1#ifndef CS_SOURCE_TERM_H
2#define CS_SOURCE_TERM_H
150 const int n_source_terms,
Definition: cs_defs.h:332
unsigned short int cs_flag_t
Definition: cs_defs.h:334
unsigned char cs_mask_t
Definition: cs_flag.h:157
unsigned int cs_eflag_t
Definition: cs_flag.h:190
cs_param_space_scheme_t
Definition: cs_param_types.h:215
void cs_source_term_set_default_flag(cs_param_space_scheme_t scheme, cs_flag_t *state_flag, cs_flag_t *meta_flag)
Set the default flag related to a source term according to the numerical scheme chosen for discretizi...
Definition: cs_source_term.cpp:503
void cs_source_term_pvsp_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Compute the contribution for a cell related to a source term and add it to the given array of values....
Definition: cs_source_term.cpp:1065
void cs_source_term_hhosd_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Compute the contribution of a source term for a cell and add it to the given array of values....
Definition: cs_source_term.cpp:3013
void cs_source_term_fcb_pcsd_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.cpp:2522
void cs_source_term_init_sharing(const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect)
Definition: cs_source_term.cpp:484
void cs_source_term_fb_pcvd_bary_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.cpp:2690
void cs_source_term_dcsd_q1o1_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.cpp:1752
void cs_source_term_set_reduction(cs_xdef_t *st, cs_flag_t flag)
Set advanced parameters which are defined by default in a source term structure.
Definition: cs_source_term.cpp:551
void cs_source_term_dcsd_none_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.cpp:1603
void cs_source_term_compute_cellwise(const int n_source_terms, cs_xdef_t *const *source_terms, const cs_cell_mesh_t *cm, const cs_mask_t *source_mask, cs_source_term_cellwise_t *compute_source[], cs_real_t time_eval, void *input, cs_cell_builder_t *cb, cs_real_t *result)
Compute the local contributions of source terms in a cell.
Definition: cs_source_term.cpp:1001
void cs_source_term_pvsp_by_c2v_array(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.cpp:1235
void cs_source_term_dcsd_by_dof_func(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.cpp:1551
void cs_source_term_dfsf_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.cpp:3374
cs_flag_t cs_source_term_get_flag(const cs_xdef_t *st)
Get metadata related to the given source term structure.
Definition: cs_source_term.cpp:608
void cs_source_term_fcb_pcsd_by_array(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.cpp:2647
void cs_source_term_hhosd_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.cpp:3140
void cs_source_term_fb_pcvd_by_dof_func(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.cpp:2380
void cs_source_term_dcsd_by_c2v_array(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Compute the contribution of a source term in a cell and add it to the given array of values....
Definition: cs_source_term.cpp:1460
void cs_source_term_hhovd_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.cpp:3259
void cs_source_term_fb_pcvd_by_array(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.cpp:2967
void cs_source_term_fb_pcvd_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Compute the contribution for a cell related to a source term and add it the given array of values....
Definition: cs_source_term.cpp:2431
void cs_source_term_vcsp_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.cpp:2225
void cs_source_term_fcb_pcsd_bary_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.cpp:2472
void cs_source_term_vcsp_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.cpp:2169
void cs_source_term_dcsd_q5o3_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.cpp:2062
void cs_source_term_fb_pcvd_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.cpp:2834
void cs_source_term_dcsd_bary_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.cpp:1655
void cs_source_term_dcsd_by_pc_array(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.cpp:1509
void cs_source_term_dcvd_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.cpp:1327
void cs_source_term_fcb_pcsd_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.cpp:2292
void cs_source_term_dcsd_q10o2_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.cpp:1831
void cs_source_term_macfb_pcvd_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.cpp:2745
void cs_source_term_pvsp_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.cpp:1121
void() cs_source_term_cellwise_t(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.h:64
cs_eflag_t cs_source_term_init(cs_param_space_scheme_t space_scheme, const int n_source_terms, cs_xdef_t *const *source_terms, cs_source_term_cellwise_t **p_compute_source[], cs_flag_t *sys_flag, cs_mask_t *source_mask[])
Initialize data to build the source terms.
Definition: cs_source_term.cpp:633
void cs_source_term_dcvd_by_pv_array(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.cpp:1412
void cs_source_term_pvsp_by_array(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.cpp:1176
void cs_source_term_dcsd_by_pv_array(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.cpp:1368
void cs_source_term_dcsd_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.cpp:1287
void cs_source_term_fcb_pcsd_by_dof_func(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition: cs_source_term.cpp:2331
Definition: cs_cdo_connect.h:57
Definition: cs_cdo_quantities.h:142
Definition: cs_cdo_local.h:56
Definition: cs_cdo_local.h:242
Definition: cs_xdef.h:156
