1#ifndef CS_LAGR_PROTOTYPES_H
2#define CS_LAGR_PROTOTYPES_H
51#if defined(__cplusplus)
Definition: cs_defs.h:332
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:349
cs_real_t cs_real_2_t[2]
Definition: cs_defs.h:348
cs_real_t cs_real_33_t[3][3]
Definition: cs_defs.h:358
Definition: cs_defs.h:325
double cs_nreal_t
Definition: cs_defs.h:336
@ dt
Definition: cs_field_pointer.h:61
void cs_lagr_user_boundary_interaction(cs_lagr_particle_set_t &p_set, cs_lnum_t p_id, cs_lnum_t face_id, const cs_real_t face_norm[3], const cs_real_t c_intersect[3], cs_real_t t_intersect, int b_zone_id, int *event_flag, cs_lagr_tracking_state_t *tracking_state)
Handling of a particle interaction with a boundary of type CS_LAGR_BC_USER.
Definition: cs_user_lagr_boundary_conditions.cpp:89
void cs_user_lagr_boundary_conditions(const int itypfb[])
Define particle boundary conditions.
Definition: cs_user_lagr_boundary_conditions.cpp:63
void cs_user_lagr_in(cs_lagr_particle_set_t &p_set, const cs_lagr_injection_set_t *zis, const cs_lnum_t particle_range[2], const cs_lnum_t particle_face_id[], const cs_real_t visc_length[])
User modification of newly injected particles.
Definition: cs_user_lagr_particle.cpp:209
void cs_user_lagr_ef(cs_real_t dt_p, const cs_lnum_t p_id, const cs_real_t *taup, const cs_real_3_t *tlag, const cs_real_3_t *piil, const cs_real_33_t *bx, const cs_real_t tsfext, const cs_real_3_t gradpr, const cs_real_33_t gradvf, cs_real_t rho_p, cs_real_3_t fextla)
User definition of an external force field acting on the particles.
Definition: cs_user_lagr_particle.cpp:84
void cs_user_lagr_in_force_coords(cs_lagr_particle_set_t &p_set, const cs_lagr_injection_set_t *zis, const cs_lnum_t particle_range[2], const cs_lnum_t particle_face_id[], const cs_real_t visc_length[])
User modification of newly injected particle location and cell_id.
Definition: cs_user_lagr_particle.cpp:170
void cs_user_lagr_extra_operations(const cs_real_t dt[])
User function (non-mandatory intervention)
Definition: cs_user_lagr_particle.cpp:112
void cs_user_lagr_volume_conditions(void)
Define particle volume conditions.
Definition: cs_user_lagr_volume_conditions.cpp:61
void cs_user_lagr_rt_t(cs_lagr_particle_set_t &p_set, cs_lnum_t p_id, cs_real_t re_p, cs_real_t uvwr, cs_real_t rho_f, cs_real_t rho_p, cs_real_t nu_f, cs_real_t cp_f, cs_real_t k_f, cs_real_2_t tempct, const cs_real_t dt)
Modification of the calculation of the thermal relaxation time of the particles with respect to the c...
Definition: cs_user_lagr_particle.cpp:309
void cs_user_lagr_sde(const cs_real_t dt, const cs_lnum_t p_id, const cs_real_t *taup, const cs_real_3_t *tlag, const cs_real_2_t tempct, const int nor)
User integration of the SDE for the user-defined variables.
Definition: cs_user_lagr_particle.cpp:365
void cs_user_lagr_rt(int phase_id, cs_lagr_particle_set_t &p_set, cs_lnum_t p_id, cs_real_t re_p, cs_real_t uvwr, cs_real_t rho_f, cs_real_t rho_p, cs_real_t nu_f, cs_real_t *taup, const cs_real_t dt)
Modification of the calculation of the particle relaxation time with respect to the chosen formulatio...
Definition: cs_user_lagr_particle.cpp:267
void cs_lagr_user_internal_interaction(cs_lagr_particle_set_t &p_set, cs_lnum_t p_id, cs_lnum_t face_id, const cs_nreal_t face_u_norm[3], const cs_real_t c_intersect[3], cs_real_t t_intersect, cs_lagr_tracking_state_t *tracking_state)
Handling of a particle interaction with a interior face of type CS_LAGR_BC_USER.
Definition: cs_user_lagr_volume_conditions.cpp:85
void cs_user_lagr_imposed_motion(cs_lagr_particle_set_t &p_set, cs_lnum_t p_id, const cs_real_t coords[3], const cs_real_t dt, cs_real_t disp[3])
Impose the motion of a particle flagged CS_LAGR_PART_IMPOSED_MOTION.
Definition: cs_user_lagr_particle.cpp:134
void cs_user_lagr_model(void)
Definition: cs_user_lagr_model.cpp:55
Definition: cs_lagr_tracking.h:50
Definition: cs_lagr.h:615
Definition: cs_lagr_particle.h:324
