1#ifndef CS_NAVSTO_COUPLING_H
2#define CS_NAVSTO_COUPLING_H
Definition: cs_field.h:275
Definition: cs_defs.h:332
void cs_navsto_ac_init_setup(const cs_navsto_param_t *nsp, cs_adv_field_t *adv_field, void *context)
Start setting-up the Navier-Stokes equations when an Artificial Compressibility algorithm is used to ...
Definition: cs_navsto_coupling.cpp:234
cs_equation_t * cs_navsto_ac_get_momentum_eq(void *context)
Retrieve the pointer to the cs_equation_t structure related to the momentum equation in case of artif...
Definition: cs_navsto_coupling.cpp:316
void * cs_navsto_projection_create_context(cs_param_bc_type_t bc, cs_navsto_param_t *nsp)
Allocate and initialize a context structure when the Navier-Stokes system is coupled using an increme...
Definition: cs_navsto_coupling.cpp:569
void * cs_navsto_projection_free_context(void *context)
Free the context structure related to a Projection approach.
Definition: cs_navsto_coupling.cpp:638
void cs_navsto_projection_last_setup(const cs_cdo_quantities_t *quant, const cs_navsto_param_t *nsp, void *context)
Finalize the setup for the Navier-Stokes equations when a projection algorithm is used to coupled the...
Definition: cs_navsto_coupling.cpp:738
void * cs_navsto_ac_create_context(cs_param_bc_type_t bc, cs_navsto_param_t *nsp)
Allocate and initialize a context structure when the Navier-Stokes system is coupled using an Artific...
Definition: cs_navsto_coupling.cpp:166
cs_equation_t * cs_navsto_monolithic_get_momentum_eq(void *context)
Retrieve the pointer to the cs_equation_t structure related to the momentum equation in case of a mon...
Definition: cs_navsto_coupling.cpp:545
cs_equation_t * cs_navsto_projection_get_momentum_eq(void *context)
Retrieve the pointer to the cs_equation_t structure related to the momentum equation in case of a pro...
Definition: cs_navsto_coupling.cpp:794
void cs_navsto_monolithic_init_setup(const cs_navsto_param_t *nsp, cs_adv_field_t *adv_field, void *context)
Start setting-up the Navier-Stokes equations when a monolithic algorithm is used to coupled the syste...
Definition: cs_navsto_coupling.cpp:468
void cs_navsto_ac_last_setup(const cs_navsto_param_t *nsp, void *context)
Finalize the setup for the Navier-Stokes equations when an Artificial Compressibility algorithm is us...
Definition: cs_navsto_coupling.cpp:281
void * cs_navsto_ac_free_context(void *context)
Free the context structure related to an Artificial Compressibility approach.
Definition: cs_navsto_coupling.cpp:212
void * cs_navsto_monolithic_create_context(cs_param_bc_type_t bc, cs_navsto_param_t *nsp)
Allocate and initialize a context structure when the Navier-Stokes system is coupled using a monolith...
Definition: cs_navsto_coupling.cpp:339
void * cs_navsto_monolithic_free_context(void *context)
Free the context structure related to a monolithic approach.
Definition: cs_navsto_coupling.cpp:446
void cs_navsto_monolithic_last_setup(const cs_navsto_param_t *nsp, void *context)
Finalize the setup for the Navier-Stokes equations when a monolithic algorithm is used to coupled the...
Definition: cs_navsto_coupling.cpp:523
void cs_navsto_projection_init_setup(const cs_navsto_param_t *nsp, cs_adv_field_t *adv_field, bool has_previous, void *context)
Start setting-up the Navier-Stokes equations when a projection algorithm is used to coupled the syste...
Definition: cs_navsto_coupling.cpp:664
cs_equation_param_t * cs_navsto_coupling_get_momentum_eqp(const cs_navsto_param_t *nsp, void *context)
Retrieve the cs_equation_param_t structure related to the momentum equation according to the type of ...
Definition: cs_navsto_coupling.cpp:112
cs_param_bc_type_t
Definition: cs_param_types.h:501
Definition: cs_advection_field.h:151
Definition: cs_cdo_quantities.h:142
Set of parameters specific for solving the Navier-Stokes system with the "artificial compressibility"...
Definition: cs_navsto_coupling.h:58
cs_equation_t * momentum
Definition: cs_navsto_coupling.h:60
cs_property_t * zeta
Definition: cs_navsto_coupling.h:67
Set of parameters specific for solving the Navier-Stokes system with a fully coupled monolithic algor...
Definition: cs_navsto_coupling.h:77
Definition: cs_navsto_coupling.h:79
Definition: cs_navsto_param.h:296
Set of parameters specific for solving the Navier-Stokes system with an incremental projection algori...
Definition: cs_navsto_coupling.h:91
cs_equation_t * correction
Definition: cs_navsto_coupling.h:95
cs_field_t * predicted_velocity
Definition: cs_navsto_coupling.h:117
cs_equation_t * prediction
Definition: cs_navsto_coupling.h:93
cs_field_t * phi
Definition: cs_navsto_coupling.h:122
cs_field_t * pressure_incr_gradient
Definition: cs_navsto_coupling.h:128
cs_real_t * bdy_pressure_incr
Definition: cs_navsto_coupling.h:110
cs_real_t * div_st
Definition: cs_navsto_coupling.h:103
