cs_cdofb_priv.h
1#ifndef CS_CDOFB_PRIV_H
2#define CS_CDOFB_PRIV_H
5 * Definition of cs_cdofb_scaleq_t and cs_cdofb_vecteq structures
28/*----------------------------------------------------------------------------
29 * Local headers
30 *----------------------------------------------------------------------------*/
33#include "cdo/cs_equation_bc.h"
35#include "cdo/cs_hodge.h"
36
37/*============================================================================
38 * Macro definitions
39 *============================================================================*/
41/*============================================================================
42 * Type definitions
43 *============================================================================*/
45/* Algebraic system for CDO face-based discretization */
46
48
49 /* Ids related to the variable field and to the boundary flux field */
50
53
54 /* System size (n_faces + n_cells) */
55
58
59 /* Solution of the algebraic system DoF unknowns (x) + BCs */
60
61 cs_real_t *face_values; /* At the last iteration */
62 cs_real_t *face_values_pre; /* At the previous iteration */
63
64 /* Members related to the static condensation */
65
66 cs_real_t *rc_tilda; /* Acc^-1 * RHS_cell */
67 cs_real_t *acf_tilda; /* Acc^-1 * Acf
68 Cell-faces lower-left block of the full matrix
69 Access to the values thanks to the c2f
70 connectivity */
71
72 /* Array storing the value arising from the contribution of all source
73 terms (only allocated to n_cells) */
74
76
77 /* Pointer of function to build the diffusion term */
78
84
85 /* Pointer of functions to define the advection term:
86 * advection_open is called first, then advection_main which calls
87 * advection_scheme and after the build step, advection_close is called last
88 */
89
94
96
97 /* If one needs to build a local hodge op. for time and reaction */
98
102
103};
104
105typedef struct _cs_cdofb_t cs_cdofb_priv_t;
106
107/*============================================================================
108 * Public function prototypes
109 *============================================================================*/
110
111/*----------------------------------------------------------------------------*/
120/*----------------------------------------------------------------------------*/
121
122void
125 cs_cdofb_priv_t *eqc);
126
127#endif /* CS_CDOFB_PRIV_H */
void() cs_cdofb_adv_build_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, const cs_property_data_t *diff_pty, cs_cdofb_adv_scheme_t *scheme_func, cs_cell_builder_t *cb)
Build the cellwise advection operator for CDO-Fb schemes The local matrix related to this operator is...
Definition: cs_cdo_advection.h:112
void() cs_cdofb_adv_scheme_t(int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Define the local convection operator in CDO-Fb schemes. Case of an operator that should be assemble i...
Definition: cs_cdo_advection.h:88
void() cs_cdofb_adv_close_hook_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Operation done after the matrix related to the advection term has been defined.
Definition: cs_cdo_advection.h:133
void() cs_cdofb_adv_open_hook_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, void *input, cs_cell_builder_t *cb)
Perform preprocessing such as the computation of the advection flux at the expected location in order...
Definition: cs_cdo_advection.h:67
void cs_cdofb_set_advection_function(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, cs_cdofb_priv_t *eqc)
Set the advection-related parameters in the context structure of CDO face-based schemes.
Definition: cs_cdofb_priv.cpp:86
Definition: cs_defs.h:332
Definition: cs_defs.h:325
void() cs_cdo_enforce_bc_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Enforcement of a boundary condition (Dirichlet, Robin, sliding...)
Definition: cs_equation_bc.h:86
bool() cs_hodge_compute_t(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a discrete Hodge operator or a related operator (such as the stiffmess matrix) for a given cell...
Definition: cs_hodge.h:214
Definition: cs_cdofb_priv.h:47
cs_real_t * rc_tilda
Definition: cs_cdofb_priv.h:66
cs_lnum_t n_dofs
Definition: cs_cdofb_priv.h:57
cs_cdo_enforce_bc_t * enforce_sliding
Definition: cs_cdofb_priv.h:83
cs_cdofb_adv_open_hook_t * advection_open
Definition: cs_cdofb_priv.h:90
cs_cdofb_adv_scheme_t * advection_scheme
Definition: cs_cdofb_priv.h:93
cs_hodge_param_t mass_hodgep
Definition: cs_cdofb_priv.h:99
cs_hodge_t ** diffusion_hodge
Definition: cs_cdofb_priv.h:79
cs_cdo_enforce_bc_t * enforce_dirichlet
Definition: cs_cdofb_priv.h:81
cs_lnum_t n_faces
Definition: cs_cdofb_priv.h:56
cs_cdofb_adv_close_hook_t * advection_close
Definition: cs_cdofb_priv.h:92
cs_real_t * acf_tilda
Definition: cs_cdofb_priv.h:67
cs_hodge_compute_t * get_stiffness_matrix
Definition: cs_cdofb_priv.h:80
cs_cdofb_adv_build_t * advection_main
Definition: cs_cdofb_priv.h:91
cs_real_t * face_values_pre
Definition: cs_cdofb_priv.h:62
cs_hodge_compute_t * get_mass_matrix
Definition: cs_cdofb_priv.h:101
void * advection_input
Definition: cs_cdofb_priv.h:95
cs_real_t * source_terms
Definition: cs_cdofb_priv.h:75
int bflux_field_id
Definition: cs_cdofb_priv.h:52
cs_cdo_enforce_bc_t * enforce_robin_bc
Definition: cs_cdofb_priv.h:82
Definition: cs_cdofb_priv.h:61
int var_field_id
Definition: cs_cdofb_priv.h:51
cs_hodge_t ** mass_hodge
Definition: cs_cdofb_priv.h:100
Structure storing all metadata/parameters related to the usage of a discrete Hodge operator.
Definition: cs_hodge.h:147
Definition: cs_hodge.h:179
