cs_lagr_tracking.cpp File Reference
#include <limits.h>
#include <stddef.h>
#include <ctype.h>
#include <float.h>
#include "bft/bft_printf.h"
#include "bft/bft_error.h"
#include "fvm/fvm_periodicity.h"
#include "base/cs_base.h"
#include "mesh/cs_geom.h"
#include "base/cs_halo.h"
#include "base/cs_interface.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "mesh/cs_mesh.h"
#include "mesh/cs_mesh_adjacencies.h"
#include "base/cs_order.h"
#include "base/cs_parall.h"
#include "base/cs_porous_model.h"
#include "base/cs_random.h"
#include "base/cs_rotation.h"
#include "base/cs_search.h"
#include "base/cs_timer_stats.h"
#include "base/cs_turbomachinery.h"
#include "base/cs_field.h"
#include "lagr/cs_lagr.h"
#include "lagr/cs_lagr_car.h"
#include "lagr/cs_lagr_clogging.h"
#include "lagr/cs_lagr_coupling.h"
#include "lagr/cs_lagr_deposition_model.h"
#include "lagr/cs_lagr_dlvo.h"
#include "lagr/cs_lagr_orientation.h"
#include "lagr/cs_lagr_event.h"
#include "lagr/cs_lagr_particle.h"
#include "lagr/cs_lagr_porosity.h"
#include "lagr/cs_lagr_prototypes.h"
#include "lagr/cs_lagr_post.h"
#include "lagr/cs_lagr_resuspension.h"
#include "lagr/cs_lagr_roughness.h"
#include "lagr/cs_lagr_sde.h"
#include "lagr/cs_lagr_sde_model.h"
#include "lagr/cs_lagr_stat.h"
#include "lagr/cs_lagr_tracking.h"
void cs_lagr_tracking_initialize (void)
 Initialize particle tracking subsystem. More...
void cs_lagr_integ_track_particles (const cs_real_t visc_length[], cs_lnum_t particle_range[2], const bool resol_sde)
 Integrate or not SDEs associated to the particle and apply one trajectography step to track the displacement. More...
void cs_lagr_tracking_finalize (void)
 Finalize Lagrangian module. More...
void cs_lagr_test_wall_cell (cs_lagr_particle_set_t &p_set, cs_lnum_t p_id, const cs_real_t visc_length[], cs_real_t *yplus, cs_lnum_t *face_id)
 Determine the number of the closest wall face from the particle as well as the corresponding wall normal distance (y_p^+) More...
◆ cs_lagr_integ_track_particles()
void cs_lagr_integ_track_particles ( const cs_real_t  visc_length[],
Integrate or not SDEs associated tot the particle and apply one trajectography step to track the displacement.
[in]visc_lengthviscous layer thickness
[in,out]particle_rangestart and past-the-end ids of tracked
[in]resol_sdetrue the sdes will be resolved false only the trajectography step is done
◆ cs_lagr_test_wall_cell()
void cs_lagr_test_wall_cell ( cs_lagr_particle_set_t &  p_set,
cs_lnum_t  p_id,
cs_real_t *  yplus,
cs_lnum_t *  face_id
Used for the deposition model.
[in]p_setparticle set
[in]p_idparticle id
[out]yplusassociated yplus value
[out]face_idassociated neighbor wall face, or -1
◆ cs_lagr_tracking_finalize()
void cs_lagr_tracking_finalize ( void  )
◆ cs_lagr_tracking_initialize()
void cs_lagr_tracking_initialize ( void  )
