1#ifndef CS_CDOFB_MONOLITHIC_H
2#define CS_CDOFB_MONOLITHIC_H
time step descriptor
Definition: cs_time_step.h:60
int cs_boundary_type_t
Definition: cs_boundary.h:65
void cs_cdofb_monolithic_init_sharing(const cs_equation_param_t *mom_eqp, const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
Definition: cs_cdofb_monolithic.cpp:2163
void cs_cdofb_monolithic_steady_nl(const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, cs_cdofb_monolithic_t *sc)
Solve the steady Navier-Stokes system with a CDO face-based scheme using a monolithic approach and Pi...
Definition: cs_cdofb_monolithic.cpp:2716
void * cs_cdofb_monolithic_free_scheme_context(cs_cdofb_monolithic_t *sc)
Destroy a cs_cdofb_monolithic_t structure.
Definition: cs_cdofb_monolithic.cpp:2559
void cs_cdofb_monolithic_nl(const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, cs_cdofb_monolithic_t *sc)
Solve the unsteady Navier-Stokes system with a CDO face-based scheme using a monolithic approach....
Definition: cs_cdofb_monolithic.cpp:3021
void cs_cdofb_monolithic_steady(const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, cs_cdofb_monolithic_t *sc)
Solve the steady Navier-Stokes system with a CDO face-based scheme using a monolithic approach.
Definition: cs_cdofb_monolithic.cpp:2603
void cs_cdofb_monolithic_finalize_common(void)
Free shared pointers with lifecycle dedicated to this file.
Definition: cs_cdofb_monolithic.cpp:2221
void cs_cdofb_monolithic(const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, cs_cdofb_monolithic_t *sc)
Definition: cs_cdofb_monolithic.cpp:2912
cs::cdo_navsto_ctx_t * cs_cdofb_monolithic_init_scheme_context(const cs_navsto_param_t *nsp, cs_adv_field_t *adv_field, cs_real_t *mflux, cs_real_t *mflux_pre, cs_boundary_type_t *bf_type, void *cc_context)
Initialize a cs_cdofb_monolithic_t structure.
Definition: cs_cdofb_monolithic.cpp:2256
static cs_real_t * cs_cdofb_monolithic_get_face_velocity(bool previous)
Retrieve the values of the velocity on the faces.
Definition: cs_cdofb_monolithic.h:74
Structures and function pointers useful to build and solve the Navier-Stokes equations with face-base...
struct _cs_cdofb_monolithic_t cs_cdofb_monolithic_t
Definition: cs_cdofb_monolithic_priv.h:73
Definition: cs_defs.h:332
cs_real_t * cs_equation_get_face_values(const cs_equation_t *eq, bool previous)
For a given equation, retrieve an array of values related to each face of the mesh for the unknowns.
Definition: cs_equation.cpp:3253
cs_equation_t * cs_equation_by_name(const char *eqname)
Find the cs_equation_t structure with name eqname Return null if not find.
Definition: cs_equation.cpp:495
Context related to CDO face-based discretization when dealing with Navier-Stokes equations and vector...
Definition: cs_navsto_context.h:48
Definition: cs_advection_field.h:151
Definition: cs_cdo_connect.h:57
Definition: cs_cdo_quantities.h:142
Definition: cs_navsto_param.h:296
