navier-Stokes system. More...
Public Attributes
Main field variables
Fields for every main variable of the equation. Got from cs_navsto_system_t
cs_field_t * velocity
cs_field_t * pressure
cs_field_t * divergence
Advection quantities
Members related to the advection
cs_adv_field_t * adv_field
cs_real_t * mass_flux_array
cs_real_t * mass_flux_array_pre
Boundary conditions (BC) management
Functions and elements used for enforcing the BCs
const cs_boundary_type_t * bf_type
cs_cdo_bc_face_t * pressure_bc
int pressure_rescaling
cs_cdo_apply_boundary_t * apply_fixed_wall
cs_cdo_apply_boundary_t * apply_sliding_wall
cs_cdo_apply_boundary_t * apply_velocity_inlet
cs_cdo_apply_boundary_t * apply_symmetry
Performance monitoring
Monitoring the efficiency of the algorithm used to solve the Navier-Stokes system
cs_timer_counter_t timer
Member Function Documentation
◆ get_mass_flux()
cs_real_t * get_mass_flux ( bool  previous) const
inline
[in]previousif true return the previous state otherwise the current state.
a pointer to an array of cs_real_t
Member Data Documentation
◆ adv_field
adv_field
Pointer to the cs_adv_field_t related to the Navier-Stokes eqs (Shared)
◆ apply_fixed_wall
apply_fixed_wall
cs_cdo_apply_boundary_t function pointer defining how to apply a wall boundary (no slip boundary)
◆ apply_sliding_wall
apply_sliding_wall
cs_cdo_apply_boundary_t function pointer defining how to apply a wall boundary (a tangential velocity is specified at the wall)
◆ apply_symmetry
apply_symmetry
cs_cdo_apply_boundary_t function pointer defining how to apply a symmetry boundary
◆ apply_velocity_inlet
cs_cdo_apply_boundary_t function pointer defining how to apply a boundary with a fixed velocity at the inlet
◆ bf_type
bf_type
Array of boundary type for each boundary face. (Shared)
◆ divergence
divergence
Pointer to cs_real_t containing the values of the divergence on the cells
◆ mass_flux_array
mass_flux_array
Current values of the mass flux at primal faces (Shared)
◆ mass_flux_array_pre
mass_flux_array_pre
Previous values of the mass flux at primal faces (Shared)
◆ pressure
pressure
Pointer to cs_field_t (owned by cs_navsto_system_t) containing the cell DoFs of the pressure
◆ pressure_bc
pressure_bc
Structure storing the metadata after processing the user-defined boundary conditions related to the pressure field
◆ pressure_rescaling
◆ timer
timer
Cumulated elapsed time for building and solving the Navier–Stokes system
◆ velocity
velocity
Pointer to cs_field_t (owned by cs_navsto_system_t) containing the cell DoFs of the velocity
