cs_cdofb_monolithic_sles.h
1#ifndef CS_CDOFB_MONOLITHIC_SLES_H
2#define CS_CDOFB_MONOLITHIC_SLES_H
5 * Functions dedicated to the linear algebra settings and operations in case
6 * of CDO face-based schemes with a monolithic velocity-pressure coupling
7 *============================================================================*/
8
9/*
10 This file is part of code_saturne, a general-purpose CFD tool.
11
12 Copyright (C) 1998-2026 EDF S.A.
13
14 This program is free software; you can redistribute it and/or modify it under
15 the terms of the GNU General Public License as published by the Free Software
16 Foundation; either version 2 of the License, or (at your option) any later
17 version.
18
19 This program is distributed in the hope that it will be useful, but WITHOUT
20 ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
21 FOR A PARTICULAR PURPOSE. See the GNU General Public License for more
22 details.
23
24 You should have received a copy of the GNU General Public License along with
25 this program; if not, write to the Free Software Foundation, Inc., 51 Franklin
26 Street, Fifth Floor, Boston, MA 02110-1301, USA.
27*/
28
29/*----------------------------------------------------------------------------*/
30
31#include "base/cs_defs.h"
32
33/*----------------------------------------------------------------------------
34 * Standard C library headers
35 *----------------------------------------------------------------------------*/
36
37/*----------------------------------------------------------------------------
38 * Local headers
39 *----------------------------------------------------------------------------*/
42#include "cdo/cs_navsto_param.h"
45 * Macro definitions
49 * Type definitions
51
52/* Forward declarations */
53typedef struct _cs_cdofb_monolithic_t cs_cdofb_monolithic_t;
54
55/*============================================================================
56 * Public function prototypes
58
59/*----------------------------------------------------------------------------*/
67/*----------------------------------------------------------------------------*/
68
69void
71 const cs_cdo_connect_t *connect,
72 const cs_cdo_quantities_t *quant);
73
74/*----------------------------------------------------------------------------*/
84/*----------------------------------------------------------------------------*/
85
86void
88 const cs_param_saddle_t *saddlep,
90
91/*----------------------------------------------------------------------------*/
101/*----------------------------------------------------------------------------*/
102
103void
105 const cs_param_saddle_t *saddlep,
107
108/*----------------------------------------------------------------------------*/
122/*----------------------------------------------------------------------------*/
123
124int
126 cs_saddle_solver_t *solver,
127 cs_real_t *u_f,
128 cs_real_t *p_c);
129
130/*----------------------------------------------------------------------------*/
145/*----------------------------------------------------------------------------*/
146
147int
149 cs_saddle_solver_t *solver,
150 cs_real_t *u_f,
151 cs_real_t *p_c);
152
153/*----------------------------------------------------------------------------*/
169/*----------------------------------------------------------------------------*/
170
171int
173 cs_saddle_solver_t *solver,
174 cs_real_t *u_f,
175 cs_real_t *p_c);
176
177/*----------------------------------------------------------------------------*/
191/*----------------------------------------------------------------------------*/
192
193int
195 cs_saddle_solver_t *solver,
196 cs_real_t *u_f,
197 cs_real_t *p_c);
198
199/*----------------------------------------------------------------------------*/
215/*----------------------------------------------------------------------------*/
216
217int
219 cs_saddle_solver_t *solver,
220 cs_real_t *u_f,
221 cs_real_t *p_c);
222
223/*----------------------------------------------------------------------------*/
237/*----------------------------------------------------------------------------*/
238
239int
241 cs_saddle_solver_t *solver,
242 cs_real_t *u_f,
243 cs_real_t *p_c);
244
245/*----------------------------------------------------------------------------*/
260/*----------------------------------------------------------------------------*/
261
262int
264 cs_saddle_solver_t *solver,
265 cs_real_t *u_f,
266 cs_real_t *p_c);
267
268/*----------------------------------------------------------------------------*/
269
270#endif /* CS_CDOFB_MONOLITHIC_SLES_H */
Definition: cs_cdofb_monolithic_priv.h:73
int cs_cdofb_monolithic_sles_alu(const cs_navsto_param_t *nsp, cs_saddle_solver_t *solver, cs_real_t *u_f, cs_real_t *p_c)
Solve a linear system arising from the discretization of the Navier-Stokes equation using a monolithi...
Definition: cs_cdofb_monolithic_sles.cpp:1103
int cs_cdofb_monolithic_sles_gkb_inhouse(const cs_navsto_param_t *nsp, cs_saddle_solver_t *solver, cs_real_t *u_f, cs_real_t *p_c)
Definition: cs_cdofb_monolithic_sles.cpp:1488
int cs_cdofb_monolithic_sles_uzawa_cg(const cs_navsto_param_t *nsp, cs_saddle_solver_t *solver, cs_real_t *u_f, cs_real_t *p_c)
Definition: cs_cdofb_monolithic_sles.cpp:1662
int cs_cdofb_monolithic_sles_notay(const cs_navsto_param_t *nsp, cs_saddle_solver_t *solver, cs_real_t *u_f, cs_real_t *p_c)
Definition: cs_cdofb_monolithic_sles.cpp:1585
void cs_cdofb_monolithic_sles_init_system_helper(const cs_navsto_param_t *nsp, const cs_param_saddle_t *saddlep, cs_cdofb_monolithic_t *sc)
Define the system helper for a CDO-Fb scheme solving the Navier-Stokes equation using a monolithic ap...
Definition: cs_cdofb_monolithic_sles.cpp:727
void cs_cdofb_monolithic_sles_init_sharing(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant)
Set pointers to shared structures.
Definition: cs_cdofb_monolithic_sles.cpp:703
int cs_cdofb_monolithic_sles_block_krylov(const cs_navsto_param_t *nsp, cs_saddle_solver_t *solver, cs_real_t *u_f, cs_real_t *p_c)
Solve a linear system arising from the discretization of the Navier-Stokes equation with a CDO face-b...
Definition: cs_cdofb_monolithic_sles.cpp:1193
int cs_cdofb_monolithic_sles_full_system(const cs_navsto_param_t *nsp, cs_saddle_solver_t *solver, cs_real_t *u_f, cs_real_t *p_c)
Definition: cs_cdofb_monolithic_sles.cpp:1408
int cs_cdofb_monolithic_sles_afs(const cs_navsto_param_t *nsp, cs_saddle_solver_t *solver, cs_real_t *u_f, cs_real_t *p_c)
Definition: cs_cdofb_monolithic_sles.cpp:1856
void cs_cdofb_monolithic_sles_init_solver(const cs_navsto_param_t *nsp, const cs_param_saddle_t *saddlep, cs_cdofb_monolithic_t *sc)
Define the saddle solver and its context for a CDO-Fb scheme solving the Navier-Stokes equation using...
Definition: cs_cdofb_monolithic_sles.cpp:901
Definition: cs_defs.h:332
Definition: mesh.f90:26
Definition: cs_cdo_connect.h:57
Definition: cs_cdo_quantities.h:142
Definition: cs_mesh.h:85
Definition: cs_navsto_param.h:296
Structure storing all metadata related to the resolution of a saddle-point linear system....
Definition: cs_param_saddle.h:280
Definition: cs_saddle_solver.h:85
